This is my first, and I'm fairly new. Please be merciful.
I have just completed a WU, and more than an hour has passed and I haven't received any points. This is the second time this happened -- I never received the points the first time. I don't understand why this is happening and I appreciate any help.
This is the Log:
*********************** Log Started 2020-04-23T11:38:50Z ***********************
11:38:50:************************* Folding@home Client *************************
11:38:50: Website: https://foldingathome.org/
11:38:50: Copyright: (c) 2009-2018 foldingathome.org
11:38:50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:38:50: Args:
11:38:50: Config: C:\Users\matth\AppData\Roaming\FAHClient\config.xml
11:38:50:******************************** Build ********************************
11:38:50: Version: 7.5.1
11:38:50: Date: May 11 2018
11:38:50: Time: 13:06:32
11:38:50: Repository: Git
11:38:50: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
11:38:50: Branch: master
11:38:50: Compiler: Visual C++ 2008
11:38:50: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:38:50: Platform: win32 10
11:38:50: Bits: 32
11:38:50: Mode: Release
11:38:50:******************************* System ********************************
11:38:50: CPU: Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz
11:38:50: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
11:38:50: CPUs: 4
11:38:50: Memory: 7.87GiB
11:38:50: Free Memory: 4.49GiB
11:38:50: Threads: WINDOWS_THREADS
11:38:50: OS Version: 6.2
11:38:50: Has Battery: true
11:38:50: On Battery: false
11:38:50: UTC Offset: 2
11:38:50: PID: 2488
11:38:50: CWD: C:\Users\matth\AppData\Roaming\FAHClient
11:38:50: OS: Windows 10 Home
11:38:50: OS Arch: AMD64
11:38:50: GPUs: 1
11:38:50: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Sun [Radeon HD 8600M Series]
11:38:50: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
11:38:50: specified module could not be found.
11:38:50:
11:38:50:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:23.20
11:38:50:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2841.19
11:38:50: Win32 Service: false
11:38:50:***********************************************************************
11:38:50:<config>
11:38:50: <!-- Network -->
11:38:50: <proxy v=':8080'/>
11:38:50:
11:38:50: <!-- Slot Control -->
11:38:50: <power v='FULL'/>
11:38:50:
11:38:50: <!-- User Information -->
11:38:50: <passkey v='********************************'/>
11:38:50: <team v='1262'/>
11:38:50: <user v='o_hio'/>
11:38:50:
11:38:50: <!-- Folding Slots -->
11:38:50: <slot id='0' type='CPU'/>
11:38:50: <slot id='1' type='GPU'/>
11:38:50:</config>
11:38:50:Trying to access database...
11:38:50:Successfully acquired database lock
11:38:50:Enabled folding slot 00: READY cpu:3
11:38:50:Enabled folding slot 01: READY gpu:0:Sun [Radeon HD 8600M Series]
11:38:50:WU00:FS01:Starting
11:38:50:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\matth\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 2488 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
11:38:50:WU00:FS01:Started FahCore on PID 7368
11:38:50:WU00:FS01:Core PID:9928
11:38:50:WU00:FS01:FahCore 0x22 started
11:38:50:WU02:FS00:Starting
11:38:50:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\matth\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 2488 -checkpoint 15 -np 3
11:38:50:WU02:FS00:Started FahCore on PID 9920
11:38:50:WU02:FS00:Core PID:12372
11:38:50:WU02:FS00:FahCore 0xa7 started
11:38:50:WU00:FS01:0x22:*********************** Log Started 2020-04-23T11:38:50Z ***********************
11:38:50:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
11:38:50:WU00:FS01:0x22: Type: 0x22
11:38:50:WU00:FS01:0x22: Core: Core22
11:38:50:WU00:FS01:0x22: Website: https://foldingathome.org/
11:38:50:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
11:38:50:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
11:38:50:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
11:38:50:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 7368 -checkpoint 15
11:38:50:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
11:38:50:WU00:FS01:0x22: Config: <none>
11:38:50:WU00:FS01:0x22:************************************ Build *************************************
11:38:50:WU00:FS01:0x22: Version: 0.0.2
11:38:50:WU00:FS01:0x22: Date: Dec 6 2019
11:38:50:WU00:FS01:0x22: Time: 21:30:31
11:38:50:WU00:FS01:0x22: Repository: Git
11:38:50:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
11:38:50:WU00:FS01:0x22: Branch: HEAD
11:38:50:WU00:FS01:0x22: Compiler: Visual C++ 2008
11:38:50:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:38:50:WU00:FS01:0x22: Platform: win32 10
11:38:50:WU00:FS01:0x22: Bits: 64
11:38:50:WU00:FS01:0x22: Mode: Release
11:38:50:WU00:FS01:0x22:************************************ System ************************************
11:38:50:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz
11:38:50:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
11:38:50:WU00:FS01:0x22: CPUs: 4
11:38:50:WU00:FS01:0x22: Memory: 7.87GiB
11:38:50:WU00:FS01:0x22:Free Memory: 4.40GiB
11:38:50:WU00:FS01:0x22: Threads: WINDOWS_THREADS
11:38:50:WU00:FS01:0x22: OS Version: 6.2
11:38:50:WU00:FS01:0x22:Has Battery: true
11:38:50:WU00:FS01:0x22: On Battery: false
11:38:50:WU00:FS01:0x22: UTC Offset: 2
11:38:50:WU00:FS01:0x22: PID: 9928
11:38:50:WU00:FS01:0x22: CWD: C:\Users\matth\AppData\Roaming\FAHClient\work
11:38:50:WU00:FS01:0x22: OS: Windows 10 Home Single Language
11:38:50:WU00:FS01:0x22: OS Arch: AMD64
11:38:50:WU00:FS01:0x22:********************************************************************************
11:38:50:WU00:FS01:0x22:Project: 14538 (Run 0, Clone 1934, Gen 44)
11:38:50:WU00:FS01:0x22:Unit: 0x000000400d5262775e7b9cda7e24cfdb
11:38:50:WU00:FS01:0x22:Digital signatures verified
11:38:50:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
11:38:50:WU00:FS01:0x22:Version 0.0.2
11:38:51:WU02:FS00:0xa7:*********************** Log Started 2020-04-23T11:38:50Z ***********************
11:38:51:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:38:51:WU02:FS00:0xa7: Type: 0xa7
11:38:51:WU02:FS00:0xa7: Core: Gromacs
11:38:51:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 9920 -checkpoint 15 -np 3
11:38:51:WU02:FS00:0xa7:************************************ CBang *************************************
11:38:51:WU02:FS00:0xa7: Date: Oct 26 2019
11:38:51:WU02:FS00:0xa7: Time: 01:38:25
11:38:51:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:38:51:WU02:FS00:0xa7: Branch: master
11:38:51:WU02:FS00:0xa7: Compiler: Visual C++ 2008
11:38:51:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:38:51:WU02:FS00:0xa7: Platform: win32 10
11:38:51:WU02:FS00:0xa7: Bits: 64
11:38:51:WU02:FS00:0xa7: Mode: Release
11:38:51:WU02:FS00:0xa7:************************************ System ************************************
11:38:51:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz
11:38:51:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
11:38:51:WU02:FS00:0xa7: CPUs: 4
11:38:51:WU02:FS00:0xa7: Memory: 7.87GiB
11:38:51:WU02:FS00:0xa7:Free Memory: 4.38GiB
11:38:51:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
11:38:51:WU02:FS00:0xa7: OS Version: 6.2
11:38:51:WU02:FS00:0xa7:Has Battery: true
11:38:51:WU02:FS00:0xa7: On Battery: false
11:38:51:WU02:FS00:0xa7: UTC Offset: 2
11:38:51:WU02:FS00:0xa7: PID: 12372
11:38:51:WU02:FS00:0xa7: CWD: C:\Users\matth\AppData\Roaming\FAHClient\work
11:38:51:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
11:38:51:WU02:FS00:0xa7: Version: 0.0.18
11:38:51:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:38:51:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
11:38:51:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
11:38:51:WU02:FS00:0xa7: Time: 01:52:30
11:38:51:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:38:51:WU02:FS00:0xa7:************************************ Build *************************************
11:38:51:WU02:FS00:0xa7: SIMD: avx_256
11:38:51:WU02:FS00:0xa7:********************************************************************************
11:38:51:WU02:FS00:0xa7:Project: 16424 (Run 1517, Clone 0, Gen 11)
11:38:51:WU02:FS00:0xa7:Unit: 0x0000000ca8f5c67d5e8f68842c123ae8
11:38:51:WU02:FS00:0xa7:Digital signatures verified
11:38:51:WU02:FS00:0xa7:Calling: mdrun -s frame11.tpr -o frame11.trr -x frame11.xtc -cpi state.cpt -cpt 15 -nt 3
11:38:51:WU02:FS00:0xa7:Steps: first=2750000 total=250000
11:38:51:WU00:FS01:0x22: Found a checkpoint file
11:38:58:WU02:FS00:0xa7:Completed 174582 out of 250000 steps (69%)
11:39:07:11:127.0.0.1:New Web connection
11:39:15:WU00:FS01:0x22:Completed 2450000 out of 4000000 steps (61%)
11:39:15:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:40:47:WU02:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
11:52:48:WU02:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
12:03:40:WU00:FS01:0x22:Completed 2480000 out of 4000000 steps (62%)
12:05:40:WU02:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
12:17:04:WU02:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
12:27:08:WU02:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
12:36:43:WU02:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
12:37:08:WU00:FS01:0x22:Completed 2520000 out of 4000000 steps (63%)
12:46:22:WU02:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
12:56:01:WU02:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
13:06:57:WU02:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
13:10:49:WU00:FS01:0x22:Completed 2560000 out of 4000000 steps (64%)
13:18:01:WU02:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
13:29:25:WU02:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
13:39:10:WU02:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
13:45:48:WU00:FS01:0x22:Completed 2600000 out of 4000000 steps (65%)
13:49:47:WU02:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
14:00:29:WU02:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
14:11:03:WU02:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
14:20:02:WU00:FS01:0x22:Completed 2640000 out of 4000000 steps (66%)
14:22:22:WU02:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
14:33:26:WU02:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
14:45:26:WU02:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
14:53:44:WU00:FS01:0x22:Completed 2680000 out of 4000000 steps (67%)
14:55:36:WU02:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
15:05:49:WU02:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
15:16:03:WU02:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
15:16:52:46:127.0.0.1:New Web connection
15:26:10:WU02:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
15:26:45:WU00:FS01:0x22:Completed 2720000 out of 4000000 steps (68%)
15:36:09:WU02:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
15:46:05:WU02:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
15:58:04:WU02:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
16:00:39:WU00:FS01:0x22:Completed 2760000 out of 4000000 steps (69%)
16:10:07:WU02:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
16:20:04:WU02:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
16:29:35:WU02:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
16:34:35:WU00:FS01:0x22:Completed 2800000 out of 4000000 steps (70%)
16:38:50:WU02:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
16:48:10:WU02:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
16:48:11:WU01:FS00:Connecting to 65.254.110.245:8080
16:48:12:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:48:12:WU01:FS00:Connecting to 18.218.241.186:80
16:48:12:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:48:12:ERROR:WU01:FS00:Exception: Could not get an assignment
16:48:12:WU01:FS00:Connecting to 65.254.110.245:8080
16:48:13:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:48:13:WU01:FS00:Connecting to 18.218.241.186:80
16:48:13:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:48:13:ERROR:WU01:FS00:Exception: Could not get an assignment
16:49:12:WU01:FS00:Connecting to 65.254.110.245:8080
16:49:13:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:49:13:WU01:FS00:Connecting to 18.218.241.186:80
16:49:14:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:49:14:ERROR:WU01:FS00:Exception: Could not get an assignment
16:50:49:WU01:FS00:Connecting to 65.254.110.245:8080
16:50:50:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:50:50:WU01:FS00:Connecting to 18.218.241.186:80
16:50:50:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:50:50:ERROR:WU01:FS00:Exception: Could not get an assignment
16:53:27:WU01:FS00:Connecting to 65.254.110.245:8080
16:53:27:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:53:27:WU01:FS00:Connecting to 18.218.241.186:80
16:53:28:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:53:28:ERROR:WU01:FS00:Exception: Could not get an assignment
16:57:41:WU01:FS00:Connecting to 65.254.110.245:8080
16:57:42:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:57:42:WU01:FS00:Connecting to 18.218.241.186:80
16:57:42:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:57:42:ERROR:WU01:FS00:Exception: Could not get an assignment
16:57:52:WU02:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
16:58:00:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
16:58:00:WU02:FS00:0xa7:Saving result file frame11.trr
16:58:00:WU02:FS00:0xa7:Saving result file frame11.xtc
16:58:00:WU02:FS00:0xa7:Saving result file md.log
16:58:00:WU02:FS00:0xa7:Saving result file science.log
16:58:00:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
16:58:00:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:58:00:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:16424 run:1517 clone:0 gen:11 core:0xa7 unit:0x0000000ca8f5c67d5e8f68842c123ae8
16:58:00:WU02:FS00:Uploading 7.02MiB to 168.245.198.125
16:58:00:WU02:FS00:Connecting to 168.245.198.125:8080
16:58:06:WU02:FS00:Upload 20.49%
16:58:12:WU02:FS00:Upload 46.33%
16:58:18:WU02:FS00:Upload 71.27%
16:58:24:WU02:FS00:Upload 97.11%
16:58:25:WU02:FS00:Upload complete
16:58:25:WU02:FS00:Server responded WORK_ACK (400)
16:58:25:WU02:FS00:Final credit estimate, 4391.00 points
16:58:25:WU02:FS00:Cleaning up
17:03:12:WU00:FS01:0x22:Completed 2840000 out of 4000000 steps (71%)
17:04:33:WU01:FS00:Connecting to 65.254.110.245:8080
17:04:33:WU01:FS00:Assigned to work server 155.247.164.213
17:04:33:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.213
17:04:33:WU01:FS00:Connecting to 155.247.164.213:8080
17:04:42:WU01:FS00:Downloading 135.00KiB
17:04:43:WU01:FS00:Download complete
17:04:43:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14638 run:1425 clone:0 gen:17 core:0xa7 unit:0x000000139bf7a4d55e8b1efb974dba80
17:04:43:WU01:FS00:Starting
17:04:43:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\matth\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 2488 -checkpoint 15 -np 3
17:04:43:WU01:FS00:Started FahCore on PID 2764
17:04:43:WU01:FS00:Core PID:3256
17:04:43:WU01:FS00:FahCore 0xa7 started
17:04:44:WU01:FS00:0xa7:*********************** Log Started 2020-04-23T17:04:43Z ***********************
17:04:44:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:04:44:WU01:FS00:0xa7: Type: 0xa7
17:04:44:WU01:FS00:0xa7: Core: Gromacs
17:04:44:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 2764 -checkpoint 15 -np 3
17:04:44:WU01:FS00:0xa7:************************************ CBang *************************************
17:04:44:WU01:FS00:0xa7: Date: Oct 26 2019
17:04:44:WU01:FS00:0xa7: Time: 01:38:25
17:04:44:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:04:44:WU01:FS00:0xa7: Branch: master
17:04:44:WU01:FS00:0xa7: Compiler: Visual C++ 2008
17:04:44:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:04:44:WU01:FS00:0xa7: Platform: win32 10
17:04:44:WU01:FS00:0xa7: Bits: 64
17:04:44:WU01:FS00:0xa7: Mode: Release
17:04:44:WU01:FS00:0xa7:************************************ System ************************************
17:04:44:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz
17:04:44:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
17:04:44:WU01:FS00:0xa7: CPUs: 4
17:04:44:WU01:FS00:0xa7: Memory: 7.87GiB
17:04:44:WU01:FS00:0xa7:Free Memory: 4.38GiB
17:04:44:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
17:04:44:WU01:FS00:0xa7: OS Version: 6.2
17:04:44:WU01:FS00:0xa7:Has Battery: true
17:04:44:WU01:FS00:0xa7: On Battery: false
17:04:44:WU01:FS00:0xa7: UTC Offset: 2
17:04:44:WU01:FS00:0xa7: PID: 3256
17:04:44:WU01:FS00:0xa7: CWD: C:\Users\matth\AppData\Roaming\FAHClient\work
17:04:44:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:04:44:WU01:FS00:0xa7: Version: 0.0.18
17:04:44:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:04:44:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
17:04:44:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
17:04:44:WU01:FS00:0xa7: Time: 01:52:30
17:04:44:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:04:44:WU01:FS00:0xa7:************************************ Build *************************************
17:04:44:WU01:FS00:0xa7: SIMD: avx_256
17:04:44:WU01:FS00:0xa7:********************************************************************************
17:04:44:WU01:FS00:0xa7:Project: 14638 (Run 1425, Clone 0, Gen 17)
17:04:44:WU01:FS00:0xa7:Unit: 0x000000139bf7a4d55e8b1efb974dba80
17:04:44:WU01:FS00:0xa7:Reading tar file core.xml
17:04:44:WU01:FS00:0xa7:Reading tar file frame17.tpr
17:04:44:WU01:FS00:0xa7:Digital signatures verified
17:04:44:WU01:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpt 15 -nt 3
17:04:44:WU01:FS00:0xa7:Steps: first=0 total=2500000
17:04:44:WU01:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
17:07:39:WU01:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
17:11:16:WU01:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
17:13:08:82:127.0.0.1:New Web connection
17:14:59:WU01:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
17:18:48:WU01:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
17:22:06:114:127.0.0.1:New Web connection
17:22:20:WU00:FS01:0x22:Completed 2880000 out of 4000000 steps (72%)
17:22:34:WU01:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
17:26:01:WU01:FS00:0xa7:Completed 150000 out of 2500000 steps (6%)
17:29:14:WU01:FS00:0xa7:Completed 175000 out of 2500000 steps (7%)
17:32:17:WU01:FS00:0xa7:Completed 200000 out of 2500000 steps (8%)
17:35:21:WU01:FS00:0xa7:Completed 225000 out of 2500000 steps (9%)
17:38:22:WU01:FS00:0xa7:Completed 250000 out of 2500000 steps (10%)
******************************* Date: 2020-04-23 *******************************
17:41:23:WU01:FS00:0xa7:Completed 275000 out of 2500000 steps (11%)
17:41:24:WU00:FS01:0x22:Completed 2920000 out of 4000000 steps (73%)
17:44:26:WU01:FS00:0xa7:Completed 300000 out of 2500000 steps (12%)
17:47:27:WU01:FS00:0xa7:Completed 325000 out of 2500000 steps (13%)
17:47:31:132:127.0.0.1:New Web connection
Dell Inspiron 15-3567
Core: Intel Core i7-7500U
GPU: Radeon (TM) R5 M430
Memory: 8 GB DDR4
