I have been folding on three system since yesterday. I have logged in to the same Passkey and username. But stil haven't gotten my bonus points from any machine.
Here is my profile: donor/115761773 (cant actually print the link due to the forum rules)
Here you can see i have 13 000 points on 8 WUs. I i think i should have more. The esitmate always says something like 4000-5000 points on CPU tasks and 60 000-
70 000 Points on the GPU. But i
never get that. Always just the base points.-
Not getting bonus points.
Re: Not getting bonus points.
I believe bonus points first are given after your 10th WU, correct me if i am wrong, but thats what i experienced as well.
skydivingcatfan
- Hardware configuration: AMD 5700x, Asus Prime X570-Pro, EVGA 3080 12gb, G.SKILL Aegis 16GB DDR4 3200, Windows 10
What are the qualifications for the QRB?
The bonus is applied for users who use a passkey, have successfully returned at least 10 bonus-eligible WUs, have successfully returned 80% or more of assigned WUs, and returned the unit before its Timeout (formerly Preferred Deadline). Bonus points do not apply to partial returns.
If you have used the same username/opasskey pairing on all three systems then once they have successfully completed 1O WUs in total between them then you will become eligible for QRB … If you have used three different username/passkey pairing then they will need 10 each … If you enter your passkey here https://apps.foldingathome.org/bonus you will be able to check the status of your bonus … Full description of how points work and the QRB requirements can be found here https://foldingathome.org/support/faq/points/
