GPU Slot won't show
badzer
GPU Slot won't show
Post by badzer »
Hello everyone
I have just started using Folding@home and I cannot see my GPU slot, only my CPU slot is working. I have a NVIDIA RTX 2070 Super. When I try to manually add a slot in the FAH Control app, it dissapears as soon as I click save. I did not change anything and left all slot values as -1. I have added the log bellow. Please note that I am running folding on my CPU so some of that will show in the log.
 *********************** Log Started 2020-04-20T10:39:57Z ***********************
10:39:57:****************************** FAHClient ******************************
10:39:57:        Version: 7.6.9
10:39:57:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:39:57:      Copyright: 2020 foldingathome.org
10:39:57:       Homepage: https://foldingathome.org/
10:39:57:           Date: Apr 17 2020
10:39:57:           Time: 11:13:06
10:39:57:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
10:39:57:         Branch: master
10:39:57:       Compiler: Visual C++ 2008
10:39:57:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:39:57:       Platform: win32 10
10:39:57:           Bits: 32
10:39:57:           Mode: Release
10:39:57:           Args: --open-web-control
10:39:57:******************************** CBang ********************************
10:39:57:           Time: 11:10:09
10:39:57:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
10:39:57:           Bits: 32
10:39:57:******************************* System ********************************
10:39:57:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
10:39:57:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
10:39:57:           CPUs: 16
10:39:57:         Memory: 31.92GiB
10:39:57:    Free Memory: 23.00GiB
10:39:57:        Threads: WINDOWS_THREADS
10:39:57:     OS Version: 6.2
10:39:57:    Has Battery: false
10:39:57:     On Battery: false
10:39:57:     UTC Offset: 3
10:39:57:            PID: 11536
10:39:57:            CWD: C:\Users\binma\AppData\Roaming\FAHClient
10:39:57:             OS: Windows 10 Enterprise
10:39:57:        OS Arch: AMD64
10:39:57:           GPUs: 0
10:39:57:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
10:39:57:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.75
10:39:57:  Win32 Service: false
10:39:57:******************************* libFAH ********************************
10:39:57:           Date: Apr 15 2020
10:39:57:           Time: 14:53:14
10:39:57:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
10:39:57:           Bits: 32
10:39:57:***********************************************************************
10:39:57:<config>
10:39:57:  <!-- Folding Slots -->
10:39:57:</config>
10:39:57:Trying to access database...
10:39:57:Successfully acquired database lock
10:39:57:Enabled folding slot 00: PAUSED cpu:15 (not configured)
10:40:01:17:127.0.0.1:New Web session
10:40:58:Saving configuration to config.xml
10:40:58:<config>
10:40:58:  <!-- Folding Slots -->
10:40:58:  <slot id='0' type='CPU'/>
10:40:58:</config>
10:40:58:Set client configured
10:40:59:WU00:FS00:Connecting to 65.254.110.245:80
10:41:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
10:41:00:WU00:FS00:Connecting to 18.218.241.186:80
10:41:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:41:00:WU00:FS00:Connecting to 65.254.110.245:80
10:41:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
10:41:01:WU00:FS00:Connecting to 18.218.241.186:80
10:41:02:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:41:02:ERROR:WU00:FS00:Exception: Could not get an assignment
10:41:02:WU00:FS00:Connecting to 65.254.110.245:80
10:41:03:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
10:41:03:WU00:FS00:Connecting to 18.218.241.186:80
10:41:04:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:41:04:WU00:FS00:Connecting to 65.254.110.245:80
10:41:04:WU00:FS00:Assigned to work server 13.90.152.57
10:41:04:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 13.90.152.57
10:41:04:WU00:FS00:Connecting to 13.90.152.57:8080
10:41:05:WU00:FS00:Downloading 2.28MiB
10:41:08:WU00:FS00:Download complete
10:41:08:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13862 run:0 clone:2464 gen:85 core:0xa7 unit:0x000000640d5a98395e7640eef8ad5874
10:41:08:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
10:41:08:WU00:FS00:Connecting to cores.foldingathome.org:80
10:41:09:WU00:FS00:FahCore a7: Downloading 6.71MiB
10:41:13:WU00:FS00:FahCore a7: Download complete
10:41:13:WU00:FS00:Valid core signature
10:41:13:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
10:41:13:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
10:41:13:WU00:FS00:Starting
10:41:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\binma\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11536 -checkpoint 15 -np 15
10:41:13:WU00:FS00:Started FahCore on PID 14868
10:41:13:WU00:FS00:Core PID:23924
10:41:13:WU00:FS00:FahCore 0xa7 started
10:41:13:WU00:FS00:0xa7:*********************** Log Started 2020-04-20T10:41:13Z ***********************
10:41:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:41:13:WU00:FS00:0xa7:       Type: 0xa7
10:41:13:WU00:FS00:0xa7:       Core: Gromacs
10:41:13:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 14868 -checkpoint 15 -np
10:41:13:WU00:FS00:0xa7:             15
10:41:13:WU00:FS00:0xa7:************************************ CBang *************************************
10:41:13:WU00:FS00:0xa7:       Date: Oct 26 2019
10:41:13:WU00:FS00:0xa7:       Time: 01:38:25
10:41:13:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:41:13:WU00:FS00:0xa7:     Branch: master
10:41:13:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:41:13:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:41:13:WU00:FS00:0xa7:   Platform: win32 10
10:41:13:WU00:FS00:0xa7:       Bits: 64
10:41:13:WU00:FS00:0xa7:       Mode: Release
10:41:13:WU00:FS00:0xa7:************************************ System ************************************
10:41:13:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
10:41:13:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
10:41:13:WU00:FS00:0xa7:       CPUs: 16
10:41:13:WU00:FS00:0xa7:     Memory: 31.92GiB
10:41:13:WU00:FS00:0xa7:Free Memory: 22.96GiB
10:41:13:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:41:13:WU00:FS00:0xa7: OS Version: 6.2
10:41:13:WU00:FS00:0xa7:Has Battery: false
10:41:13:WU00:FS00:0xa7: On Battery: false
10:41:13:WU00:FS00:0xa7: UTC Offset: 3
10:41:13:WU00:FS00:0xa7:        PID: 23924
10:41:13:WU00:FS00:0xa7:        CWD: C:\Users\binma\AppData\Roaming\FAHClient\work
10:41:13:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:41:13:WU00:FS00:0xa7:    Version: 0.0.18
10:41:13:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:41:13:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:41:13:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:41:13:WU00:FS00:0xa7:       Time: 01:52:30
10:41:13:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:41:13:WU00:FS00:0xa7:************************************ Build *************************************
10:41:13:WU00:FS00:0xa7:       SIMD: avx_256
10:41:13:WU00:FS00:0xa7:********************************************************************************
10:41:13:WU00:FS00:0xa7:Project: 13862 (Run 0, Clone 2464, Gen 85)
10:41:13:WU00:FS00:0xa7:Unit: 0x000000640d5a98395e7640eef8ad5874
10:41:13:WU00:FS00:0xa7:Reading tar file core.xml
10:41:13:WU00:FS00:0xa7:Reading tar file frame85.tpr
10:41:13:WU00:FS00:0xa7:Digital signatures verified
10:41:13:WU00:FS00:0xa7:Calling: mdrun -s frame85.tpr -o frame85.trr -x frame85.xtc -e frame85.edr -cpt 15 -nt 15
10:41:13:WU00:FS00:0xa7:Steps: first=10625000 total=125000
10:41:15:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
10:41:34:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
10:41:53:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
10:41:59:Saving configuration to config.xml
10:41:59:<config>
10:41:59:  <!-- Folding Slot Configuration -->
10:41:59:  <cause v='COVID_19'/>
10:41:59:
10:41:59:  <!-- User Information -->
10:41:59:  <user v='BaDZeR'/>
10:41:59:
10:41:59:  <!-- Folding Slots -->
10:41:59:  <slot id='0' type='CPU'/>
10:41:59:</config>
10:42:13:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
10:42:31:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
10:42:45:FS00:Shutting core down
10:42:46:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 23924
10:42:46:WU00:FS00:0xa7:Exiting, please wait. . .
10:42:47:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:42:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:42:47:WU00:FS00:Starting
10:42:47:WARNING:WU00:FS00:Changed SMP threads from 15 to 16 this can cause some work units to fail
10:42:47:WARNING:WU00:FS00:AS lowered CPUs from 16 to 15
10:42:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\binma\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11536 -checkpoint 15 -np 15
10:42:47:WU00:FS00:Started FahCore on PID 17940
10:42:47:WU00:FS00:Core PID:24152
10:42:47:WU00:FS00:FahCore 0xa7 started
10:42:48:WU00:FS00:0xa7:*********************** Log Started 2020-04-20T10:42:47Z ***********************
10:42:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:42:48:WU00:FS00:0xa7:       Type: 0xa7
10:42:48:WU00:FS00:0xa7:       Core: Gromacs
10:42:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17940 -checkpoint 15 -np
10:42:48:WU00:FS00:0xa7:             15
10:42:48:WU00:FS00:0xa7:************************************ CBang *************************************
10:42:48:WU00:FS00:0xa7:       Date: Oct 26 2019
10:42:48:WU00:FS00:0xa7:       Time: 01:38:25
10:42:48:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:42:48:WU00:FS00:0xa7:     Branch: master
10:42:48:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:42:48:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:42:48:WU00:FS00:0xa7:   Platform: win32 10
10:42:48:WU00:FS00:0xa7:       Bits: 64
10:42:48:WU00:FS00:0xa7:       Mode: Release
10:42:48:WU00:FS00:0xa7:************************************ System ************************************
10:42:48:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
10:42:48:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
10:42:48:WU00:FS00:0xa7:       CPUs: 16
10:42:48:WU00:FS00:0xa7:     Memory: 31.92GiB
10:42:48:WU00:FS00:0xa7:Free Memory: 23.00GiB
10:42:48:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:42:48:WU00:FS00:0xa7: OS Version: 6.2
10:42:48:WU00:FS00:0xa7:Has Battery: false
10:42:48:WU00:FS00:0xa7: On Battery: false
10:42:48:WU00:FS00:0xa7: UTC Offset: 3
10:42:48:WU00:FS00:0xa7:        PID: 24152
10:42:48:WU00:FS00:0xa7:        CWD: C:\Users\binma\AppData\Roaming\FAHClient\work
10:42:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:42:48:WU00:FS00:0xa7:    Version: 0.0.18
10:42:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:42:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:42:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:42:48:WU00:FS00:0xa7:       Time: 01:52:30
10:42:48:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:42:48:WU00:FS00:0xa7:************************************ Build *************************************
10:42:48:WU00:FS00:0xa7:       SIMD: avx_256
10:42:48:WU00:FS00:0xa7:********************************************************************************
10:42:48:WU00:FS00:0xa7:Project: 13862 (Run 0, Clone 2464, Gen 85)
10:42:48:WU00:FS00:0xa7:Unit: 0x000000640d5a98395e7640eef8ad5874
10:42:48:WU00:FS00:0xa7:Digital signatures verified
10:42:48:WU00:FS00:0xa7:Calling: mdrun -s frame85.tpr -o frame85.trr -x frame85.xtc -e frame85.edr -cpi state.cpt -cpt 15 -nt 15
10:42:48:WU00:FS00:0xa7:Steps: first=10625000 total=125000
10:42:49:WU00:FS00:0xa7:Completed 5942 out of 125000 steps (4%)
10:42:54:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
10:43:00:Saving configuration to config.xml
10:43:00:<config>
10:43:00:  <!-- Folding Slot Configuration -->
10:43:00:  <cause v='COVID_19'/>
10:43:00:
10:43:00:  <!-- Slot Control -->
10:43:00:  <power v='FULL'/>
10:43:00:
10:43:00:  <!-- User Information -->
10:43:00:  <user v='BaDZeR'/>
10:43:00:
10:43:00:  <!-- Folding Slots -->
10:43:00:  <slot id='0' type='CPU'/>
10:43:00:</config>
10:43:14:WU00:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
10:43:33:WU00:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
10:43:52:WU00:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
10:44:12:WU00:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
10:44:31:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
10:44:50:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
10:44:57:Connecting to assign1.foldingathome.org:80
10:44:57:Updated GPUs.txt
10:45:10:WU00:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
10:45:29:WU00:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
10:45:48:WU00:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
10:46:07:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
10:46:27:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
10:46:46:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
10:47:05:WU00:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
10:47:25:WU00:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
10:47:45:WU00:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
10:48:04:WU00:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
10:48:24:WU00:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
10:48:43:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
10:49:03:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
10:49:22:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
10:49:41:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
10:50:00:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
10:50:19:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
10:50:39:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
10:50:58:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
10:51:17:WU00:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
10:51:32:34:127.0.0.1:New Web session
10:51:37:WU00:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
10:51:57:WU00:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
10:52:07:44:127.0.0.1:New Web session
10:52:17:WU00:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
10:52:36:WU00:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
10:52:55:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
10:53:15:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
10:53:34:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
10:53:53:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
10:54:13:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
10:54:32:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
10:54:52:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
10:55:11:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
10:55:31:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
10:55:50:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
10:56:10:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
10:56:30:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
10:56:49:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
10:57:09:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
10:57:28:WU00:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
10:57:48:WU00:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
10:58:09:WU00:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
10:58:28:WU00:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
10:58:49:WU00:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
10:59:08:WU00:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
10:59:28:WU00:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
10:59:48:WU00:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
11:00:07:WU00:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
11:00:27:WU00:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
11:00:46:WU00:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
11:01:05:WU00:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
11:01:25:WU00:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
11:01:44:WU00:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
11:02:05:WU00:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
11:02:24:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
11:02:44:WU00:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
11:03:03:WU00:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
11:03:23:WU00:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
11:03:42:WU00:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
11:04:01:WU00:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
11:04:21:WU00:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
11:04:40:WU00:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
11:04:59:WU00:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
11:05:19:WU00:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
11:05:38:WU00:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
11:05:57:WU00:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
11:06:16:WU00:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
11:06:36:WU00:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
11:06:56:WU00:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
11:07:15:WU00:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
11:07:34:WU00:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
11:07:54:WU00:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
11:08:13:WU00:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
11:08:25:Saving configuration to config.xml
11:08:25:<config>
11:08:25:  <!-- Folding Slot Configuration -->
11:08:25:  <cause v='COVID_19'/>
11:08:25:
11:08:25:  <!-- Network -->
11:08:25:  <proxy v=':8080'/>
11:08:25:
11:08:25:  <!-- Slot Control -->
11:08:25:  <power v='FULL'/>
11:08:25:
11:08:25:  <!-- User Information -->
11:08:25:  <user v='BaDZeR'/>
11:08:25:
11:08:25:  <!-- Folding Slots -->
11:08:25:  <slot id='0' type='CPU'/>
11:08:25:</config>
11:08:33:WU00:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
11:08:54:WU00:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
11:08:59:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
11:09:13:WU00:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
11:09:16:58:127.0.0.1:New Web session
11:09:33:WU00:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
11:09:53:WU00:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
11:10:12:WU00:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
11:10:31:WU00:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
11:10:51:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
11:11:10:WU00:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
11:11:30:WU00:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
11:11:50:WU00:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
11:12:09:WU00:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
11:12:28:WU00:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
11:12:48:WU00:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
11:13:08:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
11:13:28:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
11:13:28:WU01:FS00:Connecting to 65.254.110.245:80
11:13:29:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:13:29:WU01:FS00:Connecting to 18.218.241.186:80
11:13:30:WU01:FS00:Assigned to work server 128.252.203.9
11:13:30:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 128.252.203.9
11:13:30:WU01:FS00:Connecting to 128.252.203.9:8080
11:13:33:ERROR:WU01:FS00:Exception: Server did not assign work unit
11:13:33:WU01:FS00:Connecting to 65.254.110.245:80
11:13:34:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:13:34:WU01:FS00:Connecting to 18.218.241.186:80
11:13:35:WU01:FS00:Assigned to work server 13.90.152.57
11:13:35:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:16 from 13.90.152.57
11:13:35:WU01:FS00:Connecting to 13.90.152.57:8080
11:13:36:WU01:FS00:Downloading 4.50MiB
11:13:40:WU01:FS00:Download complete
11:13:40:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:8604 gen:104 core:0xa7 unit:0x000000720d5a98395e7312d52999bcd1
11:13:47:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
11:13:49:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
11:13:49:WU00:FS00:0xa7:Saving result file frame85.edr
11:13:49:WU00:FS00:0xa7:Saving result file frame85.trr
11:13:49:WU00:FS00:0xa7:Saving result file frame85.xtc
11:13:49:WU00:FS00:0xa7:Saving result file md.log
11:13:49:WU00:FS00:0xa7:Saving result file science.log
11:13:49:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:13:49:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:13:49:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13862 run:0 clone:2464 gen:85 core:0xa7 unit:0x000000640d5a98395e7640eef8ad5874
11:13:49:WU00:FS00:Uploading 5.29MiB to 13.90.152.57
11:13:49:WU00:FS00:Connecting to 13.90.152.57:8080
11:13:49:WU01:FS00:Starting
11:13:49:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\binma\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11536 -checkpoint 15 -np 16
11:13:49:WU01:FS00:Started FahCore on PID 2444
11:13:49:WU01:FS00:Core PID:11612
11:13:49:WU01:FS00:FahCore 0xa7 started
11:13:50:WU01:FS00:0xa7:*********************** Log Started 2020-04-20T11:13:49Z ***********************
11:13:50:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:13:50:WU01:FS00:0xa7:       Type: 0xa7
11:13:50:WU01:FS00:0xa7:       Core: Gromacs
11:13:50:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 2444 -checkpoint 15 -np
11:13:50:WU01:FS00:0xa7:             16
11:13:50:WU01:FS00:0xa7:************************************ CBang *************************************
11:13:50:WU01:FS00:0xa7:       Date: Oct 26 2019
11:13:50:WU01:FS00:0xa7:       Time: 01:38:25
11:13:50:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:13:50:WU01:FS00:0xa7:     Branch: master
11:13:50:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:13:50:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:13:50:WU01:FS00:0xa7:   Platform: win32 10
11:13:50:WU01:FS00:0xa7:       Bits: 64
11:13:50:WU01:FS00:0xa7:       Mode: Release
11:13:50:WU01:FS00:0xa7:************************************ System ************************************
11:13:50:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
11:13:50:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
11:13:50:WU01:FS00:0xa7:       CPUs: 16
11:13:50:WU01:FS00:0xa7:     Memory: 31.92GiB
11:13:50:WU01:FS00:0xa7:Free Memory: 23.39GiB
11:13:50:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
11:13:50:WU01:FS00:0xa7: OS Version: 6.2
11:13:50:WU01:FS00:0xa7:Has Battery: false
11:13:50:WU01:FS00:0xa7: On Battery: false
11:13:50:WU01:FS00:0xa7: UTC Offset: 3
11:13:50:WU01:FS00:0xa7:        PID: 11612
11:13:50:WU01:FS00:0xa7:        CWD: C:\Users\binma\AppData\Roaming\FAHClient\work
11:13:50:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:13:50:WU01:FS00:0xa7:    Version: 0.0.18
11:13:50:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:13:50:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:13:50:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:13:50:WU01:FS00:0xa7:       Time: 01:52:30
11:13:50:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:13:50:WU01:FS00:0xa7:************************************ Build *************************************
11:13:50:WU01:FS00:0xa7:       SIMD: avx_256
11:13:50:WU01:FS00:0xa7:********************************************************************************
11:13:50:WU01:FS00:0xa7:Project: 13860 (Run 0, Clone 8604, Gen 104)
11:13:50:WU01:FS00:0xa7:Unit: 0x000000720d5a98395e7312d52999bcd1
11:13:50:WU01:FS00:0xa7:Reading tar file core.xml
11:13:50:WU01:FS00:0xa7:Reading tar file frame104.tpr
11:13:50:WU01:FS00:0xa7:Digital signatures verified
11:13:50:WU01:FS00:0xa7:Calling: mdrun -s frame104.tpr -o frame104.trr -x frame104.xtc -e frame104.edr -cpt 15 -nt 16
11:13:50:WU01:FS00:0xa7:Steps: first=13000000 total=125000
11:13:51:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
11:13:55:WU00:FS00:Upload 7.09%
11:14:01:WU00:FS00:Upload 18.90%
11:14:07:WU00:FS00:Upload 28.35%
11:14:12:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
11:14:13:WU00:FS00:Upload 36.62%
11:14:19:WU00:FS00:Upload 47.26%
11:14:25:WU00:FS00:Upload 62.62%
11:14:31:WU00:FS00:Upload 80.34%
11:14:33:69:127.0.0.1:New Web session
11:14:34:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
11:14:37:WU00:FS00:Upload 93.33%
11:14:40:WU00:FS00:Upload complete
11:14:40:WU00:FS00:Server responded WORK_ACK (400)
11:14:40:WU00:FS00:Final credit estimate, 4650.00 points
11:14:40:WU00:FS00:Cleaning up
11:14:55:WU01:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
11:15:17:WU01:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
11:15:38:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
11:15:59:WU01:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
11:16:20:WU01:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
11:16:32:76:127.0.0.1:New Web session
11:16:42:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
11:17:03:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
11:17:23:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
11:17:44:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
11:18:06:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
11:18:12:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
11:18:28:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
11:18:49:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
11:19:11:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
11:19:32:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
11:19:55:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
11:20:16:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
11:20:38:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
11:20:59:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
11:21:21:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
11:21:41:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
11:22:02:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
11:22:23:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
11:22:44:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
11:23:07:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
11:23:29:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
11:23:50:WU01:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
11:24:11:WU01:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
11:24:32:WU01:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
11:24:52:WU01:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
11:25:13:WU01:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
11:25:34:WU01:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
11:25:55:WU01:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
11:26:17:WU01:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
11:26:21:86:127.0.0.1:New Web session
11:26:38:WU01:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
11:26:50:Adding folding slot 01: READY cpu:16
11:26:50:Saving configuration to config.xml
11:26:50:<config>
11:26:50:  <!-- Folding Slot Configuration -->
11:26:50:  <cause v='COVID_19'/>
11:26:50:
11:26:50:  <!-- Network -->
11:26:50:  <proxy v=':8080'/>
11:26:50:
11:26:50:  <!-- Slot Control -->
11:26:50:  <power v='FULL'/>
11:26:50:
11:26:50:  <!-- User Information -->
11:26:50:  <user v='BaDZeR'/>
11:26:50:
11:26:50:  <!-- Folding Slots -->
11:26:50:  <slot id='0' type='CPU'/>
11:26:50:  <slot id='1' type='CPU'/>
11:26:50:</config>
11:26:50:FS00:Shutting core down
11:26:50:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 11612
11:26:50:WU01:FS00:0xa7:Exiting, please wait. . .
11:26:51:WU00:FS01:Connecting to 65.254.110.245:80
11:26:51:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:26:51:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:26:52:WU01:FS00:Starting
11:26:52:WARNING:WU01:FS00:Changed SMP threads from 16 to 8 this can cause some work units to fail
11:26:52:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\binma\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11536 -checkpoint 15 -np 8
11:26:52:WU01:FS00:Started FahCore on PID 20196
11:26:52:WU01:FS00:Core PID:1172
11:26:52:WU01:FS00:FahCore 0xa7 started
11:26:52:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:26:52:WU00:FS01:Connecting to 18.218.241.186:80
11:26:52:WU01:FS00:0xa7:*********************** Log Started 2020-04-20T11:26:52Z ***********************
11:26:52:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:26:52:WU01:FS00:0xa7:       Type: 0xa7
11:26:52:WU01:FS00:0xa7:       Core: Gromacs
11:26:52:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 20196 -checkpoint 15 -np
11:26:52:WU01:FS00:0xa7:             8
11:26:52:WU01:FS00:0xa7:************************************ CBang *************************************
11:26:52:WU01:FS00:0xa7:       Date: Oct 26 2019
11:26:52:WU01:FS00:0xa7:       Time: 01:38:25
11:26:52:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:26:52:WU01:FS00:0xa7:     Branch: master
11:26:52:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:26:52:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:26:52:WU01:FS00:0xa7:   Platform: win32 10
11:26:52:WU01:FS00:0xa7:       Bits: 64
11:26:52:WU01:FS00:0xa7:       Mode: Release
11:26:52:WU01:FS00:0xa7:************************************ System ************************************
11:26:52:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
11:26:52:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
11:26:52:WU01:FS00:0xa7:       CPUs: 16
11:26:52:WU01:FS00:0xa7:     Memory: 31.92GiB
11:26:52:WU01:FS00:0xa7:Free Memory: 23.62GiB
11:26:52:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
11:26:52:WU01:FS00:0xa7: OS Version: 6.2
11:26:52:WU01:FS00:0xa7:Has Battery: false
11:26:52:WU01:FS00:0xa7: On Battery: false
11:26:52:WU01:FS00:0xa7: UTC Offset: 3
11:26:52:WU01:FS00:0xa7:        PID: 1172
11:26:52:WU01:FS00:0xa7:        CWD: C:\Users\binma\AppData\Roaming\FAHClient\work
11:26:52:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:26:52:WU01:FS00:0xa7:    Version: 0.0.18
11:26:52:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:26:52:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:26:52:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:26:52:WU01:FS00:0xa7:       Time: 01:52:30
11:26:52:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:26:52:WU01:FS00:0xa7:************************************ Build *************************************
11:26:52:WU01:FS00:0xa7:       SIMD: avx_256
11:26:52:WU01:FS00:0xa7:********************************************************************************
11:26:52:WU01:FS00:0xa7:Project: 13860 (Run 0, Clone 8604, Gen 104)
11:26:52:WU01:FS00:0xa7:Unit: 0x000000720d5a98395e7312d52999bcd1
11:26:52:WU01:FS00:0xa7:Digital signatures verified
11:26:52:WU01:FS00:0xa7:Calling: mdrun -s frame104.tpr -o frame104.trr -x frame104.xtc -e frame104.edr -cpi state.cpt -cpt 15 -nt 8
11:26:52:WU01:FS00:0xa7:Steps: first=13000000 total=125000
11:26:53:WU01:FS00:0xa7:Completed 45732 out of 125000 steps (36%)
11:26:54:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:26:54:WU00:FS01:Connecting to 65.254.110.245:80
11:26:55:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:26:55:WU00:FS01:Connecting to 18.218.241.186:80
11:26:56:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:26:56:ERROR:WU00:FS01:Exception: Could not get an assignment
11:26:56:WU00:FS01:Connecting to 65.254.110.245:80
11:26:57:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:26:57:WU00:FS01:Connecting to 18.218.241.186:80
11:26:57:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:26:57:WU00:FS01:Connecting to 65.254.110.245:80
11:26:58:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:26:58:WU00:FS01:Connecting to 18.218.241.186:80
11:26:59:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:26:59:ERROR:WU00:FS01:Exception: Could not get an assignment
11:27:05:WU01:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
11:27:34:WU01:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
11:27:44:Saving configuration to config.xml
11:27:44:<config>
11:27:44:  <!-- Folding Slot Configuration -->
11:27:44:  <cause v='COVID_19'/>
11:27:44:
11:27:44:  <!-- Network -->
11:27:44:  <proxy v=':8080'/>
11:27:44:
11:27:44:  <!-- Slot Control -->
11:27:44:  <power v='FULL'/>
11:27:44:
11:27:44:  <!-- User Information -->
11:27:44:  <user v='BaDZeR'/>
11:27:44:
11:27:44:  <!-- Folding Slots -->
11:27:44:  <slot id='0' type='CPU'/>
11:27:44:  <slot id='1' type='CPU'/>
11:27:44:</config>
11:27:57:WU00:FS01:Connecting to 65.254.110.245:80
11:27:57:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:27:57:WU00:FS01:Connecting to 18.218.241.186:80
11:27:58:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:27:58:WU00:FS01:Connecting to 65.254.110.245:80
11:27:59:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:27:59:WU00:FS01:Connecting to 18.218.241.186:80
11:27:59:WU00:FS01:Assigned to work server 155.247.164.213
11:27:59:WU00:FS01:Requesting new work unit for slot 01: READY cpu:8 from 155.247.164.213
11:27:59:WU00:FS01:Connecting to 155.247.164.213:8080
11:28:02:WU01:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
11:28:30:WU01:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
11:28:42:Adding folding slot 02: READY cpu:16
11:28:42:FS00:Shutting core down
11:28:42:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 1172
11:28:42:WU01:FS00:0xa7:Exiting, please wait. . .
11:28:42:WU02:FS02:Connecting to 65.254.110.245:80
11:28:43:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:28:43:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:28:43:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:28:43:WU02:FS02:Connecting to 18.218.241.186:80
11:28:43:WARNING:WU01:Slot ID 0 no longer exists, migrating to FS02
11:28:43:WU01:Starting
11:28:43:WARNING:WU01:Changed SMP threads from 8 to 16 this can cause some work units to fail
11:28:43:WU01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\binma\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11536 -checkpoint 15 -np 16
11:28:43:WU01:Started FahCore on PID 13064
11:28:43:WU01:Core PID:18660
11:28:43:WU01:FahCore 0xa7 started
11:28:44:WU01:FS02:0xa7:*********************** Log Started 2020-04-20T11:28:43Z ***********************
11:28:44:WU01:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
11:28:44:WU01:FS02:0xa7:       Type: 0xa7
11:28:44:WU01:FS02:0xa7:       Core: Gromacs
11:28:44:WU01:FS02:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 13064 -checkpoint 15 -np
11:28:44:WU01:FS02:0xa7:             16
11:28:44:WU01:FS02:0xa7:************************************ CBang *************************************
11:28:44:WU01:FS02:0xa7:       Date: Oct 26 2019
11:28:44:WU01:FS02:0xa7:       Time: 01:38:25
11:28:44:WU01:FS02:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:28:44:WU01:FS02:0xa7:     Branch: master
11:28:44:WU01:FS02:0xa7:   Compiler: Visual C++ 2008
11:28:44:WU01:FS02:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:28:44:WU01:FS02:0xa7:   Platform: win32 10
11:28:44:WU01:FS02:0xa7:       Bits: 64
11:28:44:WU01:FS02:0xa7:       Mode: Release
11:28:44:WU01:FS02:0xa7:************************************ System ************************************
11:28:44:WU01:FS02:0xa7:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
11:28:44:WU01:FS02:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
11:28:44:WU01:FS02:0xa7:       CPUs: 16
11:28:44:WU01:FS02:0xa7:     Memory: 31.92GiB
11:28:44:WU01:FS02:0xa7:Free Memory: 23.59GiB
11:28:44:WU01:FS02:0xa7:    Threads: WINDOWS_THREADS
11:28:44:WU01:FS02:0xa7: OS Version: 6.2
11:28:44:WU01:FS02:0xa7:Has Battery: false
11:28:44:WU01:FS02:0xa7: On Battery: false
11:28:44:WU01:FS02:0xa7: UTC Offset: 3
11:28:44:WU01:FS02:0xa7:        PID: 18660
11:28:44:WU01:FS02:0xa7:        CWD: C:\Users\binma\AppData\Roaming\FAHClient\work
11:28:44:WU01:FS02:0xa7:******************************** Build - libFAH ********************************
11:28:44:WU01:FS02:0xa7:    Version: 0.0.18
11:28:44:WU01:FS02:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:28:44:WU01:FS02:0xa7:  Copyright: 2019 foldingathome.org
11:28:44:WU01:FS02:0xa7:   Homepage: https://foldingathome.org/
11:28:44:WU01:FS02:0xa7:       Time: 01:52:30
11:28:44:WU01:FS02:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:28:44:WU01:FS02:0xa7:************************************ Build *************************************
11:28:44:WU01:FS02:0xa7:       SIMD: avx_256
11:28:44:WU01:FS02:0xa7:********************************************************************************
11:28:44:WU01:FS02:0xa7:Project: 13860 (Run 0, Clone 8604, Gen 104)
11:28:44:WU01:FS02:0xa7:Unit: 0x000000720d5a98395e7312d52999bcd1
11:28:44:WU01:FS02:0xa7:Digital signatures verified
11:28:44:WU01:FS02:0xa7:Calling: mdrun -s frame104.tpr -o frame104.trr -x frame104.xtc -e frame104.edr -cpi state.cpt -cpt 15 -nt 16
11:28:44:WU01:FS02:0xa7:Steps: first=13000000 total=125000
11:28:44:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:28:44:WU02:FS02:Connecting to 65.254.110.245:80
11:28:45:WU01:FS02:0xa7:Completed 50552 out of 125000 steps (40%)
11:28:45:Saving configuration to config.xml
11:28:45:<config>
11:28:45:  <!-- Folding Slot Configuration -->
11:28:45:  <cause v='COVID_19'/>
11:28:45:
11:28:45:  <!-- Network -->
11:28:45:  <proxy v=':8080'/>
11:28:45:
11:28:45:  <!-- Slot Control -->
11:28:45:  <power v='FULL'/>
11:28:45:
11:28:45:  <!-- User Information -->
11:28:45:  <user v='BaDZeR'/>
11:28:45:
11:28:45:  <!-- Folding Slots -->
11:28:45:  <slot id='2' type='CPU'/>
11:28:45:</config>
11:28:46:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:28:46:WU02:FS02:Connecting to 18.218.241.186:80
11:28:47:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:28:47:ERROR:WU02:FS02:Exception: Could not get an assignment
11:28:47:WU02:FS02:Connecting to 65.254.110.245:80
11:28:48:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:28:48:WU02:FS02:Connecting to 18.218.241.186:80
11:28:48:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:28:48:WU02:FS02:Connecting to 65.254.110.245:80
11:28:49:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:28:49:WU02:FS02:Connecting to 18.218.241.186:80
11:28:50:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:28:50:ERROR:WU02:FS02:Exception: Could not get an assignment
11:28:56:WU01:FS02:0xa7:Completed 51250 out of 125000 steps (41%)
11:29:08:WU00:FS01:Downloading 1.23MiB
11:29:14:WU00:FS01:Download 35.43%
11:29:17:WU01:FS02:0xa7:Completed 52500 out of 125000 steps (42%)
11:29:18:WU00:FS01:Download complete
11:29:18:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14198 run:0 clone:378 gen:93 core:0xa7 unit:0x0000006a9bf7a4d55e66d068f93d3cda
11:29:18:WARNING:WU00:FS01:Slot ID 1 no longer exists, migrating to FS02
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: GPU Slot won't show
Post by Jesse_V »
Hi and welcome to the forum.
I see a few items from the log:
1) At the top, "GPUs: 0" generally means that the software doesn't recognize any compatible graphics cards. You have the Nvidia 445.75 driver installed, right?
2) You mentioned adding a slot, but I see a part of the configuration where you had two CPU slots set up. Could you try manually adding a GPU slot? When you have the "Folding Slot" window open, choose the GPU radio button on the left-hand side. If the GPU is not supported, FAHControl should immediately show you an alert when you save that configuration.
ajm
Post by ajm »
There is an issue with the CPU as well:
I think the best would be to edit your cpu slot and enter 12 as the number of CPUs, where you now have "-1". By default, the client uses the whole CPU minus one thread, that is 15 here. But 15 is not optimal, so that the client changed it to 16, which is better for domain decomposition. But then one is needed for a Nvidia GPU. So there is a back and forth.
For the GPU problem, if you are using the version 7.6.9 of the client, there is a known issue that you should be able solve this way:
I would suggest that you manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to %AppData%\FAHClient
Reboot your system
Start up the client and ensure that you can see your GPU in the log file
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
This problem doesn't appear in versions 7.5.1, 7.6.8, and (so I've heard) beta 7.6.10.
