Am I the only one not getting GPU projects?
glad1us
Post by glad1us »
RTX 2070
After days folding with my GPU I have stopped receiving any new GPU projects while CPU works non-stop. At has been almost 48 hours since last GPU project.
Roadpower
Re: Am I the only one not getting GPU projects?
Post by Roadpower »
Appears to be a shortage of GPU WU's. I'm sure that they are working on it. :)
NoMoreQuarantine
Post by NoMoreQuarantine »
I only got 1 OPENMM WU all day yesterday :(
Jan
Post by Jan »
The staff is working on getting more GPU WUs out. If your timer for the next WU request goes up to multiple hours, you can pause the idle slot for a minute and then restart it. This resets the timer.
The scientists are operating at saturation levels to produce more research studies. GPUs do a better job of chewing through bigger projects rapidly.
Fortunately, the projects that are routed to CPUs often are smaller and are more prone to having a family of projects like "try all of these old drugs and see which ones are promising...." Both are important research tools but the laws of suppy and demand work differently.
Then, too, our perception varies. Several small projects may seem more rewarding than one larger project.
You have to wonder why they bother saying all this on the splash screen, it is obvious no one reads it.
ManInTheSun
Post by ManInTheSun »
nVidia has powered up their rig and ate all the WUs. Check out team 259918.
glad1us
Post by glad1us »
update: issue was resolved only the second I updated to the new stable version.
viewtopic.php?f=24&t=34466
I am back to chewing WUs.
Post by Neil-B »
ManInTheSun wrote:nVidia has powered up their rig and ate all the WUs. Check out team 259918.
… or check out ec2spot https://stats.foldingathome.org/donor/71687954 or at EOC https://folding.extremeoverclocking.com ... =&u=928671 ... Simply awesome throughput !!!
ToeBlister
Post by ToeBlister »
absolute monsters of WUs crunchers. their daily is what my measly 1x RTX2060 would make in 1.4 years.
godspeed to the WSs/CSs and scientist with their research.
Octofinger
Post by Octofinger »
I haven't received a single WU for my GPU since I fired up folding@home a couple of weeks ago.
I'm running a Radeon HD 6950. Not the fastest car on the block but still enough to do DP floats so it should qualify for most GPU WUs, right?
I have OpenCL 2.0.4.0 which should be sufficient?
I've tried to be patient, but now I felt I just had to ask...
NoMoreQuarantine
Octofinger wrote:I'm running a Radeon HD 6950. Not the fastest car on the block but still enough to do DP floats so it should qualify for most GPU WUs, right?
FAH uses SP floats mostly. Your card should be fine though. It sounds like you may be encountering some kind of error. We would need more information about your setup to help you. I suggest making a new post including your system info and log dump.
Octofinger
NoMoreQuarantine wrote: FAH uses SP floats mostly. Your card should be fine though. It sounds like you may be encountering some kind of error. We would need more information about your setup to help you. I suggest making a new post including your system info and log dump.
Thanks for the swift response. Just because I posted, I probably sorted my issue out. I've had all sorts of timeout messages and also no available WU messages, but turns out in between I have had failed WUs for GPU. Just after posting I got a WU but error messages that FAH couldn't set the opencl-index automatically so now that I manually set it to zero, it started to process the WU. So guess I'm all sorted out now after all.
