Ubuntu 18.04, Nvidia NVS 295 Still Supported?
Dravor
Post by Dravor »
Hi All,
I'm running n NVS 295, with 7.6.9 and tried it with 7.6.10 and the GPU keeps connecting to 192.0.2.1. I've read this sometimes means the GPU isn't support, but yet the GPU is on the whitelist still.
07:39:37:WU00:FS01:Assigned to work server 192.0.2.1
07:39:37:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G98 [Quadro NVS 295] from 192.0.2.1
Any way to know if it is truly supported or not?
*********************** Log Started 2020-04-24T07:33:28Z ***********************
07:33:28:****************************** FAHClient ******************************
07:33:28:        Version: 7.6.10
07:33:28:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:33:28:      Copyright: 2020 foldingathome.org
07:33:28:       Homepage: https://foldingathome.org/
07:33:28:           Date: Apr 18 2020
07:33:28:           Time: 03:31:35
07:33:28:       Revision: 05835e6a32e37abf3c82dbb9d2050d906637a345
07:33:28:         Branch: master
07:33:28:       Compiler: GNU 8.3.0
07:33:28:        Options: -std=c++11 -ffunction-sections -fdata-sections -O3
07:33:28:                 -funroll-loops -fno-pie
07:33:28:       Platform: linux2 4.19.0-5-amd64
07:33:28:           Bits: 64
07:33:28:           Mode: Release
07:33:28:           Args: --child /etc/fahclient/config.xml --run-as fahclient
07:33:28:                 --pid-file=/var/run/fahclient.pid --daemon
07:33:28:         Config: /etc/fahclient/config.xml
07:33:28:******************************** CBang ********************************
07:33:28:           Date: Apr 17 2020
07:33:28:           Time: 18:10:13
07:33:28:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
07:33:28:                 -funroll-loops -fno-pie -fPIC
07:33:28:           Bits: 64
07:33:28:******************************* System ********************************
07:33:28:            CPU: Intel(R) Xeon(R) CPU W3550 @ 3.07GHz
07:33:28:         CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
07:33:28:           CPUs: 8
07:33:28:         Memory: 5.80GiB
07:33:28:    Free Memory: 4.37GiB
07:33:28:        Threads: POSIX_THREADS
07:33:28:     OS Version: 5.3
07:33:28:    Has Battery: false
07:33:28:     On Battery: false
07:33:28:     UTC Offset: -4
07:33:28:            PID: 2643
07:33:28:            CWD: /var/lib/fahclient
07:33:28:             OS: Linux 5.3.0-46-generic x86_64
07:33:28:        OS Arch: AMD64
07:33:28:           GPUs: 1
07:33:28:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:0 G98 [Quadro NVS 295]
07:33:28:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.1 Driver:6.5
07:33:28:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.0 Driver:340.108
07:33:28:******************************* libFAH ********************************
07:33:28:           Date: Apr 15 2020
07:33:28:           Time: 21:43:24
07:33:28:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:33:28:           Bits: 64
07:33:28:***********************************************************************
Re: Ubuntu 18.04, Nvidia NVS 295 Still Supported?
Unfortunately, Quadro NVS 295 is not supported as it lacks OpenCL 1.2 and Double Precision: https://www.techpowerup.com/gpu-specs/q ... -295.c1450 :(
Dravor
Post by Dravor »
PantherX wrote:Unfortunately, Quadro NVS 295 is not supported as it lacks OpenCL 1.2 and Double Precision: https://www.techpowerup.com/gpu-specs/q ... -295.c1450 :(
Thanks Panther, that's what I figured, but I still saw it listed in the GPUs.txt file and just hoped =)
Dravor wrote:...I still saw it listed in the GPUs.txt file and just hoped =)
The GPUs.txt is a grey list, it contains GPUs that are supported (whitelist) and also GPUs that are not supported (blacklist). If a GPU isn't in that file, the client will not recognize it.
Toe expand on that, if you see an entry with the 3rd and 4th fields blank, then the device is on the blacklist. For example, the NVS 295 entry:
0x10de:0x06fd:::G98 [Quadro NVS 295]
