Work Server 192.0.2.1
WardoftheWood
Post by WardoftheWood »
GPU has not received WU's in days. Poll time > 4hours
(Yes I have paused and Fold to reset the timer per comments in forum :D )
is the work server address correct (192.0.2.1)?
Is this address local to the machine and the software makes adjustment as necessary ?
Thanks
Chris
11:28:10:Removing old file 'configs/config-20200420-200559.xml'
11:28:10:Saving configuration to config.xml
11:28:10:<config>
11:28:10:  <!-- Folding Core -->
11:28:10:  <checkpoint v='30'/>
11:28:10:
11:28:10:  <!-- Folding Slot Configuration -->
11:28:10:  <cause v='COVID_19'/>
11:28:10:
11:28:10:  <!-- HTTP Server -->
11:28:10:  <allow v='192.168.1.0/0'/>
11:28:10:
11:28:10:  <!-- Network -->
11:28:10:  <proxy v=':8080'/>
11:28:10:
11:28:10:  <!-- Remote Command Server -->
11:28:10:  <password v='*****'/>
11:28:10:
11:28:10:  <!-- Slot Control -->
11:28:10:  <power v='FULL'/>
11:28:10:
11:28:10:  <!-- User Information -->
11:28:10:  <passkey v='*****'/>
11:28:10:  <team v='241777'/>
11:28:10:  <user v='WotW_1_i5'/>
11:28:10:
11:28:10:  <!-- Folding Slots -->
11:28:10:  <slot id='1' type='GPU'>
11:28:10:    <paused v='true'/>
11:28:10:  </slot>
11:28:10:  <slot id='2' type='CPU'>
11:28:10:  </slot>
11:28:10:</config>
11:28:19:FS01:Unpaused
11:28:19:FS02:Unpaused
11:28:19:WU00:FS01:Connecting to 65.254.110.245:80
11:28:19:WU00:FS01:Assigned to work server 192.0.2.1
11:28:19:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G92 [GeForce GTS 250] from 192.0.2.1
11:28:19:WU00:FS01:Connecting to 192.0.2.1:8080
11:28:19:WU01:FS02:Starting
11:28:19:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\wardo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 7964 -checkpoint 30 -np 3
11:28:19:WU01:FS02:Started FahCore on PID 6684
11:28:19:WU01:FS02:Core PID:4136
11:28:19:WU01:FS02:FahCore 0xa7 started
11:28:19:WU01:FS02:0xa7:*********************** Log Started 2020-04-23T11:28:19Z ***********************
11:28:19:WU01:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
11:28:19:WU01:FS02:0xa7:       Type: 0xa7
11:28:20:WU01:FS02:0xa7:       Core: Gromacs
11:28:20:WU01:FS02:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6684 -checkpoint 30 -np 3
11:28:20:WU01:FS02:0xa7:************************************ CBang *************************************
11:28:20:WU01:FS02:0xa7:       Date: Oct 26 2019
11:28:20:WU01:FS02:0xa7:       Time: 01:38:25
11:28:20:WU01:FS02:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:28:20:WU01:FS02:0xa7:     Branch: master
11:28:20:WU01:FS02:0xa7:   Compiler: Visual C++ 2008
11:28:20:WU01:FS02:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:28:20:WU01:FS02:0xa7:   Platform: win32 10
11:28:20:WU01:FS02:0xa7:       Bits: 64
11:28:20:WU01:FS02:0xa7:       Mode: Release
11:28:20:WU01:FS02:0xa7:************************************ System ************************************
11:28:20:WU01:FS02:0xa7:        CPU: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
11:28:20:WU01:FS02:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
11:28:20:WU01:FS02:0xa7:       CPUs: 4
11:28:20:WU01:FS02:0xa7:     Memory: 7.89GiB
11:28:20:WU01:FS02:0xa7:Free Memory: 4.78GiB
11:28:20:WU01:FS02:0xa7:    Threads: WINDOWS_THREADS
11:28:20:WU01:FS02:0xa7: OS Version: 6.2
11:28:20:WU01:FS02:0xa7:Has Battery: false
11:28:20:WU01:FS02:0xa7: On Battery: false
11:28:20:WU01:FS02:0xa7: UTC Offset: -5
11:28:20:WU01:FS02:0xa7:        PID: 4136
11:28:20:WU01:FS02:0xa7:        CWD: C:\Users\wardo\AppData\Roaming\FAHClient\work
11:28:20:WU01:FS02:0xa7:******************************** Build - libFAH ********************************
11:28:20:WU01:FS02:0xa7:    Version: 0.0.18
11:28:20:WU01:FS02:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:28:20:WU01:FS02:0xa7:  Copyright: 2019 foldingathome.org
11:28:20:WU01:FS02:0xa7:   Homepage: https://foldingathome.org/
11:28:20:WU01:FS02:0xa7:       Time: 01:52:30
11:28:20:WU01:FS02:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:28:20:WU01:FS02:0xa7:************************************ Build *************************************
11:28:20:WU01:FS02:0xa7:       SIMD: avx_256
11:28:20:WU01:FS02:0xa7:********************************************************************************
11:28:20:WU01:FS02:0xa7:Project: 16502 (Run 0, Clone 1737, Gen 0)
11:28:20:WU01:FS02:0xa7:Unit: 0x000000008f59f36f5e9302e7bf944bbf
11:28:20:WU01:FS02:0xa7:Digital signatures verified
11:28:20:WU01:FS02:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 30 -nt 3
11:28:20:Removing old file 'configs/config-20200420-201508.xml'
11:28:20:Saving configuration to config.xml
11:28:20:<config>
11:28:20:  <!-- Folding Core -->
11:28:20:  <checkpoint v='30'/>
11:28:20:
11:28:20:  <!-- Folding Slot Configuration -->
11:28:20:  <cause v='COVID_19'/>
11:28:20:
11:28:20:  <!-- HTTP Server -->
11:28:20:  <allow v='192.168.1.0/0'/>
11:28:20:
11:28:20:  <!-- Network -->
11:28:20:  <proxy v=':8080'/>
11:28:20:
11:28:20:  <!-- Remote Command Server -->
11:28:20:  <password v='*****'/>
11:28:20:
11:28:20:  <!-- Slot Control -->
11:28:20:  <power v='FULL'/>
11:28:20:
11:28:20:  <!-- User Information -->
11:28:20:  <passkey v='*****'/>
11:28:20:  <team v='241777'/>
11:28:20:  <user v='WotW_1_i5'/>
11:28:20:
11:28:20:  <!-- Folding Slots -->
11:28:20:  <slot id='1' type='GPU'/>
11:28:20:  <slot id='2' type='CPU'/>
11:28:20:</config>
11:28:20:WU01:FS02:0xa7:Steps: first=0 total=250000
11:28:23:WU01:FS02:0xa7:Completed 27922 out of 250000 steps (11%)
11:28:40:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:28:40:WU00:FS01:Connecting to 192.0.2.1:80
11:29:01:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:29:56:WU00:FS01:Connecting to 65.254.110.245:80
11:29:56:WU00:FS01:Assigned to work server 192.0.2.1
11:29:56:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G92 [GeForce GTS 250] from 192.0.2.1
11:29:56:WU00:FS01:Connecting to 192.0.2.1:8080
11:30:18:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:30:18:WU00:FS01:Connecting to 192.0.2.1:80
11:30:39:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:32:33:WU00:FS01:Connecting to 65.254.110.245:80
11:32:33:WU00:FS01:Assigned to work server 192.0.2.1
11:32:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G92 [GeForce GTS 250] from 192.0.2.1
11:32:33:WU00:FS01:Connecting to 192.0.2.1:8080
11:32:54:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:32:54:WU00:FS01:Connecting to 192.0.2.1:80
11:33:16:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Re: Work Server 192.0.2.1
Post by Neil-B »
This card may not be able to fold .. that IP is used when cards are not capable enough .. let me get to pc and I'll check (on phone atm)
HaloJones
Post by HaloJones »
No, I don't think it is but I also don't think a GTS250 is able to fold. It's too old.
viewtopic.php?p=273981
4070 super
Post by Neil-B »
Regrettably your GPU doesn't support Double Precision Floating Point calculations and therefore is not capable of folding ... https://www.techpowerup.com/gpu-specs/g ... -250.c3178
Basically any nVidia card before the GT 400 series is not able to be used for folding and should already be blacklisted in the GPUs.txt file. The client will not automatically set up a GPU slot for cards on the blacklist during installation.
