2080ti OpenCL Not detected: clGetDeviceIDs() returned -1
I installed 7.6.9 and have not been able to get my GPU running.
I've pulled the GPUs.txt and added it to my FAH directory replacing the old version. Restarted and still am unable to get my gpu to start.
Re: 2080ti OpenCL Not detected: clGetDeviceIDs() returned -1
The error is pointing to a missing install of support for OpenCL, or the setup pointing to the wrong device.
If installed on Windows or Linux, drivers and OpenCL support from nVidia needs to be installed. Then the FAHClient software gets installed after that.
If you could post the first couple hundred lines of your log file, that would be useful in seeing what the client detected on installation, and how the systems is set up. Information on locating and posting the log file is part of the Welcome topic - viewtopic.php?f=61&t=26036.
Welcome to Folding@Home!
We know nothing about your computer. If you post the first 200 lines of your Log we will get details about what the software sees about your PC.
viewtopic.php?f=24&t=26036
(I often post the latest Geforce driver at this point but I do not know enough to guess which one is right for you)
*********************** Log Started 2020-04-19T23:36:30Z ***********************
23:36:30:****************************** FAHClient ******************************
23:36:30: Version: 7.6.9
23:36:30: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:36:30: Copyright: 2020 foldingathome.org
23:36:30: Homepage: https://foldingathome.org/
23:36:30: Date: Apr 17 2020
23:36:30: Time: 11:13:06
23:36:30: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
23:36:30: Branch: master
23:36:30: Compiler: Visual C++ 2008
23:36:30: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:36:30: Platform: win32 10
23:36:30: Bits: 32
23:36:30: Mode: Release
23:36:30: Config: C:\Users\Brian\AppData\Roaming\FAHClient\config.xml
23:36:30:******************************** CBang ********************************
23:36:30: Time: 11:10:09
23:36:30: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
23:36:30: Bits: 32
23:36:30:******************************* System ********************************
23:36:30: CPU: AMD Ryzen Threadripper 2990WX 32-Core Processor
23:36:30: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
23:36:30: CPUs: 32
23:36:30: Memory: 127.87GiB
23:36:30: Free Memory: 121.46GiB
23:36:30: Threads: WINDOWS_THREADS
23:36:30: OS Version: 6.2
23:36:30: Has Battery: false
23:36:30: On Battery: false
23:36:30: UTC Offset: -4
23:36:30: PID: 22632
23:36:30: CWD: C:\Users\Brian\AppData\Roaming\FAHClient
23:36:30: OS: Windows 10 Enterprise
23:36:30: OS Arch: AMD64
23:36:30: GPUs: 1
23:36:30: GPU 0: Bus:65 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
23:36:30: M 13448
23:36:30:CUDA Device 0: Platform:0 Device:0 Bus:65 Slot:0 Compute:7.5 Driver:11.0
23:36:30: OpenCL: Not detected: clGetDeviceIDs() returned -1
23:36:30:Win32 Service: false
23:36:30:******************************* libFAH ********************************
23:36:30: Date: Apr 15 2020
23:36:30: Time: 14:53:14
23:36:30: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
23:36:30: Bits: 32
23:36:30:***********************************************************************
23:36:30:<config>
23:36:30: <!-- Network -->
23:36:30: <proxy v=':8080'/>
23:36:30:
23:36:30: <!-- Slot Control -->
23:36:30: <power v='MEDIUM'/>
23:36:30:
23:36:30: <!-- User Information -->
23:36:30: <passkey v='*****'/>
23:36:30: <team v='XXXXXX'/>
23:36:30: <user v='XXXXXX'/>
23:36:30:
23:36:30: <!-- Folding Slots -->
23:36:30: <slot id='0' type='CPU'/>
23:36:30:</config>
23:36:30:Trying to access database...
23:36:30:Successfully acquired database lock
23:36:30:Enabled folding slot 00: READY cpu:31
23:36:30:WU00:FS00:Starting
23:36:30:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Brian\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 22632 -checkpoint 15 -np 31
23:36:30:WU00:FS00:Started FahCore on PID 23016
23:36:30:WU00:FS00:Core PID:23064
23:36:30:WU00:FS00:FahCore 0xa7 started
23:36:30:WU00:FS00:0xa7:*********************** Log Started 2020-04-19T23:36:30Z ***********************
23:36:30:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:36:30:WU00:FS00:0xa7: Type: 0xa7
23:36:30:WU00:FS00:0xa7: Core: Gromacs
23:36:30:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 23016 -checkpoint 15 -np
23:36:30:WU00:FS00:0xa7: 31
23:36:30:WU00:FS00:0xa7:************************************ CBang *************************************
23:36:30:WU00:FS00:0xa7: Date: Oct 26 2019
23:36:30:WU00:FS00:0xa7: Time: 01:38:25
23:36:30:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:36:30:WU00:FS00:0xa7: Branch: master
23:36:30:WU00:FS00:0xa7: Compiler: Visual C++ 2008
23:36:30:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:36:30:WU00:FS00:0xa7: Platform: win32 10
23:36:30:WU00:FS00:0xa7: Bits: 64
23:36:30:WU00:FS00:0xa7: Mode: Release
23:36:30:WU00:FS00:0xa7:************************************ System ************************************
23:36:30:WU00:FS00:0xa7: CPU: AMD Ryzen Threadripper 2990WX 32-Core Processor
23:36:30:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
23:36:30:WU00:FS00:0xa7: CPUs: 64
23:36:30:WU00:FS00:0xa7: Memory: 127.87GiB
23:36:30:WU00:FS00:0xa7:Free Memory: 121.40GiB
23:36:30:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
23:36:30:WU00:FS00:0xa7: OS Version: 6.2
23:36:30:WU00:FS00:0xa7:Has Battery: false
23:36:30:WU00:FS00:0xa7: On Battery: false
23:36:30:WU00:FS00:0xa7: UTC Offset: -4
23:36:30:WU00:FS00:0xa7: PID: 23064
23:36:30:WU00:FS00:0xa7: CWD: C:\Users\Brian\AppData\Roaming\FAHClient\work
23:36:30:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:36:30:WU00:FS00:0xa7: Version: 0.0.18
23:36:30:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:36:30:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
23:36:30:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
23:36:30:WU00:FS00:0xa7: Time: 01:52:30
23:36:30:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:36:30:WU00:FS00:0xa7:************************************ Build *************************************
23:36:30:WU00:FS00:0xa7: SIMD: avx_256
23:36:30:WU00:FS00:0xa7:********************************************************************************
23:36:30:WU00:FS00:0xa7:Project: 14607 (Run 19, Clone 0, Gen 61)
23:36:30:WU00:FS00:0xa7:Unit: 0x000000419bf7a4d65e79f1a74aef952c
23:36:30:WU00:FS00:0xa7:Digital signatures verified
23:36:30:WU00:FS00:0xa7:Reducing thread count from 31 to 30 to avoid domain decomposition by a prime number > 3
23:36:30:WU00:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -cpi state.cpt -cpt 15 -nt 30
23:36:30:WU00:FS00:0xa7:ERROR:Guru Meditation #f3e3c2a1337915cb.2cb1a2851d2b1cb9 (2016.2604) '00/01/pullf.xvg'
23:36:30:WU00:FS00:0xa7:WARNING:Unexpected exit() call
23:36:30:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
23:36:30:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
23:36:30:WU00:FS00:0xa7:Saving result file dhdl.xvg
23:36:30:WU00:FS00:0xa7:Saving result file frame61.trr
23:36:30:WU00:FS00:0xa7:Saving result file md.log
23:36:30:WU00:FS00:0xa7:Saving result file pullf.xvg
23:36:32:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
23:36:32:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
23:36:32:7:127.0.0.1:New Web session
23:36:32:WU00:FS00:Starting
23:36:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Brian\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 22632 -checkpoint 15 -np 31
23:36:32:WU00:FS00:Started FahCore on PID 24056
23:36:32:WU00:FS00:Core PID:24080
23:36:32:WU00:FS00:FahCore 0xa7 started
23:36:32:WU00:FS00:0xa7:*********************** Log Started 2020-04-19T23:36:32Z ***********************
23:36:32:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:36:32:WU00:FS00:0xa7: Type: 0xa7
23:36:32:WU00:FS00:0xa7: Core: Gromacs
23:36:32:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 24056 -checkpoint 15 -np
23:36:32:WU00:FS00:0xa7: 31
23:36:33:WU00:FS00:0xa7:************************************ CBang *************************************
23:36:33:WU00:FS00:0xa7: Date: Oct 26 2019
23:36:33:WU00:FS00:0xa7: Time: 01:38:25
23:36:33:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:36:33:WU00:FS00:0xa7: Branch: master
23:36:33:WU00:FS00:0xa7: Compiler: Visual C++ 2008
23:36:33:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:36:33:WU00:FS00:0xa7: Platform: win32 10
23:36:33:WU00:FS00:0xa7: Bits: 64
23:36:33:WU00:FS00:0xa7: Mode: Release
23:36:33:WU00:FS00:0xa7:************************************ System ************************************
23:36:33:WU00:FS00:0xa7: CPU: AMD Ryzen Threadripper 2990WX 32-Core Processor
23:36:33:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
23:36:33:WU00:FS00:0xa7: CPUs: 64
23:36:33:WU00:FS00:0xa7: Memory: 127.87GiB
23:36:33:WU00:FS00:0xa7:Free Memory: 121.19GiB
23:36:33:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
23:36:33:WU00:FS00:0xa7: OS Version: 6.2
23:36:33:WU00:FS00:0xa7:Has Battery: false
23:36:33:WU00:FS00:0xa7: On Battery: false
23:36:33:WU00:FS00:0xa7: UTC Offset: -4
23:36:33:WU00:FS00:0xa7: PID: 24080
23:36:33:WU00:FS00:0xa7: CWD: C:\Users\Brian\AppData\Roaming\FAHClient\work
23:36:33:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:36:33:WU00:FS00:0xa7: Version: 0.0.18
23:36:33:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:36:33:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
23:36:33:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
23:36:33:WU00:FS00:0xa7: Time: 01:52:30
23:36:33:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:36:33:WU00:FS00:0xa7:************************************ Build *************************************
23:36:33:WU00:FS00:0xa7: SIMD: avx_256
23:36:33:WU00:FS00:0xa7:********************************************************************************
23:36:33:WU00:FS00:0xa7:Project: 14607 (Run 19, Clone 0, Gen 61)
23:36:33:WU00:FS00:0xa7:Unit: 0x000000419bf7a4d65e79f1a74aef952c
23:36:33:WU00:FS00:0xa7:Digital signatures verified
23:36:33:WU00:FS00:0xa7:Reducing thread count from 31 to 30 to avoid domain decomposition by a prime number > 3
23:36:33:WU00:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -cpi state.cpt -cpt 15 -nt 30
23:36:33:WU00:FS00:0xa7:ERROR:Guru Meditation #f3e3c2a1337915cb.2cb1a2851d2b1cb9 (2016.2604) '00/01/pullf.xvg'
23:36:33:WU00:FS00:0xa7:WARNING:Unexpected exit() call
23:36:33:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
23:36:33:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
23:36:33:WU00:FS00:0xa7:Saving result file dhdl.xvg
23:36:33:WU00:FS00:0xa7:Saving result file frame61.trrRe: 2080ti OpenCL Not detected: clGetDeviceIDs() returned -1
Currently on the most recent Nvidia drivers from 4/15/2020 445.87
You have configured only one slot, for your CPU. Try adding a GPU slot with FAHControl. If that doesn't work, find the setting that says gpu=false and remove it, then restart.
I've tried adding my GPU multiple times it will not add it to the slot list. Which file would the gpu=false be located? I don't see it in the config file.bruce wrote:You have configured only one slot, for your CPU. Try adding a GPU slot with FAHControl. If that doesn't work, find the setting that says gpu=false and remove it, then restart.
Currently GPU is ion Ready Status in Folding Slots but Work Queue is in status download and will not start.
download means it is trying to get work. it doesn't have any yet - there is a shortage unfortunately. try pausing the gpu slot (right click on the slot using Advanced Control and select pause), then wait for a few minutes and then right click to select fold again. You may get lucky and get some work.
However! I don't think your drivers are correctly installed. can you repost the beginning of the current log?
You have very high-end hardware and it isn't a simple config with such a beast. I would think you should have two folding slots for that cpu because there isn't much work that will work on a 64-thread slot. Search your Windows user directory for config.xml. If you could paste its contents into a post here (delete the line that contains your passkey!) we might be able to suggest how to get the most our of your system
single 1070
*********************** Log Started 2020-04-20T03:04:02Z ***********************
03:04:02:****************************** FAHClient ******************************
03:04:02: Version: 7.6.9
03:04:02: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:04:02: Copyright: 2020 foldingathome.org
03:04:02: Homepage: https://foldingathome.org/
03:04:02: Date: Apr 17 2020
03:04:02: Time: 11:13:06
03:04:02: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
03:04:02: Branch: master
03:04:02: Compiler: Visual C++ 2008
03:04:02: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:04:02: Platform: win32 10
03:04:02: Bits: 32
03:04:02: Mode: Release
03:04:02: Config: C:\Users\Brian\AppData\Roaming\FAHClient\config.xml
03:04:02:******************************** CBang ********************************
03:04:02: Time: 11:10:09
03:04:02: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
03:04:02: Bits: 32
03:04:02:******************************* System ********************************
03:04:02: CPU: AMD Ryzen Threadripper 2990WX 32-Core Processor
03:04:02: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
03:04:02: CPUs: 32
03:04:02: Memory: 127.87GiB
03:04:02: Free Memory: 121.08GiB
03:04:02: Threads: WINDOWS_THREADS
03:04:02: OS Version: 6.2
03:04:02: Has Battery: false
03:04:02: On Battery: false
03:04:02: UTC Offset: -4
03:04:02: PID: 26496
03:04:02: CWD: C:\Users\Brian\AppData\Roaming\FAHClient
03:04:02: OS: Windows 10 Enterprise
03:04:02: OS Arch: AMD64
03:04:02: GPUs: 1
03:04:02: GPU 0: Bus:65 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
03:04:02: M 13448
03:04:02:CUDA Device 0: Platform:0 Device:0 Bus:65 Slot:0 Compute:7.5 Driver:11.0
03:04:02: OpenCL: Not detected: clGetDeviceIDs() returned -1
03:04:02:Win32 Service: false
03:04:02:******************************* libFAH ********************************
03:04:02: Date: Apr 15 2020
03:04:02: Time: 14:53:14
03:04:02: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
03:04:02: Bits: 32
03:04:02:***********************************************************************
03:04:02:<config>
03:04:02: <!-- Network -->
03:04:02: <proxy v=':8080'/>
03:04:02:
03:04:02: <!-- Slot Control -->
03:04:02: <power v='MEDIUM'/>
03:04:02:
03:04:02: <!-- User Information -->
03:04:02: <passkey v='*****'/>
03:04:02: <team v='XXXXXX'/>
03:04:02: <user v='XXXXXX'/>
03:04:02:
03:04:02: <!-- Folding Slots -->
03:04:02: <slot id='0' type='CPU'/>
03:04:02: <slot id='1' type='GPU'/>
03:04:02:</config>
03:04:02:Trying to access database...
03:04:02:Successfully acquired database lock
03:04:02:Enabled folding slot 00: READY cpu:30
03:04:02:Enabled folding slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448
03:04:02:WU00:FS00:Starting
03:04:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Brian\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 26496 -checkpoint 15 -np 30
03:04:02:WU00:FS00:Started FahCore on PID 25952
03:04:02:WU00:FS00:Core PID:26164
03:04:02:WU00:FS00:FahCore 0xa7 started
03:04:03:WU00:FS00:0xa7:*********************** Log Started 2020-04-20T03:04:02Z ***********************
03:04:03:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:04:03:WU00:FS00:0xa7: Type: 0xa7
03:04:03:WU00:FS00:0xa7: Core: Gromacs
03:04:03:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 25952 -checkpoint 15 -np
03:04:03:WU00:FS00:0xa7: 30
03:04:03:WU00:FS00:0xa7:************************************ CBang *************************************
03:04:03:WU00:FS00:0xa7: Date: Oct 26 2019
03:04:03:WU00:FS00:0xa7: Time: 01:38:25
03:04:03:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:04:03:WU00:FS00:0xa7: Branch: master
03:04:03:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:04:03:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:04:03:WU00:FS00:0xa7: Platform: win32 10
03:04:03:WU00:FS00:0xa7: Bits: 64
03:04:03:WU00:FS00:0xa7: Mode: Release
03:04:03:WU00:FS00:0xa7:************************************ System ************************************
03:04:03:WU00:FS00:0xa7: CPU: AMD Ryzen Threadripper 2990WX 32-Core Processor
03:04:03:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
03:04:03:WU00:FS00:0xa7: CPUs: 64
03:04:03:WU00:FS00:0xa7: Memory: 127.87GiB
03:04:03:WU00:FS00:0xa7:Free Memory: 120.99GiB
03:04:03:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:04:03:WU00:FS00:0xa7: OS Version: 6.2
03:04:03:WU00:FS00:0xa7:Has Battery: false
03:04:03:WU00:FS00:0xa7: On Battery: false
03:04:03:WU00:FS00:0xa7: UTC Offset: -4
03:04:03:WU00:FS00:0xa7: PID: 26164
03:04:03:WU00:FS00:0xa7: CWD: C:\Users\Brian\AppData\Roaming\FAHClient\work
03:04:03:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:04:03:WU00:FS00:0xa7: Version: 0.0.18
03:04:03:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:04:03:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:04:03:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:04:03:WU00:FS00:0xa7: Time: 01:52:30
03:04:03:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:04:03:WU00:FS00:0xa7:************************************ Build *************************************
03:04:03:WU00:FS00:0xa7: SIMD: avx_256
03:04:03:WU00:FS00:0xa7:********************************************************************************
03:04:03:WU00:FS00:0xa7:Project: 14379 (Run 2182, Clone 0, Gen 24)
03:04:03:WU00:FS00:0xa7:Unit: 0x0000001a455e42075e932f98710229e2
03:04:03:WU00:FS00:0xa7:Digital signatures verified
03:04:03:WU00:FS00:0xa7:Calling: mdrun -s frame24.tpr -o frame24.trr -cpi state.cpt -cpt 15 -nt 30
03:04:03:WU00:FS00:0xa7:ERROR:Guru Meditation #295fd479e52264f0.3abde92b9efb8473 (10212.11004) '00/01/pullf.xvg'
03:04:03:WU00:FS00:0xa7:WARNING:Unexpected exit() call
03:04:03:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
03:04:03:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
03:04:03:WU00:FS00:0xa7:Saving result file dhdl.xvg
03:04:03:WU00:FS00:0xa7:Saving result file frame24.trr
03:04:03:WU00:FS00:0xa7:Saving result file md.log
03:04:03:WU00:FS00:0xa7:Saving result file pullf.xvg
03:04:07:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
03:04:07:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)Re: 2080ti OpenCL Not detected: clGetDeviceIDs() returned -1
-<config>
<!-- Network -->
<proxy v=":8080"/>
<power v="MEDIUM"/>
<passkey v="XXXXX"/>
<team v="XXXXX"/>
<user v="XXXXX"/>
<slot type="CPU" id="0"/>
<slot type="GPU" id="1"/>
</config>
<!-- Network -->
<proxy v=":8080"/>
<power v="MEDIUM"/>
<team v="XXXXX"/>
<user v="XXXXX"/>
</config>
I did see this in the logs
13:10:23:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, make sure the OpenCL driver is installed or try setting 'opencl-index' manually
Not sure if this is properly configured but here are my settings currently
13:23:11: <slot id='1' type='GPU'>
13:23:11: <cuda-index v='0'/>
13:23:11: <gpu-index v='0'/>
13:23:11: <opencl-index v='0'/>
13:23:11: </slot>
13:23:11: </slot>
On the GPU front … "03:04:02: OpenCL: Not detected: clGetDeviceIDs() returned -1" makes me believe that your OpenCL drivers are not installed correctly … Are you using the latest drivers from nvidia (latest is 445.87 I think) - I believe these should have the OpenCL drivers incorporated.
On the CPU front you have a 30core slot configured I think - which is not particularly advisable - dropping this to 24core and maybe running a 6core as well should reduce the number of errors on that.
It's working now needed to manually set the opencl-index to 0 as well as the gpu and cuda index to 0Neil-B wrote:On the GPU front … "03:04:02: OpenCL: Not detected: clGetDeviceIDs() returned -1" makes me believe that your OpenCL drivers are not installed correctly … Are you using the latest drivers from nvidia (latest is 445.87 I think) - I believe these should have the OpenCL drivers incorporated.
