Hey guys,
I have a problem:
My PC has 2 GPU's as follows:
1. AMD Radeon 550RX 4GB
2. Nvidia 1060 GTX 6GB
The AMD GPU gets WU with no problems, but the Nvidia GPU won't get any work for the last 12 hours.
I have adjusted from COVID-19 to ANY, ant yet again nothing, no WU.
Help would be highly appreciated since it is a very powerful GPU.
Nvidia 1060 GTX 6GB Won't Get Ant WU
Re: Nvidia 1060 GTX 6GB Won't Get Ant WU
Welcome to the F@H Forum Jalishkov,
Please note that there's a huge demand for GPU WUs and supply is struggling right now. Work is underway to meet the demand but it will take a bit of time. The reason you're seeing differences between the AMD and Nvidia GPUs is because some projects run only on AMD, others are Nvidia only while rest are fine for both. Thus, you have a steady supply of AMD WUs while your Nvidia is struggling a bit.
Thanks
WU received
WU received
For more detailed help, we would need to see the first 200 lines of your log so we knew how the drivers were set up
viewtopic.php?f=24&t=26036
Without seeing the log, all I can suggest is installing the latest driver straight from Nvidia.
https://www.geforce.com/drivers/results/159423
