AMD Radeon Pro WX 3100
Oh4ccidentalMeow
Post by Oh4ccidentalMeow »
Please whitelist this GPU
Display adapter 0
ID 0x2000000
Name AMD Radeon Pro WX 3100
Board Manufacturer ATI Technologies
Memory size 4 GB
PCI device bus 41 (0x29), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1002)
Model ID 0x6985 (0x0B0C)
Revision ID 0x0
Performance Level 0
Performance Level 1
Win32_VideoController AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController DriverVersion = 26.20.13032.13
Win32_VideoController DriverDate = 11/26/2019
Re: AMD Radeon Pro WX 3100
This GPU is already on the whitelist:
0x1002:0x6985:1:5:[Radeon WX 3100]
If you are having issues using it for folding, please describe them and post the beginning section of your log, the first 200 or so lines that have the system info and folding configuration.
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/r ... 3100.c2978
It should fold well!
Hints on how to post the log:
viewtopic.php?f=24&t=26036
Oh4ccidentalMeow
*********************** Log Started 2020-04-19T13:32:42Z ***********************
13:32:42:****************************** FAHClient ******************************
13:32:42:        Version: 7.6.9
13:32:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:32:42:      Copyright: 2020 foldingathome.org
13:32:42:       Homepage: https://foldingathome.org/
13:32:42:           Date: Apr 17 2020
13:32:42:           Time: 11:13:06
13:32:42:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
13:32:42:         Branch: master
13:32:42:       Compiler: Visual C++ 2008
13:32:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:32:42:       Platform: win32 10
13:32:42:           Bits: 32
13:32:42:           Mode: Release
13:32:42:           Args: --open-web-control
13:32:42:         Config: C:\Users\****\AppData\Roaming\FAHClient\config.xml
13:32:42:******************************** CBang ********************************
13:32:42:           Time: 11:10:09
13:32:42:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
13:32:42:           Bits: 32
13:32:42:******************************* System ********************************
13:32:42:            CPU: AMD Ryzen 7 2700 Eight-Core Processor
13:32:42:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
13:32:42:           CPUs: 16
13:32:42:         Memory: 15.95GiB
13:32:42:    Free Memory: 12.77GiB
13:32:42:        Threads: WINDOWS_THREADS
13:32:42:     OS Version: 6.2
13:32:42:    Has Battery: false
13:32:42:     On Battery: false
13:32:42:     UTC Offset: 2
13:32:42:            PID: 9616
13:32:42:            CWD: C:\Users\****\AppData\Roaming\FAHClient
13:32:42:             OS: Windows 10 Enterprise
13:32:42:        OS Arch: AMD64
13:32:42:           GPUs: 1
13:32:42:          GPU 0: Bus:41 Slot:0 Func:0 AMD:5 [Radeon WX 3100]
13:32:42:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
13:32:42:                 specified module could not be found.
13:32:42:
13:32:42:OpenCL Device 0: Platform:0 Device:0 Bus:41 Slot:0 Compute:1.2 Driver:3004.5
13:32:42:  Win32 Service: false
13:32:42:******************************* libFAH ********************************
13:32:42:           Date: Apr 15 2020
13:32:42:           Time: 14:53:14
13:32:42:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
13:32:42:           Bits: 32
13:32:42:***********************************************************************
Oh4ccidentalMeow
I just updated my Radeon driver to the latest version. It looks like FAH is looking for CUDA but this card does not support that.
Post by Neil-B »
Believe that is one of those odd message which is true in that you dont have cuda but is irrelevant as you don't have an nvidia card so you can ignore it !! … I'll let one of the more technical people confirm this, but I am fairly sure it is nothing to worry about.
The client tests for both CUDA and OpenCL for all set ups, so the message can be ignored if you have just AMD cards. The CUDA test is the first part on testing for nVidia cards as they bundle OpenCL support wit the CUDA support install.
Oh4ccidentalMeow
Thank you for helping me out. How can I make the Windows FAH client to ignore this message and get it to fold?
The message is not keeping you from folding. If you are getting messages that the server is unable to assign, that is from there being more requests for GPU folding WUs that they can supply. If you leave your system active, it should eventually get an assignment.
Neil-B wrote:.. [It] is true in that you dont have cuda but is irrelevant as you don't have an nvidia card so you can ignore it !!
True. Sure the FAHClient could have an enhancement saying add code like IF GPU=NVIDIA AND (...) THEN (issue this message and) OTHERWISE CONTINUE but I don't think they're going to "stop the presses" to fix that right now. :D
Oh4ccidentalMeow
Joe_H wrote:If you are getting messages that the server is unable to assign, that is from there being more requests for GPU folding WUs that they can supply.
Ah I did not know that (new at folding). No messages... I just noticed that only my CPU is working while my GPU is idle. I thought is was a configuration thing. Thank you.
