Request to Add RX 570 to Whitelist
SixFiveMil
Post by SixFiveMil »
fahclient --lspci Output
C:\Users\Josh>fahclient --lspci
0x1022:0x43c6:2:0:2:Advanced Micro Devices, Inc. [AMD]:PCI Express Upstream Switch Port
0x1022:0x1457:9:0:3:Advanced Micro Devices, Inc. [AMD]:High Definition Audio Controller
0x1022:0x1466:0:24:6:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x43c7:3:0:0:Advanced Micro Devices, Inc. [AMD]:PCI Express Downstream Switch Port
0x1022:0x1450:0:0:0:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1452:0:1:0:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1452:0:2:0:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1452:0:3:0:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1452:0:4:0:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1452:0:7:0:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1452:0:8:0:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x15b7:0x5009:1:0:0:Sandisk Corp:Standard NVM Express Controller
0x1022:0x145f:8:0:3:Advanced Micro Devices, Inc. [AMD]:USB xHCI Compliant Host Controller
0x1022:0x1454:0:7:1:Advanced Micro Devices, Inc. [AMD]:PCI Express Root Port
0x1022:0x1454:0:8:1:Advanced Micro Devices, Inc. [AMD]:PCI Express Root Port
0x1022:0x1463:0:24:3:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x790e:0:20:3:Advanced Micro Devices, Inc. [AMD]:PCI standard ISA bridge
0x1022:0x43d5:2:0:0:Advanced Micro Devices, Inc. [AMD]:USB xHCI Compliant Host Controller
0x1022:0x145a:8:0:0:Advanced Micro Devices, Inc. [AMD]:AMD PCI
0x1022:0x43c7:3:1:0:Advanced Micro Devices, Inc. [AMD]:PCI Express Downstream Switch Port
0x1002:0x67df:7:0:0:Advanced Micro Devices, Inc. [AMD/ATI]:Radeon RX 570 Series
0x1022:0x43c7:3:4:0:Advanced Micro Devices, Inc. [AMD]:PCI Express Downstream Switch Port
0x1022:0x1460:0:24:0:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1002:0xaaf0:7:0:1:Advanced Micro Devices, Inc. [AMD/ATI]:High Definition Audio Controller
0x1022:0x1455:9:0:0:Advanced Micro Devices, Inc. [AMD]:AMD PCI
0x1022:0x43c8:2:0:1:Advanced Micro Devices, Inc. [AMD]:Standard SATA AHCI Controller
0x1022:0x1465:0:24:5:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1462:0:24:2:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1453:0:1:1:Advanced Micro Devices, Inc. [AMD]:PCI Express Root Port
0x1022:0x1453:0:1:3:Advanced Micro Devices, Inc. [AMD]:PCI Express Root Port
0x1022:0x1453:0:3:1:Advanced Micro Devices, Inc. [AMD]:PCI Express Root Port
0x1022:0x1467:0:24:7:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x1022:0x1456:8:0:2:Advanced Micro Devices, Inc. [AMD]:AMD PSP 3.0 Device
0x1022:0x790b:0:20:0:Advanced Micro Devices, Inc. [AMD]:AMD SMBus
0x1022:0x7901:9:0:2:Advanced Micro Devices, Inc. [AMD]:Standard SATA AHCI Controller
0x1022:0x1464:0:24:4:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
0x10ec:0x8168:5:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIe GbE Family Controller
0x1022:0x1461:0:24:1:Advanced Micro Devices, Inc. [AMD]:PCI standard host CPU bridge
*********************** Log Started 2020-04-20T18:12:09Z ***********************
18:12:09:****************************** FAHClient ******************************
18:12:09:        Version: 7.6.9
18:12:09:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:12:09:      Copyright: 2020 foldingathome.org
18:12:09:       Homepage: https://foldingathome.org/
18:12:09:           Date: Apr 17 2020
18:12:09:           Time: 11:13:06
18:12:09:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
18:12:09:         Branch: master
18:12:09:       Compiler: Visual C++ 2008
18:12:09:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:12:09:       Platform: win32 10
18:12:09:           Bits: 32
18:12:09:           Mode: Release
18:12:09:           Args: --open-web-control
18:12:09:******************************** CBang ********************************
18:12:09:           Time: 11:10:09
18:12:09:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
18:12:09:           Bits: 32
18:12:09:******************************* System ********************************
18:12:09:            CPU: AMD Ryzen 5 1600 Six-Core Processor
18:12:09:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
18:12:09:           CPUs: 12
18:12:09:         Memory: 15.95GiB
18:12:09:    Free Memory: 10.06GiB
18:12:09:        Threads: WINDOWS_THREADS
18:12:09:     OS Version: 6.2
18:12:09:    Has Battery: false
18:12:09:     On Battery: false
18:12:09:     UTC Offset: -7
18:12:09:            PID: 18596
18:12:09:            CWD: C:\Users\User\AppData\Roaming\FAHClient
18:12:09:             OS: Windows 10 Home
18:12:09:        OS Arch: AMD64
18:12:09:           GPUs: 0
18:12:09:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:12:09:                 specified module could not be found.
18:12:09:
18:12:09:OpenCL Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:1.2 Driver:3004.8
18:12:09:  Win32 Service: false
18:12:09:******************************* libFAH ********************************
18:12:09:           Date: Apr 15 2020
18:12:09:           Time: 14:53:14
18:12:09:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:12:09:           Bits: 32
18:12:09:***********************************************************************
18:12:09:<config>
18:12:09:  <!-- Folding Slots -->
18:12:09:</config>
18:12:09:Trying to access database...
18:12:09:Successfully acquired database lock
18:12:09:Enabled folding slot 00: PAUSED cpu:11 (not configured)
18:12:11:3:127.0.0.1:New Web session
18:12:28:Set client configured
18:12:28:WU00:FS00:Connecting to 65.254.110.245:80
18:12:29:WU00:FS00:Connecting to 65.254.110.245:80
18:12:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:12:29:WU00:FS00:Connecting to 18.218.241.186:80
18:12:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:12:30:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:12:30:ERROR:WU00:FS00:Exception: Could not get an assignment
18:12:30:WU00:FS00:Connecting to 65.254.110.245:80
18:12:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:12:30:WU00:FS00:Connecting to 18.218.241.186:80
18:12:31:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:12:31:WU00:FS00:Connecting to 18.218.241.186:80
18:12:31:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:12:31:ERROR:WU00:FS00:Exception: Could not get an assignment
18:13:10:Saving configuration to config.xml
18:13:10:<config>
18:13:10:  <!-- Network -->
18:13:10:  <proxy v=':8080'/>
18:13:10:
18:13:10:  <!-- User Information -->
18:13:10:  <passkey v='*****'/>
18:13:10:  <user v='SixFiveMil'/>
18:13:10:
18:13:10:  <!-- Folding Slots -->
18:13:10:  <slot id='0' type='CPU'/>
18:13:10:</config>
18:13:30:WU00:FS00:Connecting to 65.254.110.245:80
18:13:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:13:30:WU00:FS00:Connecting to 18.218.241.186:80
18:13:31:WU00:FS00:Assigned to work server 168.245.198.125
18:13:31:WU00:FS00:Requesting new work unit for slot 00: READY cpu:11 from 168.245.198.125
18:13:31:WU00:FS00:Connecting to 168.245.198.125:8080
18:13:31:WU00:FS00:Downloading 1.23MiB
18:13:31:WU00:FS00:Download complete
18:13:31:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16406 run:264 clone:2 gen:92 core:0xa7 unit:0x00000065a8f5c67d5e801edcad7262a8
18:13:32:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
18:13:32:WU00:FS00:Connecting to cores.foldingathome.org:80
18:13:32:WU00:FS00:FahCore a7: Downloading 6.71MiB
18:13:33:WU00:FS00:FahCore a7: Download complete
18:13:33:WU00:FS00:Valid core signature
18:13:33:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
18:13:33:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
18:13:33:WU00:FS00:Starting
18:13:33:WARNING:WU00:FS00:AS lowered CPUs from 11 to 9
18:13:33:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Josh\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 18596 -checkpoint 15 -np 9
18:13:33:WU00:FS00:Started FahCore on PID 9936
18:13:33:WU00:FS00:Core PID:4932
18:13:33:WU00:FS00:FahCore 0xa7 started
18:13:34:WU00:FS00:0xa7:*********************** Log Started 2020-04-20T18:13:33Z ***********************
18:13:34:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:13:34:WU00:FS00:0xa7:       Type: 0xa7
18:13:34:WU00:FS00:0xa7:       Core: Gromacs
18:13:34:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 9936 -checkpoint 15 -np 9
18:13:34:WU00:FS00:0xa7:************************************ CBang *************************************
18:13:34:WU00:FS00:0xa7:       Date: Oct 26 2019
18:13:34:WU00:FS00:0xa7:       Time: 01:38:25
18:13:34:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:13:34:WU00:FS00:0xa7:     Branch: master
18:13:34:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
18:13:34:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:13:34:WU00:FS00:0xa7:   Platform: win32 10
18:13:34:WU00:FS00:0xa7:       Bits: 64
18:13:34:WU00:FS00:0xa7:       Mode: Release
18:13:34:WU00:FS00:0xa7:************************************ System ************************************
18:13:34:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 1600 Six-Core Processor
18:13:34:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
18:13:34:WU00:FS00:0xa7:       CPUs: 12
18:13:34:WU00:FS00:0xa7:     Memory: 15.95GiB
18:13:34:WU00:FS00:0xa7:Free Memory: 10.01GiB
18:13:34:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:13:34:WU00:FS00:0xa7: OS Version: 6.2
18:13:34:WU00:FS00:0xa7:Has Battery: false
18:13:34:WU00:FS00:0xa7: On Battery: false
18:13:34:WU00:FS00:0xa7: UTC Offset: -7
18:13:34:WU00:FS00:0xa7:        PID: 4932
18:13:34:WU00:FS00:0xa7:        CWD: C:\Users\Josh\AppData\Roaming\FAHClient\work
18:13:34:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
18:13:34:WU00:FS00:0xa7:    Version: 0.0.18
18:13:34:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:13:34:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:13:34:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
18:13:34:WU00:FS00:0xa7:       Time: 01:52:30
18:13:34:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:13:34:WU00:FS00:0xa7:************************************ Build *************************************
18:13:34:WU00:FS00:0xa7:       SIMD: avx_256
18:13:34:WU00:FS00:0xa7:********************************************************************************
18:13:34:WU00:FS00:0xa7:Project: 16406 (Run 264, Clone 2, Gen 92)
18:13:34:WU00:FS00:0xa7:Unit: 0x00000065a8f5c67d5e801edcad7262a8
18:13:34:WU00:FS00:0xa7:Reading tar file core.xml
18:13:34:WU00:FS00:0xa7:Reading tar file frame92.tpr
18:13:34:WU00:FS00:0xa7:Digital signatures verified
18:13:34:WU00:FS00:0xa7:Calling: mdrun -s frame92.tpr -o frame92.trr -x frame92.xtc -cpt 15 -nt 9
18:13:34:WU00:FS00:0xa7:Steps: first=46000000 total=500000
18:13:34:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
18:14:37:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
18:15:04:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
18:15:12:Saving configuration to config.xml
18:15:12:<config>
18:15:12:  <!-- Folding Slot Configuration -->
18:15:12:  <cause v='COVID_19'/>
18:15:12:
18:15:12:  <!-- Network -->
18:15:12:  <proxy v=':8080'/>
18:15:12:
18:15:12:  <!-- User Information -->
18:15:12:  <passkey v='*****'/>
18:15:12:  <user v='SixFiveMil'/>
18:15:12:
18:15:12:  <!-- Folding Slots -->
18:15:12:  <slot id='0' type='CPU'/>
18:15:12:</config>
18:15:41:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
18:16:44:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
18:17:09:Connecting to assign1.foldingathome.org:80
18:17:09:Updated GPUs.txt
18:17:47:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
18:18:51:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
18:19:55:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
18:20:59:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
18:22:03:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
18:23:06:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
18:24:10:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
18:25:13:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
18:26:17:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
18:27:22:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
18:28:25:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
18:29:29:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
18:30:33:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
18:31:36:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
18:32:40:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
18:33:43:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
Re: Request to Add RX 570 to Whitelist
This GPU is already whitelisted:
0x1002:0x67df:1:5:Ellesmere XT [Radeon RX 470/480/570/580/590]
The problem is within the installer for the 7.6.9 version of the client. It doesn't download an updated copy of GPUs.txt and your client doesn't recognize the GPU. You can download the file and manually place it in the Appdata\Roaming\FAHClient directory, or try the current beta installer - https://download.foldingathome.org/rele ... 10_x86.exe.
Also, which video drivers are you using? If installed through Windows Update, download drivers directly from AMD and install those.
