Died with the warning.
[17:29:17] Warning: long 1-4 interactions
[17:29:21] CoreStatus = 1 (1)
[17:29:21] Client-core communications error: ERROR 0x1
[17:29:21] Deleting current work unit & continuing...
[17:33:42] - Warning: Could not delete all work unit files (1): Core returned invalid code
Then it hung for a day.
Queue and work dir removed, client restarted, all is well so far.
Project: 3064 (Run 4, Clone 45, Gen 63)
v00d00
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
v00d00
- 16GB DDR3,
Debian 9.
Re: Project: 3064 (Run 4, Clone 45, Gen 63)
Somehow i managed to get the same workunit again. It died at 9% some time yesterday. Same error as above.
Same action taken.
Same action taken.
Hi there,
Thanks for the report. Will keep track of this.
Paula
Paula
No one has returned this WU yet ... it might be a bad one
