GPU GEforce GT 530
AndreaDP75
GPU GEforce GT 530
Post by AndreaDP75 »
I have installed the 7.6.9 client but the GPU isn't working. Isn't it supported or it's a problem of che client? Here is my log:
*********************** Log Started 2020-04-21T06:25:24Z ***********************
06:25:24:****************************** FAHClient ******************************
06:25:24:        Version: 7.6.9
06:25:24:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:25:24:      Copyright: 2020 foldingathome.org
06:25:24:       Homepage: https://foldingathome.org/
06:25:24:           Date: Apr 17 2020
06:25:24:           Time: 11:13:06
06:25:24:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
06:25:24:         Branch: master
06:25:24:       Compiler: Visual C++ 2008
06:25:24:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:25:24:       Platform: win32 10
06:25:24:           Bits: 32
06:25:24:           Mode: Release
06:25:24:         Config: C:\Users\Andrea\AppData\Roaming\FAHClient\config.xml
06:25:24:******************************** CBang ********************************
06:25:24:           Time: 11:10:09
06:25:24:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
06:25:24:           Bits: 32
06:25:24:******************************* System ********************************
06:25:24:            CPU: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
06:25:24:         CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
06:25:24:           CPUs: 4
06:25:24:         Memory: 7.99GiB
06:25:24:    Free Memory: 6.08GiB
06:25:24:        Threads: WINDOWS_THREADS
06:25:24:     OS Version: 6.2
06:25:24:    Has Battery: false
06:25:24:     On Battery: false
06:25:24:     UTC Offset: 2
06:25:24:            PID: 7576
06:25:24:            CWD: C:\Users\Andrea\AppData\Roaming\FAHClient
06:25:24:             OS: Windows 10 Home
06:25:24:        OS Arch: AMD64
06:25:24:           GPUs: 1
06:25:24:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF108 [GeForce GT 530] 268.8
06:25:24:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.1 Driver:9.1
06:25:24:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:390.77
06:25:24:  Win32 Service: false
06:25:24:******************************* libFAH ********************************
06:25:24:           Date: Apr 15 2020
06:25:24:           Time: 14:53:14
06:25:24:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
06:25:24:           Bits: 32
06:25:24:***********************************************************************
06:25:24:<config>
06:25:24:  <!-- Folding Slot Configuration -->
06:25:24:  <cause v='COVID_19'/>
06:25:24:
06:25:24:  <!-- Network -->
06:25:24:  <proxy v=':8080'/>
06:25:24:
06:25:24:  <!-- Slot Control -->
06:25:24:  <power v='FULL'/>
06:25:24:
06:25:24:  <!-- User Information -->
06:25:24:  <passkey v='*****'/>
06:25:24:  <user v='AndreaDP75'/>
06:25:24:
06:25:24:  <!-- Folding Slots -->
06:25:24:  <slot id='0' type='CPU'/>
06:25:24:</config>
06:25:24:Trying to access database...
06:25:25:Successfully acquired database lock
06:25:25:Enabled folding slot 00: READY cpu:4
06:25:25:WU00:FS00:Starting
06:25:26:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Andrea\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 7576 -checkpoint 15 -np 4
06:25:35:WU00:FS00:Started FahCore on PID 6340
06:25:42:WU00:FS00:Core PID:8604
06:25:42:WU00:FS00:FahCore 0xa7 started
06:25:45:WU00:FS00:0xa7:*********************** Log Started 2020-04-21T06:25:45Z ***********************
06:25:45:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:25:45:WU00:FS00:0xa7:       Type: 0xa7
06:25:45:WU00:FS00:0xa7:       Core: Gromacs
06:25:45:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 6340 -checkpoint 15 -np 4
06:25:45:WU00:FS00:0xa7:************************************ CBang *************************************
06:25:45:WU00:FS00:0xa7:       Date: Oct 26 2019
06:25:45:WU00:FS00:0xa7:       Time: 01:38:35
06:25:45:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
06:25:45:WU00:FS00:0xa7:     Branch: master
06:25:45:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:25:45:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:25:45:WU00:FS00:0xa7:   Platform: win32 10
06:25:45:WU00:FS00:0xa7:       Bits: 64
06:25:45:WU00:FS00:0xa7:       Mode: Release
06:25:45:WU00:FS00:0xa7:************************************ System ************************************
06:25:45:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
06:25:45:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
06:25:45:WU00:FS00:0xa7:       CPUs: 4
06:25:45:WU00:FS00:0xa7:     Memory: 7.99GiB
06:25:45:WU00:FS00:0xa7:Free Memory: 5.93GiB
06:25:45:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
06:25:45:WU00:FS00:0xa7: OS Version: 6.2
06:25:45:WU00:FS00:0xa7:Has Battery: false
06:25:45:WU00:FS00:0xa7: On Battery: false
06:25:45:WU00:FS00:0xa7: UTC Offset: 2
06:25:45:WU00:FS00:0xa7:        PID: 8604
06:25:45:WU00:FS00:0xa7:        CWD: C:\Users\Andrea\AppData\Roaming\FAHClient\work
06:25:45:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:25:45:WU00:FS00:0xa7:    Version: 0.0.18
06:25:45:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:25:45:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:25:45:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:25:45:WU00:FS00:0xa7:       Time: 01:52:44
06:25:45:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
06:25:45:WU00:FS00:0xa7:************************************ Build *************************************
06:25:45:WU00:FS00:0xa7:       SIMD: sse2
06:25:45:WU00:FS00:0xa7:********************************************************************************
06:25:46:WU00:FS00:0xa7:Project: 14633 (Run 782, Clone 0, Gen 15)
06:25:46:WU00:FS00:0xa7:Unit: 0x000000109bf7a4d65e848be8efaa5213
06:25:46:WU00:FS00:0xa7:Digital signatures verified
06:25:46:WU00:FS00:0xa7:Calling: mdrun -s frame15.tpr -o frame15.trr -cpi state.cpt -cpt 15 -nt 4
06:25:48:WU00:FS00:0xa7:Steps: first=0 total=2500000
06:25:48:WU00:FS00:0xa7:Completed 321093 out of 2500000 steps (12%)
06:26:27:WU00:FS00:0xa7:Completed 325000 out of 2500000 steps (13%)
06:30:44:WU00:FS00:0xa7:Completed 350000 out of 2500000 steps (14%)
06:34:45:WU00:FS00:0xa7:Completed 375000 out of 2500000 steps (15%)
06:38:23:WU00:FS00:0xa7:Completed 400000 out of 2500000 steps (16%)
06:41:46:WU00:FS00:0xa7:Completed 425000 out of 2500000 steps (17%)
06:45:08:WU00:FS00:0xa7:Completed 450000 out of 2500000 steps (18%)
06:48:32:WU00:FS00:0xa7:Completed 475000 out of 2500000 steps (19%)
06:50:46:2:127.0.0.1:New Web session
06:50:47:7:127.0.0.1:New Web session
06:52:40:WU00:FS00:0xa7:Completed 500000 out of 2500000 steps (20%)
06:58:27:WU00:FS00:0xa7:Completed 525000 out of 2500000 steps (21%)
07:03:03:WU00:FS00:0xa7:Completed 550000 out of 2500000 steps (22%)
07:07:02:WU00:FS00:0xa7:Completed 575000 out of 2500000 steps (23%)
07:11:31:WU00:FS00:0xa7:Completed 600000 out of 2500000 steps (24%)
07:15:43:WU00:FS00:0xa7:Completed 625000 out of 2500000 steps (25%)
07:19:51:WU00:FS00:0xa7:Completed 650000 out of 2500000 steps (26%)
07:23:30:WU00:FS00:0xa7:Completed 675000 out of 2500000 steps (27%)
07:27:53:WU00:FS00:0xa7:Completed 700000 out of 2500000 steps (28%)
07:31:51:WU00:FS00:0xa7:Completed 725000 out of 2500000 steps (29%)
07:35:50:WU00:FS00:0xa7:Completed 750000 out of 2500000 steps (30%)
07:39:19:WU00:FS00:0xa7:Completed 775000 out of 2500000 steps (31%)
07:42:46:WU00:FS00:0xa7:Completed 800000 out of 2500000 steps (32%)
07:46:13:WU00:FS00:0xa7:Completed 825000 out of 2500000 steps (33%)
07:50:28:WU00:FS00:0xa7:Completed 850000 out of 2500000 steps (34%)
07:55:29:WU00:FS00:0xa7:Completed 875000 out of 2500000 steps (35%)
07:59:59:WU00:FS00:0xa7:Completed 900000 out of 2500000 steps (36%)
08:03:45:WU00:FS00:0xa7:Completed 925000 out of 2500000 steps (37%)
08:07:10:WU00:FS00:0xa7:Completed 950000 out of 2500000 steps (38%)
08:10:34:WU00:FS00:0xa7:Completed 975000 out of 2500000 steps (39%)
08:13:55:WU00:FS00:0xa7:Completed 1000000 out of 2500000 steps (40%)
08:17:17:WU00:FS00:0xa7:Completed 1025000 out of 2500000 steps (41%)
08:20:40:WU00:FS00:0xa7:Completed 1050000 out of 2500000 steps (42%)
08:24:44:WU00:FS00:0xa7:Completed 1075000 out of 2500000 steps (43%)
08:29:38:WU00:FS00:0xa7:Completed 1100000 out of 2500000 steps (44%)
08:33:14:WU00:FS00:0xa7:Completed 1125000 out of 2500000 steps (45%)
08:37:19:WU00:FS00:0xa7:Completed 1150000 out of 2500000 steps (46%)
08:41:41:WU00:FS00:0xa7:Completed 1175000 out of 2500000 steps (47%)
08:46:04:WU00:FS00:0xa7:Completed 1200000 out of 2500000 steps (48%)
08:49:35:WU00:FS00:0xa7:Completed 1225000 out of 2500000 steps (49%)
08:53:53:WU00:FS00:0xa7:Completed 1250000 out of 2500000 steps (50%)
08:57:35:WU00:FS00:0xa7:Completed 1275000 out of 2500000 steps (51%)
09:00:54:WU00:FS00:0xa7:Completed 1300000 out of 2500000 steps (52%)
09:04:16:WU00:FS00:0xa7:Completed 1325000 out of 2500000 steps (53%)
09:07:39:WU00:FS00:0xa7:Completed 1350000 out of 2500000 steps (54%)
09:11:00:WU00:FS00:0xa7:Completed 1375000 out of 2500000 steps (55%)
09:14:24:WU00:FS00:0xa7:Completed 1400000 out of 2500000 steps (56%)
09:17:45:WU00:FS00:0xa7:Completed 1425000 out of 2500000 steps (57%)
09:21:04:WU00:FS00:0xa7:Completed 1450000 out of 2500000 steps (58%)
09:24:30:WU00:FS00:0xa7:Completed 1475000 out of 2500000 steps (59%)
09:27:52:WU00:FS00:0xa7:Completed 1500000 out of 2500000 steps (60%)
09:31:13:WU00:FS00:0xa7:Completed 1525000 out of 2500000 steps (61%)
09:34:33:WU00:FS00:0xa7:Completed 1550000 out of 2500000 steps (62%)
09:37:58:WU00:FS00:0xa7:Completed 1575000 out of 2500000 steps (63%)
09:41:22:WU00:FS00:0xa7:Completed 1600000 out of 2500000 steps (64%)
09:44:44:WU00:FS00:0xa7:Completed 1625000 out of 2500000 steps (65%)
09:48:03:WU00:FS00:0xa7:Completed 1650000 out of 2500000 steps (66%)
09:51:31:WU00:FS00:0xa7:Completed 1675000 out of 2500000 steps (67%)
09:54:53:WU00:FS00:0xa7:Completed 1700000 out of 2500000 steps (68%)
09:58:14:WU00:FS00:0xa7:Completed 1725000 out of 2500000 steps (69%)
10:01:36:WU00:FS00:0xa7:Completed 1750000 out of 2500000 steps (70%)
10:04:59:WU00:FS00:0xa7:Completed 1775000 out of 2500000 steps (71%)
10:08:22:WU00:FS00:0xa7:Completed 1800000 out of 2500000 steps (72%)
10:11:43:WU00:FS00:0xa7:Completed 1825000 out of 2500000 steps (73%)
10:15:04:WU00:FS00:0xa7:Completed 1850000 out of 2500000 steps (74%)
10:18:31:WU00:FS00:0xa7:Completed 1875000 out of 2500000 steps (75%)
10:21:59:WU00:FS00:0xa7:Completed 1900000 out of 2500000 steps (76%)
10:25:38:WU00:FS00:0xa7:Completed 1925000 out of 2500000 steps (77%)
10:29:04:WU00:FS00:0xa7:Completed 1950000 out of 2500000 steps (78%)
10:32:29:WU00:FS00:0xa7:Completed 1975000 out of 2500000 steps (79%)
10:35:53:WU00:FS00:0xa7:Completed 2000000 out of 2500000 steps (80%)
10:39:18:WU00:FS00:0xa7:Completed 2025000 out of 2500000 steps (81%)
10:42:42:WU00:FS00:0xa7:Completed 2050000 out of 2500000 steps (82%)
10:46:06:WU00:FS00:0xa7:Completed 2075000 out of 2500000 steps (83%)
10:49:32:WU00:FS00:0xa7:Completed 2100000 out of 2500000 steps (84%)
10:52:58:WU00:FS00:0xa7:Completed 2125000 out of 2500000 steps (85%)
10:56:25:WU00:FS00:0xa7:Completed 2150000 out of 2500000 steps (86%)
10:59:51:WU00:FS00:0xa7:Completed 2175000 out of 2500000 steps (87%)
11:03:13:WU00:FS00:0xa7:Completed 2200000 out of 2500000 steps (88%)
11:06:34:WU00:FS00:0xa7:Completed 2225000 out of 2500000 steps (89%)
11:09:57:WU00:FS00:0xa7:Completed 2250000 out of 2500000 steps (90%)
11:13:22:WU00:FS00:0xa7:Completed 2275000 out of 2500000 steps (91%)
11:16:46:WU00:FS00:0xa7:Completed 2300000 out of 2500000 steps (92%)
11:20:05:WU00:FS00:0xa7:Completed 2325000 out of 2500000 steps (93%)
11:23:26:WU00:FS00:0xa7:Completed 2350000 out of 2500000 steps (94%)
11:26:46:WU00:FS00:0xa7:Completed 2375000 out of 2500000 steps (95%)
11:30:45:WU00:FS00:0xa7:Completed 2400000 out of 2500000 steps (96%)
11:34:39:WU00:FS00:0xa7:Completed 2425000 out of 2500000 steps (97%)
11:38:29:WU00:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
11:42:12:WU00:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
11:42:13:WU01:FS00:Connecting to 65.254.110.245:80
11:42:14:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:42:14:WU01:FS00:Connecting to 18.218.241.186:80
11:42:14:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:42:14:WU01:FS00:Connecting to 65.254.110.245:80
11:42:15:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:42:15:WU01:FS00:Connecting to 18.218.241.186:80
11:42:15:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:42:15:ERROR:WU01:FS00:Exception: Could not get an assignment
11:42:15:WU01:FS00:Connecting to 65.254.110.245:80
11:42:16:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:42:16:WU01:FS00:Connecting to 18.218.241.186:80
11:42:16:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:42:16:WU01:FS00:Connecting to 65.254.110.245:80
11:42:17:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:42:17:WU01:FS00:Connecting to 18.218.241.186:80
11:42:17:WU01:FS00:Assigned to work server 168.245.198.125
11:42:17:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 168.245.198.125
11:42:17:WU01:FS00:Connecting to 168.245.198.125:8080
11:42:18:WU01:FS00:Downloading 872.50KiB
11:42:19:WU01:FS00:Download complete
11:42:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:16425 run:1372 clone:3 gen:25 core:0xa7 unit:0x0000001aa8f5c67d5e9140a7cd3494b9
11:46:26:WU00:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
11:46:27:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
11:46:27:WU00:FS00:0xa7:Saving result file dhdl.xvg
11:46:27:WU00:FS00:0xa7:Saving result file frame15.trr
11:46:27:WU00:FS00:0xa7:Saving result file md.log
11:46:27:WU00:FS00:0xa7:Saving result file science.log
11:46:27:WU00:FS00:0xa7:Saving result file traj_comp.xtc
11:46:27:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:46:28:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:46:28:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14633 run:782 clone:0 gen:15 core:0xa7 unit:0x000000109bf7a4d65e848be8efaa5213
11:46:28:WU00:FS00:Uploading 8.31MiB to 155.247.164.214
11:46:28:WU00:FS00:Connecting to 155.247.164.214:8080
11:46:28:WU01:FS00:Starting
11:46:28:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Andrea\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 7576 -checkpoint 15 -np 4
11:46:29:WU01:FS00:Started FahCore on PID 6112
11:46:30:WU01:FS00:Core PID:6280
11:46:30:WU01:FS00:FahCore 0xa7 started
11:46:30:WU01:FS00:0xa7:*********************** Log Started 2020-04-21T11:46:30Z ***********************
11:46:30:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:46:30:WU01:FS00:0xa7:       Type: 0xa7
11:46:30:WU01:FS00:0xa7:       Core: Gromacs
11:46:30:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 6112 -checkpoint 15 -np 4
11:46:30:WU01:FS00:0xa7:************************************ CBang *************************************
11:46:30:WU01:FS00:0xa7:       Date: Oct 26 2019
11:46:30:WU01:FS00:0xa7:       Time: 01:38:35
11:46:30:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:46:30:WU01:FS00:0xa7:     Branch: master
11:46:30:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:46:30:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:46:30:WU01:FS00:0xa7:   Platform: win32 10
11:46:30:WU01:FS00:0xa7:       Bits: 64
11:46:30:WU01:FS00:0xa7:       Mode: Release
11:46:30:WU01:FS00:0xa7:************************************ System ************************************
11:46:30:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
11:46:30:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
11:46:30:WU01:FS00:0xa7:       CPUs: 4
11:46:30:WU01:FS00:0xa7:     Memory: 7.99GiB
11:46:30:WU01:FS00:0xa7:Free Memory: 3.87GiB
11:46:30:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
11:46:30:WU01:FS00:0xa7: OS Version: 6.2
11:46:30:WU01:FS00:0xa7:Has Battery: false
11:46:30:WU01:FS00:0xa7: On Battery: false
11:46:30:WU01:FS00:0xa7: UTC Offset: 2
11:46:30:WU01:FS00:0xa7:        PID: 6280
11:46:30:WU01:FS00:0xa7:        CWD: C:\Users\Andrea\AppData\Roaming\FAHClient\work
11:46:30:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:46:30:WU01:FS00:0xa7:    Version: 0.0.18
11:46:30:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:46:30:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:46:30:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:46:30:WU01:FS00:0xa7:       Time: 01:52:44
11:46:30:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:46:30:WU01:FS00:0xa7:************************************ Build *************************************
11:46:30:WU01:FS00:0xa7:       SIMD: sse2
11:46:30:WU01:FS00:0xa7:********************************************************************************
11:46:30:WU01:FS00:0xa7:Project: 16425 (Run 1372, Clone 3, Gen 25)
11:46:30:WU01:FS00:0xa7:Unit: 0x0000001aa8f5c67d5e9140a7cd3494b9
11:46:30:WU01:FS00:0xa7:Reading tar file core.xml
11:46:30:WU01:FS00:0xa7:Reading tar file frame25.tpr
11:46:30:WU01:FS00:0xa7:Digital signatures verified
11:46:30:WU01:FS00:0xa7:Calling: mdrun -s frame25.tpr -o frame25.trr -x frame25.xtc -cpt 15 -nt 4
11:46:30:WU01:FS00:0xa7:Steps: first=25000000 total=1000000
11:46:31:WU01:FS00:0xa7:Completed 1 out of 1000000 steps (0%)
11:46:38:WU00:FS00:Upload 1.50%
11:47:02:WU00:FS00:Upload 2.26%
11:47:44:WU00:FS00:Upload 3.01%
11:52:00:WU01:FS00:0xa7:Completed 10000 out of 1000000 steps (1%)
11:52:50:WU00:FS00:Upload 3.76%
11:52:50:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
11:52:50:WU00:FS00:Trying to send results to collection server
11:52:50:WU00:FS00:Uploading 8.31MiB to 52.224.109.74
11:52:50:WU00:FS00:Connecting to 52.224.109.74:8080
11:52:56:WU00:FS00:Upload 23.32%
11:53:02:WU00:FS00:Upload 40.63%
11:53:08:WU00:FS00:Upload 78.24%
11:53:11:WU00:FS00:Upload complete
11:53:11:WU00:FS00:Server responded WORK_ACK (400)
11:53:11:WU00:FS00:Final credit estimate, 1357.00 points
11:53:12:WU00:FS00:Cleaning up
11:58:04:WU01:FS00:0xa7:Completed 20000 out of 1000000 steps (2%)
12:03:48:WU01:FS00:0xa7:Completed 30000 out of 1000000 steps (3%)
12:09:30:WU01:FS00:0xa7:Completed 40000 out of 1000000 steps (4%)
12:15:18:WU01:FS00:0xa7:Completed 50000 out of 1000000 steps (5%)
12:21:17:WU01:FS00:0xa7:Completed 60000 out of 1000000 steps (6%)
******************************* Date: 2020-04-21 *******************************
12:27:14:WU01:FS00:0xa7:Completed 70000 out of 1000000 steps (7%)
12:32:38:WU01:FS00:0xa7:Completed 80000 out of 1000000 steps (8%)
12:38:11:WU01:FS00:0xa7:Completed 90000 out of 1000000 steps (9%)
12:43:42:WU01:FS00:0xa7:Completed 100000 out of 1000000 steps (10%)
12:48:39:WU01:FS00:0xa7:Completed 110000 out of 1000000 steps (11%)
12:54:10:WU01:FS00:0xa7:Completed 120000 out of 1000000 steps (12%)
12:59:22:WU01:FS00:0xa7:Completed 130000 out of 1000000 steps (13%)
13:04:51:WU01:FS00:0xa7:Completed 140000 out of 1000000 steps (14%)
13:09:57:WU01:FS00:0xa7:Completed 150000 out of 1000000 steps (15%)
13:14:32:WU01:FS00:0xa7:Completed 160000 out of 1000000 steps (16%)
13:19:06:WU01:FS00:0xa7:Completed 170000 out of 1000000 steps (17%)
13:23:38:WU01:FS00:0xa7:Completed 180000 out of 1000000 steps (18%)
13:28:12:WU01:FS00:0xa7:Completed 190000 out of 1000000 steps (19%)
13:32:44:WU01:FS00:0xa7:Completed 200000 out of 1000000 steps (20%)
13:37:17:WU01:FS00:0xa7:Completed 210000 out of 1000000 steps (21%)
13:41:48:WU01:FS00:0xa7:Completed 220000 out of 1000000 steps (22%)
13:46:21:WU01:FS00:0xa7:Completed 230000 out of 1000000 steps (23%)
13:50:53:WU01:FS00:0xa7:Completed 240000 out of 1000000 steps (24%)
13:55:24:WU01:FS00:0xa7:Completed 250000 out of 1000000 steps (25%)
13:59:57:WU01:FS00:0xa7:Completed 260000 out of 1000000 steps (26%)
14:04:28:WU01:FS00:0xa7:Completed 270000 out of 1000000 steps (27%)
14:08:59:WU01:FS00:0xa7:Completed 280000 out of 1000000 steps (28%)
14:13:32:WU01:FS00:0xa7:Completed 290000 out of 1000000 steps (29%)
14:18:05:WU01:FS00:0xa7:Completed 300000 out of 1000000 steps (30%)
14:22:37:WU01:FS00:0xa7:Completed 310000 out of 1000000 steps (31%)
14:27:10:WU01:FS00:0xa7:Completed 320000 out of 1000000 steps (32%)
14:31:44:WU01:FS00:0xa7:Completed 330000 out of 1000000 steps (33%)
14:36:19:WU01:FS00:0xa7:Completed 340000 out of 1000000 steps (34%)
14:40:52:WU01:FS00:0xa7:Completed 350000 out of 1000000 steps (35%)
14:45:24:WU01:FS00:0xa7:Completed 360000 out of 1000000 steps (36%)
14:49:57:WU01:FS00:0xa7:Completed 370000 out of 1000000 steps (37%)
14:54:28:WU01:FS00:0xa7:Completed 380000 out of 1000000 steps (38%)
14:59:00:WU01:FS00:0xa7:Completed 390000 out of 1000000 steps (39%)
15:03:35:WU01:FS00:0xa7:Completed 400000 out of 1000000 steps (40%)
15:08:06:WU01:FS00:0xa7:Completed 410000 out of 1000000 steps (41%)
15:12:41:WU01:FS00:0xa7:Completed 420000 out of 1000000 steps (42%)
15:14:41:15:127.0.0.1:New Web session
15:17:40:WU01:FS00:0xa7:Completed 430000 out of 1000000 steps (43%)
15:22:28:WU01:FS00:0xa7:Completed 440000 out of 1000000 steps (44%)
15:27:20:WU01:FS00:0xa7:Completed 450000 out of 1000000 steps (45%)
15:32:41:WU01:FS00:0xa7:Completed 460000 out of 1000000 steps (46%)
15:38:20:WU01:FS00:0xa7:Completed 470000 out of 1000000 steps (47%)
15:43:30:WU01:FS00:0xa7:Completed 480000 out of 1000000 steps (48%)
Re: GPU GEforce GT 530
There is a bug in the 7.6.9 installer that ends up often not configuring a GPU slot. You could manually configure a GPU slot, but you may run into problem completing WUs. One it is at about the minimum processing power to complete current GPU projects within the deadlines. The second is that most nVidia cards of that series only support OpenCL 1.1. Depending in which capabilities are needed, from reports received here, some projects will work on these cards, but others will fail.
https://www.techpowerup.com/gpu-specs/g ... 0-oem.c630
Yes it only supports OpenCL 1.1, and with 96 cores it won't complete Work Units before the deadline.
