I'm interested in joining the beta team, and for that I need to give good feedback, but I can't sit here constantly monitoring which projects are currently running and whether they're beta projects or not.
Any visual indications if a project is in beta? A notification would be even better.
Are there any indications on FAHControl for beta projects?
Re: Are there any indications on FAHControl for beta project
Not that I know of. Part of being a beta team member is paying attention to what the work is, what your machine(s) are doing and reporting back. If you aren't constantly obsessing over what is happening you may not be of the appropriate mindset for the beta team
single 1070
Haha yeah, but it's not about mindset, just that I'm pretty busy with work to be obsessing about it all the time.HaloJones wrote:If you aren't constantly obsessing over what is happening you may not be of the appropriate mindset for the beta team
You can use HFM.NET to collect the data and check to see what projects are in beta and see if HFM.NET has any of them. Also, stalled systems would need to be monitored. Have a read of the rules and see what you think of them
There are reqular announcements of new projects when they appear in Beta. As a memeber of the beta team, you will have R/W access to the beta forum and you can see what else is being discussed. When I'm running with the beta flag set, i generally check daily for new error messages and make any reports that seem appropriate. When my clients are going to be unmonitored for a few days I remove the beta flag or switch to Advanced.
