Access denied on Advance Control Client
IlDav
Post by IlDav »
Hi all,
I just update the client to the newer version and the web client looks fine but if I open Advanced Control I got the error message:
On client "local" 127.0.0.1:36330:
Access denied, invalid password
I tried to use a new passkey but still got the same error, how could I fix it?
Thanks!
Re: Access denied on Advance Control Client
You didn't really give us enough information to help you.
Please post FAHlog per the instructions below.
cdtdelta
Post by cdtdelta »
If you clear out the passkey in the client does it start working? I have the same issue and that's what I had to do.
Running Ubuntu 18.04
But as soon as I put the passkey back in the client gives me an access denied. The web client still works in any case, it's only the FAHControl application that gives me an error.
20:42:41:WARNING:Command server access denied
20:42:46:WARNING:Command server access denied
20:42:51:WARNING:Command server access denied
20:42:56:WARNING:Command server access denied
20:43:01:WARNING:Command server access denied
20:43:06:WARNING:Command server access denied
