GPU shows as available, doesn't get utilized
KA1J
Hardware configuration: ROG Strix Z390-E Motherboard - i7-8700K @ 5100 MHz - 32 Gig GSkill RAM - NVIDIA GaForce GTX 1080
ASUS P8Z68-DELUXE-GEN3 - i72600K - 16 Gig Ram EVGA RTX 2060 KO Ultra - GTX 1060
Post by KA1J »
I have a NVIDIA GeForce GTX 1080 in one computer. In configure GPU is selected. All options are left at -1 and this GPU shows in both Web control and Client Advanced Control. I am interested in Covid research and the designated research is "Any disease".
Although it shows in the web control as GPU:0:GP104 and says ready, I have never seen it working on a WU, it remains at 0(0,0,0) Work Units and estimated points is 0. The "sphere" which is green on the 6 cores are green and showing rotation, the GPU sphere is always orange with no activity.
I have the latest NVidea drivers for this card but nada. Any suggestions for what I can do to get Coronavirus WUs working with the GPU?
Thanks
i7-8700K @ 5100 MHz
32 Gig GSkill RAM
BP2020
Re: GPU shows as available, doesn't get utilized
Post by BP2020 »
I'm new here but look at the log tab in the Advanced control, sometimes you'll have things like this:
02:45:56:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:45:56:ERROR:WU02:FS01:Exception: Could not get an assignment
There is a shortage of GPU assignments sometimes, for instance I got 3 today, with 4 hours between the last 2, whereas I always get CPU ones right away. This is also alluded to here: viewtopic.php?f=61&t=33193 and viewtopic.php?f=61&t=34581.
Intel Core i5-2500K CPU @ 3.30GHz @ 98%, 4 cores
Asus ROG STRIX RX480 8Gb
Can you please post your log file? Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=24&t=26036 :)
