Windows client, NVS 5400M GPU Failing
AndrewBienhaus
Post by AndrewBienhaus »
Hi,
hope you don't mind me asking.... 24 fails in a row for my GPU.
I had wondered about blacklist, but it's getting jobs and then failing.
Looked it up on the whitelist, and it shows as a "2,2".. so I think that means it should be working?
log here, maybe it's obvious, but I can't see it... looks like it's repeatedly saying "bad work unit" or faulty...?
28 in the last day. (4 more in the last hour, since I started typing this post, and then had to clear the log to get a size of log I could post)
had 5 on my other machine, but it just finished one with complete success as well.
are there some bad WU's in the batch?
*********************** Log Started 2020-04-18T21:18:11Z ***********************
21:18:11:****************************** FAHClient ******************************
21:18:11:        Version: 7.6.9
21:18:11:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:18:11:      Copyright: 2020 foldingathome.org
21:18:11:       Homepage: https://foldingathome.org/
21:18:11:           Date: Apr 17 2020
21:18:11:           Time: 11:13:06
21:18:11:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
21:18:11:         Branch: master
21:18:11:       Compiler: Visual C++ 2008
21:18:11:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:18:11:       Platform: win32 10
21:18:11:           Bits: 32
21:18:11:           Mode: Release
21:18:11:           Args: --open-web-control
21:18:11:         Config: C:\Users\andy\AppData\Roaming\FAHClient\config.xml
21:18:11:******************************** CBang ********************************
21:18:11:           Time: 11:10:09
21:18:11:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
21:18:11:           Bits: 32
21:18:11:******************************* System ********************************
21:18:11:            CPU: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz
21:18:11:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:18:11:           CPUs: 8
21:18:11:         Memory: 15.70GiB
21:18:11:    Free Memory: 7.53GiB
21:18:11:        Threads: WINDOWS_THREADS
21:18:11:     OS Version: 6.2
21:18:11:    Has Battery: true
21:18:11:     On Battery: false
21:18:11:     UTC Offset: -4
21:18:11:            PID: 30300
21:18:11:            CWD: C:\Users\andy\AppData\Roaming\FAHClient
21:18:11:             OS: Windows 10 Enterprise
21:18:11:        OS Arch: AMD64
21:18:11:           GPUs: 1
21:18:11:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF108 [NVS 5400M]
21:18:11:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.1 Driver:9.1
21:18:11:OpenCL Device 1: Platform:0 Device:1 Bus:NA Slot:NA Compute:1.2 Driver:10.18
21:18:11:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:389.8
21:18:11:  Win32 Service: false
21:18:11:******************************* libFAH ********************************
21:18:11:           Date: Apr 15 2020
21:18:11:           Time: 14:53:14
21:18:11:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
21:18:11:           Bits: 32
21:18:11:***********************************************************************
21:18:11:<config>
21:18:11:  <!-- HTTP Server -->
21:18:11:  <allow v='127.0.0.1 192.168.69.0/24'/>
21:18:11:
21:18:11:  <!-- Network -->
21:18:11:  <proxy v=':8080'/>
21:18:11:
21:18:11:  <!-- Remote Command Server -->
21:18:11:  <command-allow-no-pass v='127.0.0.1 192.168.69.0/24'/>
21:18:11:
21:18:11:  <!-- Slot Control -->
21:18:11:  <power v='FULL'/>
21:18:11:
21:18:11:  <!-- User Information -->
21:18:11:  <passkey v='*****'/>
21:18:11:  <team v='250015'/>
21:18:11:  <user v='1stBinbrookCanada'/>
21:18:11:
21:18:11:  <!-- Folding Slots -->
21:18:11:  <slot id='0' type='CPU'/>
21:18:11:  <slot id='1' type='GPU'/>
21:18:11:</config>
21:18:11:Trying to access database...
21:18:11:Successfully acquired database lock
21:18:11:Enabled folding slot 00: READY cpu:7
21:18:11:Enabled folding slot 01: READY gpu:0:GF108 [NVS 5400M]
21:18:11:WU02:FS00:Starting
21:18:11:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\andy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 30300 -checkpoint 15 -np 7
21:18:12:WU02:FS00:Started FahCore on PID 54824
21:18:12:WU02:FS00:Core PID:4912
21:18:12:WU02:FS00:FahCore 0xa7 started
21:18:13:WU02:FS00:0xa7:*********************** Log Started 2020-04-18T21:18:12Z ***********************
21:18:13:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:18:13:WU02:FS00:0xa7:       Type: 0xa7
21:18:13:WU02:FS00:0xa7:       Core: Gromacs
21:18:13:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 54824 -checkpoint 15 -np
21:18:13:WU02:FS00:0xa7:             7
21:18:13:WU02:FS00:0xa7:************************************ CBang *************************************
21:18:13:WU02:FS00:0xa7:       Date: Oct 26 2019
21:18:13:WU02:FS00:0xa7:       Time: 01:38:25
21:18:13:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:18:13:WU02:FS00:0xa7:     Branch: master
21:18:13:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
21:18:13:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:18:13:WU02:FS00:0xa7:   Platform: win32 10
21:18:13:WU02:FS00:0xa7:       Bits: 64
21:18:13:WU02:FS00:0xa7:       Mode: Release
21:18:13:WU02:FS00:0xa7:************************************ System ************************************
21:18:13:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz
21:18:13:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:18:13:WU02:FS00:0xa7:       CPUs: 8
21:18:13:WU02:FS00:0xa7:     Memory: 15.70GiB
21:18:13:WU02:FS00:0xa7:Free Memory: 7.50GiB
21:18:13:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
21:18:13:WU02:FS00:0xa7: OS Version: 6.2
21:18:13:WU02:FS00:0xa7:Has Battery: true
21:18:13:WU02:FS00:0xa7: On Battery: false
21:18:13:WU02:FS00:0xa7: UTC Offset: -4
21:18:13:WU02:FS00:0xa7:        PID: 4912
21:18:13:WU02:FS00:0xa7:        CWD: C:\Users\andy\AppData\Roaming\FAHClient\work
21:18:13:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
21:18:13:WU02:FS00:0xa7:    Version: 0.0.18
21:18:13:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:18:13:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:18:13:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
21:18:13:WU02:FS00:0xa7:       Time: 01:52:30
21:18:13:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:18:13:WU02:FS00:0xa7:************************************ Build *************************************
21:18:13:WU02:FS00:0xa7:       SIMD: avx_256
21:18:13:WU02:FS00:0xa7:********************************************************************************
21:18:13:WU02:FS00:0xa7:Project: 13871 (Run 0, Clone 614, Gen 85)
21:18:13:WU02:FS00:0xa7:Unit: 0x0000005d0d5262775e76c94f61be9bf7
21:18:13:WU02:FS00:0xa7:Digital signatures verified
21:18:13:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
21:18:13:WU02:FS00:0xa7:Calling: mdrun -s frame85.tpr -o frame85.trr -x frame85.xtc -e frame85.edr -cpi state.cpt -cpt 15 -nt 6
21:18:13:WU02:FS00:0xa7:Steps: first=10625000 total=125000
21:18:15:WU02:FS00:0xa7:Completed 84852 out of 125000 steps (67%)
21:18:24:WU00:FS01:Connecting to 65.254.110.245:80
21:18:25:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:18:25:WU00:FS01:Connecting to 18.218.241.186:80
21:18:25:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:18:25:WU00:FS01:Connecting to 65.254.110.245:80
21:18:26:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:18:26:WU00:FS01:Connecting to 18.218.241.186:80
21:18:26:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:18:26:ERROR:WU00:FS01:Exception: Could not get an assignment
21:18:26:18:127.0.0.1:New Web session
21:18:26:WU00:FS01:Connecting to 65.254.110.245:80
21:18:27:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:18:27:WU00:FS01:Connecting to 18.218.241.186:80
21:18:27:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:18:27:WU00:FS01:Connecting to 65.254.110.245:80
21:18:28:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:18:28:WU00:FS01:Connecting to 18.218.241.186:80
21:18:28:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:18:28:ERROR:WU00:FS01:Exception: Could not get an assignment
21:18:37:WU02:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
21:19:26:WU00:FS01:Connecting to 65.254.110.245:80
21:19:27:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:19:27:WU00:FS01:Connecting to 18.218.241.186:80
21:19:27:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:19:27:WU00:FS01:Connecting to 65.254.110.245:80
21:19:28:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:19:28:WU00:FS01:Connecting to 18.218.241.186:80
21:19:28:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:19:28:ERROR:WU00:FS01:Exception: Could not get an assignment
21:21:04:WU00:FS01:Connecting to 65.254.110.245:80
21:21:04:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:21:04:WU00:FS01:Connecting to 18.218.241.186:80
21:21:04:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:21:05:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:21:05:WU00:FS01:Connecting to 18.218.241.186:80
21:21:05:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:21:05:ERROR:WU00:FS01:Exception: Could not get an assignment
21:21:37:WU02:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
21:23:41:WU00:FS01:Connecting to 65.254.110.245:80
21:23:41:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:23:41:WU00:FS01:Connecting to 18.218.241.186:80
21:23:42:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:23:42:WU00:FS01:Connecting to 65.254.110.245:80
21:23:42:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:23:42:WU00:FS01:Connecting to 18.218.241.186:80
21:23:42:ERROR:WU00:FS01:Exception: Could not get an assignment
21:24:34:WU02:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
21:27:27:WU02:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
21:27:55:WU00:FS01:Connecting to 65.254.110.245:80
21:27:55:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:27:55:WU00:FS01:Connecting to 18.218.241.186:80
21:27:56:WU00:FS01:Assigned to work server 140.163.4.231
21:27:56:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [NVS 5400M] from 140.163.4.231
21:27:56:WU00:FS01:Connecting to 140.163.4.231:8080
21:28:17:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
21:30:23:WU02:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
21:33:16:WU02:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
21:34:47:WU00:FS01:Connecting to 65.254.110.245:80
21:34:47:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:34:47:WU00:FS01:Connecting to 18.218.241.186:80
21:34:47:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:34:49:WU00:FS01:Assigned to work server 13.82.98.119
21:34:49:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [NVS 5400M] from 13.82.98.119
21:34:49:WU00:FS01:Connecting to 13.82.98.119:8080
21:35:10:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
21:35:10:WU00:FS01:Connecting to 13.82.98.119:80
21:35:43:WU00:FS01:Downloading 13.26MiB
21:35:45:WU00:FS01:Download complete
21:35:45:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14538 run:0 clone:961 gen:48 core:0x22 unit:0x000000410d5262775e7b9cdd174e3e6d
21:35:45:WU00:FS01:Starting
21:35:45:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\andy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 30300 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
21:35:45:WU00:FS01:Started FahCore on PID 1620
21:35:45:WU00:FS01:Core PID:57984
21:35:45:WU00:FS01:FahCore 0x22 started
21:35:45:WU00:FS01:0x22:*********************** Log Started 2020-04-18T21:35:45Z ***********************
21:35:45:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:35:45:WU00:FS01:0x22:       Type: 0x22
21:35:45:WU00:FS01:0x22:       Core: Core22
21:35:45:WU00:FS01:0x22:    Website: https://foldingathome.org/
21:35:45:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:35:45:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:35:45:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:35:45:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 1620 -checkpoint 15
21:35:45:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
21:35:45:WU00:FS01:0x22:             0 -gpu 0
21:35:45:WU00:FS01:0x22:     Config: <none>
21:35:45:WU00:FS01:0x22:************************************ Build *************************************
21:35:45:WU00:FS01:0x22:    Version: 0.0.2
21:35:45:WU00:FS01:0x22:       Date: Dec 6 2019
21:35:45:WU00:FS01:0x22:       Time: 21:30:31
21:35:45:WU00:FS01:0x22: Repository: Git
21:35:45:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:35:45:WU00:FS01:0x22:     Branch: HEAD
21:35:45:WU00:FS01:0x22:   Compiler: Visual C++ 2008
21:35:45:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:35:45:WU00:FS01:0x22:   Platform: win32 10
21:35:45:WU00:FS01:0x22:       Bits: 64
21:35:45:WU00:FS01:0x22:       Mode: Release
21:35:45:WU00:FS01:0x22:************************************ System ************************************
21:35:45:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz
21:35:45:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:35:45:WU00:FS01:0x22:       CPUs: 8
21:35:45:WU00:FS01:0x22:     Memory: 15.70GiB
21:35:45:WU00:FS01:0x22:Free Memory: 7.65GiB
21:35:45:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:35:45:WU00:FS01:0x22: OS Version: 6.2
21:35:45:WU00:FS01:0x22:Has Battery: true
21:35:45:WU00:FS01:0x22: On Battery: false
21:35:45:WU00:FS01:0x22: UTC Offset: -4
21:35:45:WU00:FS01:0x22:        PID: 57984
21:35:45:WU00:FS01:0x22:        CWD: C:\Users\andy\AppData\Roaming\FAHClient\work
21:35:45:WU00:FS01:0x22:         OS: Windows 10 Pro
21:35:45:WU00:FS01:0x22:    OS Arch: AMD64
21:35:45:WU00:FS01:0x22:********************************************************************************
21:35:45:WU00:FS01:0x22:Project: 14538 (Run 0, Clone 961, Gen 48)
21:35:45:WU00:FS01:0x22:Unit: 0x000000410d5262775e7b9cdd174e3e6d
21:35:45:WU00:FS01:0x22:Reading tar file core.xml
21:35:45:WU00:FS01:0x22:Reading tar file integrator.xml
21:35:45:WU00:FS01:0x22:Reading tar file state.xml
21:35:45:WU00:FS01:0x22:Reading tar file system.xml
21:35:45:WU00:FS01:0x22:Digital signatures verified
21:35:45:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:35:45:WU00:FS01:0x22:Version 0.0.2
21:35:50:WU00:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:35:50:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
21:35:50:WU00:FS01:0x22:Saving result file science.log
21:35:50:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:35:51:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:35:51:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14538 run:0 clone:961 gen:48 core:0x22 unit:0x000000410d5262775e7b9cdd174e3e6d
21:35:51:WU00:FS01:Uploading 8.50KiB to 13.82.98.119
21:35:51:WU00:FS01:Connecting to 13.82.98.119:8080
21:35:51:WU01:FS01:Connecting to 65.254.110.245:80
21:35:51:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:35:51:WU01:FS01:Connecting to 18.218.241.186:80
21:35:52:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:35:52:WU01:FS01:Connecting to 65.254.110.245:80
21:35:52:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:35:52:WU01:FS01:Connecting to 18.218.241.186:80
21:35:53:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:35:53:ERROR:WU01:FS01:Exception: Could not get an assignment
21:35:53:WU01:FS01:Connecting to 65.254.110.245:80
21:35:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:35:53:WU01:FS01:Connecting to 18.218.241.186:80
21:35:54:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:35:54:WU01:FS01:Connecting to 18.218.241.186:80
21:35:54:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:35:54:ERROR:WU01:FS01:Exception: Could not get an assignment
21:36:10:WU02:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
21:36:26:WU00:FS01:Upload complete
21:36:26:WU00:FS01:Server responded WORK_ACK (400)
21:36:26:WU00:FS01:Cleaning up
21:36:53:WU01:FS01:Connecting to 65.254.110.245:80
21:36:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:36:53:WU01:FS01:Connecting to 18.218.241.186:80
21:36:54:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:36:54:WU01:FS01:Connecting to 65.254.110.245:80
21:36:54:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:36:54:WU01:FS01:Connecting to 18.218.241.186:80
21:36:54:ERROR:WU01:FS01:Exception: Could not get an assignment
21:38:30:WU01:FS01:Connecting to 65.254.110.245:80
21:38:31:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
21:38:31:WU01:FS01:Connecting to 18.218.241.186:80
21:38:31:WU01:FS01:Assigned to work server 128.252.203.10
21:38:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [NVS 5400M] from 128.252.203.10
21:38:31:WU01:FS01:Connecting to 128.252.203.10:8080
21:39:03:WU02:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
21:39:18:WU01:FS01:Downloading 79.12MiB
21:39:24:WU01:FS01:Download 50.16%
21:39:30:WU01:FS01:Download 92.26%
21:39:31:WU01:FS01:Download complete
21:39:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11759 run:0 clone:12785 gen:7 core:0x22 unit:0x0000000e80fccb0a5e6ebe042a851327
21:39:31:WU01:FS01:Starting
21:39:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\andy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 30300 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
21:39:31:WU01:FS01:Started FahCore on PID 48196
21:39:31:WU01:FS01:Core PID:40060
21:39:31:WU01:FS01:FahCore 0x22 started
21:39:31:WU01:FS01:0x22:*********************** Log Started 2020-04-18T21:39:31Z ***********************
21:39:31:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:39:31:WU01:FS01:0x22:       Type: 0x22
21:39:31:WU01:FS01:0x22:       Core: Core22
21:39:31:WU01:FS01:0x22:    Website: https://foldingathome.org/
21:39:31:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:39:31:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:39:31:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:39:31:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 48196 -checkpoint 15
21:39:31:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
21:39:31:WU01:FS01:0x22:             0 -gpu 0
21:39:31:WU01:FS01:0x22:     Config: <none>
21:39:31:WU01:FS01:0x22:************************************ Build *************************************
21:39:31:WU01:FS01:0x22:    Version: 0.0.2
21:39:31:WU01:FS01:0x22:       Date: Dec 6 2019
21:39:31:WU01:FS01:0x22:       Time: 21:30:31
21:39:31:WU01:FS01:0x22: Repository: Git
21:39:31:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:39:31:WU01:FS01:0x22:     Branch: HEAD
21:39:31:WU01:FS01:0x22:   Compiler: Visual C++ 2008
21:39:31:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:39:31:WU01:FS01:0x22:   Platform: win32 10
21:39:31:WU01:FS01:0x22:       Bits: 64
21:39:31:WU01:FS01:0x22:       Mode: Release
21:39:31:WU01:FS01:0x22:************************************ System ************************************
21:39:31:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz
21:39:31:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:39:31:WU01:FS01:0x22:       CPUs: 8
21:39:31:WU01:FS01:0x22:     Memory: 15.70GiB
21:39:31:WU01:FS01:0x22:Free Memory: 7.83GiB
21:39:31:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:39:31:WU01:FS01:0x22: OS Version: 6.2
21:39:31:WU01:FS01:0x22:Has Battery: true
21:39:31:WU01:FS01:0x22: On Battery: false
21:39:31:WU01:FS01:0x22: UTC Offset: -4
21:39:31:WU01:FS01:0x22:        PID: 40060
21:39:31:WU01:FS01:0x22:        CWD: C:\Users\andy\AppData\Roaming\FAHClient\work
21:39:31:WU01:FS01:0x22:         OS: Windows 10 Pro
21:39:31:WU01:FS01:0x22:    OS Arch: AMD64
21:39:31:WU01:FS01:0x22:********************************************************************************
21:39:31:WU01:FS01:0x22:Project: 11759 (Run 0, Clone 12785, Gen 7)
21:39:31:WU01:FS01:0x22:Unit: 0x0000000e80fccb0a5e6ebe042a851327
21:39:31:WU01:FS01:0x22:Reading tar file core.xml
21:39:31:WU01:FS01:0x22:Reading tar file integrator.xml
21:39:31:WU01:FS01:0x22:Reading tar file state.xml
21:39:32:WU01:FS01:0x22:Reading tar file system.xml
21:39:32:WU01:FS01:0x22:Digital signatures verified
21:39:32:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:39:32:WU01:FS01:0x22:Version 0.0.2
21:39:57:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:39:57:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:39:57:WU01:FS01:0x22:Saving result file science.log
21:39:57:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:39:58:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:39:58:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11759 run:0 clone:12785 gen:7 core:0x22 unit:0x0000000e80fccb0a5e6ebe042a851327
21:39:58:WU01:FS01:Uploading 8.50KiB to 128.252.203.10
Re: Windows client, NVS 5400M GPU Failing
Post by Neil-B »
I have my doubts it is server/project end as it appears the failures are across multiple projects - feels more an issue at client end ... whether it is something failing gpu wise - but that would be two different machines at the same time if I understood your post ... or something firewall/antivirus ... hopefully someone will recognise the symptoms and be able to advise ... one of the opencl drivers is 1.1 which may play into it
The NVS 5400m falls into an edge case. It is listed as only supporting OpenCL 1.1, but some nVidia cards like that have been able to fold on some GPU projects, but not others. Not enough is known at this point to give a definite answer as to which of these GPUs will work or not.
In your case it appears to not be working at all, or have you had some WUs succeed before this run of 24 failures? It could be the driver version, or just missing some OpenCL instruction that another nVidia GPU listed as only OpenCL 1.1 does have.
Another thought, as this GPU and the CPU are both mobile, I am assuming this is a laptop. Some laptops with nVidia discrete GPUs have a technology called nVidia Optmus to use the Intel integrated GPU on the CPU chip for low power video display usage and switches to the discrete GPU for high power needs.
This can be a problem for folding, if the iGPU is active when the GPU folding core is started, the WU will fail. The workaround is to disable use of the iGPU on the Intel processor, and only use the NVS. Details on how to do this depend on the laptop, it may need to be disabled in the BIOS, or there can be an option in the display driver control panel.
AndrewBienhaus
Thanks Joe.... sounds like I should just shut off GPU processing on this machine. :)
https://www.techpowerup.com/gpu-specs/nvs-5400m.c1742
96 cores, it will never complete before deadlines, also only OpenCL 1.1.
That appears to be the last driver for the NVS 5400M.
Removing the gpu slot may allow all 8 CPU cores to fold.
