14416 (0, 580, 9): 5d deadline for 82d ETA
squeegily
Hardware configuration: Xeon E5410 [Fedora 31]
i5-3230M + Radeon HD 7570M [Windows 10.0.18363]
Post by squeegily »
  • 14416 (0, 580, 9)
  • Core 0x22 (GPU)
  • TPF 19 hours 52 mins
  • ETA 82.38 days
  • Radeon HD 7570M (has completed PLENTY of units within-schedule before this)
  • Assigned 2020-04-21T18:55:17Z
  • Timeout 2020-04-23T18:55:17Z
  • Expiration 2020-04-26T18:55:17Z
  • Work Server 13.82.98.119
  • Collection Server 52.224.109.74
The estimates seem accurate.
22:12:55:WU00:FS01:0x22:*********************** Log Started 2020-04-23T22:12:54Z ***********************
22:12:55:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:12:55:WU00:FS01:0x22:       Type: 0x22
22:12:55:WU00:FS01:0x22:       Core: Core22
22:12:55:WU00:FS01:0x22:    Website: https://foldingathome.org/
22:12:55:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
22:12:55:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
22:12:55:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
22:12:55:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 14272 -checkpoint 15
22:12:55:WU00:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
22:12:55:WU00:FS01:0x22:     Config: <none>
22:12:55:WU00:FS01:0x22:************************************ Build *************************************
22:12:55:WU00:FS01:0x22:    Version: 0.0.2
22:12:55:WU00:FS01:0x22:       Date: Dec 6 2019
22:12:55:WU00:FS01:0x22:       Time: 21:30:31
22:12:55:WU00:FS01:0x22: Repository: Git
22:12:55:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
22:12:55:WU00:FS01:0x22:     Branch: HEAD
22:12:55:WU00:FS01:0x22:   Compiler: Visual C++ 2008
22:12:55:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:12:55:WU00:FS01:0x22:   Platform: win32 10
22:12:55:WU00:FS01:0x22:       Bits: 64
22:12:55:WU00:FS01:0x22:       Mode: Release
22:12:55:WU00:FS01:0x22:************************************ System ************************************
22:12:55:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
22:12:55:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
22:12:55:WU00:FS01:0x22:       CPUs: 4
22:12:55:WU00:FS01:0x22:     Memory: 7.94GiB
22:12:55:WU00:FS01:0x22:Free Memory: 2.82GiB
22:12:55:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
22:12:55:WU00:FS01:0x22: OS Version: 6.2
22:12:55:WU00:FS01:0x22:Has Battery: true
22:12:55:WU00:FS01:0x22: On Battery: false
22:12:55:WU00:FS01:0x22: UTC Offset: 0
22:12:55:WU00:FS01:0x22:        PID: 13652
22:12:55:WU00:FS01:0x22:        CWD: C:\Users\micro\AppData\Roaming\FAHClient\work
22:12:55:WU00:FS01:0x22:         OS: Windows 10 Pro
22:12:55:WU00:FS01:0x22:    OS Arch: AMD64
22:12:55:WU00:FS01:0x22:********************************************************************************
22:12:55:WU00:FS01:0x22:Project: 14416 (Run 0, Clone 580, Gen 9)
22:12:55:WU00:FS01:0x22:Unit: 0x000000110d5262775e84c8a7805b36c9
22:12:55:WU00:FS01:0x22:Digital signatures verified
22:12:55:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:12:55:WU00:FS01:0x22:Version 0.0.2
22:14:14:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
22:14:14:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
Xe E5410 (1x)
i5-3230M (1x)
Ra HD 7570M (1x)
Re: 14416 (0, 580, 9): 5d deadline for 82d ETA
Post by Neil-B »
If this is a new project for you the client has no data to generate any type of estimate ... once 3-5% has been completed the estimate becomes much more valid ... 1,000,000 steps is the high end but could be valid - 14416 is big/has many atoms ... but also has the 2nd highest base point of any project ... give it a while and I think you will see the estimate tumble to something more representative - it may well still be significantly longer than some other WUs you are used to.
Not sure what you local timezone is so can't tell how long it has actually been running - but to complete within Timeout something just less than half an hour per fold would suffice - so you may need to wait a couple of hours to check that if there are really issues.
I am slightly surprised as the GPU you state if it is this https://www.techpowerup.com/gpu-specs/r ... 7570m.c399 appears not to have Double Precision Floating Point capabilities which I thought was pretty much a requirement for GPU cards to be able to fold ... When did you last fold with this card?
squeegily
Post by squeegily »
Neil-B wrote:If this is a new project for you the client has no data to generate any type of estimate ... once 3-5% has been completed the estimate becomes much more valid ... 1,000,000 steps is the high end but could be valid - 14416 is big/has many atoms ... but also has the 2nd highest base point of any project ... give it a while and I think you will see the estimate tumble to something more representative - it may well still be significantly longer than some other WUs you are used to.
It's been between one and three days since I started this unit; it's crawled from (according to the Advanced Control UI) 0.53% completion to 0.58% completion since I begun this thread, so (extrapolating:) I suspect it's been running for several days.
I'll check back in 8 hours and see how it all is then.
I keep all my devices on UTC: the ones with me, I'd rather not have to think about timezones; and the ones that aren't on a cross-country journey, I'd rather also not think about timezones on :mrgreen: (scheduling meetings is so much easier without them; I've only got to worry about my clients' wall clocks, and not my own)
That is (modulo any deficiencies in Techpowerup's DB) my card. For what it's worth, the field OpenCL™ Version in the Radeon settings lists 2.0.4.0, and I've watched the GPU slot finish maybe around 3 units so far (I've been running it for a few days); not counting any that finished during the night or while I was away (I'm not keeping track of it very much; I only know about the 3 GPU units for sure because I, too, was vaguely surprised that it supports everything needed). I've been folding with this card for about a week.
Xe E5410 (1x)
i5-3230M (1x)
Ra HD 7570M (1x)
Post by Neil-B »
It isn't the OpenCL that worries me http://www.gpuzoo.com/GPU-AMD/Radeon_HD_7570M_DDR3.html also shows no Double Precision Floating Point for this card ... From everything I have seen on the forum lately it really surprises me that it has actually been completing WUs.
Hopefully someone will be able to advise you soon ... From what you are saying this WU won't get finished and will probably need to be dumped but there a good ways to dump WUs so I am sure someone will advise on that.
squeegily
Post by squeegily »
Neil-B wrote:It isn't the OpenCL that worries me http://www.gpuzoo.com/GPU-AMD/Radeon_HD_7570M_DDR3.html also shows no Double Precision Floating Point for this card ... From everything I have seen on the forum lately it really surprises me that it has actually been completing WUs.
hmm. I think the GPUZoo database might be outdated; preliminarily: it conflicts with this report by "ohansfav" at gpuinfo.org reporting it's running OpenGL 4.5; this agrees with Wikipedia's broad claims about TS2 capabilities, but disagrees with GPUZoo and Techpowerup's 4.4 listed for this specific card.
My earlier intuition that the numbers in Radeon Settings UI are externally-meaningless Library versions was, sadly, confirmed by the OpenGL "version" being 6.14.10.13417. Further disappointingly: clein 0.2 was unable to even see my GPU, despite recognizing amdocl.dll as apparently the only provider library on my system. ( :?: how odd)
So it looks like wrt "real [fresh] data" about the card we're SOL until I can rez up a Linux distro and try clinfo and glxinfo.
In any case, the rate has continued preeetty much precisely as estimated since earlier (now 0.64%); so I'm not going to be "holding my breath" for not-dumping this WU being suddenly revealed viable; though I do await seeing the Proper Procedure to do so. :( (not to mention, it'll be interesting to actually observe/record the project IDs of the WUs it is completing, once this dud's out of the way.)
I am reasonably certain that I'm not imagining having witnessed the GPU slot process WUs before: I observed it intentionally for that purpose; I believe I remember contrasting it with the CPU slot's WU-per-day rate and previously noting no order-of-magnitude discrepancies between them, and I remember musing over the fact that Project 01 was assigned to Slot 00 and vice-versa.
Xe E5410 (1x)
i5-3230M (1x)
Ra HD 7570M (1x)
I am surprised as well. Has the log actually reported the WU getting past Step 1 to completing a full percent? From what I understand about this project, it spends a considerable time on the CPU getting the data set up to be processed on the GPU, and can use a lot of VM in the process. Once it started processing on the GPU, then you would see if it failed on the DP calculations.
Now the GPU should have been able to complete some older projects' WUs, they did not require DP. And there was a test done when they first decided to do some critical calculations in DP that offloaded those to the CPU. That did not work well enough and was abandoned.
Could you post the beginning 100 or so lines of the log that show the system info as the client sees it? It would be interesting to see which driver and OpenCL version is seen. Other information I have come across is that AMD dropped OpenCL support in the drivers a few versions ago for the older Terascalle and some of the early GCN based GPUs.
As for seeing what happens under Linux, you may have to stick with an older version for the same reason, OpenCL support in the drivers.
squeegily
Post by squeegily »
Joe_H wrote:I am surprised as well. Has the log actually reported the WU getting past Step 1 to completing a full percent?]
yes- it did just recently:
16:37:41:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
The Progress bar is, as of now [posting time] at 1.04%
I assume that this (seemingly-crucial) transition-point is, sadly, not logged anywhere?
So you're saying that there's a chance [the older projects which finished properly] had some beta-code which DOES cause 64-bit floating point math to fall back to CPU on unsupported GPUs?
Or that [14416 (0, 580, 9)] contains this fallback code and it's causing the problems?
Other information I have come across is that AMD dropped OpenCL support in the drivers a few versions ago for the older Terascale and some of the early GCN based GPUs.
That is...absolutely disgusting, if true. :eo and it looks like it is.
Relevant excerpt:
17:48:02:WU00:FS01:Starting
17:48:02:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
17:49:39:WU00:FS01:Starting
17:49:39:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
17:52:17:WU00:FS01:Starting
17:52:17:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
If I'm interpreting the situation correctly: Not only are they no longer updating the drivers, but they sent one last "F.U." (Farewell to You) update to the legacy GPUs dropping important standardized API support.
Well, thankfully I think the folks running the Mesa graphics driver system over at Linux are far less likely to pull shenanigans like that- even the infamous Poulsbo/GMA500 chip never experienced degradations in driver functionality under theirs (but it did under Intel's drivers).
Well, I'll try downgrading the driver to WHQL 7/29/2015 and see if that works. If not, I'll drop this WU; and if this bizarre slow-work bug happens again then I'll just delete the GPU slot until it's running Linux again?
Xe E5410 (1x)
i5-3230M (1x)
Ra HD 7570M (1x)
squeegily
Post by squeegily »
15.100.1062.1004 (2015-08-03) from "amd-catalyst-15.7.1-win10-64bit" causes CLein to see the card as simply "Turks" (and as unsupporting double-precision floating point arithmetic).
With that installed, the log shows the following:
18:10:46:WU00:FS01:Starting
18:10:46:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\micro\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10976 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:10:46:WU00:FS01:Started FahCore on PID 9500
18:10:46:WU00:FS01:FahCore 0x22 started
18:10:46:WU00:FS01:0x22:*********************** Log Started 2020-04-24T18:10:46Z ***********************
18:10:46:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:10:46:WU00:FS01:0x22:       Type: 0x22
18:10:46:WU00:FS01:0x22:       Core: Core22
18:10:46:WU00:FS01:0x22:    Website: https://foldingathome.org/
18:10:46:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
18:10:46:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:10:46:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
18:10:46:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9500 -checkpoint 15
18:10:46:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:10:46:WU00:FS01:0x22:     Config: <none>
18:10:46:WU00:FS01:0x22:************************************ Build *************************************
18:10:46:WU00:FS01:0x22:    Version: 0.0.2
18:10:46:WU00:FS01:0x22:       Date: Dec 6 2019
18:10:46:WU00:FS01:0x22:       Time: 21:30:31
18:10:46:WU00:FS01:0x22: Repository: Git
18:10:46:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:10:46:WU00:FS01:0x22:     Branch: HEAD
18:10:46:WU00:FS01:0x22:   Compiler: Visual C++ 2008
18:10:46:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:10:46:WU00:FS01:0x22:   Platform: win32 10
18:10:46:WU00:FS01:0x22:       Bits: 64
18:10:46:WU00:FS01:0x22:       Mode: Release
18:10:46:WU00:FS01:0x22:************************************ System ************************************
18:10:46:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
18:10:46:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:10:46:WU00:FS01:0x22:       CPUs: 4
18:10:46:WU00:FS01:0x22:     Memory: 7.94GiB
18:10:46:WU00:FS01:0x22:Free Memory: 4.38GiB
18:10:46:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:10:46:WU00:FS01:0x22: OS Version: 6.2
18:10:46:WU00:FS01:0x22:Has Battery: true
18:10:46:WU00:FS01:0x22: On Battery: false
18:10:46:WU00:FS01:0x22: UTC Offset: 0
18:10:46:WU00:FS01:0x22:        PID: 11748
18:10:46:WU00:FS01:0x22:        CWD: C:\Users\micro\AppData\Roaming\FAHClient\work
18:10:46:WU00:FS01:0x22:         OS: Windows 10 Pro
18:10:46:WU00:FS01:0x22:    OS Arch: AMD64
18:10:46:WU00:FS01:0x22:********************************************************************************
18:10:46:WU00:FS01:0x22:Project: 14416 (Run 0, Clone 580, Gen 9)
18:10:46:WU00:FS01:0x22:Unit: 0x000000110d5262775e84c8a7805b36c9
18:10:46:WU00:FS01:0x22:Digital signatures verified
18:10:46:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:10:46:WU00:FS01:0x22:Version 0.0.2
18:11:26:WU00:FS01:0x22:ERROR:exception: No compatible OpenCL platform is available
18:11:26:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:11:26:WU00:FS01:0x22:Saving result file checkpt.crc
18:11:26:WU00:FS01:0x22:Saving result file science.log
18:11:26:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:11:27:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:11:27:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14416 run:0 clone:580 gen:9 core:0x22 unit:0x000000110d5262775e84c8a7805b36c9
18:11:27:WU00:FS01:Uploading 54.50KiB to 13.82.98.119
18:11:27:WU00:FS01:Connecting to 13.82.98.119:8080
18:11:27:WU02:FS01:Connecting to 65.254.110.245:80
18:11:27:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:11:27:WU02:FS01:Connecting to 18.218.241.186:80
18:11:28:WU02:FS01:Assigned to work server 128.252.203.10
18:11:28:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Thames [Radeon 7500M/7600M Series] from 128.252.203.10
18:11:28:WU02:FS01:Connecting to 128.252.203.10:8080
18:11:34:WU00:FS01:Upload 100.00%
18:12:08:WU00:FS01:Upload complete
18:12:09:WU00:FS01:Server responded WORK_ACK (400)
18:12:09:WU00:FS01:Cleaning up
18:12:20:WU02:FS01:Downloading 51.19MiB
18:12:26:WU02:FS01:Download 47.74%
18:12:31:WU02:FS01:Download complete
18:12:31:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11763 run:0 clone:10919 gen:7 core:0x22 unit:0x0000001880fccb0a5e71133fefb65914
18:12:31:WU02:FS01:Starting
18:12:31:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\micro\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 10976 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:12:31:WU02:FS01:Started FahCore on PID 12080
18:12:31:WU02:FS01:Core PID:3388
18:12:31:WU02:FS01:FahCore 0x22 started
18:12:32:WU02:FS01:0x22:*********************** Log Started 2020-04-24T18:12:31Z ***********************
18:12:32:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:12:32:WU02:FS01:0x22:       Type: 0x22
18:12:32:WU02:FS01:0x22:       Core: Core22
18:12:32:WU02:FS01:0x22:    Website: https://foldingathome.org/
18:12:32:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
18:12:32:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:12:32:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
18:12:32:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 12080 -checkpoint 15
18:12:32:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:12:32:WU02:FS01:0x22:     Config: <none>
18:12:32:WU02:FS01:0x22:************************************ Build *************************************
18:12:32:WU02:FS01:0x22:    Version: 0.0.2
18:12:32:WU02:FS01:0x22:       Date: Dec 6 2019
18:12:32:WU02:FS01:0x22:       Time: 21:30:31
18:12:32:WU02:FS01:0x22: Repository: Git
18:12:32:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:12:32:WU02:FS01:0x22:     Branch: HEAD
18:12:32:WU02:FS01:0x22:   Compiler: Visual C++ 2008
18:12:32:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:12:32:WU02:FS01:0x22:   Platform: win32 10
18:12:32:WU02:FS01:0x22:       Bits: 64
18:12:32:WU02:FS01:0x22:       Mode: Release
18:12:32:WU02:FS01:0x22:************************************ System ************************************
18:12:32:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
18:12:32:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:12:32:WU02:FS01:0x22:       CPUs: 4
18:12:32:WU02:FS01:0x22:     Memory: 7.94GiB
18:12:32:WU02:FS01:0x22:Free Memory: 4.26GiB
18:12:32:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
18:12:32:WU02:FS01:0x22: OS Version: 6.2
18:12:32:WU02:FS01:0x22:Has Battery: true
18:12:32:WU02:FS01:0x22: On Battery: false
18:12:32:WU02:FS01:0x22: UTC Offset: 0
18:12:32:WU02:FS01:0x22:        PID: 3388
18:12:32:WU02:FS01:0x22:        CWD: C:\Users\micro\AppData\Roaming\FAHClient\work
18:12:32:WU02:FS01:0x22:         OS: Windows 10 Pro
18:12:32:WU02:FS01:0x22:    OS Arch: AMD64
18:12:32:WU02:FS01:0x22:********************************************************************************
18:12:32:WU02:FS01:0x22:Project: 11763 (Run 0, Clone 10919, Gen 7)
18:12:32:WU02:FS01:0x22:Unit: 0x0000001880fccb0a5e71133fefb65914
18:12:32:WU02:FS01:0x22:Reading tar file core.xml
18:12:32:WU02:FS01:0x22:Reading tar file integrator.xml
18:12:32:WU02:FS01:0x22:Reading tar file state.xml
18:12:32:WU02:FS01:0x22:Reading tar file system.xml
18:12:34:WU02:FS01:0x22:Digital signatures verified
18:12:34:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:12:34:WU02:FS01:0x22:Version 0.0.2
18:12:47:WU02:FS01:0x22:ERROR:exception: No compatible OpenCL platform is available
18:12:47:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
18:12:47:WU02:FS01:0x22:Saving result file science.log
18:12:47:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:12:47:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:12:47:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11763 run:0 clone:10919 gen:7 core:0x22 unit:0x0000001880fccb0a5e71133fefb65914
18:12:47:WU02:FS01:Uploading 8.00KiB to 128.252.203.10
18:12:47:WU02:FS01:Connecting to 128.252.203.10:8080
18:12:48:WU00:FS01:Connecting to 65.254.110.245:80
18:12:48:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:12:48:WU00:FS01:Connecting to 18.218.241.186:80
18:12:48:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:12:49:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:12:49:ERROR:WU00:FS01:Exception: Could not get an assignment
18:12:49:WU00:FS01:Connecting to 65.254.110.245:80
18:12:49:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:12:49:WU00:FS01:Connecting to 18.218.241.186:80
18:12:50:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:12:50:WU00:FS01:Connecting to 18.218.241.186:80
18:12:50:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:12:50:ERROR:WU00:FS01:Exception: Could not get an assignment
18:13:46:WU02:FS01:Upload complete
18:13:46:WU02:FS01:Server responded WORK_ACK (400)
18:13:46:WU02:FS01:Cleaning up
18:13:49:WU00:FS01:Connecting to 65.254.110.245:80
18:13:49:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:13:49:WU00:FS01:Connecting to 18.218.241.186:80
18:13:49:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:13:50:WU00:FS01:Assigned to work server 13.82.98.119
18:13:50:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Thames [Radeon 7500M/7600M Series] from 13.82.98.119
18:13:50:WU00:FS01:Connecting to 13.82.98.119:8080
18:14:11:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
18:14:11:WU00:FS01:Connecting to 13.82.98.119:80
18:15:27:WU00:FS01:Downloading 13.26MiB
18:15:30:WU00:FS01:Download complete
18:15:30:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14538 run:0 clone:1847 gen:102 core:0x22 unit:0x000000870d5262775e7b9cda2399d16a
18:15:30:WU00:FS01:Starting
18:15:30:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\micro\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 10976 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:15:30:WU00:FS01:Started FahCore on PID 13372
18:15:30:WU00:FS01:Core PID:5996
18:15:30:WU00:FS01:FahCore 0x22 started
18:15:31:WU00:FS01:0x22:*********************** Log Started 2020-04-24T18:15:30Z ***********************
18:15:31:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:15:31:WU00:FS01:0x22:       Type: 0x22
18:15:31:WU00:FS01:0x22:       Core: Core22
18:15:31:WU00:FS01:0x22:    Website: https://foldingathome.org/
18:15:31:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
18:15:31:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:15:31:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
18:15:31:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13372 -checkpoint 15
18:15:31:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:15:31:WU00:FS01:0x22:     Config: <none>
18:15:31:WU00:FS01:0x22:************************************ Build *************************************
18:15:31:WU00:FS01:0x22:    Version: 0.0.2
18:15:31:WU00:FS01:0x22:       Date: Dec 6 2019
18:15:31:WU00:FS01:0x22:       Time: 21:30:31
18:15:31:WU00:FS01:0x22: Repository: Git
18:15:31:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:15:31:WU00:FS01:0x22:     Branch: HEAD
18:15:31:WU00:FS01:0x22:   Compiler: Visual C++ 2008
18:15:31:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:15:31:WU00:FS01:0x22:   Platform: win32 10
18:15:31:WU00:FS01:0x22:       Bits: 64
18:15:31:WU00:FS01:0x22:       Mode: Release
18:15:31:WU00:FS01:0x22:************************************ System ************************************
18:15:31:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz
18:15:31:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:15:31:WU00:FS01:0x22:       CPUs: 4
18:15:31:WU00:FS01:0x22:     Memory: 7.94GiB
18:15:31:WU00:FS01:0x22:Free Memory: 4.30GiB
18:15:31:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:15:31:WU00:FS01:0x22: OS Version: 6.2
18:15:31:WU00:FS01:0x22:Has Battery: true
18:15:31:WU00:FS01:0x22: On Battery: false
18:15:31:WU00:FS01:0x22: UTC Offset: 0
18:15:31:WU00:FS01:0x22:        PID: 5996
18:15:31:WU00:FS01:0x22:        CWD: C:\Users\micro\AppData\Roaming\FAHClient\work
18:15:31:WU00:FS01:0x22:         OS: Windows 10 Pro
18:15:31:WU00:FS01:0x22:    OS Arch: AMD64
18:15:31:WU00:FS01:0x22:********************************************************************************
18:15:31:WU00:FS01:0x22:Project: 14538 (Run 0, Clone 1847, Gen 102)
18:15:31:WU00:FS01:0x22:Unit: 0x000000870d5262775e7b9cda2399d16a
18:15:31:WU00:FS01:0x22:Reading tar file core.xml
18:15:31:WU00:FS01:0x22:Reading tar file integrator.xml
18:15:31:WU00:FS01:0x22:Reading tar file state.xml
18:15:31:WU00:FS01:0x22:Reading tar file system.xml
18:15:31:WU00:FS01:0x22:Digital signatures verified
18:15:31:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:15:31:WU00:FS01:0x22:Version 0.0.2
18:15:35:WU00:FS01:0x22:ERROR:exception: No compatible OpenCL platform is available
18:15:35:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
18:15:35:WU00:FS01:0x22:Saving result file science.log
18:15:35:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:15:35:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:15:35:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14538 run:0 clone:1847 gen:102 core:0x22 unit:0x000000870d5262775e7b9cda2399d16a
18:15:36:WU00:FS01:Uploading 8.00KiB to 13.82.98.119
18:15:36:WU00:FS01:Connecting to 13.82.98.119:8080
18:15:36:WU02:FS01:Connecting to 65.254.110.245:80
18:15:36:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:15:36:WU02:FS01:Connecting to 18.218.241.186:80
18:15:36:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:15:36:WU02:FS01:Assigned to work server 128.252.203.10
18:15:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Thames [Radeon 7500M/7600M Series] from 128.252.203.10
18:15:36:WU02:FS01:Connecting to 128.252.203.10:8080
18:15:57:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
18:15:57:WU02:FS01:Connecting to 128.252.203.10:80
18:16:06:WU00:FS01:Upload complete
18:16:06:WU00:FS01:Server responded WORK_ACK (400)
18:16:06:WU00:FS01:Cleaning up
18:16:44:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:16:45:WU02:FS01:Connecting to 65.254.110.245:80
18:16:45:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:16:45:WU02:FS01:Connecting to 18.218.241.186:80
18:16:45:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:16:46:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:16:46:ERROR:WU02:FS01:Exception: Could not get an assignment
18:17:45:WU02:FS01:Connecting to 65.254.110.245:80
18:17:45:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:17:45:WU02:FS01:Connecting to 18.218.241.186:80
18:17:45:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:17:46:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:17:46:ERROR:WU02:FS01:Exception: Could not get an assignment
:!: Note the "ERROR:exception: No compatible OpenCL platform is available" here yielding "BAD_WORK_UNIT (114 = 0x72)"; yikes!
Updating the driver 1 increment to version 15.301.1901.0 (2016-02-26) from "non-whql-win10-64bit-radeon-software-crimson-relive-16.2.1-sep20"
and resumes the error
20:30:46:Enabled folding slot 01: READY gpu:0:Thames [Radeon 7500M/7600M Series]
20:30:46:ERROR:No compute devices matched GPU #0 {
20:30:46:ERROR:  "vendor": 4098,
20:30:46:ERROR:  "device": 26689,
20:30:46:ERROR:  "type": 1,
20:30:46:ERROR:  "species": 5,
20:30:46:ERROR:  "description": "Thames [Radeon 7500M/7600M Series]"
20:30:46:ERROR:}.  You may need to update your graphics drivers.
Xe E5410 (1x)
i5-3230M (1x)
Ra HD 7570M (1x)
