Please add NVIDIA GeForce GTX 480
COBRA_111
Post by COBRA_111 »
Name: Nvidia GeForce GTX 480
Device ID: 10DE 06C0 - 1043 8349
*********************** Log Started 2020-04-20T14:31:56Z ***********************
14:31:56:****************************** FAHClient ******************************
14:31:56:        Version: 7.6.9
14:31:56:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:31:56:      Copyright: 2020 foldingathome.org
14:31:56:       Homepage: https://foldingathome.org/
14:31:56:           Date: Apr 17 2020
14:31:56:           Time: 11:13:06
14:31:56:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
14:31:56:         Branch: master
14:31:56:       Compiler: Visual C++ 2008
14:31:56:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:31:56:       Platform: win32 10
14:31:56:           Bits: 32
14:31:56:           Mode: Release
14:31:56:           Args: --open-web-control
14:31:56:         Config: C:\Users\...\AppData\Roaming\FAHClient\config.xml
14:31:56:******************************** CBang ********************************
14:31:56:           Time: 11:10:09
14:31:56:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
14:31:56:           Bits: 32
14:31:56:******************************* System ********************************
14:31:56:            CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
14:31:56:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:31:56:           CPUs: 4
14:31:56:         Memory: 15.90GiB
14:31:56:    Free Memory: 9.79GiB
14:31:56:        Threads: WINDOWS_THREADS
14:31:56:     OS Version: 6.1
14:31:56:    Has Battery: false
14:31:56:     On Battery: false
14:31:56:     UTC Offset: 2
14:31:56:            PID: 9948
14:31:56:            CWD: C:\Users\...\AppData\Roaming\FAHClient
14:31:56:             OS: Windows 7 Ultimate
14:31:56:        OS Arch: AMD64
14:31:56:           GPUs: 1
14:31:56:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF100 [GeForce GTX 480]
14:31:56:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.0 Driver:9.1
14:31:56:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:388.71
14:31:56:  Win32 Service: false
Note: I removed personal details form the the path directories
Re: Please add NVIDIA GeForce GTX 480
This GPU is already in the list, and has been for a long time.
0x10de:0x06c0:2:2:GF100 [GeForce GTX 480]
It is even whitelisted. However, since it is listed as only supporting OpenCL 1.1 it may not work.
The issues come down to there are different missing elements for OpenCL 1.2 on the various GT 400 and 500 series cards. Depending on what is missing, and what project is assigned, the GX 480 may work. Otherwise it will fail on the WU.
