Are my slots configured correctly?
KA1J
Hardware configuration: ROG Strix Z390-E Motherboard - i7-8700K @ 5100 MHz - 32 Gig GSkill RAM - NVIDIA GaForce GTX 1080
ASUS P8Z68-DELUXE-GEN3 - i72600K - 16 Gig Ram EVGA RTX 2060 KO Ultra - GTX 1060
Post by KA1J »
Hi,
I have six cores in the processor and a NVidea video card that performs CGU tasks. When looking at the "web control I see cores 1, 4 & 3 being used, but CPU 1 is used three times. CPU3 two times and CPU 4 one time.
The slots are all set up for the one CGU and 6 cores. All are set for -1
For it to show core one repeated three times & anther twice, do I have something incorrectly set in my configuration and am not utilizing my cores efficiently?
Thanks.
i7-8700K @ 5100 MHz
32 Gig GSkill RAM
NVIDIA GeForce GTX 1080
Re: Are my slots configured correctly?
Post by Neil-B »
Welcome to the fourms.
Please post your log as explained here viewtopic.php?f=61&t=26036 ... I'm going to guess that you have a 4core slot,a 3core slot and 3 one core slots and possibly another I can't quite see in the image (which is what the web interface is showing - those aren't the cpu numbers rather the numbers of cpu cores) - but the logs will confirm and then it can be sorted out a bit ... make sure to include the top 200 lines of the log as that has the configuration details in it.
Post by foldy »
You want to have only one CPU slot as it is using multicore.
Post by Neil-B »
With the log we will know a little more about the kit and can tell how many cores to set the slot to and help the OP "finish" the current WUs and then pare the slot count down to one with a decently high core count :)
What is probably the route forward is to flag each of the CPU slots to Finish - or Pause when Finish - which will complete the WUs in fold and send the result in ... As each one finishes (and has completed the upload) that slot can be deleted ... Once the final CPU slot has finished then that slot can have its number of cores increased to a sensible value.
We can also check from your logs that you have things like a passkey set up.
KA1J
Post by KA1J »
Thanks for the replies.
Here's the log & I've set them to finish. Always best to have things set properly!
I appreciate the help!
18:10:01:WU07:FS02:Started FahCore on PID 14156
18:10:01:WU07:FS02:Core PID:4412
18:10:01:WU07:FS02:FahCore 0xa7 started
18:10:01:WU01:FS06:0xa7:*********************** Log Started 2020-04-23T18:10:01Z ***********************
18:10:01:WU01:FS06:0xa7:************************** Gromacs Folding@home Core ***************************
18:10:01:WU01:FS06:0xa7:       Type: 0xa7
18:10:01:WU01:FS06:0xa7:       Core: Gromacs
18:10:01:WU01:FS06:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 13840 -checkpoint 3 -np 1
18:10:01:WU01:FS06:0xa7:************************************ CBang *************************************
18:10:01:WU01:FS06:0xa7:       Date: Oct 26 2019
18:10:01:WU01:FS06:0xa7:       Time: 01:38:25
18:10:01:WU01:FS06:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:10:01:WU01:FS06:0xa7:     Branch: master
18:10:01:WU01:FS06:0xa7:   Compiler: Visual C++ 2008
18:10:01:WU01:FS06:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:10:01:WU01:FS06:0xa7:   Platform: win32 10
18:10:01:WU01:FS06:0xa7:       Bits: 64
18:10:01:WU01:FS06:0xa7:       Mode: Release
18:10:01:WU01:FS06:0xa7:************************************ System ************************************
18:10:01:WU01:FS06:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:10:01:WU01:FS06:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:10:01:WU01:FS06:0xa7:       CPUs: 12
18:10:01:WU01:FS06:0xa7:     Memory: 31.92GiB
18:10:01:WU01:FS06:0xa7:Free Memory: 28.00GiB
18:10:01:WU01:FS06:0xa7:    Threads: WINDOWS_THREADS
18:10:01:WU01:FS06:0xa7: OS Version: 6.2
18:10:01:WU01:FS06:0xa7:Has Battery: false
18:10:01:WU01:FS06:0xa7: On Battery: false
18:10:01:WU01:FS06:0xa7: UTC Offset: -4
18:10:01:WU01:FS06:0xa7:        PID: 13816
18:10:01:WU01:FS06:0xa7:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
18:10:01:WU01:FS06:0xa7:******************************** Build - libFAH ********************************
18:10:01:WU01:FS06:0xa7:    Version: 0.0.18
18:10:01:WU01:FS06:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:10:01:WU01:FS06:0xa7:  Copyright: 2019 foldingathome.org
18:10:01:WU01:FS06:0xa7:   Homepage: https://foldingathome.org/
18:10:01:WU01:FS06:0xa7:       Time: 01:52:30
18:10:01:WU01:FS06:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:10:01:WU01:FS06:0xa7:************************************ Build *************************************
18:10:01:WU01:FS06:0xa7:       SIMD: avx_256
18:10:01:WU01:FS06:0xa7:********************************************************************************
18:10:01:WU01:FS06:0xa7:Project: 13860 (Run 0, Clone 1614, Gen 86)
18:10:01:WU01:FS06:0xa7:Unit: 0x000000600d5a98395e72df6031c15dfe
18:10:01:WU01:FS06:0xa7:Digital signatures verified
18:10:01:WU01:FS06:0xa7:Calling: mdrun -s frame86.tpr -o frame86.trr -x frame86.xtc -e frame86.edr -cpi state.cpt -cpt 3 -nt 1
18:10:01:WU01:FS06:0xa7:Steps: first=10750000 total=125000
18:10:01:WU02:FS03:0xa7:*********************** Log Started 2020-04-23T18:10:01Z ***********************
18:10:01:WU02:FS03:0xa7:************************** Gromacs Folding@home Core ***************************
18:10:01:WU02:FS03:0xa7:       Type: 0xa7
18:10:01:WU02:FS03:0xa7:       Core: Gromacs
18:10:01:WU02:FS03:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 528 -checkpoint 3 -np 4
18:10:01:WU02:FS03:0xa7:************************************ CBang *************************************
18:10:01:WU02:FS03:0xa7:       Date: Oct 26 2019
18:10:01:WU02:FS03:0xa7:       Time: 01:38:25
18:10:01:WU02:FS03:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:10:01:WU02:FS03:0xa7:     Branch: master
18:10:01:WU02:FS03:0xa7:   Compiler: Visual C++ 2008
18:10:01:WU02:FS03:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:10:01:WU02:FS03:0xa7:   Platform: win32 10
18:10:01:WU02:FS03:0xa7:       Bits: 64
18:10:01:WU02:FS03:0xa7:       Mode: Release
18:10:01:WU02:FS03:0xa7:************************************ System ************************************
18:10:01:WU02:FS03:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:10:01:WU02:FS03:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:10:01:WU02:FS03:0xa7:       CPUs: 12
18:10:01:WU02:FS03:0xa7:     Memory: 31.92GiB
18:10:01:WU02:FS03:0xa7:Free Memory: 27.98GiB
18:10:01:WU02:FS03:0xa7:    Threads: WINDOWS_THREADS
18:10:01:WU02:FS03:0xa7: OS Version: 6.2
18:10:01:WU02:FS03:0xa7:Has Battery: false
18:10:01:WU02:FS03:0xa7: On Battery: false
18:10:01:WU02:FS03:0xa7: UTC Offset: -4
18:10:01:WU02:FS03:0xa7:        PID: 2232
18:10:01:WU02:FS03:0xa7:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
18:10:01:WU02:FS03:0xa7:******************************** Build - libFAH ********************************
18:10:01:WU02:FS03:0xa7:    Version: 0.0.18
18:10:01:WU02:FS03:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:10:01:WU02:FS03:0xa7:  Copyright: 2019 foldingathome.org
18:10:01:WU02:FS03:0xa7:   Homepage: https://foldingathome.org/
18:10:01:WU08:FS04:0xa7:*********************** Log Started 2020-04-23T18:10:01Z ***********************
18:10:01:WU02:FS03:0xa7:       Time: 01:52:30
18:10:01:WU08:FS04:0xa7:************************** Gromacs Folding@home Core ***************************
18:10:01:WU02:FS03:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:10:02:WU08:FS04:0xa7:       Type: 0xa7
18:10:02:WU02:FS03:0xa7:     Branch: master
18:10:02:WU08:FS04:0xa7:       Core: Gromacs
18:10:02:WU02:FS03:0xa7:   Compiler: Visual C++ 2008
18:10:02:WU08:FS04:0xa7:       Args: -dir 08 -suffix 01 -version 705 -lifeline 2464 -checkpoint 3 -np 3
18:10:02:WU02:FS03:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:10:02:WU08:FS04:0xa7:************************************ CBang *************************************
18:10:02:WU02:FS03:0xa7:   Platform: win32 10
18:10:02:WU08:FS04:0xa7:       Date: Oct 26 2019
18:10:02:WU02:FS03:0xa7:       Bits: 64
18:10:02:WU08:FS04:0xa7:       Time: 01:38:25
18:10:02:WU02:FS03:0xa7:       Mode: Release
18:10:02:WU08:FS04:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:10:02:WU02:FS03:0xa7:************************************ Build *************************************
18:10:02:WU08:FS04:0xa7:     Branch: master
18:10:02:WU02:FS03:0xa7:       SIMD: avx_256
18:10:02:WU08:FS04:0xa7:   Compiler: Visual C++ 2008
18:10:02:WU02:FS03:0xa7:********************************************************************************
18:10:02:WU08:FS04:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:10:02:WU02:FS03:0xa7:Project: 16401 (Run 77, Clone 3, Gen 110)
18:10:02:WU08:FS04:0xa7:   Platform: win32 10
18:10:02:WU02:FS03:0xa7:Unit: 0x0000007696880e6e5e814cc4078a6017
18:10:02:WU08:FS04:0xa7:       Bits: 64
18:10:02:WU02:FS03:0xa7:Digital signatures verified
18:10:02:WU08:FS04:0xa7:       Mode: Release
18:10:02:WU02:FS03:0xa7:Calling: mdrun -s frame110.tpr -o frame110.trr -x frame110.xtc -cpt 3 -nt 4
18:10:02:WU08:FS04:0xa7:************************************ System ************************************
18:10:02:WU02:FS03:0xa7:Steps: first=55000000 total=500000
18:10:02:WU08:FS04:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:10:02:WU08:FS04:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:10:02:WU08:FS04:0xa7:       CPUs: 12
18:10:02:WU08:FS04:0xa7:     Memory: 31.92GiB
18:10:02:WU08:FS04:0xa7:Free Memory: 27.98GiB
18:10:02:WU08:FS04:0xa7:    Threads: WINDOWS_THREADS
18:10:02:WU08:FS04:0xa7: OS Version: 6.2
18:10:02:WU08:FS04:0xa7:Has Battery: false
18:10:02:WU08:FS04:0xa7: On Battery: false
18:10:02:WU08:FS04:0xa7: UTC Offset: -4
18:10:02:WU08:FS04:0xa7:        PID: 2604
18:10:02:WU08:FS04:0xa7:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
18:10:02:WU08:FS04:0xa7:******************************** Build - libFAH ********************************
18:10:02:WU08:FS04:0xa7:    Version: 0.0.18
18:10:02:WU08:FS04:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:10:02:WU08:FS04:0xa7:  Copyright: 2019 foldingathome.org
18:10:02:WU08:FS04:0xa7:   Homepage: https://foldingathome.org/
18:10:02:WU08:FS04:0xa7:       Time: 01:52:30
18:10:02:WU08:FS04:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:10:02:WU08:FS04:0xa7:************************************ Build *************************************
18:10:02:WU08:FS04:0xa7:       SIMD: avx_256
18:10:02:WU08:FS04:0xa7:********************************************************************************
18:10:02:WU08:FS04:0xa7:Project: 13860 (Run 0, Clone 7682, Gen 95)
18:10:02:WU08:FS04:0xa7:Unit: 0x000000690d5a98395e7313220f3724c1
18:10:02:WU08:FS04:0xa7:Digital signatures verified
18:10:02:WU08:FS04:0xa7:Calling: mdrun -s frame95.tpr -o frame95.trr -x frame95.xtc -e frame95.edr -cpi state.cpt -cpt 3 -nt 3
18:10:02:WU08:FS04:0xa7:Steps: first=11875000 total=125000
18:10:02:WU04:FS00:0xa7:*********************** Log Started 2020-04-23T18:10:01Z ***********************
18:10:02:WU04:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:10:02:WU04:FS00:0xa7:       Type: 0xa7
18:10:02:WU04:FS00:0xa7:       Core: Gromacs
18:10:02:WU04:FS00:0xa7:       Args: -dir 04 -suffix 01 -version 705 -lifeline 3764 -checkpoint 3 -np 1
18:10:02:WU04:FS00:0xa7:************************************ CBang *************************************
18:10:02:WU04:FS00:0xa7:       Date: Oct 26 2019
18:10:02:WU04:FS00:0xa7:       Time: 01:38:25
18:10:02:WU04:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:10:02:WU04:FS00:0xa7:     Branch: master
18:10:02:WU04:FS00:0xa7:   Compiler: Visual C++ 2008
18:10:02:WU04:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:10:02:WU04:FS00:0xa7:   Platform: win32 10
18:10:02:WU04:FS00:0xa7:       Bits: 64
18:10:02:WU04:FS00:0xa7:       Mode: Release
18:10:02:WU04:FS00:0xa7:************************************ System ************************************
18:10:02:WU04:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:10:02:WU04:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:10:02:WU04:FS00:0xa7:       CPUs: 12
18:10:02:WU04:FS00:0xa7:     Memory: 31.92GiB
18:10:02:WU04:FS00:0xa7:Free Memory: 27.95GiB
18:10:02:WU04:FS00:0xa7:    Threads: WINDOWS_THREADS
18:10:02:WU04:FS00:0xa7: OS Version: 6.2
18:10:02:WU04:FS00:0xa7:Has Battery: false
18:10:02:WU04:FS00:0xa7: On Battery: false
18:10:02:WU04:FS00:0xa7: UTC Offset: -4
18:10:02:WU04:FS00:0xa7:        PID: 3960
18:10:02:WU04:FS00:0xa7:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
18:10:02:WU04:FS00:0xa7:******************************** Build - libFAH ********************************
18:10:02:WU04:FS00:0xa7:    Version: 0.0.18
18:10:02:WU04:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:10:02:WU04:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:10:02:WU04:FS00:0xa7:   Homepage: https://foldingathome.org/
18:10:02:WU04:FS00:0xa7:       Time: 01:52:30
18:10:02:WU04:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:10:02:WU04:FS00:0xa7:************************************ Build *************************************
18:10:02:WU04:FS00:0xa7:       SIMD: avx_256
18:10:02:WU04:FS00:0xa7:********************************************************************************
18:10:02:WU04:FS00:0xa7:Project: 13863 (Run 0, Clone 661, Gen 118)
18:10:02:WU04:FS00:0xa7:Unit: 0x000000870d5a98395e76663c1c2fa787
18:10:02:WU04:FS00:0xa7:Digital signatures verified
18:10:02:WU04:FS00:0xa7:Calling: mdrun -s frame118.tpr -o frame118.trr -x frame118.xtc -e frame118.edr -cpt 3 -nt 1
18:10:02:WU04:FS00:0xa7:Steps: first=14750000 total=125000
18:10:02:WU02:FS03:0xa7:Completed 1 out of 500000 steps (0%)
18:10:02:WU07:FS02:0xa7:*********************** Log Started 2020-04-23T18:10:01Z ***********************
18:10:02:WU07:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
18:10:02:WU07:FS02:0xa7:       Type: 0xa7
18:10:02:WU07:FS02:0xa7:       Core: Gromacs
18:10:02:WU07:FS02:0xa7:       Args: -dir 07 -suffix 01 -version 705 -lifeline 14156 -checkpoint 3 -np 3
18:10:02:WU07:FS02:0xa7:************************************ CBang *************************************
18:10:02:WU07:FS02:0xa7:       Date: Oct 26 2019
18:10:02:WU07:FS02:0xa7:       Time: 01:38:25
18:10:02:WU07:FS02:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:10:02:WU07:FS02:0xa7:     Branch: master
18:10:02:WU07:FS02:0xa7:   Compiler: Visual C++ 2008
18:10:02:WU07:FS02:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:10:02:WU07:FS02:0xa7:   Platform: win32 10
18:10:02:WU07:FS02:0xa7:       Bits: 64
18:10:02:WU07:FS02:0xa7:       Mode: Release
18:10:02:WU07:FS02:0xa7:************************************ System ************************************
18:10:02:WU07:FS02:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:10:02:WU07:FS02:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:10:02:WU07:FS02:0xa7:       CPUs: 12
18:10:02:WU07:FS02:0xa7:     Memory: 31.92GiB
18:10:02:WU07:FS02:0xa7:Free Memory: 27.93GiB
18:10:02:WU07:FS02:0xa7:    Threads: WINDOWS_THREADS
18:10:02:WU07:FS02:0xa7: OS Version: 6.2
18:10:02:WU07:FS02:0xa7:Has Battery: false
18:10:02:WU07:FS02:0xa7: On Battery: false
18:10:02:WU07:FS02:0xa7: UTC Offset: -4
18:10:02:WU07:FS02:0xa7:        PID: 4412
18:10:02:WU07:FS02:0xa7:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
18:10:02:WU07:FS02:0xa7:******************************** Build - libFAH ********************************
18:10:02:WU07:FS02:0xa7:    Version: 0.0.18
18:10:02:WU07:FS02:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:10:02:WU07:FS02:0xa7:  Copyright: 2019 foldingathome.org
18:10:02:WU07:FS02:0xa7:   Homepage: https://foldingathome.org/
18:10:02:WU07:FS02:0xa7:       Time: 01:52:30
18:10:02:WU07:FS02:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:10:02:WU07:FS02:0xa7:************************************ Build *************************************
18:10:02:WU07:FS02:0xa7:       SIMD: avx_256
18:10:02:WU07:FS02:0xa7:********************************************************************************
18:10:02:WU07:FS02:0xa7:Project: 13872 (Run 0, Clone 1162, Gen 140)
18:10:02:WU07:FS02:0xa7:Unit: 0x000000960d5262775e796022e6fc8db5
18:10:02:WU07:FS02:0xa7:Digital signatures verified
18:10:02:WU07:FS02:0xa7:Calling: mdrun -s frame140.tpr -o frame140.trr -x frame140.xtc -e frame140.edr -cpi state.cpt -cpt 3 -nt 3
18:10:02:WU00:FS01:Connecting to 65.254.110.245:8080
18:10:02:WU03:FS05:Connecting to 65.254.110.245:8080
18:10:02:WU07:FS02:0xa7:Steps: first=8812500 total=62500
18:10:02:WU01:FS06:0xa7:Completed 1971 out of 125000 steps (1%)
18:10:02:WU04:FS00:0xa7:Completed 1 out of 125000 steps (0%)
18:10:03:WU08:FS04:0xa7:Completed 3261 out of 125000 steps (2%)
18:10:03:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:10:03:WU00:FS01:Connecting to 18.218.241.186:80
18:10:03:WARNING:WU03:FS05:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:10:03:WU03:FS05:Connecting to 18.218.241.186:80
18:10:04:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:10:04:ERROR:WU00:FS01:Exception: Could not get an assignment
18:10:04:WU07:FS02:0xa7:Completed 1401 out of 62500 steps (2%)
18:10:04:WARNING:WU03:FS05:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:10:04:ERROR:WU03:FS05:Exception: Could not get an assignment
18:10:04:WU00:FS01:Connecting to 65.254.110.245:8080
18:10:04:WU03:FS05:Connecting to 65.254.110.245:8080
18:10:05:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:10:05:WU00:FS01:Connecting to 18.218.241.186:80
18:10:05:WARNING:WU03:FS05:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:10:05:WU03:FS05:Connecting to 18.218.241.186:80
18:10:06:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:10:06:ERROR:WU00:FS01:Exception: Could not get an assignment
18:10:06:WARNING:WU03:FS05:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:10:06:ERROR:WU03:FS05:Exception: Could not get an assignment
18:10:26:9:127.0.0.1:New Web connection
18:10:39:WU08:FS04:0xa7:Completed 3750 out of 125000 steps (3%)
18:11:03:WU07:FS02:0xa7:Completed 1875 out of 62500 steps (3%)
18:11:04:WU00:FS01:Connecting to 65.254.110.245:8080
18:11:05:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:11:05:WU00:FS01:Connecting to 18.218.241.186:80
18:11:05:WU03:FS05:Connecting to 65.254.110.245:8080
18:11:05:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:11:05:ERROR:WU00:FS01:Exception: Could not get an assignment
18:11:05:WARNING:WU03:FS05:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:11:05:WU03:FS05:Connecting to 18.218.241.186:80
18:11:05:WU03:FS05:Assigned to work server 40.114.52.201
18:11:05:WU03:FS05:Requesting new work unit for slot 05: READY cpu:1 from 40.114.52.201
18:11:05:WU03:FS05:Connecting to 40.114.52.201:8080
18:11:05:WU03:FS05:Downloading 2.14MiB
18:11:07:WU03:FS05:Download complete
18:11:07:WU03:FS05:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:13850 run:0 clone:16084 gen:68 core:0xa7 unit:0x00000050287234c95e730348f7620a91
18:11:07:WU03:FS05:Starting
18:11:07:WU03:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Zuul\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 705 -lifeline 14136 -checkpoint 3 -np 1
18:11:07:WU03:FS05:Started FahCore on PID 11632
18:11:07:WU03:FS05:Core PID:11508
18:11:07:WU03:FS05:FahCore 0xa7 started
18:11:08:WU03:FS05:0xa7:*********************** Log Started 2020-04-23T18:11:07Z ***********************
18:11:08:WU03:FS05:0xa7:************************** Gromacs Folding@home Core ***************************
18:11:08:WU03:FS05:0xa7:       Type: 0xa7
18:11:08:WU03:FS05:0xa7:       Core: Gromacs
18:11:08:WU03:FS05:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 11632 -checkpoint 3 -np 1
18:11:08:WU03:FS05:0xa7:************************************ CBang *************************************
18:11:08:WU03:FS05:0xa7:       Date: Oct 26 2019
18:11:08:WU03:FS05:0xa7:       Time: 01:38:25
18:11:08:WU03:FS05:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:11:08:WU03:FS05:0xa7:     Branch: master
18:11:08:WU03:FS05:0xa7:   Compiler: Visual C++ 2008
18:11:08:WU03:FS05:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:11:08:WU03:FS05:0xa7:   Platform: win32 10
18:11:08:WU03:FS05:0xa7:       Bits: 64
18:11:08:WU03:FS05:0xa7:       Mode: Release
18:11:08:WU03:FS05:0xa7:************************************ System ************************************
18:11:08:WU03:FS05:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:11:08:WU03:FS05:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:11:08:WU03:FS05:0xa7:       CPUs: 12
18:11:08:WU03:FS05:0xa7:     Memory: 31.92GiB
18:11:08:WU03:FS05:0xa7:Free Memory: 26.60GiB
18:11:08:WU03:FS05:0xa7:    Threads: WINDOWS_THREADS
18:11:08:WU03:FS05:0xa7: OS Version: 6.2
18:11:08:WU03:FS05:0xa7:Has Battery: false
18:11:08:WU03:FS05:0xa7: On Battery: false
18:11:08:WU03:FS05:0xa7: UTC Offset: -4
18:11:08:WU03:FS05:0xa7:        PID: 11508
18:11:08:WU03:FS05:0xa7:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
18:11:08:WU03:FS05:0xa7:******************************** Build - libFAH ********************************
18:11:08:WU03:FS05:0xa7:    Version: 0.0.18
18:11:08:WU03:FS05:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:11:08:WU03:FS05:0xa7:  Copyright: 2019 foldingathome.org
18:11:08:WU03:FS05:0xa7:   Homepage: https://foldingathome.org/
18:11:08:WU03:FS05:0xa7:       Time: 01:52:30
18:11:08:WU03:FS05:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:11:08:WU03:FS05:0xa7:************************************ Build *************************************
18:11:08:WU03:FS05:0xa7:       SIMD: avx_256
18:11:08:WU03:FS05:0xa7:********************************************************************************
18:11:08:WU03:FS05:0xa7:Project: 13850 (Run 0, Clone 16084, Gen 68)
18:11:08:WU03:FS05:0xa7:Unit: 0x00000050287234c95e730348f7620a91
18:11:08:WU03:FS05:0xa7:Reading tar file core.xml
18:11:08:WU03:FS05:0xa7:Reading tar file frame68.tpr
18:11:08:WU03:FS05:0xa7:Digital signatures verified
18:11:08:WU03:FS05:0xa7:Calling: mdrun -s frame68.tpr -o frame68.trr -x frame68.xtc -e frame68.edr -cpt 3 -nt 1
18:11:08:WU03:FS05:0xa7:Steps: first=34000000 total=500000
18:11:08:WU03:FS05:0xa7:Completed 1 out of 500000 steps (0%)
18:11:36:WU01:FS06:0xa7:Completed 2500 out of 125000 steps (2%)
18:12:24:WU08:FS04:0xa7:Completed 5000 out of 125000 steps (4%)
18:12:32:WU02:FS03:0xa7:Completed 5000 out of 500000 steps (1%)
18:12:32:WU07:FS02:0xa7:Completed 2500 out of 62500 steps (4%)
18:12:42:WU00:FS01:Connecting to 65.254.110.245:8080
18:12:42:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:12:42:WU00:FS01:Connecting to 18.218.241.186:80
18:12:42:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:12:42:ERROR:WU00:FS01:Exception: Could not get an assignment
18:13:42:WU04:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
18:13:59:WU07:FS02:0xa7:Completed 3125 out of 62500 steps (5%)
18:14:10:WU08:FS04:0xa7:Completed 6250 out of 125000 steps (5%)
18:15:15:WU01:FS06:0xa7:Completed 3750 out of 125000 steps (3%)
18:15:19:WU00:FS01:Connecting to 65.254.110.245:8080
18:15:19:WU00:FS01:Assigned to work server 140.163.4.231
18:15:19:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.231
18:15:19:WU00:FS01:Connecting to 140.163.4.231:8080
18:15:25:WU07:FS02:0xa7:Completed 3750 out of 62500 steps (6%)
18:16:05:WU08:FS04:0xa7:Completed 7500 out of 125000 steps (6%)
18:16:33:WU02:FS03:0xa7:Completed 10000 out of 500000 steps (2%)
18:16:44:WU00:FS01:Downloading 4.53MiB
18:16:45:WU00:FS01:Download complete
18:16:45:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:89 gen:23 core:0x22 unit:0x000000358ca304e75e6a7fdf8764e161
18:16:45:WU00:FS01:Starting
18:16:45:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Zuul\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 14136 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:16:45:WU00:FS01:Started FahCore on PID 6968
18:16:45:WU00:FS01:Core PID:1932
18:16:45:WU00:FS01:FahCore 0x22 started
18:16:46:WU00:FS01:0x22:*********************** Log Started 2020-04-23T18:16:46Z ***********************
18:16:46:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:16:46:WU00:FS01:0x22:       Type: 0x22
18:16:46:WU00:FS01:0x22:       Core: Core22
18:16:46:WU00:FS01:0x22:    Website: https://foldingathome.org/
18:16:46:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
18:16:46:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:16:46:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
18:16:46:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 6968 -checkpoint 3
18:16:46:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
18:16:46:WU00:FS01:0x22:             0 -gpu 0
18:16:46:WU00:FS01:0x22:     Config: <none>
18:16:46:WU00:FS01:0x22:************************************ Build *************************************
18:16:46:WU00:FS01:0x22:    Version: 0.0.2
18:16:46:WU00:FS01:0x22:       Date: Dec 6 2019
18:16:46:WU00:FS01:0x22:       Time: 21:30:31
18:16:46:WU00:FS01:0x22: Repository: Git
18:16:46:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:16:46:WU00:FS01:0x22:     Branch: HEAD
18:16:46:WU00:FS01:0x22:   Compiler: Visual C++ 2008
18:16:46:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:16:46:WU00:FS01:0x22:   Platform: win32 10
18:16:46:WU00:FS01:0x22:       Bits: 64
18:16:46:WU00:FS01:0x22:       Mode: Release
18:16:46:WU00:FS01:0x22:************************************ System ************************************
18:16:46:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:16:46:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:16:46:WU00:FS01:0x22:       CPUs: 12
18:16:46:WU00:FS01:0x22:     Memory: 31.92GiB
18:16:46:WU00:FS01:0x22:Free Memory: 25.95GiB
18:16:46:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:16:46:WU00:FS01:0x22: OS Version: 6.2
18:16:46:WU00:FS01:0x22:Has Battery: false
18:16:46:WU00:FS01:0x22: On Battery: false
18:16:46:WU00:FS01:0x22: UTC Offset: -4
18:16:46:WU00:FS01:0x22:        PID: 1932
18:16:46:WU00:FS01:0x22:        CWD: C:\Users\Zuul\AppData\Roaming\FAHClient\work
18:16:46:WU00:FS01:0x22:         OS: Windows 10 Enterprise
18:16:46:WU00:FS01:0x22:    OS Arch: AMD64
18:16:46:WU00:FS01:0x22:********************************************************************************
18:16:46:WU00:FS01:0x22:Project: 11748 (Run 0, Clone 89, Gen 23)
18:16:46:WU00:FS01:0x22:Unit: 0x000000358ca304e75e6a7fdf8764e161
18:16:46:WU00:FS01:0x22:Reading tar file core.xml
18:16:46:WU00:FS01:0x22:Reading tar file integrator.xml
18:16:46:WU00:FS01:0x22:Reading tar file state.xml
18:16:47:WU00:FS01:0x22:Reading tar file system.xml
18:16:47:WU00:FS01:0x22:Digital signatures verified
18:16:47:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:16:47:WU00:FS01:0x22:Version 0.0.2
18:16:59:WU07:FS02:0xa7:Completed 4375 out of 62500 steps (7%)
18:17:01:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
18:17:01:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:17:26:WU04:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
18:18:06:WU08:FS04:0xa7:Completed 8750 out of 125000 steps (7%)
18:18:22:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
18:18:39:WU07:FS02:0xa7:Completed 5000 out of 62500 steps (8%)
18:18:51:WU03:FS05:0xa7:Completed 5000 out of 500000 steps (1%)
18:18:58:WU01:FS06:0xa7:Completed 5000 out of 125000 steps (4%)
18:19:42:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
18:20:22:WU07:FS02:0xa7:Completed 5625 out of 62500 steps (9%)
18:20:25:WU08:FS04:0xa7:Completed 10000 out of 125000 steps (8%)
18:21:06:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
18:21:08:WU04:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
18:22:02:WU07:FS02:0xa7:Completed 6250 out of 62500 steps (10%)
18:22:26:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
18:22:41:WU01:FS06:0xa7:Completed 6250 out of 125000 steps (5%)
18:22:41:WU08:FS04:0xa7:Completed 11250 out of 125000 steps (9%)
18:22:58:WU02:FS03:0xa7:Completed 15000 out of 500000 steps (3%)
18:23:46:WU07:FS02:0xa7:Completed 6875 out of 62500 steps (11%)
18:23:46:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
18:24:47:WU04:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
18:25:09:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
18:25:12:WU08:FS04:0xa7:Completed 12500 out of 125000 steps (10%)
18:25:35:WU07:FS02:0xa7:Completed 7500 out of 62500 steps (12%)
18:26:21:WU01:FS06:0xa7:Completed 7500 out of 125000 steps (6%)
18:26:30:WU00:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
18:26:33:WU03:FS05:0xa7:Completed 10000 out of 500000 steps (2%)
18:27:18:WU07:FS02:0xa7:Completed 8125 out of 62500 steps (13%)
18:27:38:WU08:FS04:0xa7:Completed 13750 out of 125000 steps (11%)
18:27:54:WU00:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
18:28:31:WU04:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
18:29:03:WU07:FS02:0xa7:Completed 8750 out of 62500 steps (14%)
18:29:15:WU00:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
18:29:37:WU02:FS03:0xa7:Completed 20000 out of 500000 steps (4%)
18:29:57:WU08:FS04:0xa7:Completed 15000 out of 125000 steps (12%)
18:30:02:WU01:FS06:0xa7:Completed 8750 out of 125000 steps (7%)
18:30:38:WU00:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
18:30:47:WU07:FS02:0xa7:Completed 9375 out of 62500 steps (15%)
18:31:06:39:127.0.0.1:New Web connection
18:32:09:WU00:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
18:32:14:WU04:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
18:33:15:WU07:FS02:0xa7:Completed 10000 out of 62500 steps (16%)
18:33:30:WU08:FS04:0xa7:Completed 16250 out of 125000 steps (13%)
18:33:32:WU00:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
18:33:45:WU01:FS06:0xa7:Completed 10000 out of 125000 steps (8%)
18:34:16:WU03:FS05:0xa7:Completed 15000 out of 500000 steps (3%)
18:35:03:WU00:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
18:35:32:WU07:FS02:0xa7:Completed 10625 out of 62500 steps (17%)
18:35:57:WU04:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
18:36:31:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
18:36:56:WU08:FS04:0xa7:Completed 17500 out of 125000 steps (14%)
18:37:26:WU01:FS06:0xa7:Completed 11250 out of 125000 steps (9%)
18:37:56:WU07:FS02:0xa7:Completed 11250 out of 62500 steps (18%)
18:37:56:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
18:39:12:WU02:FS03:0xa7:Completed 25000 out of 500000 steps (5%)
18:39:22:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
18:39:36:WU04:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
18:40:12:WU08:FS04:0xa7:Completed 18750 out of 125000 steps (15%)
18:40:15:WU07:FS02:0xa7:Completed 11875 out of 62500 steps (19%)
18:40:46:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
18:41:09:WU01:FS06:0xa7:Completed 12500 out of 125000 steps (10%)
18:42:01:WU03:FS05:0xa7:Completed 20000 out of 500000 steps (4%)
18:42:13:WU00:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
18:42:23:WU07:FS02:0xa7:Completed 12500 out of 62500 steps (20%)
18:43:18:WU04:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
18:43:22:WU08:FS04:0xa7:Completed 20000 out of 125000 steps (16%)
18:43:39:WU00:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
18:44:35:WU07:FS02:0xa7:Completed 13125 out of 62500 steps (21%)
18:44:45:WU01:FS06:0xa7:Completed 13750 out of 125000 steps (11%)
18:45:03:WU00:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
18:46:28:WU00:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
18:46:29:WU07:FS02:0xa7:Completed 13750 out of 62500 steps (22%)
18:46:37:WU08:FS04:0xa7:Completed 21250 out of 125000 steps (17%)
18:46:55:WU02:FS03:0xa7:Completed 30000 out of 500000 steps (6%)
18:46:58:WU04:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
18:47:53:WU00:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
18:48:29:WU01:FS06:0xa7:Completed 15000 out of 125000 steps (12%)
18:48:36:WU07:FS02:0xa7:Completed 14375 out of 62500 steps (23%)
18:49:20:WU00:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
18:49:39:WU03:FS05:0xa7:Completed 25000 out of 500000 steps (5%)
18:49:40:WU08:FS04:0xa7:Completed 22500 out of 125000 steps (18%)
18:50:37:WU04:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
18:50:47:WU00:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
18:50:47:WU07:FS02:0xa7:Completed 15000 out of 62500 steps (24%)
18:52:09:WU00:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
18:52:09:WU01:FS06:0xa7:Completed 16250 out of 125000 steps (13%)
18:52:39:WU07:FS02:0xa7:Completed 15625 out of 62500 steps (25%)
18:53:00:WU08:FS04:0xa7:Completed 23750 out of 125000 steps (19%)
18:53:36:WU00:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
18:54:20:WU04:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
18:54:44:WU07:FS02:0xa7:Completed 16250 out of 62500 steps (26%)
18:54:56:WU00:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
18:55:50:WU01:FS06:0xa7:Completed 17500 out of 125000 steps (14%)
18:55:58:WU08:FS04:0xa7:Completed 25000 out of 125000 steps (20%)
18:56:03:WU02:FS03:0xa7:Completed 35000 out of 500000 steps (7%)
18:56:23:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
18:56:54:WU07:FS02:0xa7:Completed 16875 out of 62500 steps (27%)
18:57:19:WU03:FS05:0xa7:Completed 30000 out of 500000 steps (6%)
18:57:50:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
18:58:00:WU04:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
18:59:04:WU07:FS02:0xa7:Completed 17500 out of 62500 steps (28%)
18:59:10:WU08:FS04:0xa7:Completed 26250 out of 125000 steps (21%)
18:59:18:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
18:59:36:WU01:FS06:0xa7:Completed 18750 out of 125000 steps (15%)
19:00:48:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
19:01:22:WU07:FS02:0xa7:Completed 18125 out of 62500 steps (29%)
19:01:48:WU04:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
19:02:13:WU08:FS04:0xa7:Completed 27500 out of 125000 steps (22%)
19:02:15:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
19:03:20:WU01:FS06:0xa7:Completed 20000 out of 125000 steps (16%)
19:03:40:WU07:FS02:0xa7:Completed 18750 out of 62500 steps (30%)
19:03:46:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
19:05:03:WU03:FS05:0xa7:Completed 35000 out of 500000 steps (7%)
19:05:13:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
19:05:28:WU08:FS04:0xa7:Completed 28750 out of 125000 steps (23%)
19:05:32:WU04:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
19:05:53:WU07:FS02:0xa7:Completed 19375 out of 62500 steps (31%)
19:06:15:WU02:FS03:0xa7:Completed 40000 out of 500000 steps (8%)
19:06:35:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
19:07:02:WU01:FS06:0xa7:Completed 21250 out of 125000 steps (17%)
19:07:57:WU07:FS02:0xa7:Completed 20000 out of 62500 steps (32%)
19:08:01:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
19:08:24:WU08:FS04:0xa7:Completed 30000 out of 125000 steps (24%)
19:09:14:WU04:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
19:09:24:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
19:10:14:WU07:FS02:0xa7:Completed 20625 out of 62500 steps (33%)
19:10:44:WU01:FS06:0xa7:Completed 22500 out of 125000 steps (18%)
19:10:52:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
19:11:44:WU08:FS04:0xa7:Completed 31250 out of 125000 steps (25%)
19:12:16:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
19:12:21:WU07:FS02:0xa7:Completed 21250 out of 62500 steps (34%)
19:12:46:WU03:FS05:0xa7:Completed 40000 out of 500000 steps (8%)
19:12:55:WU04:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
19:13:39:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
19:14:24:WU01:FS06:0xa7:Completed 23750 out of 125000 steps (19%)
19:14:25:WU07:FS02:0xa7:Completed 21875 out of 62500 steps (35%)
19:14:54:WU08:FS04:0xa7:Completed 32500 out of 125000 steps (26%)
19:15:10:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
19:15:35:WU02:FS03:0xa7:Completed 45000 out of 500000 steps (9%)
19:16:32:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
19:16:32:WU07:FS02:0xa7:Completed 22500 out of 62500 steps (36%)
19:16:35:WU04:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
19:17:45:WU08:FS04:0xa7:Completed 33750 out of 125000 steps (27%)
19:17:55:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
19:18:04:WU01:FS06:0xa7:Completed 25000 out of 125000 steps (20%)
19:18:27:WU07:FS02:0xa7:Completed 23125 out of 62500 steps (37%)
19:19:16:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
19:20:16:WU04:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
19:20:27:WU03:FS05:0xa7:Completed 45000 out of 500000 steps (9%)
19:20:31:WU07:FS02:0xa7:Completed 23750 out of 62500 steps (38%)
19:20:41:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
19:20:45:WU08:FS04:0xa7:Completed 35000 out of 125000 steps (28%)
19:21:48:WU01:FS06:0xa7:Completed 26250 out of 125000 steps (21%)
19:22:09:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
19:22:56:WU07:FS02:0xa7:Completed 24375 out of 62500 steps (39%)
19:23:38:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
19:23:56:WU04:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
19:24:16:WU08:FS04:0xa7:Completed 36250 out of 125000 steps (29%)
19:24:37:WU02:FS03:0xa7:Completed 50000 out of 500000 steps (10%)
19:25:08:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
19:25:23:WU07:FS02:0xa7:Completed 25000 out of 62500 steps (40%)
19:25:28:WU01:FS06:0xa7:Completed 27500 out of 125000 steps (22%)
19:26:32:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
19:27:26:WU08:FS04:0xa7:Completed 37500 out of 125000 steps (30%)
19:27:29:WU07:FS02:0xa7:Completed 25625 out of 62500 steps (41%)
19:27:34:WU04:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
19:27:59:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
19:28:04:WU03:FS05:0xa7:Completed 50000 out of 500000 steps (10%)
19:29:06:WU01:FS06:0xa7:Completed 28750 out of 125000 steps (23%)
19:29:17:WU07:FS02:0xa7:Completed 26250 out of 62500 steps (42%)
19:29:24:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
19:30:04:WU08:FS04:0xa7:Completed 38750 out of 125000 steps (31%)
19:30:45:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
19:31:15:WU04:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
19:31:16:WU07:FS02:0xa7:Completed 26875 out of 62500 steps (43%)
19:32:10:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
19:32:46:WU01:FS06:0xa7:Completed 30000 out of 125000 steps (24%)
19:33:04:WU08:FS04:0xa7:Completed 40000 out of 125000 steps (32%)
19:33:29:WU07:FS02:0xa7:Completed 27500 out of 62500 steps (44%)
19:33:36:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
19:34:20:WU02:FS03:0xa7:Completed 55000 out of 500000 steps (11%)
19:34:52:WU04:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
19:34:58:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
19:35:32:WU07:FS02:0xa7:Completed 28125 out of 62500 steps (45%)
19:35:34:WU03:FS05:0xa7:Completed 55000 out of 500000 steps (11%)
19:36:09:WU08:FS04:0xa7:Completed 41250 out of 125000 steps (33%)
19:36:20:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
19:36:24:WU01:FS06:0xa7:Completed 31250 out of 125000 steps (25%)
19:37:34:WU07:FS02:0xa7:Completed 28750 out of 62500 steps (46%)
19:37:40:WU00:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
19:38:33:WU04:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
19:39:10:WU00:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
19:39:24:WU08:FS04:0xa7:Completed 42500 out of 125000 steps (34%)
19:39:37:WU07:FS02:0xa7:Completed 29375 out of 62500 steps (47%)
19:40:02:WU01:FS06:0xa7:Completed 32500 out of 125000 steps (26%)
19:40:34:WU00:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
19:41:52:WU07:FS02:0xa7:Completed 30000 out of 62500 steps (48%)
19:42:01:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
19:42:09:WU04:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
19:42:44:WU08:FS04:0xa7:Completed 43750 out of 125000 steps (35%)
19:43:11:WU03:FS05:0xa7:Completed 60000 out of 500000 steps (12%)
19:43:28:WU00:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
19:43:44:WU01:FS06:0xa7:Completed 33750 out of 125000 steps (27%)
19:43:53:WU02:FS03:0xa7:Completed 60000 out of 500000 steps (12%)
19:43:57:WU07:FS02:0xa7:Completed 30625 out of 62500 steps (49%)
19:44:46:WU00:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
19:45:18:WU08:FS04:0xa7:Completed 45000 out of 125000 steps (36%)
19:45:50:WU04:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
19:46:02:WU07:FS02:0xa7:Completed 31250 out of 62500 steps (50%)
19:46:10:WU00:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
19:47:20:WU01:FS06:0xa7:Completed 35000 out of 125000 steps (28%)
19:47:32:WU00:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
19:48:09:WU08:FS04:0xa7:Completed 46250 out of 125000 steps (37%)
19:48:14:WU07:FS02:0xa7:Completed 31875 out of 62500 steps (51%)
19:48:56:WU00:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
19:49:27:WU04:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
19:50:17:WU00:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
19:50:30:WU07:FS02:0xa7:Completed 32500 out of 62500 steps (52%)
19:50:45:WU03:FS05:0xa7:Completed 65000 out of 500000 steps (13%)
19:50:57:WU01:FS06:0xa7:Completed 36250 out of 125000 steps (29%)
19:51:40:WU00:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
19:51:40:WU02:FS03:0xa7:Completed 65000 out of 500000 steps (13%)
19:51:48:WU08:FS04:0xa7:Completed 47500 out of 125000 steps (38%)
19:52:55:WU07:FS02:0xa7:Completed 33125 out of 62500 steps (53%)
19:53:04:WU04:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
19:53:11:WU00:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
19:54:37:WU00:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
19:54:38:WU01:FS06:0xa7:Completed 37500 out of 125000 steps (30%)
19:55:09:WU07:FS02:0xa7:Completed 33750 out of 62500 steps (54%)
19:55:21:WU08:FS04:0xa7:Completed 48750 out of 125000 steps (39%)
19:56:05:WU00:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
19:56:47:WU04:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
19:57:21:WU07:FS02:0xa7:Completed 34375 out of 62500 steps (55%)
19:57:32:WU00:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
19:58:20:WU01:FS06:0xa7:Completed 38750 out of 125000 steps (31%)
19:58:23:WU08:FS04:0xa7:Completed 50000 out of 125000 steps (40%)
19:58:24:WU03:FS05:0xa7:Completed 70000 out of 500000 steps (14%)
19:58:58:WU00:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
19:59:29:WU07:FS02:0xa7:Completed 35000 out of 62500 steps (56%)
20:00:23:WU00:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
20:00:27:WU04:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
20:00:45:WU02:FS03:0xa7:Completed 70000 out of 500000 steps (14%)
20:01:10:WU08:FS04:0xa7:Completed 51250 out of 125000 steps (41%)
20:01:36:WU07:FS02:0xa7:Completed 35625 out of 62500 steps (57%)
20:01:47:WU00:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
20:01:58:WU01:FS06:0xa7:Completed 40000 out of 125000 steps (32%)
20:03:16:WU00:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
20:03:50:WU07:FS02:0xa7:Completed 36250 out of 62500 steps (58%)
20:04:08:WU04:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
20:04:34:WU08:FS04:0xa7:Completed 52500 out of 125000 steps (42%)
20:04:40:WU00:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
20:05:40:WU01:FS06:0xa7:Completed 41250 out of 125000 steps (33%)
20:06:01:WU03:FS05:0xa7:Completed 75000 out of 500000 steps (15%)
20:06:02:WU00:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
20:06:03:WU07:FS02:0xa7:Completed 36875 out of 62500 steps (59%)
20:07:08:WU08:FS04:0xa7:Completed 53750 out of 125000 steps (43%)
20:07:28:WU00:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
20:07:52:WU04:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
20:07:56:WU07:FS02:0xa7:Completed 37500 out of 62500 steps (60%)
i7-8700K @ 5100 MHz
32 Gig GSkill RAM
Post by Neil-B »
Well it looks like you have an 12core CPU ... Is you are running a GPU you want to leave a core for that but 11and 10 aren't great numbers so maybe aim to end up with a 9core CPU slot, a 2core CPU slot and your GPU slot - that will probably do the most for science and get you the most points ... If you need help doing this just ask and I or someone will walk you through this.
Can't see the bit of your log that shows if you have a passkey but if you read this https://foldingathome.org/support/faq/points/ it explains how points work and importantly the Quick Return Bonus and howto qualify for it, which makes a huge difference (all estimated Points Per Day and WUs Points tallies include this) as Base Points are much less.
Oh yes, If you edit your previous post, select all of the log and then click on the code button at the top of the editor text pane it will put "tags" around the log so that when you submit the post again the log will appear in a scrollable window which can make it a bit easier to read.
KA1J
Post by KA1J »
My Processor is: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz, 3696 Mhz, 6 Core(s), 12 Logical Processor(s)
I didn't have a passkey, I just obtained one but see no way to enter it. In the blurb is mentions adding it during installation & not to add it to the configuration file. I see no option to add it. Do I need to wait till all is finished and then delete F@H and re-install?
Thanks for the hint on adding the code widget to my log post, I just did that.
So, I have two of the WU's stopped and as I have clicked on finish, they have not renewed. Based on the suggestions above, I removed them in the slots configuration page.
Not sure where to go from here.
Thanks
i7-8700K @ 5100 MHz
32 Gig GSkill RAM
In Web Control go to the top left where it lists the user and team information. Click on Change Identity, you can enter the passkey and leave the entries for user and team unchanged. Then save the changes.
HaloJones
Post by HaloJones »
Go to Advanced Control (folding icon int he task bar on the bottom left). Click Configure, Identity. You can enter the passkey at the bottom of that tab.
single 1070
Post by Neil-B »
OK so the easiest way to get passkey in is probably to click on the "Change Identity" link under your user name and team identity on the top left part of the web control pane and then paste/enter the passkey in there ... If using the advanced control which is for most things easier in that it gives you more options - then click on configure select the identity tab and paste/enter the passkey details there.
Advanced control will make deleting/reconfiguring slots easier as well ... having clicked on configure choose the slots tab - select a cpu tab - click remove/or edit - on the slots you are keeping change the cpus count to the desired value then click ok and then save.
To find the advance control if you haven't already either navigate to it through the programs menus (it is called FAHControl) or right click on the little FAH icon in the pop up tool tray items on the right hand end of the toolbar.
Advanced control at its top level has a status tab which lets you see what your cores are doing and a log tab which can be useful for troubleshooting ... the status tab will also help you identify which cores have finished and what their slot id numbers are so you know which ones can be deleted - be sure the WUs have been sent before doing this
KA1J
Post by KA1J »
LOL, well this is interesting. I had a total score of 2,474,029 & I joined a team a while ago and it started at 0 points for the team. Since joining the team, 297,992 have gone to it. When I added the passkey it now says I have 0 points and 0 have gone to my team though when I click on (see stats) I see what I've generated and where points have gone to.
Add to that, as soon as I clicked on save after entering the passkey, the GPU which was idle (with the advanced setting as "Finish") now shows GPU running with 10% completed.
Looks like I'm starting out at zero & all over again.
All that actually matters is this computer is helping to help with fighting the Corona virus, so what matters is OK, but I was trying to help my team with credits.
Such is life ;)
i7-8700K @ 5100 MHz
32 Gig GSkill RAM
The points are still there and belong to you and your team. It is just that the Web Control displays points based on the user and passkey entered. So if you search on the Donor stats through the F@h site by just your username entered, all of your points will show up.
HaloJones
Post by HaloJones »
Historic points aren't transferred when you move or join a team. The points go to the team that was entered when they were awarded.
As you say, you haven't lost too much. Now all your points will stay with you (but see what I said earlier about team points).
single 1070
Post by Neil-B »
not as such starting at zero as you never "lose" anything - it just gets recorded separately - with a unique user name you should be easily able to track them down and gather the points together ... every username/passkey pairing has to qualify for QRB and will count up from 0 for that pairing ... but you will always be able to find/see/add you past points in ... and tbh once you get past 10WUs you should be gaining points so much quicker than in the past you will soon past previous totals.
Post by Neil-B »
If you haven't changed the team info they will still get points - as soon as the QRB kicks in they will gain them quicker ... don't worry too much about finishing/pausing the GPU slot as you can resort the CPU slots without stopping/pausing it when using the Advanced Control.
