Just keeps attempting but doesnt actually start folding
on web control, it just says ready but doesn't start or do anything, On advanced control under status it keeps attempting and the number of attempts goes up and up and keeps scheduling the next attempt but just does not start. Another thing is whatever I do it cannot discover/recognize that I have a GPU (1050ti - on latest drivers) and tries to fold off CPU, I have been into advanced control>configure>slots and the only thing that shows up is my CPU. When I am in advanced control every so often the whole thing greys out (like the buttons) and says at top 'Client: local updating inactive' after a few minutes it goes back to 'online' instead of updating, another thing to note is that the 'inactive' bit has never changed. Please help I cannot find anything anywhere else.
Thanks.
Thanks.
Re: Just keeps attempting but doesnt actually start folding
Could you please post your log including the first 100-200 lines?
Regarding the attempts: Its absolutely possible that you struggle for a bit in the search for WUs. There are many folders active right now and there are simply not enough WUs for everyone. You should get some rather soon however. The attempt timer can be reset by pausing the folding slot for a minute and restarting it. If the timer goes up to hours at some point...
Try to manually add a GPU slot in FAHControl. Configure - Slots - Add - GPU with default settings. If that doesnt work, try the quote, then try again.
PantherX wrote:Regarding the inability to add a GPU slot, I would suggest that you:
Manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to %AppData%\FAHClient
Reboot your system
Start up the client and ensure that you can see your GPU in the log file
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
Welcome to the F@H Forum lewi2995,
If you need guidance with posting your log file, please have a look at this topic: viewtopic.php?f=24&t=26036
Ok I have tried the add GPU before but I did it again, it now says 0 CPU , 1 CPU under the folding slots parts. Here's the Log,
Also did I mention if it helps the version I am on is 7.6.9
Thanks.
*********************** Log Started 2020-04-21T07:43:53Z ***********************
07:43:53:****************************** FAHClient ******************************
07:43:53: Version: 7.6.9
07:43:53: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:43:53: Copyright: 2020 foldingathome.org
07:43:53: Homepage: https://foldingathome.org/
07:43:53: Date: Apr 17 2020
07:43:53: Time: 11:13:06
07:43:53: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
07:43:53: Branch: master
07:43:53: Compiler: Visual C++ 2008
07:43:53: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:43:53: Platform: win32 10
07:43:53: Bits: 32
07:43:53: Mode: Release
07:43:53: Config: C:\Users\Lewis\AppData\Roaming\FAHClient\config.xml
07:43:53:******************************** CBang ********************************
07:43:53: Time: 11:10:09
07:43:53: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
07:43:53: Bits: 32
07:43:53:******************************* System ********************************
07:43:53: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
07:43:53: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:43:53: CPUs: 8
07:43:53: Memory: 15.95GiB
07:43:53: Free Memory: 12.22GiB
07:43:53: Threads: WINDOWS_THREADS
07:43:53: OS Version: 6.2
07:43:53: Has Battery: false
07:43:53: On Battery: false
07:43:53: UTC Offset: 1
07:43:53: PID: 14928
07:43:53: CWD: C:\Users\Lewis\AppData\Roaming\FAHClient
07:43:53: OS: Windows 10 Enterprise
07:43:53: OS Arch: AMD64
07:43:53: GPUs: 0
07:43:53: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
07:43:53:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.8
07:43:53: Win32 Service: false
07:43:53:******************************* libFAH ********************************
07:43:53: Date: Apr 15 2020
07:43:53: Time: 14:53:14
07:43:53: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
07:43:53: Bits: 32
07:43:53:***********************************************************************
07:43:53:<config>
07:43:53: <!-- Network -->
07:43:53: <proxy v=':8080'/>
07:43:53:
07:43:53: <!-- User Information -->
07:43:53: <team v='223518'/>
07:43:53: <user v='lewisscotney'/>
07:43:53:
07:43:53: <!-- Folding Slots -->
07:43:53: <slot id='0' type='CPU'/>
07:43:53:</config>
07:43:53:Trying to access database...
07:43:53:Successfully acquired database lock
07:43:53:Enabled folding slot 00: READY cpu:7
07:43:53:WU00:FS00:Connecting to 65.254.110.245:80
07:44:25:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:44:25:WU00:FS00:Connecting to 18.218.241.186:80
07:44:47:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:44:47:WU00:FS00:Connecting to 65.254.110.245:80
07:45:10:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:45:10:WU00:FS00:Connecting to 18.218.241.186:80
07:45:31:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:45:31:ERROR:WU00:FS00:Exception: Could not get an assignment ID
07:45:32:WU00:FS00:Connecting to 65.254.110.245:80
07:45:55:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:45:55:WU00:FS00:Connecting to 18.218.241.186:80
07:46:16:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:46:16:WU00:FS00:Connecting to 65.254.110.245:80
07:46:39:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:46:39:WU00:FS00:Connecting to 18.218.241.186:80
07:47:00:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:47:00:ERROR:WU00:FS00:Exception: Could not get an assignment ID
07:47:00:WU00:FS00:Connecting to 65.254.110.245:80
07:47:26:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:47:26:WU00:FS00:Connecting to 18.218.241.186:80
07:47:50:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:47:50:WU00:FS00:Connecting to 65.254.110.245:80
07:48:13:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:48:13:WU00:FS00:Connecting to 18.218.241.186:80
07:48:36:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:48:36:ERROR:WU00:FS00:Exception: Could not get an assignment ID
07:48:38:WU00:FS00:Connecting to 65.254.110.245:80
07:48:53:Connecting to assign1.foldingathome.org:80
07:49:15:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org: Failed to read stream
07:49:15:Connecting to assign2.foldingathome.org:80
07:49:35:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org: Failed to read stream
07:49:35:Connecting to assign3.foldingathome.org:80
07:49:57:WARNING:Attempting to update GPUs.txt from assign3.foldingathome.org: Failed to read stream
07:49:57:Connecting to assign4.foldingathome.org:80
07:50:16:WARNING:Attempting to update GPUs.txt from assign4.foldingathome.org: Failed to read stream
07:50:17:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:50:17:WU00:FS00:Connecting to 18.218.241.186:80
07:50:38:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:50:38:WU00:FS00:Connecting to 65.254.110.245:80
07:50:58:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:50:58:WU00:FS00:Connecting to 18.218.241.186:80
07:51:18:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:51:18:ERROR:WU00:FS00:Exception: Could not get an assignment ID
07:51:19:WU00:FS00:Connecting to 65.254.110.245:80
07:51:40:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:51:40:WU00:FS00:Connecting to 18.218.241.186:80
07:52:00:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:52:00:WU00:FS00:Connecting to 65.254.110.245:80
07:52:20:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:52:20:WU00:FS00:Connecting to 18.218.241.186:80
07:52:40:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:52:40:ERROR:WU00:FS00:Exception: Could not get an assignment ID
07:53:53:Connecting to assign1.foldingathome.org:80
07:54:15:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org: Failed to read stream
07:54:15:Connecting to assign2.foldingathome.org:80
07:54:39:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org: Failed to read stream
07:54:39:Connecting to assign3.foldingathome.org:80
07:55:00:WARNING:Attempting to update GPUs.txt from assign3.foldingathome.org: Failed to read stream
07:55:00:Connecting to assign4.foldingathome.org:80
07:55:20:WARNING:Attempting to update GPUs.txt from assign4.foldingathome.org: Failed to read stream
07:55:33:WU00:FS00:Connecting to 65.254.110.245:80
07:55:54:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:55:54:WU00:FS00:Connecting to 18.218.241.186:80
07:56:15:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:56:15:WU00:FS00:Connecting to 65.254.110.245:80
07:56:36:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
07:56:36:WU00:FS00:Connecting to 18.218.241.186:80
07:56:55:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
07:56:55:ERROR:WU00:FS00:Exception: Could not get an assignment ID
07:57:41:18:127.0.0.1:New Web session
07:58:53:Connecting to assign1.foldingathome.org:80
07:59:15:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org: Failed to read stream
07:59:15:Connecting to assign2.foldingathome.org:80
07:59:36:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org: Failed to read stream
07:59:36:Connecting to assign3.foldingathome.org:80
07:59:57:WARNING:Attempting to update GPUs.txt from assign3.foldingathome.org: Failed to read stream
07:59:57:Connecting to assign4.foldingathome.org:80
08:00:18:WARNING:Attempting to update GPUs.txt from assign4.foldingathome.org: Failed to read stream
08:00:19:39:127.0.0.1:New Web session
08:02:07:Adding folding slot 01: READY cpu:7
08:02:07:Saving configuration to config.xml
08:02:07:<config>
08:02:07: <!-- Network -->
08:02:07: <proxy v=':8080'/>
08:02:07:
08:02:07: <!-- User Information -->
08:02:07: <team v='223518'/>
08:02:07: <user v='lewisscotney'/>
08:02:07:
08:02:07: <!-- Folding Slots -->
08:02:07: <slot id='0' type='CPU'/>
08:02:07: <slot id='1' type='CPU'/>
08:02:07:</config>
08:02:07:WU01:FS01:Connecting to 65.254.110.245:80
08:02:20:Saving configuration to config.xml
08:02:20:<config>
08:02:20: <!-- Network -->
08:02:20: <proxy v=':8080'/>
08:02:20:
08:02:20: <!-- User Information -->
08:02:20: <team v='223518'/>
08:02:20: <user v='lewisscotney'/>
08:02:20:
08:02:20: <!-- Folding Slots -->
08:02:20: <slot id='0' type='CPU'/>
08:02:20: <slot id='1' type='CPU'/>
08:02:20:</config>
08:02:24:WU00:FS00:Connecting to 65.254.110.245:80
08:02:27:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:02:27:WU01:FS01:Connecting to 18.218.241.186:80
08:02:47:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:02:47:WU01:FS01:Connecting to 65.254.110.245:80
08:02:47:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:02:47:WU00:FS00:Connecting to 18.218.241.186:80
08:03:07:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:03:07:WU00:FS00:Connecting to 65.254.110.245:80
08:03:10:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:03:10:WU01:FS01:Connecting to 18.218.241.186:80
08:03:29:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:03:29:WU00:FS00:Connecting to 18.218.241.186:80
08:03:34:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:03:34:ERROR:WU01:FS01:Exception: Could not get an assignment ID
08:03:34:WU01:FS01:Connecting to 65.254.110.245:80
08:03:51:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:03:51:ERROR:WU00:FS00:Exception: Could not get an assignment ID
08:03:53:Connecting to assign1.foldingathome.org:80
08:04:13:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org: Failed to read stream
08:04:13:Connecting to assign2.foldingathome.org:80
08:04:34:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org: Failed to read stream
08:04:34:Connecting to assign3.foldingathome.org:80
08:05:00:WARNING:Attempting to update GPUs.txt from assign3.foldingathome.org: Failed to read stream
08:05:00:Connecting to assign4.foldingathome.org:80
08:05:24:WARNING:Attempting to update GPUs.txt from assign4.foldingathome.org: Failed to read stream
08:05:26:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:05:26:WU01:FS01:Connecting to 18.218.241.186:80
08:05:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:05:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:05:46:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:05:46:WU01:FS01:Connecting to 65.254.110.245:80
08:06:08:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:06:08:WU01:FS01:Connecting to 18.218.241.186:80
08:06:28:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:06:28:ERROR:WU01:FS01:Exception: Could not get an assignment ID
08:06:28:WU01:FS01:Connecting to 65.254.110.245:80
08:06:49:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:06:49:WU01:FS01:Connecting to 18.218.241.186:80
08:07:11:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:07:11:WU01:FS01:Connecting to 65.254.110.245:80
08:07:34:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:07:34:WU01:FS01:Connecting to 18.218.241.186:80
08:07:55:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:07:55:ERROR:WU01:FS01:Exception: Could not get an assignment ID
08:08:05:WU01:FS01:Connecting to 65.254.110.245:80
08:08:26:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:08:26:WU01:FS01:Connecting to 18.218.241.186:80
08:08:46:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
08:08:46:WU01:FS01:Connecting to 65.254.110.245:80
08:08:53:Connecting to assign1.foldingathome.org:80
08:09:16:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org: Failed to read stream
08:09:16:Connecting to assign2.foldingathome.org:80
08:09:36:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org: Failed to read stream
08:09:36:Connecting to assign3.foldingathome.org:80
08:09:56:WARNING:Attempting to update GPUs.txt from assign3.foldingathome.org: Failed to read stream
08:09:56:Connecting to assign4.foldingathome.org:80
08:10:18:WARNING:Attempting to update GPUs.txt from assign4.foldingathome.org: Failed to read stream
08:10:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
08:10:21:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
08:10:21:WU01:FS01:Connecting to 18.218.241.186:80
08:10:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Thanks.
Thanks for posting your log. It seems that you have ended up adding another CPU Slot and you have lots of connectivity issues. This is the sequence of tasks that needs to happen in this order:
A - Removal of Extra CPU Slot
1) Open up Advanced Control (AKA FAHControl)
2) Click Configure
3) Click Slots Tabs
4) Click "1 CPU "
5) Click "Remove"
6) Click "Save"
B - Configure CPU Slot
2) Click Configure
3) Click Slots Tabs
4) Click "0 CPU "
5) Click "Edit"
6) In CPU Value, enter 6
7) Click "OK"
8) Click "Save"
C - Download GPUs.txt file
1) Manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
2) Exit FAHControl
3) Right click on the icon in the notification tray and select "Quit"
4) Copy the GPUs.txt file from the Downloads folder to C:\Users\Lewis\AppData\Roaming\FAHClient
5) Reboot your system
6) Start up the client
7) Open up Advanced Control (AKA FAHControl)
8) Click Configure
9) Click Slots Tabs
10) Click "Add"
11) Select "GPU"
12) Click "OK"
13) Click "Save"
D - Post a fresh copy of the log.
E - Troubleshooting Server Issues
You seem to have lots of connectivity issues so please review this topic and work through it: viewtopic.php?f=18&t=17794
2) Click Configure
3) Click Slots Tabs
4) Click "1 CPU "
5) Click "Remove"
6) Click "Save"
2) Click Configure
3) Click Slots Tabs
4) Click "0 CPU "
5) Click "Edit"
7) Click "OK"
8) Click "Save"
2) Exit FAHControl
8) Click Configure
9) Click Slots Tabs
10) Click "Add"
11) Select "GPU"
12) Click "OK"
13) Click "Save"
Ok done down the D
All went well as so far, its found my GPU. so I will work through E.
Thanks again.
*********************** Log Started 2020-04-21T09:13:32Z ***********************
09:13:32:****************************** FAHClient ******************************
09:13:32: Version: 7.6.9
09:13:32: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:13:32: Copyright: 2020 foldingathome.org
09:13:32: Homepage: https://foldingathome.org/
09:13:32: Date: Apr 17 2020
09:13:32: Time: 11:13:06
09:13:32: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
09:13:32: Branch: master
09:13:32: Compiler: Visual C++ 2008
09:13:32: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:13:32: Platform: win32 10
09:13:32: Bits: 32
09:13:32: Mode: Release
09:13:32: Args: --open-web-control
09:13:32: Config: C:\Users\Lewis\AppData\Roaming\FAHClient\config.xml
09:13:32:******************************** CBang ********************************
09:13:32: Time: 11:10:09
09:13:32: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
09:13:32: Bits: 32
09:13:32:******************************* System ********************************
09:13:32: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
09:13:32: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
09:13:32: CPUs: 8
09:13:32: Memory: 15.95GiB
09:13:32: Free Memory: 12.15GiB
09:13:32: Threads: WINDOWS_THREADS
09:13:32: OS Version: 6.2
09:13:32: Has Battery: false
09:13:32: On Battery: false
09:13:32: UTC Offset: 1
09:13:32: PID: 14736
09:13:32: CWD: C:\Users\Lewis\AppData\Roaming\FAHClient
09:13:32: OS: Windows 10 Enterprise
09:13:32: OS Arch: AMD64
09:13:32: GPUs: 1
09:13:32: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
09:13:32: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
09:13:32:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.8
09:13:32: Win32 Service: false
09:13:32:******************************* libFAH ********************************
09:13:32: Date: Apr 15 2020
09:13:32: Time: 14:53:14
09:13:32: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
09:13:32: Bits: 32
09:13:32:***********************************************************************
09:13:32:<config>
09:13:32: <!-- Network -->
09:13:32: <proxy v=':8080'/>
09:13:32:
09:13:32: <!-- User Information -->
09:13:32: <team v='223518'/>
09:13:32: <user v='lewisscotney'/>
09:13:32:
09:13:32: <!-- Folding Slots -->
09:13:32: <slot id='0' type='CPU'>
09:13:32: <cpus v='6'/>
09:13:32: <paused v='False'/>
09:13:32: </slot>
09:13:32:</config>
09:13:32:Trying to access database...
09:13:32:Successfully acquired database lock
09:13:32:Enabled folding slot 00: READY cpu:6
09:13:32:WU00:FS00:Connecting to 65.254.110.245:80
09:13:37:19:127.0.0.1:New Web session
09:13:55:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
09:13:55:WU00:FS00:Connecting to 18.218.241.186:80
09:14:19:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
09:14:19:WU00:FS00:Connecting to 65.254.110.245:80
09:14:38:Adding folding slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti] 2138
09:14:38:Saving configuration to config.xml
09:14:38:<config>
09:14:38: <!-- Network -->
09:14:38: <proxy v=':8080'/>
09:14:38:
09:14:38: <!-- User Information -->
09:14:38: <team v='223518'/>
09:14:38: <user v='lewisscotney'/>
09:14:38:
09:14:38: <!-- Folding Slots -->
09:14:38: <slot id='0' type='CPU'>
09:14:38: <cpus v='6'/>
09:14:38: <paused v='False'/>
09:14:38: </slot>
09:14:38: <slot id='1' type='GPU'/>
09:14:38:</config>
09:14:39:WU01:FS01:Connecting to 65.254.110.245:80
09:14:43:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
09:14:43:WU00:FS00:Connecting to 18.218.241.186:80
09:15:00:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
09:15:00:WU01:FS01:Connecting to 18.218.241.186:80
09:15:02:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
09:15:02:ERROR:WU00:FS00:Exception: Could not get an assignment ID
09:15:02:WU00:FS00:Connecting to 65.254.110.245:80
Yep, so far it looks good and the last issue seems to be network related. Hopefully, the troubleshooting thread can resolve your issue(s)
Hi,
I've tried all the troubleshooting things and non seem to work,
on status on AC it always says waiting on: WS Assignment - not sure if that helps.
I heard some people say when it says that its just a waiting game for the server to assign you something.
Thanks.
Thanks.
Lewi2995,
Welcome to Folding@Home!
This is often a sign your firewall is blocking fahclient. I would go in the firewall and add a rule for the application fahclient that it is allowed to send and receive on public and private networks.
Control Panel> Networking and Internet>Windows Firewall>Allow an App through the Firewall>Change Setting, Allow another app then search for fahclient
One 'secret' to getting Work Units is to reboot your PC if you notice you are not getting work.
The longer it sits waiting, the more rarely it checks to see if there is work. Rebooting restarts the timer.
So when you are waiting, update your Nvidia Drivers and reboot, or update Windows and reboot. Or just reboot for faster WU checking.
https://www.geforce.com/drivers/results/159423
still no luck, I've changed the firewall and updated drivers and restarted 3 times, I've left it for a while and the log is still displaying the same as before:
*********************** Log Started 2020-04-21T12:18:38Z ***********************
12:18:38:****************************** FAHClient ******************************
12:18:38: Version: 7.6.9
12:18:38: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:18:38: Copyright: 2020 foldingathome.org
12:18:38: Homepage: https://foldingathome.org/
12:18:38: Date: Apr 17 2020
12:18:38: Time: 11:13:06
12:18:38: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
12:18:38: Branch: master
12:18:38: Compiler: Visual C++ 2008
12:18:38: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:18:38: Platform: win32 10
12:18:38: Bits: 32
12:18:38: Mode: Release
12:18:38: Args: --open-web-control
12:18:38: Config: C:\Users\Lewis\AppData\Roaming\FAHClient\config.xml
12:18:38:******************************** CBang ********************************
12:18:38: Time: 11:10:09
12:18:38: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
12:18:38: Bits: 32
12:18:38:******************************* System ********************************
12:18:38: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
12:18:38: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:18:38: CPUs: 8
12:18:38: Memory: 15.95GiB
12:18:38: Free Memory: 12.88GiB
12:18:38: Threads: WINDOWS_THREADS
12:18:38: OS Version: 6.2
12:18:38: Has Battery: false
12:18:38: On Battery: false
12:18:38: UTC Offset: 1
12:18:38: PID: 12476
12:18:38: CWD: C:\Users\Lewis\AppData\Roaming\FAHClient
12:18:38: OS: Windows 10 Enterprise
12:18:38: OS Arch: AMD64
12:18:38: GPUs: 1
12:18:38: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
12:18:38: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
12:18:38:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
12:18:38: Win32 Service: false
12:18:38:******************************* libFAH ********************************
12:18:38: Date: Apr 15 2020
12:18:38: Time: 14:53:14
12:18:38: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
12:18:38: Bits: 32
12:18:38:***********************************************************************
12:18:38:<config>
12:18:38: <!-- Folding Slot Configuration -->
12:18:38: <cause v='COVID_19'/>
12:18:38:
12:18:38: <!-- Network -->
12:18:38: <proxy v=':8080'/>
12:18:38:
12:18:38: <!-- User Information -->
12:18:38: <team v='223518'/>
12:18:38: <user v='lewisscotney'/>
12:18:38:
12:18:38: <!-- Folding Slots -->
12:18:38: <slot id='0' type='CPU'>
12:18:38: <cpus v='6'/>
12:18:38: </slot>
12:18:38: <slot id='1' type='GPU'/>
12:18:38:</config>
12:18:39:Trying to access database...
12:18:39:Successfully acquired database lock
12:18:39:Enabled folding slot 00: READY cpu:6
12:18:39:Enabled folding slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti] 2138
12:18:39:WU00:FS00:Connecting to 65.254.110.245:80
12:18:39:WU01:FS01:Connecting to 65.254.110.245:80
12:18:42:4:127.0.0.1:New Web session
12:18:44:8:127.0.0.1:New Web session
12:19:02:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:19:02:WU00:FS00:Connecting to 18.218.241.186:80
12:19:02:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:19:02:WU01:FS01:Connecting to 18.218.241.186:80
12:19:24:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:19:24:WU01:FS01:Connecting to 65.254.110.245:80
12:19:25:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:19:25:WU00:FS00:Connecting to 65.254.110.245:80
12:19:45:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:19:45:WU01:FS01:Connecting to 18.218.241.186:80
12:19:49:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:19:49:WU00:FS00:Connecting to 18.218.241.186:80
12:20:04:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:20:04:ERROR:WU01:FS01:Exception: Could not get an assignment ID
12:20:04:WU01:FS01:Connecting to 65.254.110.245:80
12:20:10:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:20:10:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:20:10:WU00:FS00:Connecting to 65.254.110.245:80
12:20:28:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:20:28:WU01:FS01:Connecting to 18.218.241.186:80
12:20:31:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:20:31:WU00:FS00:Connecting to 18.218.241.186:80
12:20:49:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:20:49:WU01:FS01:Connecting to 65.254.110.245:80
12:20:52:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:20:52:WU00:FS00:Connecting to 65.254.110.245:80
12:21:13:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:21:13:WU00:FS00:Connecting to 18.218.241.186:80
12:21:14:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:21:14:WU01:FS01:Connecting to 18.218.241.186:80
12:21:32:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:21:32:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:21:32:WU00:FS00:Connecting to 65.254.110.245:80
12:21:33:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:21:33:ERROR:WU01:FS01:Exception: Could not get an assignment ID
12:21:34:WU01:FS01:Connecting to 65.254.110.245:80
12:21:55:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:21:55:WU00:FS00:Connecting to 18.218.241.186:80
12:21:57:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:21:57:WU01:FS01:Connecting to 18.218.241.186:80
12:22:15:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:22:15:WU00:FS00:Connecting to 65.254.110.245:80
12:22:17:WARNING:WU01:FS01:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:22:17:WU01:FS01:Connecting to 65.254.110.245:80
12:22:38:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:22:38:WU00:FS00:Connecting to 18.218.241.186:80
12:22:40:WARNING:WU01:FS01:Failed to get ID from '65.254.110.245:80': 10002: Received short response, expected 8 bytes, got 0
12:22:40:WU01:FS01:Connecting to 18.218.241.186:80
Just to confirm, you can successfully open these web pages and see the F@H Logo along with the text "Assignment Server":lewi2995 wrote:...I've tried all the troubleshooting things and non seem to work..
F@H AS1: https://assign1.foldingathome.org/
F@H AS2: https://assign2.foldingathome.org/
That's a good start but unfortunately, there's no clear path. Do you have any software/hardware firewall that could block/intercept network traffic? How about anti-virus/anti-malware/anti-spyware/anti-ransomware application?
So would you say its just down to no WU being assigned ? or is something still incorrectly configured?
As for windows firewall I have sorted that out and that's not a problem, I don't actually have any anti virus or anything and the standard windows one is always disabled because I've had problems with it before.
