api.foldingathome.org for stats
ChristianVirtual
Post by ChristianVirtual »
When I try the following URL as per description of the api page
https://api.foldingathome.org/time-series/account/daily/188510?end=20200423&count=10&sort=credit&descending=1
I get as result
{"error":"Table 'ts.daily_account' doesn't exist","status":500}
Also then I try different periods or series the result is similar. Are those time-series active or not for general public.
I tried to search but could not find fitting answers.
Re: api.foldingathome.org for stats
As I understood it, this API is a work in progress. It is possible some aspects of it don't point to the right places since the database has been reorganized a bit as part of the keeping up with the large increase in use lately.
I am not certain where best to report this, possibly through the F@h GitHub - https://github.com/FoldingAtHome/, under fah-issues.
ChristianVirtual
