Only getting base credit for all CPU jobs, with valid bonus
emf
Post by emf »
Hey, I've got that question about stats calculation again. At present, I've done 123 WU's. I've got a properly configured passkey, and I have doublechecked all the config.xml files to verify that the passkey is correct everywhere. I've checked https://apps.foldingathome.org/bonus and it shows 71 WU's; a bit of a discrepancy. I've looked up a selection of completed WU's at https://apps.foldingathome.org/wu, and they're all base credit.
I understand that everything's getting hammered right now, but this seems extra wrong, as if no QRB is being applied for CPU jobs at all?!
As an example:
10:48:23:WU00:FS00:Connecting to 18.218.241.186:80
10:48:25:WU00:FS00:Assigned to work server 143.89.243.111
10:48:25:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:24 from 143.89.243.111
10:48:25:WU00:FS00:Connecting to 143.89.243.111:8080
10:48:28:WU00:FS00:Downloading 10.27MiB
10:48:34:WU00:FS00:Download 28.61%
10:48:40:WU00:FS00:Download 61.47%
10:48:46:WU00:FS00:Download 90.69%
10:48:47:WU00:FS00:Download complete
10:48:49:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16500 run:0 clone:1758 gen:20 core:0xa7 unit:0x000000178f59f36f5e8aad09b36b5e2f
10:48:57:WU00:FS00:Starting
10:48:57:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 95720 -checkpoint 15 -np 24
10:48:57:WU00:FS00:Started FahCore on PID 11748
10:48:57:WU00:FS00:Core PID:11749
10:48:57:WU00:FS00:FahCore 0xa7 started
10:48:58:WU00:FS00:0xa7:*********************** Log Started 2020-04-21T10:48:57Z ***********************
10:48:58:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:48:58:WU00:FS00:0xa7:       Type: 0xa7
10:48:58:WU00:FS00:0xa7:       Core: Gromacs
10:48:58:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 11748 -checkpoint 15 -np
10:48:58:WU00:FS00:0xa7:             24
10:48:58:WU00:FS00:0xa7:************************************ CBang *************************************
10:48:58:WU00:FS00:0xa7:       Date: Oct 26 2019
10:48:58:WU00:FS00:0xa7:       Time: 03:00:47
10:48:58:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
10:48:58:WU00:FS00:0xa7:     Branch: master
10:48:58:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
10:48:58:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
10:48:58:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
10:48:58:WU00:FS00:0xa7:   Platform: darwin 19.0.0
10:48:58:WU00:FS00:0xa7:       Bits: 64
10:48:58:WU00:FS00:0xa7:       Mode: Release
10:48:58:WU00:FS00:0xa7:************************************ System ************************************
10:48:58:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
10:48:58:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
10:48:58:WU00:FS00:0xa7:       CPUs: 24
10:48:58:WU00:FS00:0xa7:     Memory: 96.00GiB
10:48:58:WU00:FS00:0xa7:Free Memory: 79.72GiB
10:48:58:WU00:FS00:0xa7:    Threads: POSIX_THREADS
10:48:58:WU00:FS00:0xa7: OS Version: 10.11
10:48:58:WU00:FS00:0xa7:Has Battery: true
10:48:58:WU00:FS00:0xa7: On Battery: false
10:48:58:WU00:FS00:0xa7: UTC Offset: -5
10:48:58:WU00:FS00:0xa7:        PID: 11749
10:48:58:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
10:48:58:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:48:58:WU00:FS00:0xa7:    Version: 0.0.18
10:48:58:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:48:58:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:48:58:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:48:58:WU00:FS00:0xa7:       Time: 03:06:42
10:48:58:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
10:48:58:WU00:FS00:0xa7:************************************ Build *************************************
10:48:58:WU00:FS00:0xa7:       SIMD: sse2
10:48:58:WU00:FS00:0xa7:********************************************************************************
10:48:58:WU00:FS00:0xa7:Project: 16500 (Run 0, Clone 1758, Gen 20)
10:48:58:WU00:FS00:0xa7:Unit: 0x000000178f59f36f5e8aad09b36b5e2f
10:48:58:WU00:FS00:0xa7:Reading tar file core.xml
10:48:58:WU00:FS00:0xa7:Reading tar file frame20.tpr
10:48:58:WU00:FS00:0xa7:Digital signatures verified
10:48:58:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -cpt 15 -nt 24
10:48:59:WU00:FS00:0xa7:Steps: first=5000000 total=250000
10:49:00:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
10:52:42:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
10:56:24:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
11:00:07:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
11:03:49:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
11:07:39:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
11:11:21:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
11:15:04:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
11:18:46:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
11:22:36:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
11:26:18:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
11:30:00:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
11:33:42:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
11:37:32:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
11:41:14:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
11:44:57:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
11:48:39:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
11:52:29:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
11:56:11:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
11:59:54:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
12:03:36:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
12:07:25:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
12:11:07:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
12:14:50:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
12:18:32:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
12:22:21:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
12:26:04:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
12:29:46:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
12:33:29:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
12:37:18:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
12:41:00:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
12:44:42:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
12:48:24:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
12:52:14:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
12:55:56:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
12:59:39:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
13:03:21:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
13:07:11:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
13:10:53:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
13:14:35:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
13:18:17:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
13:22:07:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
13:25:49:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
13:29:31:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
13:33:13:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
13:37:03:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
13:40:45:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
13:44:27:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
13:48:09:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
13:51:59:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
13:55:41:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
13:59:23:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
14:03:05:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
14:06:55:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
14:10:37:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
14:14:19:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
14:18:01:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
14:21:54:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
14:25:36:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
14:29:23:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
14:33:07:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
14:36:56:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
14:40:38:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
14:44:21:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
14:48:03:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
14:51:52:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:55:35:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:59:17:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
15:02:59:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
15:06:49:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
15:10:32:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
15:14:15:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
15:18:00:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
15:21:53:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
15:25:36:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
15:29:18:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
15:33:00:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
15:36:50:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
15:40:32:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
15:44:14:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
15:47:57:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
15:51:46:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
15:55:28:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
15:59:10:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
16:02:52:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
16:06:42:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
16:10:24:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
16:14:06:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
16:17:48:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
16:21:38:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
16:25:21:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
16:29:02:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
16:32:45:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
16:36:34:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
16:40:16:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
16:43:59:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
16:47:41:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
16:51:30:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
16:55:13:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
16:58:55:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
17:02:38:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
17:02:58:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
17:02:58:WU00:FS00:0xa7:Saving result file frame20.trr
17:02:58:WU00:FS00:0xa7:Saving result file frame20.xtc
17:02:58:WU00:FS00:0xa7:Saving result file md.log
17:02:58:WU00:FS00:0xa7:Saving result file science.log
17:02:58:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
17:02:58:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:02:59:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:16500 run:0 clone:1758 gen:20 core:0xa7 unit:0x000000178f59f36f5e8aad09b36b5e2f
17:02:59:WU00:FS00:Uploading 7.30MiB to 143.89.243.111
17:02:59:WU00:FS00:Connecting to 143.89.243.111:8080
17:03:05:WU00:FS00:Upload 6.85%
17:03:11:WU00:FS00:Upload 13.70%
17:03:17:WU00:FS00:Upload 20.55%
17:03:23:WU00:FS00:Upload 27.39%
17:03:29:WU00:FS00:Upload 34.24%
17:03:35:WU00:FS00:Upload 40.24%
17:03:41:WU00:FS00:Upload 47.08%
17:03:47:WU00:FS00:Upload 53.93%
17:03:53:WU00:FS00:Upload 60.78%
17:03:59:WU00:FS00:Upload 65.92%
17:04:05:WU00:FS00:Upload 71.91%
17:04:11:WU00:FS00:Upload 77.90%
17:04:17:WU00:FS00:Upload 83.90%
17:04:23:WU00:FS00:Upload 89.03%
17:04:29:WU00:FS00:Upload 95.88%
17:04:35:WU00:FS00:Upload complete
17:04:36:WU00:FS00:Server responded WORK_ACK (400)
17:04:36:WU00:FS00:Final credit estimate, 22414.00 points
17:04:36:WU00:FS00:Cleaning up
but it only got base credit after all that, https://apps.foldingathome.org/wu#proje ... 758&gen=20
Will these credits be corrected at some point in the future, and if so, how long should we expect to wait for them to catch up? I know it's not about the points, but.. you know... points. :D
Thanks.
Re: Only getting base credit for all CPU jobs, with valid bo
You're getting bonuses on some WUs and not others.
See https://apps.foldingathome.org/cpu
Bonuses have a number of conditions.
Verify that you're using exactly the same user name and passkey on each client and that we're only looking at WUs which were completed after your first 10 that you completed and that you are maintaining at least an 80% success rate and the WUs are being returned before their Timeout.
emf
Post by emf »
*sigh* Thanks. I did find it. There was a one digit transposition in the passkey on 4D79B5E2A12DB83.
Can that be corrected or are those points all lost forever?
No, and no. No corrections, ever.
The points aren't really lost, they're just recorded under a different database key ... but you'd need to complete 10 more units under the "new" passkey
emf
Post by emf »
Gotcha. Thanks!
emf
Post by emf »
"but you'd need to complete 10 more units under the "new" passkey" - uh.. the machine in question did 49 WU's on username/wrongkey. Are you saying that doing 10 more WU's on that machine with username/correctkey will 'unlock' those old points somehow?
No. I'm saying that you have points under emf+Passskey and more points uner emf+other_passkey and you had to complete 10 no-bonus WUs under each pair to start earning bonuses under that pair.
emf
Post by emf »
Uh... so why is emf+wrongkey not getting bonuses if it did 49 WU's ? shouldn't the most recent 39 have gotten bonus? (This has become an oddly interesting digression)
I'm not sure. I'd assume it would, but if you say so, I'm wrong.
The passkey entered with digits transposed may not be recognized as a valid passkey.
