If I see a GPU task is not likely to complete before expiration, will clicking Finish save the work that was done, reducing the work done by whoever picks the task up?
My first GPU task took too long and expired, which I assume means the work done was lost. Thanks!
Finish Before Expiration To Save Work?
Re: Finish Before Expiration To Save Work?
Welcome to Folding@Home!
the Finish option is for when you wish to finish this Work Unit but not automatically start another.
You can then restart by choosing Fold.
One way to send the server notification you have quit work on a WU is to remove the slot. So if your GPU is just too slow to fold:
You should see a gpu slot, click remove and save.
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Just for future reference.....
If a slot is removed per the above, is the WU re-issued before the timeout date and time, or will the system just let it sit until it passes that time?
Fold them if you get them!
BobWilliams757, my understanding is that the partial WU goes back to the server to be reassigned (from the start) to someone else. It does not need to wait for time out as the server knows you abandoned the WU.
That said, I am just a volunteer like yourself, not a Biochemist. I did not even sleep in a Holiday Inn Express last night.
