"ERROR:Guru Meditation" in Linux VM if WIN host sleeps
scic0
Hardware configuration: Client 1: Win 10 Pro; Intel Core i5-6200 2.30GHz-2.40GHz (4 Cores); 8GB RAM
Client 2 (VM running in Virtualbox in above host): Debian 9.12 (stretch) SMP; Linux 4.9.0.12-amd64; 2 Core; ~5 GB RAM.
Post by scic0 »
I have a Windows host with a Linux VM installed. I am running FaH on both host and guest. If by chance the host sleeps, the FaH in the host works just fine after wakeup, however, the FaH in Linux VM fails everytime giving error:
06:14:02:WARNING:WU01:FS00:Detected clock skew (1 hours 12 mins), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
06:14:02:WARNING:WU01:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
06:14:02:WU01:FS00:0xa7:ERROR:Guru Meditation #0.2e00e5901714a28 (0.3105096) '01/01/frame26.trr'
06:14:02:WU01:FS00:0xa7:WARNING:Unexpected exit() call
06:14:02:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
06:14:02:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
06:14:02:WU01:FS00:0xa7:Saving result file frame26.trr
06:14:03:WARNING:WU01:FS00:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
06:14:03:WARNING:WU01:FS00:Fatal error, dumping
06:14:03:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:16420 run:1964 clone:3 gen:26 core:0xa7 unit:0x00000023a8f5c67d5e8a5fa6b3bc9531
I am using latest FaH client v7.6.9 on both host and guest. I have faced same problem (only in Linux guest) with v7.5.1 also.
The Linux is Debian 9 (Kernel v4.9.0).
The host is running Win 10 Pro.
ajm
Re: "ERROR:Guru Meditation" in Linux VM if WIN host sleeps
Post by ajm »
I don't know, but there's a similar issue here: viewtopic.php?f=106&t=32011 that the OP (mat2) indicates having thus solved: viewtopic.php?p=324929#p324929
