[V7.6.9]Button "Finishing up" is buggy in WebControl
HB9EVT
Post by HB9EVT »
Hi
I hope this is the correct place to report a bug. If not, please move this article to the correct place.
In the Web Control Client is - when folding is running - the big red button "Stop Folding". If you press this button, you get the followin choice:
- green Button "Finishing up, then stop"
- red Button "Stop now"
The red Button "Stop now" is working. Folding stops.
But teh green Button "Finishing up, then stop" shows no reaction. Seems to be buggy.
In the "Client Advance Control" is the grey button "Finish" working proberly. So the bug is only in the Web Control Client.
Pepe
Re: [Win10][V7.6.9]Button "Finishing up" is buggy in WebCont
There was another report of this problem, and it has been reported on the development site - https://github.com/FoldingAtHome/fah-issues/issues/1415.
And yes, this is the right place to report such problems.
HB9EVT
Post by HB9EVT »
thanks @Joe
Pepe
Swiss Radio Scout -- Be prepared and stay on air! -- HB9EVT
comixgoddess
Hardware configuration: MacBook Pro 2017
Post by comixgoddess »
I have encountered the same issue - macOS Catalina 10.15.4 running F@h version 7.6.9. I normally use the Advanced Control Panel so not a huge deal for me.
Bratfalken
Re: [V7.6.9]Button "Finishing up" is buggy in WebControl
Post by Bratfalken »
Problem is still there in 7.9.13, which means there are WU's that never get done properly, just sent out in vain as the only way to stop is to do it in the middle of a WU. Now, my 3700X with it's 2060 doesn't need more than a few hours to do a WU, but I bet there are slower computers that doesn't finish in time because of this?
Not_a_Number
Post by Not_a_Number »
I have noticed this behavior in 7.9.13. I upgraded from 7.6.9 mainly in hopes this would be fixed.
Not a big deal as you can just open the advanced client and set the status / action to "Finish". You can even set each slot individually.
Bratfalken
Not_a_Number wrote:I have noticed this behavior in 7.9.13. I upgraded from 7.6.9 mainly in hopes this would be fixed.
Yes, I finally understood the button in the non HTML version, It works as it should, maybe just a notion on the HTML button that you have to use the advanced clients rightmost button would be enough?
