Please add GIGABYTE GeForce RTX 2060 OC GG
Jaxinc
Hardware configuration: W7P64, Gigabyte GA-990FXA-UD3, Gigabyte 7970Ghz, AMD FX-4100, G.Skill 16gb 1600, WD Black, Thermaltake 850w
Post by Jaxinc »
Card not detected by Folding@Home and can not be added.
Jan
Re: Please add GIGABYTE GeForce RTX 2060 OC GG
Post by Jan »
The card itself is whitelisted and known. Which client version do you have installed? Could you please post the first 200 lines of your log?
Also: What have you done to add the card?
*edit* Ive just noticed this is a RTX 2060 with TU104. For TU104 there is no entry as RTX 2060, also 2070 and 2080. Not sure if thats a problem though. If yes, this thread might be for you.
Jaxinc
Post by Jaxinc »
I can pull the log when I get home, but folding is not generating a "gpu.txt" file at all. So I can neither modify, nor find it.
Version is latest from the site, and I've tried adding a slot as normal and it simply doesn't add it when you click save. I've tried restarting my PC, folding, ect... and it still isn't detected.
If there is no entry for TU104 then it might still need to be whitelisted.
I just replaced my 390x with the 2060, but a clean install was done so there shouldn't be any kind of driver/brand conflict.
The card is already whitelisted, the device ID is in the GPUs.txt file:
0x10de:0x1e89:2:7:TU106-200A [GeForce RTX 2060]
No need for an entry saying TU104.
If you installed the 7.6.9 version of the client, you will probably need to download the GPUs.txt file and put it into place. Then restart the FAHClient or reboot, then add the GPU slot. This is a known issue with this version.
Or try the 7.6.10 beta - https://foldingathome.org/beta/
Jaxinc
Post by Jaxinc »
Jan wrote:The card itself is whitelisted and known. Which client version do you have installed? Could you please post the first 200 lines of your log?
*********************** Log Started 2020-04-22T17:34:26Z ***********************
17:34:26:****************************** FAHClient ******************************
17:34:26:        Version: 7.6.9
17:34:26:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:34:26:      Copyright: 2020 foldingathome.org
17:34:26:       Homepage: https://foldingathome.org/
17:34:26:           Date: Apr 17 2020
17:34:26:           Time: 11:13:06
17:34:26:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
17:34:26:         Branch: master
17:34:26:       Compiler: Visual C++ 2008
17:34:26:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:34:26:       Platform: win32 10
17:34:26:           Bits: 32
17:34:26:           Mode: Release
17:34:26:******************************** CBang ********************************
17:34:26:           Time: 11:10:09
17:34:26:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
17:34:26:           Bits: 32
17:34:26:******************************* System ********************************
17:34:26:            CPU: AMD Ryzen 5 1600 Six-Core Processor
17:34:26:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
17:34:26:           CPUs: 12
17:34:26:         Memory: 15.93GiB
17:34:26:    Free Memory: 11.65GiB
17:34:26:        Threads: WINDOWS_THREADS
17:34:26:     OS Version: 6.2
17:34:26:    Has Battery: false
17:34:26:     On Battery: false
17:34:26:     UTC Offset: -5
17:34:26:            PID: 10048
17:34:26:            CWD: C:\Program Files (x86)\FAHClient
17:34:26:             OS: Windows 10 Enterprise
17:34:26:        OS Arch: AMD64
17:34:26:           GPUs: 0
17:34:26:  CUDA Device 0: Platform:0 Device:0 Bus:38 Slot:0 Compute:7.5 Driver:10.2
17:34:26:OpenCL Device 0: Platform:0 Device:0 Bus:38 Slot:0 Compute:1.2 Driver:441.20
17:34:26:  Win32 Service: false
17:34:26:******************************* libFAH ********************************
17:34:26:           Date: Apr 15 2020
17:34:26:           Time: 14:53:14
17:34:26:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
17:34:26:           Bits: 32
17:34:26:***********************************************************************
17:34:26:<config>
17:34:26:  <!-- Folding Slots -->
17:34:26:</config>
17:34:26:Trying to access database...
17:34:26:Successfully acquired database lock
17:34:26:Enabled folding slot 00: PAUSED cpu:11 (not configured)
17:34:26:ERROR:Exception: Failed to register systray icon: Unspecified error
17:34:46:19:127.0.0.1:New Web session
17:35:09:Set client configured
17:35:10:WU00:FS00:Connecting to 65.254.110.245:80
17:35:11:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
17:35:11:WU00:FS00:Connecting to 18.218.241.186:80
17:35:11:WU00:FS00:Assigned to work server 155.247.164.214
17:35:11:WU00:FS00:Requesting new work unit for slot 00: READY cpu:11 from 155.247.164.214
17:35:11:WU00:FS00:Connecting to 155.247.164.214:8080
17:35:11:WU00:FS00:Downloading 2.90MiB
17:35:17:WU00:FS00:Download 27.99%
17:35:23:WU00:FS00:Download 71.04%
17:35:27:Saving configuration to config.xml
17:35:27:<config>
17:35:27:  <!-- Slot Control -->
17:35:27:  <power v='FULL'/>
17:35:27:
17:35:27:  <!-- User Information -->
17:35:27:  <passkey v='*****'/>
17:35:27:  <team v='223518'/>
17:35:27:  <user v='jaxinc'/>
17:35:27:
17:35:27:  <!-- Folding Slots -->
17:35:27:  <slot id='0' type='CPU'/>
17:35:27:</config>
17:35:29:WU00:FS00:Download 90.41%
17:35:32:WU00:FS00:Download complete
17:35:32:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14614 run:137 clone:2 gen:48 core:0xa7 unit:0x000000369bf7a4d65e7f6674955be70f
17:35:32:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
17:35:32:WU00:FS00:Connecting to cores.foldingathome.org:80
17:35:32:WU00:FS00:FahCore a7: Downloading 6.71MiB
17:35:38:WU00:FS00:FahCore a7: 80.09%
17:35:40:WU00:FS00:FahCore a7: Download complete
17:35:40:WU00:FS00:Valid core signature
17:35:40:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
17:35:40:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
17:35:40:WU00:FS00:Starting
17:35:40:WARNING:WU00:FS00:Changed SMP threads from 11 to 12 this can cause some work units to fail
17:35:40:WARNING:WU00:FS00:AS lowered CPUs from 12 to 11
17:35:40:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Program Files (x86)\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 706 -lifeline 10048 -checkpoint 15 -np 11
17:35:40:WU00:FS00:Started FahCore on PID 7196
17:35:40:WU00:FS00:Core PID:2352
17:35:40:WU00:FS00:FahCore 0xa7 started
17:35:40:WU00:FS00:0xa7:*********************** Log Started 2020-04-22T17:35:40Z ***********************
17:35:40:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:35:40:WU00:FS00:0xa7:       Type: 0xa7
17:35:40:WU00:FS00:0xa7:       Core: Gromacs
17:35:40:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7196 -checkpoint 15 -np
17:35:40:WU00:FS00:0xa7:             11
17:35:40:WU00:FS00:0xa7:************************************ CBang *************************************
17:35:40:WU00:FS00:0xa7:       Date: Oct 26 2019
17:35:40:WU00:FS00:0xa7:       Time: 01:38:25
17:35:40:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:35:40:WU00:FS00:0xa7:     Branch: master
17:35:40:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:35:40:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:35:40:WU00:FS00:0xa7:   Platform: win32 10
17:35:40:WU00:FS00:0xa7:       Bits: 64
17:35:40:WU00:FS00:0xa7:       Mode: Release
17:35:40:WU00:FS00:0xa7:************************************ System ************************************
17:35:40:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 1600 Six-Core Processor
17:35:40:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
17:35:40:WU00:FS00:0xa7:       CPUs: 12
17:35:40:WU00:FS00:0xa7:     Memory: 15.93GiB
17:35:40:WU00:FS00:0xa7:Free Memory: 11.61GiB
17:35:40:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:35:40:WU00:FS00:0xa7: OS Version: 6.2
17:35:40:WU00:FS00:0xa7:Has Battery: false
17:35:40:WU00:FS00:0xa7: On Battery: false
17:35:40:WU00:FS00:0xa7: UTC Offset: -5
17:35:40:WU00:FS00:0xa7:        PID: 2352
17:35:40:WU00:FS00:0xa7:        CWD: C:\Program Files (x86)\FAHClient\work
17:35:40:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:35:40:WU00:FS00:0xa7:    Version: 0.0.18
17:35:40:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:35:40:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:35:40:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:35:40:WU00:FS00:0xa7:       Time: 01:52:30
17:35:40:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:35:40:WU00:FS00:0xa7:************************************ Build *************************************
17:35:41:WU00:FS00:0xa7:       SIMD: avx_256
17:35:41:WU00:FS00:0xa7:********************************************************************************
17:35:41:WU00:FS00:0xa7:Project: 14614 (Run 137, Clone 2, Gen 48)
17:35:41:WU00:FS00:0xa7:Unit: 0x000000369bf7a4d65e7f6674955be70f
17:35:41:WU00:FS00:0xa7:Reading tar file core.xml
17:35:41:WU00:FS00:0xa7:Reading tar file frame48.tpr
17:35:41:WU00:FS00:0xa7:Digital signatures verified
17:35:41:WU00:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
17:35:41:WU00:FS00:0xa7:Calling: mdrun -s frame48.tpr -o frame48.trr -cpt 15 -nt 10
17:35:41:WU00:FS00:0xa7:Steps: first=0 total=250000
17:35:42:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
17:37:20:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
17:38:55:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
17:39:26:Connecting to assign1.foldingathome.org:80
17:39:26:Updated GPUs.txt
Jaxinc
Post by Jaxinc »
Joe_H wrote:The card is already whitelisted, the device ID is in the GPUs.txt file:
It will not let me save into the folder. The folder is set as "read only" and changing it does nothing as it reverts back.
I will try the beta.
Jaxinc
Post by Jaxinc »
Update, beta allows me to add a GPU slow although it shows as TU106 and not 104.
No, it wasn't the beta setting. It's a problem with the new 7.6.x FAHClient and the restart generally fixes it.
