Log file (1)
*Wirralgirl*
Log file (1)
Post by *Wirralgirl* »
Hi,
First post - I'd appreciate any advice, I'm getting occasional error msgs saying the client has stopped, telling me to re-start.
I have no ranking position in my team despite having higher scores than others who have ranking, but completed fewer WUs.
Seems to me to be a massive amount going on in this log - separated into two posts.
Thanks for any feedback.
*********************** Log Started 2020-04-17T14:10:04Z ***********************
14:10:04:****************************** FAHClient ******************************
14:10:04:        Version: 7.6.8
14:10:04:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:10:04:      Copyright: 2020 foldingathome.org
14:10:04:       Homepage: https://foldingathome.org/
14:10:04:           Date: Apr 15 2020
14:10:04:           Time: 14:55:26
14:10:04:       Revision: 34a6e026f7032e19bfa748ef56985f8e9fb09c99
14:10:04:         Branch: master
14:10:04:       Compiler: Visual C++ 2008
14:10:04:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:10:04:       Platform: win32 10
14:10:04:           Bits: 32
14:10:04:           Mode: Release
14:10:04:         Config: C:\Users\spk40\AppData\Roaming\FAHClient\config.xml
14:10:04:******************************** CBang ********************************
14:10:04:           Time: 14:52:13
14:10:04:       Revision: 640ed4bc1084ddf2aa9cfa32aa9a2470dc8b7857
14:10:04:           Bits: 32
14:10:04:******************************* System ********************************
14:10:04:            CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
14:10:04:         CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
14:10:04:           CPUs: 4
14:10:04:         Memory: 7.92GiB
14:10:04:    Free Memory: 4.24GiB
14:10:04:        Threads: WINDOWS_THREADS
14:10:04:     OS Version: 6.2
14:10:04:    Has Battery: true
14:10:04:     On Battery: false
14:10:04:     UTC Offset: 1
14:10:04:            PID: 4132
14:10:04:            CWD: C:\Users\spk40\AppData\Roaming\FAHClient
14:10:04:             OS: Windows 10 Home
14:10:04:        OS Arch: AMD64
14:10:04:           GPUs: 1
14:10:04:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Mars [Radeon R7 M260/M265/M270]
14:10:04:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:10:04:                 specified module could not be found.
14:10:04:
14:10:04:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:21.20
14:10:04:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.8
14:10:04:  Win32 Service: false
14:10:04:******************************* libFAH ********************************
14:10:04:           Time: 14:53:14
14:10:04:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:10:04:           Bits: 32
14:10:04:***********************************************************************
14:10:05:<config>
14:10:05:  <!-- Slot Control -->
14:10:05:  <power v='MEDIUM'/>
14:10:05:
14:10:05:  <!-- User Information -->
14:10:05:  <passkey v='*****'/>
14:10:05:  <team v='588'/>
14:10:05:  <user v='Wirralgirl'/>
14:10:05:
14:10:05:  <!-- Folding Slots -->
14:10:05:  <slot id='0' type='CPU'/>
14:10:05:  <slot id='1' type='GPU'/>
14:10:05:</config>
14:10:05:Trying to access database...
14:10:05:Successfully acquired database lock
14:10:05:Enabled folding slot 00: READY cpu:2
14:10:05:Enabled folding slot 01: READY gpu:0:Mars [Radeon R7 M260/M265/M270]
14:10:05:WU01:FS01:Starting
14:10:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
14:10:05:WU01:FS01:Started FahCore on PID 9852
14:10:07:WU01:FS01:Core PID:13648
14:10:07:WU01:FS01:FahCore 0x22 started
14:10:10:WU02:FS00:Starting
14:10:10:WARNING:WU02:FS00:AS lowered CPUs from 2 to 1
14:10:10:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 1
14:10:10:WU02:FS00:Started FahCore on PID 4356
14:10:14:WU02:FS00:Core PID:15508
14:10:14:WU02:FS00:FahCore 0xa7 started
14:10:17:WU01:FS01:0x22:*********************** Log Started 2020-04-17T14:10:16Z ***********************
14:10:17:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:10:17:WU01:FS01:0x22:       Type: 0x22
14:10:17:WU01:FS01:0x22:       Core: Core22
14:10:17:WU01:FS01:0x22:    Website: https://foldingathome.org/
14:10:17:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
14:10:17:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:10:17:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
14:10:17:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9852 -checkpoint 15
14:10:17:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
14:10:17:WU01:FS01:0x22:     Config: <none>
14:10:17:WU01:FS01:0x22:************************************ Build *************************************
14:10:19:WU01:FS01:0x22:    Version: 0.0.2
14:10:19:WU01:FS01:0x22:       Date: Dec 6 2019
14:10:19:WU01:FS01:0x22:       Time: 21:30:31
14:10:19:WU01:FS01:0x22: Repository: Git
14:10:19:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
14:10:19:WU01:FS01:0x22:     Branch: HEAD
14:10:19:WU01:FS01:0x22:   Compiler: Visual C++ 2008
14:10:19:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:10:19:WU01:FS01:0x22:   Platform: win32 10
14:10:19:WU01:FS01:0x22:       Bits: 64
14:10:19:WU01:FS01:0x22:       Mode: Release
14:10:19:WU01:FS01:0x22:************************************ System ************************************
14:10:19:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
14:10:19:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
14:10:19:WU01:FS01:0x22:       CPUs: 4
14:10:19:WU01:FS01:0x22:     Memory: 7.92GiB
14:10:19:WU01:FS01:0x22:Free Memory: 4.07GiB
14:10:19:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
14:10:19:WU01:FS01:0x22: OS Version: 6.2
14:10:19:WU01:FS01:0x22:Has Battery: true
14:10:19:WU01:FS01:0x22: On Battery: false
14:10:19:WU01:FS01:0x22: UTC Offset: 1
14:10:19:WU01:FS01:0x22:        PID: 13648
14:10:19:WU01:FS01:0x22:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
14:10:19:WU01:FS01:0x22:         OS: Windows 10 Home
14:10:19:WU01:FS01:0x22:    OS Arch: AMD64
14:10:19:WU01:FS01:0x22:********************************************************************************
14:10:19:WU01:FS01:0x22:Project: 11742 (Run 0, Clone 210, Gen 43)
14:10:19:WU01:FS01:0x22:Unit: 0x000000478ca304f15e66e0849f1e66ae
14:10:19:WU01:FS01:0x22:Digital signatures verified
14:10:19:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:10:19:WU01:FS01:0x22:Version 0.0.2
14:10:20:WU01:FS01:0x22:  Found a checkpoint file
14:10:24:WU02:FS00:0xa7:*********************** Log Started 2020-04-17T14:10:24Z ***********************
14:10:24:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:10:24:WU02:FS00:0xa7:       Type: 0xa7
14:10:24:WU02:FS00:0xa7:       Core: Gromacs
14:10:24:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 4356 -checkpoint 15 -np 1
14:10:24:WU02:FS00:0xa7:************************************ CBang *************************************
14:10:24:WU02:FS00:0xa7:       Date: Oct 26 2019
14:10:24:WU02:FS00:0xa7:       Time: 01:38:25
14:10:24:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:10:24:WU02:FS00:0xa7:     Branch: master
14:10:24:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:10:24:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:10:24:WU02:FS00:0xa7:   Platform: win32 10
14:10:24:WU02:FS00:0xa7:       Bits: 64
14:10:24:WU02:FS00:0xa7:       Mode: Release
14:10:24:WU02:FS00:0xa7:************************************ System ************************************
14:10:24:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
14:10:24:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
14:10:24:WU02:FS00:0xa7:       CPUs: 4
14:10:25:WU02:FS00:0xa7:     Memory: 7.92GiB
14:10:25:WU02:FS00:0xa7:Free Memory: 3.67GiB
14:10:25:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:10:25:WU02:FS00:0xa7: OS Version: 6.2
14:10:25:WU02:FS00:0xa7:Has Battery: true
14:10:25:WU02:FS00:0xa7: On Battery: false
14:10:25:WU02:FS00:0xa7: UTC Offset: 1
14:10:25:WU02:FS00:0xa7:        PID: 15508
14:10:25:WU02:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
14:10:25:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:10:25:WU02:FS00:0xa7:    Version: 0.0.18
14:10:25:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:10:25:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:10:25:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:10:25:WU02:FS00:0xa7:       Date: Oct 26 2019
14:10:25:WU02:FS00:0xa7:       Time: 01:52:30
14:10:25:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:10:25:WU02:FS00:0xa7:     Branch: master
14:10:25:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:10:25:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:10:25:WU02:FS00:0xa7:   Platform: win32 10
14:10:25:WU02:FS00:0xa7:       Bits: 64
14:10:25:WU02:FS00:0xa7:       Mode: Release
14:10:25:WU02:FS00:0xa7:************************************ Build *************************************
14:10:25:WU02:FS00:0xa7:       SIMD: avx_256
14:10:25:WU02:FS00:0xa7:********************************************************************************
14:10:25:WU02:FS00:0xa7:Project: 16422 (Run 5780, Clone 0, Gen 37)
14:10:25:WU02:FS00:0xa7:Unit: 0x0000002796880e6e5e8bd9c93eaa366b
14:10:25:WU02:FS00:0xa7:Digital signatures verified
14:10:25:WU02:FS00:0xa7:Calling: mdrun -s frame37.tpr -o frame37.trr -x frame37.xtc -cpi state.cpt -cpt 15 -nt 1
14:10:25:WU02:FS00:0xa7:ERROR:Guru Meditation #b9786feb5b3a1998.5ef967d07c3494bd (275228.296460) '02/01/frame37.xtc'
14:10:25:WU02:FS00:0xa7:WARNING:Unexpected exit() call
14:10:25:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
14:10:25:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
14:10:25:WU02:FS00:0xa7:Saving result file frame37.trr
14:10:25:WU02:FS00:0xa7:Saving result file frame37.xtc
14:10:28:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:10:28:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
14:10:28:WU02:FS00:Starting
14:10:28:WARNING:WU02:FS00:AS lowered CPUs from 2 to 1
14:10:28:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 1
14:10:28:WU02:FS00:Started FahCore on PID 13572
14:10:28:WU02:FS00:Core PID:12352
14:10:28:WU02:FS00:FahCore 0xa7 started
14:10:29:WU02:FS00:0xa7:*********************** Log Started 2020-04-17T14:10:28Z ***********************
14:10:29:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:10:29:WU02:FS00:0xa7:       Type: 0xa7
14:10:29:WU02:FS00:0xa7:       Core: Gromacs
14:10:29:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 13572 -checkpoint 15 -np
14:10:29:WU02:FS00:0xa7:             1
14:10:29:WU02:FS00:0xa7:************************************ CBang *************************************
14:10:29:WU02:FS00:0xa7:       Date: Oct 26 2019
14:10:29:WU02:FS00:0xa7:       Time: 01:38:25
14:10:29:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:10:29:WU02:FS00:0xa7:     Branch: master
14:10:29:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:10:29:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:10:29:WU02:FS00:0xa7:   Platform: win32 10
14:10:29:WU02:FS00:0xa7:       Bits: 64
14:10:29:WU02:FS00:0xa7:       Mode: Release
14:10:29:WU02:FS00:0xa7:************************************ System ************************************
14:10:29:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
14:10:29:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
14:10:29:WU02:FS00:0xa7:       CPUs: 4
14:10:29:WU02:FS00:0xa7:     Memory: 7.92GiB
14:10:29:WU02:FS00:0xa7:Free Memory: 3.56GiB
14:10:29:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:10:29:WU02:FS00:0xa7: OS Version: 6.2
14:10:29:WU02:FS00:0xa7:Has Battery: true
14:10:29:WU02:FS00:0xa7: On Battery: false
14:10:29:WU02:FS00:0xa7: UTC Offset: 1
14:10:29:WU02:FS00:0xa7:        PID: 12352
14:10:29:WU02:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
14:10:29:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:10:29:WU02:FS00:0xa7:    Version: 0.0.18
14:10:29:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:10:29:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:10:29:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:10:29:WU02:FS00:0xa7:       Time: 01:52:30
14:10:29:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:10:29:WU02:FS00:0xa7:************************************ Build *************************************
14:10:29:WU02:FS00:0xa7:       SIMD: avx_256
14:10:29:WU02:FS00:0xa7:********************************************************************************
14:10:29:WU02:FS00:0xa7:Project: 16422 (Run 5780, Clone 0, Gen 37)
14:10:29:WU02:FS00:0xa7:Unit: 0x0000002796880e6e5e8bd9c93eaa366b
14:10:29:WU02:FS00:0xa7:Digital signatures verified
14:10:29:WU02:FS00:0xa7:Calling: mdrun -s frame37.tpr -o frame37.trr -x frame37.xtc -cpi state.cpt -cpt 15 -nt 1
14:10:29:WU02:FS00:0xa7:ERROR:Guru Meditation #b9786feb5b3a1998.5ef967d07c3494bd (275228.296460) '02/01/frame37.xtc'
14:10:29:WU02:FS00:0xa7:WARNING:Unexpected exit() call
14:10:29:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
14:10:29:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
14:10:29:WU02:FS00:0xa7:Saving result file frame37.trr
14:10:29:WU02:FS00:0xa7:Saving result file frame37.xtc
14:10:31:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:10:31:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
14:10:39:9:127.0.0.1:New Web session
14:10:43:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
14:10:43:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:11:28:WU02:FS00:Starting
14:11:28:WARNING:WU02:FS00:AS lowered CPUs from 2 to 1
14:11:28:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 1
14:11:28:WU02:FS00:Started FahCore on PID 7732
14:11:28:WU02:FS00:Core PID:2132
14:11:28:WU02:FS00:FahCore 0xa7 started
14:11:29:WU02:FS00:0xa7:*********************** Log Started 2020-04-17T14:11:28Z ***********************
14:11:29:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:11:29:WU02:FS00:0xa7:       Type: 0xa7
14:11:29:WU02:FS00:0xa7:       Core: Gromacs
14:11:29:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 7732 -checkpoint 15 -np 1
14:11:29:WU02:FS00:0xa7:************************************ CBang *************************************
14:11:29:WU02:FS00:0xa7:       Date: Oct 26 2019
14:11:29:WU02:FS00:0xa7:       Time: 01:38:25
14:11:29:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:11:29:WU02:FS00:0xa7:     Branch: master
14:11:29:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:11:29:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:11:29:WU02:FS00:0xa7:   Platform: win32 10
14:11:29:WU02:FS00:0xa7:       Bits: 64
14:11:29:WU02:FS00:0xa7:       Mode: Release
14:11:29:WU02:FS00:0xa7:************************************ System ************************************
14:11:29:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
14:11:29:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
14:11:29:WU02:FS00:0xa7:       CPUs: 4
14:11:29:WU02:FS00:0xa7:     Memory: 7.92GiB
14:11:29:WU02:FS00:0xa7:Free Memory: 3.16GiB
14:11:29:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:11:29:WU02:FS00:0xa7: OS Version: 6.2
14:11:29:WU02:FS00:0xa7:Has Battery: true
14:11:29:WU02:FS00:0xa7: On Battery: false
14:11:29:WU02:FS00:0xa7: UTC Offset: 1
14:11:29:WU02:FS00:0xa7:        PID: 2132
14:11:29:WU02:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
14:11:29:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:11:29:WU02:FS00:0xa7:    Version: 0.0.18
14:11:29:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:11:29:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:11:29:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:11:29:WU02:FS00:0xa7:       Time: 01:52:30
14:11:29:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:11:29:WU02:FS00:0xa7:************************************ Build *************************************
14:11:29:WU02:FS00:0xa7:       SIMD: avx_256
14:11:29:WU02:FS00:0xa7:********************************************************************************
14:11:29:WU02:FS00:0xa7:Project: 16422 (Run 5780, Clone 0, Gen 37)
14:11:29:WU02:FS00:0xa7:Unit: 0x0000002796880e6e5e8bd9c93eaa366b
14:11:29:WU02:FS00:0xa7:Digital signatures verified
14:11:29:WU02:FS00:0xa7:Calling: mdrun -s frame37.tpr -o frame37.trr -x frame37.xtc -cpi state.cpt -cpt 15 -nt 1
14:11:29:WU02:FS00:0xa7:ERROR:Guru Meditation #b9786feb5b3a1998.5ef967d07c3494bd (275228.296460) '02/01/frame37.xtc'
14:11:29:WU02:FS00:0xa7:WARNING:Unexpected exit() call
14:11:29:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
14:11:29:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
14:11:29:WU02:FS00:0xa7:Saving result file frame37.trr
14:11:29:WU02:FS00:0xa7:Saving result file frame37.xtc
14:11:30:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:11:30:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
14:12:28:WU02:FS00:Starting
14:12:28:WARNING:WU02:FS00:AS lowered CPUs from 2 to 1
14:12:28:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 1
14:12:28:WU02:FS00:Started FahCore on PID 17256
14:12:28:WU02:FS00:Core PID:13740
14:12:28:WU02:FS00:FahCore 0xa7 started
14:12:29:WU02:FS00:0xa7:*********************** Log Started 2020-04-17T14:12:28Z ***********************
14:12:29:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:12:29:WU02:FS00:0xa7:       Type: 0xa7
14:12:29:WU02:FS00:0xa7:       Core: Gromacs
14:12:29:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 17256 -checkpoint 15 -np
14:12:29:WU02:FS00:0xa7:             1
14:12:29:WU02:FS00:0xa7:************************************ CBang *************************************
14:12:29:WU02:FS00:0xa7:       Date: Oct 26 2019
14:12:29:WU02:FS00:0xa7:       Time: 01:38:25
14:12:29:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:12:29:WU02:FS00:0xa7:     Branch: master
14:12:29:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
14:12:29:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:12:29:WU02:FS00:0xa7:   Platform: win32 10
14:12:29:WU02:FS00:0xa7:       Bits: 64
14:12:29:WU02:FS00:0xa7:       Mode: Release
14:12:29:WU02:FS00:0xa7:************************************ System ************************************
14:12:29:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
14:12:29:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
14:12:29:WU02:FS00:0xa7:       CPUs: 4
14:12:29:WU02:FS00:0xa7:     Memory: 7.92GiB
14:12:29:WU02:FS00:0xa7:Free Memory: 3.24GiB
14:12:29:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
14:12:29:WU02:FS00:0xa7: OS Version: 6.2
14:12:29:WU02:FS00:0xa7:Has Battery: true
14:12:29:WU02:FS00:0xa7: On Battery: false
14:12:29:WU02:FS00:0xa7: UTC Offset: 1
14:12:29:WU02:FS00:0xa7:        PID: 13740
14:12:29:WU02:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
14:12:29:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
14:12:29:WU02:FS00:0xa7:    Version: 0.0.18
14:12:29:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:12:29:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:12:29:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
14:12:29:WU02:FS00:0xa7:       Time: 01:52:30
14:12:29:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:12:29:WU02:FS00:0xa7:************************************ Build *************************************
14:12:29:WU02:FS00:0xa7:       SIMD: avx_256
14:12:29:WU02:FS00:0xa7:********************************************************************************
14:12:29:WU02:FS00:0xa7:Project: 16422 (Run 5780, Clone 0, Gen 37)
14:12:29:WU02:FS00:0xa7:Unit: 0x0000002796880e6e5e8bd9c93eaa366b
14:12:29:WU02:FS00:0xa7:Digital signatures verified
14:12:29:WU02:FS00:0xa7:Calling: mdrun -s frame37.tpr -o frame37.trr -x frame37.xtc -cpi state.cpt -cpt 15 -nt 1
14:12:29:WU02:FS00:0xa7:ERROR:Guru Meditation #b9786feb5b3a1998.5ef967d07c3494bd (275228.296460) '02/01/frame37.xtc'
14:12:29:WU02:FS00:0xa7:WARNING:Unexpected exit() call
14:12:29:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
14:12:29:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
14:12:29:WU02:FS00:0xa7:Saving result file frame37.trr
14:12:29:WU02:FS00:0xa7:Saving result file frame37.xtc
14:12:31:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:12:32:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
14:12:32:WARNING:WU02:FS00:Too many errors, failing
14:12:32:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:16422 run:5780 clone:0 gen:37 core:0xa7 unit:0x0000002796880e6e5e8bd9c93eaa366b
14:12:32:WU02:FS00:Connecting to 150.136.14.110:8080
14:12:32:WU00:FS00:Connecting to 65.254.110.245:80
14:12:33:WU02:FS00:Server responded WORK_ACK (400)
14:12:33:WU02:FS00:Cleaning up
14:12:34:WU00:FS00:Assigned to work server 13.90.152.57
14:12:34:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 13.90.152.57
14:12:34:WU00:FS00:Connecting to 13.90.152.57:8080
14:12:37:WU00:FS00:Downloading 4.50MiB
14:12:39:WU00:FS00:Download complete
14:12:39:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:1798 gen:55 core:0xa7 unit:0x000000410d5a98395e72df54225d7025
14:12:39:WU00:FS00:Starting
14:12:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 2
14:12:39:WU00:FS00:Started FahCore on PID 10520
14:12:39:WU00:FS00:Core PID:12556
14:12:39:WU00:FS00:FahCore 0xa7 started
14:12:40:WU00:FS00:0xa7:*********************** Log Started 2020-04-17T14:12:39Z ***********************
14:12:40:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:12:40:WU00:FS00:0xa7:       Type: 0xa7
14:12:40:WU00:FS00:0xa7:       Core: Gromacs
14:12:40:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10520 -checkpoint 15 -np
14:12:40:WU00:FS00:0xa7:             2
14:12:40:WU00:FS00:0xa7:************************************ CBang *************************************
14:12:40:WU00:FS00:0xa7:       Date: Oct 26 2019
14:12:40:WU00:FS00:0xa7:       Time: 01:38:25
14:12:40:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:12:40:WU00:FS00:0xa7:     Branch: master
14:12:40:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:12:40:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:12:40:WU00:FS00:0xa7:   Platform: win32 10
14:12:40:WU00:FS00:0xa7:       Bits: 64
14:12:40:WU00:FS00:0xa7:       Mode: Release
14:12:40:WU00:FS00:0xa7:************************************ System ************************************
14:12:40:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
14:12:40:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
14:12:40:WU00:FS00:0xa7:       CPUs: 4
14:12:40:WU00:FS00:0xa7:     Memory: 7.92GiB
14:12:40:WU00:FS00:0xa7:Free Memory: 3.24GiB
14:12:40:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:12:40:WU00:FS00:0xa7: OS Version: 6.2
14:12:40:WU00:FS00:0xa7:Has Battery: true
14:12:40:WU00:FS00:0xa7: On Battery: false
14:12:40:WU00:FS00:0xa7: UTC Offset: 1
14:12:40:WU00:FS00:0xa7:        PID: 12556
14:12:40:WU00:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
14:12:40:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:12:40:WU00:FS00:0xa7:    Version: 0.0.18
14:12:40:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:12:40:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:12:40:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:12:40:WU00:FS00:0xa7:       Time: 01:52:30
14:12:40:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:12:40:WU00:FS00:0xa7:************************************ Build *************************************
14:12:40:WU00:FS00:0xa7:       SIMD: avx_256
14:12:40:WU00:FS00:0xa7:********************************************************************************
14:12:40:WU00:FS00:0xa7:Project: 13860 (Run 0, Clone 1798, Gen 55)
14:12:40:WU00:FS00:0xa7:Unit: 0x000000410d5a98395e72df54225d7025
14:12:40:WU00:FS00:0xa7:Reading tar file core.xml
14:12:40:WU00:FS00:0xa7:Reading tar file frame55.tpr
14:12:40:WU00:FS00:0xa7:Digital signatures verified
14:12:40:WU00:FS00:0xa7:Calling: mdrun -s frame55.tpr -o frame55.trr -x frame55.xtc -e frame55.edr -cpt 15 -nt 2
14:12:40:WU00:FS00:0xa7:Steps: first=6875000 total=125000
14:12:42:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
14:15:53:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
14:18:48:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
18:48:53:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
18:51:34:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
18:51:35:WU02:FS00:Connecting to 65.254.110.245:80
18:51:36:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:51:36:WU02:FS00:Connecting to 18.218.241.186:80
18:51:36:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:51:36:WU02:FS00:Connecting to 65.254.110.245:80
18:51:36:WU02:FS00:Assigned to work server 13.90.152.57
18:51:36:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 13.90.152.57
18:51:36:WU02:FS00:Connecting to 13.90.152.57:8080
18:51:48:WU02:FS00:Downloading 4.50MiB
18:51:49:WU02:FS00:Download complete
18:51:49:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:24798 gen:14 core:0xa7 unit:0x000000100d5a98395e9409ecb4d149ee
18:53:35:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
18:54:13:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
18:54:19:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
18:54:19:WU00:FS00:0xa7:Saving result file frame55.edr
18:54:19:WU00:FS00:0xa7:Saving result file frame55.trr
18:54:19:WU00:FS00:0xa7:Saving result file frame55.xtc
18:54:19:WU00:FS00:0xa7:Saving result file md.log
18:54:19:WU00:FS00:0xa7:Saving result file science.log
18:54:19:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:54:19:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:54:20:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13860 run:0 clone:1798 gen:55 core:0xa7 unit:0x000000410d5a98395e72df54225d7025
18:54:20:WU00:FS00:Uploading 5.51MiB to 13.90.152.57
18:54:20:WU02:FS00:Starting
18:54:20:WU00:FS00:Connecting to 13.90.152.57:8080
18:54:20:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 2
18:54:21:WU02:FS00:Started FahCore on PID 8840
18:54:21:WU02:FS00:Core PID:10732
18:54:21:WU02:FS00:FahCore 0xa7 started
18:54:22:WU02:FS00:0xa7:*********************** Log Started 2020-04-17T18:54:22Z ***********************
18:54:22:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:54:22:WU02:FS00:0xa7:       Type: 0xa7
18:54:22:WU02:FS00:0xa7:       Core: Gromacs
18:54:22:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 8840 -checkpoint 15 -np 2
18:54:22:WU02:FS00:0xa7:************************************ CBang *************************************
18:54:22:WU02:FS00:0xa7:       Date: Oct 26 2019
18:54:22:WU02:FS00:0xa7:       Time: 01:38:25
18:54:22:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:54:23:WU02:FS00:0xa7:     Branch: master
18:54:23:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
18:54:23:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:54:23:WU02:FS00:0xa7:   Platform: win32 10
18:54:23:WU02:FS00:0xa7:       Bits: 64
18:54:23:WU02:FS00:0xa7:       Mode: Release
18:54:23:WU02:FS00:0xa7:************************************ System ************************************
18:54:23:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
18:54:23:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
18:54:23:WU02:FS00:0xa7:       CPUs: 4
18:54:23:WU02:FS00:0xa7:     Memory: 7.92GiB
18:54:23:WU02:FS00:0xa7:Free Memory: 2.96GiB
18:54:23:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
18:54:23:WU02:FS00:0xa7: OS Version: 6.2
18:54:23:WU02:FS00:0xa7:Has Battery: true
18:54:23:WU02:FS00:0xa7: On Battery: false
18:54:23:WU02:FS00:0xa7: UTC Offset: 1
18:54:23:WU02:FS00:0xa7:        PID: 10732
18:54:23:WU02:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
18:54:23:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
18:54:23:WU02:FS00:0xa7:    Version: 0.0.18
18:54:23:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:54:23:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:54:23:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
18:54:23:WU02:FS00:0xa7:       Date: Oct 26 2019
18:54:23:WU02:FS00:0xa7:       Time: 01:52:30
18:54:23:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:54:23:WU02:FS00:0xa7:************************************ Build *************************************
18:54:23:WU02:FS00:0xa7:       SIMD: avx_256
18:54:23:WU02:FS00:0xa7:********************************************************************************
18:54:23:WU02:FS00:0xa7:Project: 13860 (Run 0, Clone 24798, Gen 14)
18:54:23:WU02:FS00:0xa7:Unit: 0x000000100d5a98395e9409ecb4d149ee
18:54:23:WU02:FS00:0xa7:Reading tar file core.xml
18:54:23:WU02:FS00:0xa7:Reading tar file frame14.tpr
18:54:23:WU02:FS00:0xa7:Digital signatures verified
18:54:23:WU02:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -x frame14.xtc -e frame14.edr -cpt 15 -nt 2
18:54:23:WU02:FS00:0xa7:Steps: first=1750000 total=125000
18:54:25:WU02:FS00:0xa7:Completed 1 out of 125000 steps (0%)
18:54:36:WU00:FS00:Upload complete
18:54:36:WU00:FS00:Server responded WORK_ACK (400)
18:54:36:WU00:FS00:Final credit estimate, 1480.00 points
18:54:36:WU00:FS00:Cleaning up
18:57:20:WU02:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
19:00:19:WU02:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
23:44:42:WU02:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
23:44:43:WU00:FS00:Connecting to 65.254.110.245:80
23:44:44:WU00:FS00:Assigned to work server 168.245.198.125
23:44:44:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 168.245.198.125
23:44:44:WU00:FS00:Connecting to 168.245.198.125:8080
23:44:44:ERROR:WU00:FS00:Exception: Server did not assign work unit
23:44:44:WU00:FS00:Connecting to 65.254.110.245:80
23:44:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
23:44:45:WU00:FS00:Connecting to 18.218.241.186:80
23:44:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:44:45:WU00:FS00:Connecting to 65.254.110.245:80
23:44:46:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
23:44:46:WU00:FS00:Connecting to 18.218.241.186:80
23:44:46:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:44:46:ERROR:WU00:FS00:Exception: Could not get an assignment
23:45:45:WU00:FS00:Connecting to 65.254.110.245:80
23:45:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
23:45:45:WU00:FS00:Connecting to 18.218.241.186:80
23:45:45:WU00:FS00:Assigned to work server 13.90.152.57
23:45:45:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 13.90.152.57
23:45:45:WU00:FS00:Connecting to 13.90.152.57:8080
23:45:47:WU00:FS00:Downloading 4.50MiB
23:45:52:WU00:FS00:Download complete
23:45:53:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:3338 gen:56 core:0xa7 unit:0x000000420d5a98395e72deeb563adc36
23:47:30:WU02:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
23:47:35:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
23:47:35:WU02:FS00:0xa7:Saving result file frame14.edr
23:47:35:WU02:FS00:0xa7:Saving result file frame14.trr
23:47:35:WU02:FS00:0xa7:Saving result file frame14.xtc
23:47:35:WU02:FS00:0xa7:Saving result file md.log
23:47:35:WU02:FS00:0xa7:Saving result file science.log
23:47:35:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
23:47:36:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:47:36:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13860 run:0 clone:24798 gen:14 core:0xa7 unit:0x000000100d5a98395e9409ecb4d149ee
23:47:36:WU02:FS00:Uploading 5.48MiB to 13.90.152.57
23:47:36:WU00:FS00:Starting
23:47:36:WU02:FS00:Connecting to 13.90.152.57:8080
23:47:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 2
23:47:37:WU00:FS00:Started FahCore on PID 7092
23:47:37:WU00:FS00:Core PID:9800
23:47:37:WU00:FS00:FahCore 0xa7 started
23:47:39:WU00:FS00:0xa7:*********************** Log Started 2020-04-17T23:47:38Z ***********************
23:47:39:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:47:39:WU00:FS00:0xa7:       Type: 0xa7
23:47:39:WU00:FS00:0xa7:       Core: Gromacs
23:47:39:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7092 -checkpoint 15 -np 2
23:47:39:WU00:FS00:0xa7:************************************ CBang *************************************
23:47:39:WU00:FS00:0xa7:       Date: Oct 26 2019
23:47:39:WU00:FS00:0xa7:       Time: 01:38:25
23:47:39:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
23:47:39:WU00:FS00:0xa7:     Branch: master
23:47:39:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
23:47:39:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:47:39:WU00:FS00:0xa7:   Platform: win32 10
23:47:39:WU00:FS00:0xa7:       Bits: 64
23:47:39:WU00:FS00:0xa7:       Mode: Release
23:47:39:WU00:FS00:0xa7:************************************ System ************************************
23:47:39:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
23:47:39:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
23:47:39:WU00:FS00:0xa7:       CPUs: 4
23:47:39:WU00:FS00:0xa7:     Memory: 7.92GiB
23:47:39:WU00:FS00:0xa7:Free Memory: 3.94GiB
23:47:39:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:47:39:WU00:FS00:0xa7: OS Version: 6.2
23:47:39:WU00:FS00:0xa7:Has Battery: true
23:47:39:WU00:FS00:0xa7: On Battery: false
23:47:39:WU00:FS00:0xa7: UTC Offset: 1
23:47:39:WU00:FS00:0xa7:        PID: 9800
23:47:39:WU00:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
23:47:39:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
23:47:39:WU00:FS00:0xa7:    Version: 0.0.18
23:47:39:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:47:39:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
23:47:39:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
23:47:39:WU00:FS00:0xa7:       Time: 01:52:30
23:47:39:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
23:47:39:WU00:FS00:0xa7:************************************ Build *************************************
23:47:39:WU00:FS00:0xa7:       SIMD: avx_256
23:47:39:WU00:FS00:0xa7:********************************************************************************
23:47:39:WU00:FS00:0xa7:Project: 13860 (Run 0, Clone 3338, Gen 56)
23:47:39:WU00:FS00:0xa7:Unit: 0x000000420d5a98395e72deeb563adc36
23:47:39:WU00:FS00:0xa7:Reading tar file core.xml
23:47:39:WU00:FS00:0xa7:Reading tar file frame56.tpr
23:47:39:WU00:FS00:0xa7:Digital signatures verified
23:47:39:WU00:FS00:0xa7:Calling: mdrun -s frame56.tpr -o frame56.trr -x frame56.xtc -e frame56.edr -cpt 15 -nt 2
23:47:39:WU00:FS00:0xa7:Steps: first=7000000 total=125000
23:47:42:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
23:47:52:WU02:FS00:Upload complete
23:47:52:WU02:FS00:Server responded WORK_ACK (400)
23:47:52:WU02:FS00:Final credit estimate, 1444.00 points
23:47:52:WU02:FS00:Cleaning up
23:50:19:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
23:52:54:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
<>8.119
04:05:40:WU02:FS00:Connecting to 13.82.98.119:8080
04:06:01:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
04:06:02:WU02:FS00:Connecting to 65.254.110.245:80
04:06:02:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
04:06:02:WU02:FS00:Connecting to 18.218.241.186:80
04:06:02:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:06:03:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
04:06:03:WU02:FS00:Connecting to 18.218.241.186:80
04:06:03:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:06:03:ERROR:WU02:FS00:Exception: Could not get an assignment
04:07:02:WU02:FS00:Connecting to 65.254.110.245:80
04:07:02:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
04:07:02:WU02:FS00:Connecting to 18.218.241.186:80
04:07:02:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:07:03:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
04:07:03:WU02:FS00:Connecting to 18.218.241.186:80
04:07:03:WU02:FS00:Assigned to work server 155.247.164.214
04:07:03:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 155.247.164.214
04:07:03:WU02:FS00:Connecting to 155.247.164.214:8080
04:07:03:WU02:FS00:Downloading 2.82MiB
04:07:04:WU02:FS00:Download complete
04:07:05:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14628 run:1966 clone:4 gen:18 core:0xa7 unit:0x000000149bf7a4d65e88b1fcf30dbf21
04:08:17:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
04:08:22:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
04:08:22:WU00:FS00:0xa7:Saving result file frame56.edr
04:08:22:WU00:FS00:0xa7:Saving result file frame56.trr
04:08:22:WU00:FS00:0xa7:Saving result file frame56.xtc
04:08:22:WU00:FS00:0xa7:Saving result file md.log
04:08:22:WU00:FS00:0xa7:Saving result file science.log
04:08:22:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
04:08:23:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:08:23:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13860 run:0 clone:3338 gen:56 core:0xa7 unit:0x000000420d5a98395e72deeb563adc36
04:08:23:WU00:FS00:Uploading 5.49MiB to 13.90.152.57
*Wirralgirl*
Log file (2)of 2
Any advice appreciated.
Thanks
12:00:53:WU00:FS00:Starting
12:00:53:WU02:FS00:Connecting to 155.247.164.214:8080
12:00:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 2
12:00:54:WU00:FS00:Started FahCore on PID 4184
12:00:54:WU00:FS00:Core PID:3452
12:00:54:WU00:FS00:FahCore 0xa7 started
12:00:55:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T12:00:54Z ***********************
12:00:55:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:00:55:WU00:FS00:0xa7:       Type: 0xa7
12:00:55:WU00:FS00:0xa7:       Core: Gromacs
12:00:55:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 4184 -checkpoint 15 -np 2
12:00:55:WU00:FS00:0xa7:************************************ CBang *************************************
12:00:55:WU00:FS00:0xa7:       Date: Oct 26 2019
12:00:55:WU00:FS00:0xa7:       Time: 01:38:25
12:00:55:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:00:55:WU00:FS00:0xa7:     Branch: master
12:00:55:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:00:55:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:00:55:WU00:FS00:0xa7:   Platform: win32 10
12:00:55:WU00:FS00:0xa7:       Bits: 64
12:00:55:WU00:FS00:0xa7:       Mode: Release
12:00:55:WU00:FS00:0xa7:************************************ System ************************************
12:00:55:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
12:00:55:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
12:00:55:WU00:FS00:0xa7:       CPUs: 4
12:00:55:WU00:FS00:0xa7:     Memory: 7.92GiB
12:00:55:WU00:FS00:0xa7:Free Memory: 2.79GiB
12:00:55:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:00:55:WU00:FS00:0xa7: OS Version: 6.2
12:00:55:WU00:FS00:0xa7:Has Battery: true
12:00:55:WU00:FS00:0xa7: On Battery: false
12:00:55:WU00:FS00:0xa7: UTC Offset: 1
12:00:55:WU00:FS00:0xa7:        PID: 3452
12:00:55:WU00:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
12:00:55:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:00:55:WU00:FS00:0xa7:    Version: 0.0.18
12:00:55:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:00:55:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:00:55:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:00:55:WU00:FS00:0xa7:       Time: 01:52:30
12:00:55:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:00:55:WU00:FS00:0xa7:************************************ Build *************************************
12:00:55:WU00:FS00:0xa7:       SIMD: avx_256
12:00:55:WU00:FS00:0xa7:********************************************************************************
12:00:55:WU00:FS00:0xa7:Project: 14380 (Run 1619, Clone 1, Gen 7)
12:00:55:WU00:FS00:0xa7:Unit: 0x00000007455e42075e932e73ab859061
12:00:55:WU00:FS00:0xa7:Reading tar file core.xml
12:00:55:WU00:FS00:0xa7:Reading tar file frame7.tpr
12:00:55:WU00:FS00:0xa7:Digital signatures verified
12:00:55:WU00:FS00:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -cpt 15 -nt 2
12:00:55:WU00:FS00:0xa7:Steps: first=0 total=2500000
12:00:56:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
12:01:05:WU02:FS00:Upload complete
12:01:05:WU02:FS00:Server responded WORK_ACK (400)
12:01:05:WU02:FS00:Final credit estimate, 2362.00 points
12:01:05:WU02:FS00:Cleaning up
12:04:39:WU00:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
12:07:54:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
12:08:20:WU00:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
18:18:12:WU00:FS00:0xa7:Completed 2425000 out of 2500000 steps (97%)
18:21:55:WU00:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
18:25:39:WU00:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
18:25:40:WU02:FS00:Connecting to 65.254.110.245:80
18:25:41:WU02:FS00:Assigned to work server 128.252.203.9
18:25:41:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 128.252.203.9
18:25:41:WU02:FS00:Connecting to 128.252.203.9:8080
18:26:02:ERROR:WU02:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
18:26:02:WU02:FS00:Connecting to 65.254.110.245:80
18:26:02:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:26:02:WU02:FS00:Connecting to 18.218.241.186:80
18:26:03:WU02:FS00:Assigned to work server 155.247.164.213
18:26:03:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 155.247.164.213
18:26:03:WU02:FS00:Connecting to 155.247.164.213:8080
18:26:27:WU02:FS00:Downloading 1.23MiB
18:26:29:WU02:FS00:Download complete
18:26:29:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14198 run:4 clone:959 gen:73 core:0xa7 unit:0x0000004e9bf7a4d55e66cf8f7081ce0a
18:29:19:WU00:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
18:29:20:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
18:29:20:WU00:FS00:0xa7:Saving result file dhdl.xvg
18:29:20:WU00:FS00:0xa7:Saving result file frame7.trr
18:29:20:WU00:FS00:0xa7:Saving result file md.log
18:29:20:WU00:FS00:0xa7:Saving result file science.log
18:29:20:WU00:FS00:0xa7:Saving result file traj_comp.xtc
18:29:21:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:29:21:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:29:21:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14380 run:1619 clone:1 gen:7 core:0xa7 unit:0x00000007455e42075e932e73ab859061
18:29:21:WU00:FS00:Uploading 8.21MiB to 69.94.66.7
18:29:21:WU02:FS00:Starting
18:29:21:WU00:FS00:Connecting to 69.94.66.7:8080
18:29:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 2
18:29:21:WU02:FS00:Started FahCore on PID 920
18:29:22:WU02:FS00:Core PID:2704
18:29:22:WU02:FS00:FahCore 0xa7 started
18:29:22:WU02:FS00:0xa7:*********************** Log Started 2020-04-18T18:29:22Z ***********************
18:29:22:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:29:22:WU02:FS00:0xa7:       Type: 0xa7
18:29:22:WU02:FS00:0xa7:       Core: Gromacs
18:29:22:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 706 -lifeline 920 -checkpoint 15 -np 2
18:29:22:WU02:FS00:0xa7:************************************ CBang *************************************
18:29:22:WU02:FS00:0xa7:       Date: Oct 26 2019
18:29:22:WU02:FS00:0xa7:       Time: 01:38:25
18:29:22:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:29:22:WU02:FS00:0xa7:     Branch: master
18:29:22:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
18:29:22:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:29:22:WU02:FS00:0xa7:   Platform: win32 10
18:29:22:WU02:FS00:0xa7:       Bits: 64
18:29:22:WU02:FS00:0xa7:       Mode: Release
18:29:22:WU02:FS00:0xa7:************************************ System ************************************
18:29:22:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
18:29:22:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
18:29:22:WU02:FS00:0xa7:       CPUs: 4
18:29:22:WU02:FS00:0xa7:     Memory: 7.92GiB
18:29:22:WU02:FS00:0xa7:Free Memory: 2.20GiB
18:29:22:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
18:29:22:WU02:FS00:0xa7: OS Version: 6.2
18:29:22:WU02:FS00:0xa7:Has Battery: true
18:29:22:WU02:FS00:0xa7: On Battery: false
18:29:22:WU02:FS00:0xa7: UTC Offset: 1
18:29:22:WU02:FS00:0xa7:        PID: 2704
18:29:22:WU02:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
18:29:22:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
18:29:22:WU02:FS00:0xa7:    Version: 0.0.18
18:29:22:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:29:22:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:29:22:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
18:29:22:WU02:FS00:0xa7:       Time: 01:52:30
18:29:22:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:29:22:WU02:FS00:0xa7:************************************ Build *************************************
18:29:22:WU02:FS00:0xa7:       SIMD: avx_256
18:29:22:WU02:FS00:0xa7:********************************************************************************
18:29:22:WU02:FS00:0xa7:Project: 14198 (Run 4, Clone 959, Gen 73)
18:29:22:WU02:FS00:0xa7:Unit: 0x0000004e9bf7a4d55e66cf8f7081ce0a
18:29:22:WU02:FS00:0xa7:Reading tar file core.xml
18:29:22:WU02:FS00:0xa7:Reading tar file frame73.tpr
18:29:22:WU02:FS00:0xa7:Digital signatures verified
18:29:22:WU02:FS00:0xa7:Calling: mdrun -s frame73.tpr -o frame73.trr -cpt 15 -nt 2
18:29:22:WU02:FS00:0xa7:Steps: first=36500000 total=500000
18:29:23:WU02:FS00:0xa7:Completed 1 out of 500000 steps (0%)
18:29:30:WU00:FS00:Upload complete
18:29:30:WU00:FS00:Server responded WORK_ACK (400)
18:29:30:WU00:FS00:Final credit estimate, 2178.00 points
18:29:30:WU00:FS00:Cleaning up
18:29:53:118:127.0.0.1:New Web session
18:31:38:WU02:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
18:33:41:WU02:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
18:35:35:WU01:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
18:35:36:WU00:FS01:Connecting to 65.254.110.245:80
18:35:36:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:35:36:WU00:FS01:Connecting to 18.218.241.186:80
18:35:37:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:35:37:WU00:FS01:Connecting to 65.254.110.245:80
18:35:37:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:35:37:WU00:FS01:Connecting to 18.218.241.186:80
18:35:37:ERROR:WU00:FS01:Exception: Could not get an assignment
18:35:38:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:35:38:WU00:FS01:Connecting to 18.218.241.186:80
18:35:38:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:35:38:WU00:FS01:Connecting to 65.254.110.245:80
18:35:38:ERROR:WU00:FS01:Exception: Could not get an assignment
18:35:49:WU02:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
18:36:38:WU00:FS01:Connecting to 65.254.110.245:80
18:36:38:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:36:38:WU00:FS01:Connecting to 18.218.241.186:80
18:36:38:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:36:39:WU00:FS01:Assigned to work server 140.163.4.231
18:36:39:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Mars [Radeon R7 M260/M265/M270] from 140.163.4.231
18:36:39:WU00:FS01:Connecting to 140.163.4.231:8080
18:37:01:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:37:52:WU02:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
18:38:15:WU00:FS01:Connecting to 65.254.110.245:80
18:38:15:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:38:15:WU00:FS01:Connecting to 18.218.241.186:80
18:38:15:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:38:16:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:38:16:WU00:FS01:Connecting to 18.218.241.186:80
18:38:16:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:38:16:ERROR:WU00:FS01:Exception: Could not get an assignment
18:39:59:WU02:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
18:40:52:WU00:FS01:Connecting to 65.254.110.245:80
18:40:52:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:40:52:WU00:FS01:Connecting to 18.218.241.186:80
18:40:53:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:40:53:WU00:FS01:Connecting to 65.254.110.245:80
18:40:53:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:40:53:WU00:FS01:Connecting to 18.218.241.186:80
18:40:53:ERROR:WU00:FS01:Exception: Could not get an assignment
18:42:04:WU02:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
18:44:07:WU02:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
18:45:06:WU00:FS01:Connecting to 65.254.110.245:80
18:45:07:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:45:07:WU00:FS01:Connecting to 18.218.241.186:80
18:45:07:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:45:07:WU00:FS01:Connecting to 65.254.110.245:80
18:45:07:WU00:FS01:Assigned to work server 13.82.98.119
18:45:07:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Mars [Radeon R7 M260/M265/M270] from 13.82.98.119
18:45:07:WU00:FS01:Connecting to 13.82.98.119:8080
18:45:28:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
18:46:13:WU02:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
18:48:16:WU02:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
18:50:21:WU02:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
18:51:58:WU00:FS01:Connecting to 65.254.110.245:80
18:51:58:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
18:51:58:WU00:FS01:Connecting to 18.218.241.186:80
18:51:58:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:51:59:WU00:FS01:Assigned to work server 140.163.4.241
18:51:59:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Mars [Radeon R7 M260/M265/M270] from 140.163.4.241
18:51:59:WU00:FS01:Connecting to 140.163.4.241:8080
18:52:10:WU00:FS01:Downloading 7.93MiB
18:52:16:WU00:FS01:Download 60.72%
18:52:18:WU00:FS01:Download complete
18:52:18:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11745 run:0 clone:2683 gen:67 core:0x22 unit:0x0000005e8ca304f15e6a04b6ac284a17
18:52:25:WU02:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
18:54:27:WU02:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
18:56:35:WU02:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
18:56:57:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
18:57:01:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:57:01:WU01:FS01:0x22:Saving result file checkpointState.xml
18:57:04:WU01:FS01:0x22:Saving result file checkpt.crc
18:57:04:WU01:FS01:0x22:Saving result file positions.xtc
18:57:07:WU01:FS01:0x22:Saving result file science.log
18:57:07:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:57:08:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:57:08:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11742 run:0 clone:210 gen:43 core:0x22 unit:0x000000478ca304f15e66e0849f1e66ae
18:57:08:WU01:FS01:Uploading 12.58MiB to 140.163.4.241
18:57:08:WU00:FS01:Starting
18:57:08:WU01:FS01:Connecting to 140.163.4.241:8080
18:57:08:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
18:57:08:WU00:FS01:Started FahCore on PID 15500
18:57:08:WU00:FS01:Core PID:7576
18:57:08:WU00:FS01:FahCore 0x22 started
18:57:10:WU00:FS01:0x22:*********************** Log Started 2020-04-18T18:57:10Z ***********************
18:57:10:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:57:10:WU00:FS01:0x22:       Type: 0x22
18:57:10:WU00:FS01:0x22:       Core: Core22
18:57:10:WU00:FS01:0x22:    Website: https://foldingathome.org/
18:57:10:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
18:57:10:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:57:10:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
18:57:10:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15500 -checkpoint 15
18:57:10:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
18:57:10:WU00:FS01:0x22:     Config: <none>
18:57:10:WU00:FS01:0x22:************************************ Build *************************************
18:57:10:WU00:FS01:0x22:    Version: 0.0.2
18:57:10:WU00:FS01:0x22:       Date: Dec 6 2019
18:57:10:WU00:FS01:0x22:       Time: 21:30:31
18:57:10:WU00:FS01:0x22: Repository: Git
18:57:10:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:57:10:WU00:FS01:0x22:     Branch: HEAD
18:57:10:WU00:FS01:0x22:   Compiler: Visual C++ 2008
18:57:10:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:57:10:WU00:FS01:0x22:   Platform: win32 10
18:57:10:WU00:FS01:0x22:       Bits: 64
18:57:10:WU00:FS01:0x22:       Mode: Release
18:57:10:WU00:FS01:0x22:************************************ System ************************************
18:57:10:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
18:57:10:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
18:57:10:WU00:FS01:0x22:       CPUs: 4
18:57:10:WU00:FS01:0x22:     Memory: 7.92GiB
18:57:10:WU00:FS01:0x22:Free Memory: 2.63GiB
18:57:10:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
18:57:10:WU00:FS01:0x22: OS Version: 6.2
18:57:10:WU00:FS01:0x22:Has Battery: true
18:57:10:WU00:FS01:0x22: On Battery: false
18:57:10:WU00:FS01:0x22: UTC Offset: 1
18:57:10:WU00:FS01:0x22:        PID: 7576
18:57:10:WU00:FS01:0x22:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
18:57:10:WU00:FS01:0x22:         OS: Windows 10 Home
18:57:10:WU00:FS01:0x22:    OS Arch: AMD64
18:57:10:WU00:FS01:0x22:********************************************************************************
18:57:10:WU00:FS01:0x22:Project: 11745 (Run 0, Clone 2683, Gen 67)
18:57:10:WU00:FS01:0x22:Unit: 0x0000005e8ca304f15e6a04b6ac284a17
18:57:10:WU00:FS01:0x22:Reading tar file core.xml
18:57:10:WU00:FS01:0x22:Reading tar file integrator.xml
18:57:10:WU00:FS01:0x22:Reading tar file state.xml
18:57:13:WU00:FS01:0x22:Reading tar file system.xml
18:57:14:WU00:FS01:0x22:Digital signatures verified
18:57:14:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:57:14:WU00:FS01:0x22:Version 0.0.2
18:57:17:WU01:FS01:Upload 68.08%
18:57:30:WU01:FS01:Upload complete
18:57:30:WU01:FS01:Server responded WORK_ACK (400)
18:57:30:WU01:FS01:Final credit estimate, 12949.00 points
18:57:31:WU01:FS01:Cleaning up
18:57:41:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:57:41:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:03:11:WU02:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
22:05:34:WU02:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
22:07:42:WU02:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
22:07:42:WU01:FS00:Connecting to 65.254.110.245:80
22:07:43:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
22:07:43:WU01:FS00:Connecting to 18.218.241.186:80
22:07:43:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:07:43:WU01:FS00:Connecting to 65.254.110.245:80
22:07:43:WU01:FS00:Assigned to work server 155.247.164.214
22:07:43:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 155.247.164.214
22:07:43:WU01:FS00:Connecting to 155.247.164.214:8080
22:07:44:WU01:FS00:Downloading 2.82MiB
22:07:45:WU01:FS00:Download complete
22:07:45:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14616 run:1465 clone:2 gen:40 core:0xa7 unit:0x0000002e9bf7a4d65e8323e3ce54b946
22:09:48:WU02:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
22:09:49:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
22:09:49:WU02:FS00:0xa7:Saving result file frame73.trr
22:09:49:WU02:FS00:0xa7:Saving result file md.log
22:09:49:WU02:FS00:0xa7:Saving result file pullf.xvg
22:09:49:WU02:FS00:0xa7:Saving result file pullx.xvg
22:09:49:WU02:FS00:0xa7:Saving result file science.log
22:09:49:WU02:FS00:0xa7:Saving result file traj_comp.xtc
22:09:49:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
22:09:50:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:09:50:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14198 run:4 clone:959 gen:73 core:0xa7 unit:0x0000004e9bf7a4d55e66cf8f7081ce0a
22:09:50:WU02:FS00:Uploading 2.64MiB to 155.247.164.213
22:09:50:WU01:FS00:Starting
22:09:50:WU02:FS00:Connecting to 155.247.164.213:8080
22:09:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\spk40\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 4132 -checkpoint 15 -np 2
22:09:51:WU01:FS00:Started FahCore on PID 16348
22:09:51:WU01:FS00:Core PID:17728
22:09:51:WU01:FS00:FahCore 0xa7 started
22:09:52:WU01:FS00:0xa7:*********************** Log Started 2020-04-18T22:09:52Z ***********************
22:09:52:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:09:52:WU01:FS00:0xa7:       Type: 0xa7
22:09:52:WU01:FS00:0xa7:       Core: Gromacs
22:09:52:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 16348 -checkpoint 15 -np
22:09:52:WU01:FS00:0xa7:             2
22:09:52:WU01:FS00:0xa7:************************************ CBang *************************************
22:09:52:WU01:FS00:0xa7:       Date: Oct 26 2019
22:09:52:WU01:FS00:0xa7:       Time: 01:38:25
22:09:52:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:09:52:WU01:FS00:0xa7:     Branch: master
22:09:52:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
22:09:52:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:09:52:WU01:FS00:0xa7:   Platform: win32 10
22:09:52:WU01:FS00:0xa7:       Bits: 64
22:09:52:WU01:FS00:0xa7:       Mode: Release
22:09:52:WU01:FS00:0xa7:************************************ System ************************************
22:09:52:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
22:09:52:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
22:09:52:WU01:FS00:0xa7:       CPUs: 4
22:09:52:WU01:FS00:0xa7:     Memory: 7.92GiB
22:09:52:WU01:FS00:0xa7:Free Memory: 3.29GiB
22:09:52:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
22:09:52:WU01:FS00:0xa7: OS Version: 6.2
22:09:52:WU01:FS00:0xa7:Has Battery: true
22:09:52:WU01:FS00:0xa7: On Battery: false
22:09:52:WU01:FS00:0xa7: UTC Offset: 1
22:09:52:WU01:FS00:0xa7:        PID: 17728
22:09:52:WU01:FS00:0xa7:        CWD: C:\Users\spk40\AppData\Roaming\FAHClient\work
22:09:52:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
22:09:52:WU01:FS00:0xa7:    Version: 0.0.18
22:09:52:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:09:52:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:09:52:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
22:09:52:WU01:FS00:0xa7:       Time: 01:52:30
22:09:52:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:09:52:WU01:FS00:0xa7:************************************ Build *************************************
22:09:52:WU01:FS00:0xa7:       SIMD: avx_256
22:09:52:WU01:FS00:0xa7:********************************************************************************
22:09:52:WU01:FS00:0xa7:Project: 14616 (Run 1465, Clone 2, Gen 40)
22:09:52:WU01:FS00:0xa7:Unit: 0x0000002e9bf7a4d65e8323e3ce54b946
22:09:52:WU01:FS00:0xa7:Reading tar file core.xml
22:09:52:WU01:FS00:0xa7:Reading tar file frame40.tpr
22:09:52:WU01:FS00:0xa7:Digital signatures verified
22:09:52:WU01:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -cpt 15 -nt 2
22:09:52:WU01:FS00:0xa7:Steps: first=0 total=250000
22:09:54:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
22:10:01:FS00:Paused
22:10:01:FS01:Paused
22:10:01:FS00:Shutting core down
22:10:01:FS01:Shutting core down
22:10:02:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 17728
22:10:02:WU01:FS00:0xa7:Exiting, please wait. . .
22:10:02:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 7576
22:10:02:WU00:FS01:0x22:Exiting, please wait. . .
22:10:02:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
22:10:03:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
22:10:04:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
22:10:05:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:10:11:WU02:FS00:Upload 100.00%
22:10:11:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
22:10:11:WU02:FS00:Trying to send results to collection server
22:10:11:WU02:FS00:Uploading 2.64MiB to 155.247.166.219
22:10:11:WU02:FS00:Connecting to 155.247.166.219:8080
HaloJones
Re: Log file (1)
Post by HaloJones »
Thanks for the contribution. It appears to be the cpu client that is having problems. With such a relatively slow cpu, firstly the amount of work it can do is extremely limited. I'm guessing just a few thousand points per day. Your total is at https://stats.foldingathome.org/donor/106820668
I wouldn't worry too much about the errors. The client deals with the science so that you don't need to.
single 1070
Re: Log file (1)
The Guru Meditation errors on the CPU WU near the beginning of the log were from the folding core being unable to open one of the files from the checkpoint, and crashing. After a few tries it failed the WU and uploaded a report of the failure.
As to why it could not open the file, it could have been corrupted, locked by another process, or just missing. The first or third situations can come from the core being interrupted while writing out a checkpoint, it can take 30-60 seconds for the core to shut down. It could come from Windows shutdown not giving the client and core enough time to exit properly, safest way to handle this is to pause faolding and then shut down or restart after waiting a bit.
I didn't spot anything in the second section of the log to add to this.
*Wirralgirl*
Re: Log file (1) and 2
Post by *Wirralgirl* »
Thanks both :)
WG
Re: Log file (1)
What Joe_H said.
Prior to the begniing of the log you posted, FAH was running and it crashed. We have no information about that crash, but it's a fact that Guru Meditation means the checkpoint files were not synced to disk, a process which requires an orderly shutdown. I'm not sure how FAHCore_a7 manages the disk cache but software cannot anticipate a crash. e.g.- Unplugging the computer without doing a shutdown is likely to cause a Guru Meditation fault on restart. I'm sure you didn't do that, but [DO NOT TRY THAT YOURSELF.] The error code 0xc0000409 is Microsoft's way of telling you "We need data from your disk that isn't there."
