I would like to disable/pause the GPU folding, but not by removing the slot.
How could I do that?
Disable GPU
iceman1992
Re: Disable GPU
If you open Advanced Control, right click on the specific slot under Folding Slots, and pause. Please finish any current WUs before pausing - the "Finish" option will do this.
Re: Disable GPU
To make certain the GPU slot stays paused, you can add an option to the slot using Configure in FAHControl.
In Configure click on Slots, then click on the GPU slot and then Edit. Under the Extra Slot Options, Add the option pause-on-start and set the value to true. Then click OK and Save.
