Not recognizing RX 5700
k3wlderp
Post by k3wlderp »
I just install FAH today and it doesn't pick up my GPU only my CPU. I have tried reinstall FAH, manually installing the GPUs.txt file, restart my PC,and checking if my drivers are up to date. Games work fine and windows does pick up my GPU.
Re: Not recognizing RX 5700
Post by Neil-B »
Silly I know but have you tried a reboot?
k3wlderp
Post by k3wlderp »
Neil-B wrote:Silly I know but have you tried a reboot?
Yes, i've tried to reboot. Oops forgot to mention that
Jan
Post by Jan »
Have you tried to manually add a GPU slot after addding GPUs.txt and rebooting? Also: Could you please post your logs?
If you can post the first 200 lines of your log file we can check what the software thinks is going on.
here is instructions
viewtopic.php?f=24&t=26036
k3wlderp
Post by k3wlderp »
Jan wrote:Have you tried to manually add a GPU slot after addding GPUs.txt and rebooting? Also: Could you please post your logs?
How do I do that?
k3wlderp
Post by k3wlderp »
JimboPalmer wrote:If you can post the first 200 lines of your log file we can check what the software thinks is going on.
Here are the logs:
*********************** Log Started 2020-04-22T22:52:20Z ***********************
22:52:20:****************************** FAHClient ******************************
22:52:20:        Version: 7.6.9
22:52:20:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:52:20:      Copyright: 2020 foldingathome.org
22:52:20:       Homepage: https://foldingathome.org/
22:52:20:           Date: Apr 17 2020
22:52:20:           Time: 11:13:06
22:52:20:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
22:52:20:         Branch: master
22:52:20:       Compiler: Visual C++ 2008
22:52:20:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:52:20:       Platform: win32 10
22:52:20:           Bits: 32
22:52:20:           Mode: Release
22:52:20:         Config: C:\Users\lil_cris\AppData\Roaming\FAHClient\config.xml
22:52:20:******************************** CBang ********************************
22:52:20:           Time: 11:10:09
22:52:20:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
22:52:20:           Bits: 32
22:52:20:******************************* System ********************************
22:52:20:            CPU: AMD Ryzen 5 3600 6-Core Processor
22:52:20:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
22:52:20:           CPUs: 12
22:52:20:         Memory: 15.93GiB
22:52:20:    Free Memory: 12.88GiB
22:52:20:        Threads: WINDOWS_THREADS
22:52:20:     OS Version: 6.2
22:52:20:    Has Battery: false
22:52:20:     On Battery: false
22:52:20:     UTC Offset: -6
22:52:20:            PID: 10816
22:52:20:            CWD: C:\Users\lil_cris\AppData\Roaming\FAHClient
22:52:20:             OS: Windows 10 Home
22:52:20:        OS Arch: AMD64
22:52:20:           GPUs: 1
22:52:20:          GPU 0: Bus:9 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT /
22:52:20:                 5700/5700 XT]
22:52:20:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:52:20:                 specified module could not be found.
22:52:20:
22:52:20:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3004.8
22:52:20:  Win32 Service: false
22:52:20:******************************* libFAH ********************************
22:52:20:           Date: Apr 15 2020
22:52:20:           Time: 14:53:14
22:52:20:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
22:52:20:           Bits: 32
22:52:20:***********************************************************************
22:52:21:<config>
22:52:21:  <!-- Folding Slot Configuration -->
22:52:21:  <cause v='COVID_19'/>
22:52:21:
22:52:21:  <!-- Slot Control -->
22:52:21:  <power v='light'/>
22:52:21:
22:52:21:  <!-- User Information -->
22:52:21:  <passkey v='*****'/>
22:52:21:  <team v='223518'/>
22:52:21:  <user v='cris'/>
22:52:21:
22:52:21:  <!-- Folding Slots -->
22:52:21:  <slot id='0' type='CPU'/>
22:52:21:</config>
22:52:21:Trying to access database...
22:52:21:Successfully acquired database lock
22:52:21:Enabled folding slot 00: READY cpu:5
22:52:21:WU00:FS00:Starting
22:52:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lil_cris\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10816 -checkpoint 15 -np 5
22:52:21:WU00:FS00:Started FahCore on PID 13516
22:52:21:WU00:FS00:Core PID:13600
22:52:21:WU00:FS00:FahCore 0xa7 started
22:52:21:WU00:FS00:0xa7:*********************** Log Started 2020-04-22T22:52:21Z ***********************
22:52:21:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:52:21:WU00:FS00:0xa7:       Type: 0xa7
22:52:21:WU00:FS00:0xa7:       Core: Gromacs
22:52:21:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13516 -checkpoint 15 -np
22:52:21:WU00:FS00:0xa7:             5
22:52:21:WU00:FS00:0xa7:************************************ CBang *************************************
22:52:21:WU00:FS00:0xa7:       Date: Oct 26 2019
22:52:21:WU00:FS00:0xa7:       Time: 01:38:25
22:52:21:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:52:21:WU00:FS00:0xa7:     Branch: master
22:52:21:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:52:21:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:52:21:WU00:FS00:0xa7:   Platform: win32 10
22:52:21:WU00:FS00:0xa7:       Bits: 64
22:52:21:WU00:FS00:0xa7:       Mode: Release
22:52:21:WU00:FS00:0xa7:************************************ System ************************************
22:52:21:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 3600 6-Core Processor
22:52:21:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
22:52:21:WU00:FS00:0xa7:       CPUs: 12
22:52:21:WU00:FS00:0xa7:     Memory: 15.93GiB
22:52:21:WU00:FS00:0xa7:Free Memory: 12.26GiB
22:52:21:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:52:21:WU00:FS00:0xa7: OS Version: 6.2
22:52:21:WU00:FS00:0xa7:Has Battery: false
22:52:21:WU00:FS00:0xa7: On Battery: false
22:52:21:WU00:FS00:0xa7: UTC Offset: -6
22:52:21:WU00:FS00:0xa7:        PID: 13600
22:52:21:WU00:FS00:0xa7:        CWD: C:\Users\lil_cris\AppData\Roaming\FAHClient\work
22:52:21:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:52:21:WU00:FS00:0xa7:    Version: 0.0.18
22:52:21:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:52:21:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:52:21:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:52:21:WU00:FS00:0xa7:       Time: 01:52:30
22:52:21:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:52:21:WU00:FS00:0xa7:************************************ Build *************************************
22:52:21:WU00:FS00:0xa7:       SIMD: avx_256
22:52:21:WU00:FS00:0xa7:********************************************************************************
22:52:21:WU00:FS00:0xa7:Project: 16430 (Run 0, Clone 1152, Gen 6)
22:52:21:WU00:FS00:0xa7:Unit: 0x0000000696880e6e5e961d53dde786f8
22:52:21:WU00:FS00:0xa7:Digital signatures verified
22:52:21:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
22:52:21:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -x frame6.xtc -cpi state.cpt -cpt 15 -nt 4
22:52:21:WU00:FS00:0xa7:Steps: first=1500000 total=250000
22:52:22:WU00:FS00:0xa7:Completed 177372 out of 250000 steps (70%)
22:52:28:3:127.0.0.1:New Web session
22:52:28:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
22:53:50:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
22:55:09:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
22:56:26:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
22:57:44:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
22:59:02:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
23:00:20:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
23:01:37:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
23:02:55:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
23:04:12:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
23:05:30:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
23:06:47:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
23:08:05:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
23:09:23:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
23:10:40:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
23:11:57:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
23:13:15:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
23:14:33:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
23:15:50:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
23:17:08:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
23:18:26:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
23:19:44:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
23:21:02:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
23:22:20:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
23:23:38:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
23:24:58:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
23:26:17:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
23:27:36:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
Jan
Post by Jan »
FAHControl - Configure - Slots - Add - GPU - Save. Dont change the default settings.
Please post the logs as Code (in the editor), way better for reading comfort. :)
*edit*
1. It looks like your GPU is recognized well. You should only have to add the GPU slot.
2. I would recommend changing Folding Power to Medium or Full. On Light, your GPU will not be folding, only the CPU.
k3wlderp
Post by k3wlderp »
Jan wrote:FAHControl - Configure - Slots - Add - GPU - Save. Dont change the default settings.
*edit*
Ya I just added the slot and now it works, thanks!
nm It's stuck on "ready"
Jan
Post by Jan »
Being stuck on ready might be normal. It should be searching for work, but GPU WUs are scarce right now. So it might take some time until it actually finds something and starts folding. You can check in the client and FAHControl.
