*********************** Log Started 2020-04-20T20:24:53Z ***********************
20:24:53:****************************** FAHClient ******************************
20:24:53: Version: 7.6.9
20:24:53: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:24:53: Copyright: 2020 foldingathome.org
20:24:53: Homepage: https://foldingathome.org/
20:24:53: Date: Apr 17 2020
20:24:53: Time: 11:13:06
20:24:53: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
20:24:53: Branch: master
20:24:53: Compiler: Visual C++ 2008
20:24:53: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:24:53: Platform: win32 10
20:24:53: Bits: 32
20:24:53: Mode: Release
20:24:53: Config: C:\Users\petrz\AppData\Roaming\FAHClient\config.xml
20:24:53:******************************** CBang ********************************
20:24:53: Time: 11:10:09
20:24:53: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
20:24:53: Bits: 32
20:24:53:******************************* System ********************************
20:24:53: CPU: AMD Ryzen 9 3900X 12-Core Processor
20:24:53: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:24:53: CPUs: 24
20:24:53: Memory: 31.91GiB
20:24:53: Free Memory: 28.43GiB
20:24:53: Threads: WINDOWS_THREADS
20:24:53: OS Version: 6.2
20:24:53: Has Battery: false
20:24:53: On Battery: false
20:24:53: UTC Offset: 2
20:24:53: PID: 12328
20:24:53: CWD: C:\Users\petrz\AppData\Roaming\FAHClient
20:24:53: OS: Windows 10 Enterprise
20:24:53: OS Arch: AMD64
20:24:53: GPUs: 2
20:24:53: GPU 0: Bus:14 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
20:24:53: GPU 1: Bus:11 Slot:0 Func:0 AMD:5 Vega 10 XL/XT [Radeon RX Vega 56/64]
20:24:53: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
20:24:53: Uvedený modul nebyl nalezen.
20:24:53:
20:24:53:OpenCL Device 0: Platform:0 Device:0 Bus:11 Slot:0 Compute:1.2 Driver:3004.7
20:24:53:OpenCL Device 1: Platform:0 Device:1 Bus:14 Slot:0 Compute:1.2 Driver:3004.7
20:24:53: Win32 Service: false
20:24:53:******************************* libFAH ********************************
20:24:53: Date: Apr 15 2020
20:24:53: Time: 14:53:14
20:24:53: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
20:24:53: Bits: 32
20:24:53:***********************************************************************
20:24:53:<config>
20:24:53: <!-- Network -->
20:24:53: <proxy v=':8080'/>
20:24:53:
20:24:53: <!-- Slot Control -->
20:24:53: <power v='FULL'/>
20:24:53:
20:24:53: <!-- User Information -->
20:24:53: <passkey v='*****'/>
20:24:53: <user v='Petr_Z'/>
20:24:53:
20:24:53: <!-- Folding Slots -->
20:24:53: <slot id='0' type='CPU'/>
20:24:53: <slot id='1' type='GPU'/>
20:24:53: <slot id='2' type='GPU'/>
20:24:53:</config>
20:24:53:Trying to access database...
20:24:53:Successfully acquired database lock
20:24:53:Enabled folding slot 00: READY cpu:22
20:24:53:Enabled folding slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64]
20:24:53:Enabled folding slot 02: READY gpu:1:Vega 10 XL/XT [Radeon RX Vega 56/64]
20:24:53:WU01:FS02:Starting
20:24:53:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\petrz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 12328 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:24:53:WU01:FS02:Started FahCore on PID 12432
20:24:53:WU01:FS02:Core PID:12456
20:24:53:WU01:FS02:FahCore 0x22 started
20:24:53:WU01:FS02:0x22:*********************** Log Started 2020-04-20T20:24:53Z ***********************
20:24:53:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
20:24:53:WU01:FS02:0x22: Type: 0x22
20:24:53:WU01:FS02:0x22: Core: Core22
20:24:53:WU01:FS02:0x22: Website: https://foldingathome.org/
20:24:53:WU01:FS02:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:24:53:WU01:FS02:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:24:53:WU01:FS02:0x22: <rafal.wiewiora@choderalab.org>
20:24:53:WU01:FS02:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 12432 -checkpoint 15
20:24:53:WU01:FS02:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
20:24:53:WU01:FS02:0x22: Config: <none>
20:24:53:WU01:FS02:0x22:************************************ Build *************************************
20:24:53:WU01:FS02:0x22: Version: 0.0.2
20:24:53:WU01:FS02:0x22: Date: Dec 6 2019
20:24:53:WU01:FS02:0x22: Time: 21:30:31
20:24:53:WU01:FS02:0x22: Repository: Git
20:24:53:WU01:FS02:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:24:53:WU01:FS02:0x22: Branch: HEAD
20:24:53:WU01:FS02:0x22: Compiler: Visual C++ 2008
20:24:53:WU01:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:24:53:WU01:FS02:0x22: Platform: win32 10
20:24:53:WU01:FS02:0x22: Bits: 64
20:24:53:WU01:FS02:0x22: Mode: Release
20:24:53:WU01:FS02:0x22:************************************ System ************************************
20:24:53:WU01:FS02:0x22: CPU: AMD Ryzen 9 3900X 12-Core Processor
20:24:53:WU01:FS02:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:24:53:WU01:FS02:0x22: CPUs: 24
20:24:53:WU01:FS02:0x22: Memory: 31.91GiB
20:24:53:WU01:FS02:0x22:Free Memory: 28.41GiB
20:24:53:WU01:FS02:0x22: Threads: WINDOWS_THREADS
20:24:53:WU01:FS02:0x22: OS Version: 6.2
20:24:53:WU01:FS02:0x22:Has Battery: false
20:24:53:WU01:FS02:0x22: On Battery: false
20:24:53:WU01:FS02:0x22: UTC Offset: 2
20:24:53:WU01:FS02:0x22: PID: 12456
20:24:53:WU01:FS02:0x22: CWD: C:\Users\petrz\AppData\Roaming\FAHClient\work
20:24:53:WU01:FS02:0x22: OS: Windows 10 Pro
20:24:53:WU01:FS02:0x22: OS Arch: AMD64
20:24:53:WU01:FS02:0x22:********************************************************************************
20:24:53:WU01:FS02:0x22:Project: 11763 (Run 0, Clone 5192, Gen 44)
20:24:53:WU01:FS02:0x22:Unit: 0x0000005080fccb0a5e71137eea98fdb2
20:24:53:WU01:FS02:0x22:Digital signatures verified
20:24:53:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
20:24:53:WU01:FS02:0x22:Version 0.0.2
20:24:54:WU02:FS01:Starting
20:24:54:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\petrz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 12328 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
20:24:54:WU02:FS01:Started FahCore on PID 12500
20:24:54:WU02:FS01:Core PID:12524
20:24:54:WU02:FS01:FahCore 0x22 started
20:24:54:WU00:FS00:Connecting to 65.254.110.245:80
20:24:54:WU02:FS01:0x22:*********************** Log Started 2020-04-20T20:24:54Z ***********************
20:24:54:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:24:54:WU02:FS01:0x22: Type: 0x22
20:24:54:WU02:FS01:0x22: Core: Core22
20:24:54:WU02:FS01:0x22: Website: https://foldingathome.org/
20:24:54:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:24:54:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:24:54:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:24:54:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 12500 -checkpoint 15
20:24:54:WU02:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 1 -gpu 1
20:24:54:WU02:FS01:0x22: Config: <none>
20:24:54:WU02:FS01:0x22:************************************ Build *************************************
20:24:54:WU02:FS01:0x22: Version: 0.0.2
20:24:54:WU02:FS01:0x22: Date: Dec 6 2019
20:24:54:WU02:FS01:0x22: Time: 21:30:31
20:24:54:WU02:FS01:0x22: Repository: Git
20:24:54:WU02:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:24:54:WU02:FS01:0x22: Branch: HEAD
20:24:54:WU02:FS01:0x22: Compiler: Visual C++ 2008
20:24:54:WU02:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:24:54:WU02:FS01:0x22: Platform: win32 10
20:24:54:WU02:FS01:0x22: Bits: 64
20:24:54:WU02:FS01:0x22: Mode: Release
20:24:54:WU02:FS01:0x22:************************************ System ************************************
20:24:54:WU02:FS01:0x22: CPU: AMD Ryzen 9 3900X 12-Core Processor
20:24:54:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:24:54:WU02:FS01:0x22: CPUs: 24
20:24:54:WU02:FS01:0x22: Memory: 31.91GiB
20:24:54:WU02:FS01:0x22:Free Memory: 28.36GiB
20:24:54:WU02:FS01:0x22: Threads: WINDOWS_THREADS
20:24:54:WU02:FS01:0x22: OS Version: 6.2
20:24:54:WU02:FS01:0x22:Has Battery: false
20:24:54:WU02:FS01:0x22: On Battery: false
20:24:54:WU02:FS01:0x22: UTC Offset: 2
20:24:54:WU02:FS01:0x22: PID: 12524
20:24:54:WU02:FS01:0x22: CWD: C:\Users\petrz\AppData\Roaming\FAHClient\work
20:24:54:WU02:FS01:0x22: OS: Windows 10 Pro
20:24:54:WU02:FS01:0x22: OS Arch: AMD64
20:24:54:WU02:FS01:0x22:********************************************************************************
20:24:54:WU02:FS01:0x22:Project: 14417 (Run 0, Clone 1531, Gen 12)
20:24:54:WU02:FS01:0x22:Unit: 0x000000140d5262775e84c8a50152cd5b
20:24:54:WU02:FS01:0x22:Digital signatures verified
20:24:54:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:24:54:WU02:FS01:0x22:Version 0.0.2
20:24:55:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:24:55:WU00:FS00:Connecting to 18.218.241.186:80
20:24:56:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:24:56:WU00:FS00:Connecting to 65.254.110.245:80
20:24:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:24:57:WU00:FS00:Connecting to 18.218.241.186:80
20:24:58:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:24:58:ERROR:WU00:FS00:Exception: Could not get an assignment
20:24:58:WU00:FS00:Connecting to 65.254.110.245:80
20:24:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:24:58:WU00:FS00:Connecting to 18.218.241.186:80
20:24:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:24:59:WU00:FS00:Connecting to 65.254.110.245:80
20:24:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:24:59:WU00:FS00:Connecting to 18.218.241.186:80
20:25:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:25:00:ERROR:WU00:FS00:Exception: Could not get an assignment
20:25:06:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
20:25:06:WU01:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:25:18:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
20:25:18:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:25:41:3:127.0.0.1:New Web session
20:25:58:WU00:FS00:Connecting to 65.254.110.245:80
20:25:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:25:58:WU00:FS00:Connecting to 18.218.241.186:80
20:25:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:25:59:WU00:FS00:Connecting to 65.254.110.245:80
20:25:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:25:59:WU00:FS00:Connecting to 18.218.241.186:80
20:26:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:26:00:ERROR:WU00:FS00:Exception: Could not get an assignment
20:26:01:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
20:26:54:WU01:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
20:27:35:WU00:FS00:Connecting to 65.254.110.245:80
20:27:36:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:27:36:WU00:FS00:Connecting to 18.218.241.186:80
20:27:36:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:27:36:WU00:FS00:Connecting to 65.254.110.245:80
20:27:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
20:27:37:WU00:FS00:Connecting to 18.218.241.186:80
20:27:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:27:37:ERROR:WU00:FS00:Exception: Could not get an assignment
