Prerequisites:
*Latest Zorin OS 15.2 - Core Edition - has v5.3 Kernel, atm. https://zorinos.com/download/#core
*Latest AMD GPU Linux Driver - Radeon Software for Linux Driver for Ubuntu 18.04.4 HWE Revision Number 20.10 https://www.amd.com/en/support
*FaH Apps (Debian|Mint|Ubuntu v7.6.9) - https://foldingathome.org/alternative-downloads/
Steps:
*Install Zorin (installed mine with nomodeset)
*Download AMD GPU Linux Driver. Extract after download.
*After extract, look for the amdgpu-pro-install file. Edit with textpad that file, look for restrictions: "ubuntu|debian|mint". add "zorin". Save.
*Open a terminal from that extracted folder & run ./amdgpu-pro-install
*Reboot.
*Install clinfo to check, it shouldn't be 0 (for the opencl).
*After install, proceed with the installation of the FaH apps.
*FaH apps will ask details, just input them if you have all (donor, team, passkey).
*Reboot.
*Open the system directory, look for /etc/fahclient folder & open a terminal there. gedit the xml.config, check if the details if correct. You can also substitute "CPU" into "GPU" as folding slot. Save.
*Click on the shortcut & start "GPU" Folding.
Optional:
*If FaH Client it on the loop or other apps wouldn't load up opencl, try to upgrade the kernel. Use Ubuntu Kernel Mainline (forked from ukuu) - https://github.com/bkw777/mainline
**ukuu now is a paid app.
Happy Folding Guys. Stay Safe & Healthy. GTG, need rest.
Screenshot:
https://i.imgur.com/cfcPeGB.png
