This might have been asked, but I'm really struggling to use the search function on this forum.
I'm running FAH (recently updated to 7.6.9) on a windows 10 PC and it never starts with windows. If I restart for something, I have to look for FAHClient and FAHControl and run them myself to see what's going on, and it never returns to the system tray.
FAH doesn't start with windows
matt.noteboom
Re: FAH doesn't start with windows
This is a choice that can be made at install time. While it's possible to modify your installation I would have to ask a number of questions and then give you several steps that you'd have to follow, but the simplest way to fix it is to reinstall. While logged on as your nomal user, (not administrator or root) you can go to the website and download a fresh copy (which may or may not be a newer version). If it's windows, iit will ask you for permission to install the software in the program_files directory.
I had a similar issue insofar as the shortcut wasn't created after the install using my regular account under Windows 10 and I needed to search for the .exe to start them etc. I guess your mileage may vary but installing as a normal user didn't work for me. What I ended up doing was logging in with my Administrator account, installing, then taking the shortcut which was created and copying it to the desktop of my regular account i.e. C:\Users\myuser\Desktop. See what I went through here (viewtopic.php?f=61&t=34573). I guess after that you could technically put that shortcut in C:\Users\Myuser\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup. I haven't tried this though since I don't restart that often... I'm sure there are other ways. This is more of a DIY kind of way. I wish I didn't have to do any of this. Good luck!
Intel Core i5-2500K CPU @ 3.30GHz @ 98%, 4 cores
Asus ROG STRIX RX480 8Gb
matt.noteboom
Thanks folks. A variation on BP2020's solution worked - seems there is an issue with locating that shortcut when installing from a non-administrator account. My admin account starts FAH on login, and has a shortcut on the desktop, but those things were never generated for the day-to-day account. Copying the shortcut from admin to day-to-day profile seems to work.
jrweiss
It's actually easy to get F@H or any app to start up with Windows. Copy and paste the F@H shortcut to the C:\Users\[username]\StartMenu\Programs\Startup folder. If you want it to start with any user, put it in the C:\Users\All Users\StartMenu\Programs\Startup folder.
