Multiple work units wont send.
Mindwarp
Post by Mindwarp »
It has actually been doing this for two days some send some don't but these three just stay here. I let it go because I have found these problems usually fix themselves after a while, but these have not. Thank you for any help.
--Matt
*********************** Log Started 2020-04-19T10:12:52Z ***********************
10:12:52:************************* Folding@home Client *************************
10:12:52:        Website: https://foldingathome.org/
10:12:52:      Copyright: (c) 2009-2018 foldingathome.org
10:12:52:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:12:52:           Args:
10:12:52:         Config: C:\Users\Matthew\AppData\Roaming\FAHClient\config.xml
10:12:52:******************************** Build ********************************
10:12:52:        Version: 7.5.1
10:12:52:           Date: May 11 2018
10:12:52:           Time: 13:06:32
10:12:52:     Repository: Git
10:12:52:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:12:52:         Branch: master
10:12:52:       Compiler: Visual C++ 2008
10:12:52:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:12:52:       Platform: win32 10
10:12:52:           Bits: 32
10:12:52:           Mode: Release
10:12:52:******************************* System ********************************
10:12:52:            CPU: AMD Ryzen 5 3600 6-Core Processor
10:12:52:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
10:12:52:           CPUs: 12
10:12:52:         Memory: 15.95GiB
10:12:52:    Free Memory: 13.14GiB
10:12:52:        Threads: WINDOWS_THREADS
10:12:52:     OS Version: 6.2
10:12:52:    Has Battery: false
10:12:52:     On Battery: false
10:12:52:     UTC Offset: -4
10:12:52:            PID: 6680
10:12:52:            CWD: C:\Users\Matthew\AppData\Roaming\FAHClient
10:12:52:             OS: Windows 10 Enterprise
10:12:52:        OS Arch: AMD64
10:12:52:           GPUs: 1
10:12:52:          GPU 0: Bus:38 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2070 Super]
10:12:52:                 8218
10:12:52:  CUDA Device 0: Platform:0 Device:0 Bus:38 Slot:0 Compute:7.5 Driver:11.0
10:12:52:OpenCL Device 0: Platform:0 Device:0 Bus:38 Slot:0 Compute:1.2 Driver:445.87
10:12:52:  Win32 Service: false
10:12:52:***********************************************************************
10:12:52:<config>
10:12:52:  <!-- Folding Core -->
10:12:52:  <core-priority v='low'/>
10:12:52:
10:12:52:  <!-- Network -->
10:12:52:  <proxy v=':8080'/>
10:12:52:
10:12:52:  <!-- Slot Control -->
10:12:52:  <power v='full'/>
10:12:52:
10:12:52:  <!-- User Information -->
10:12:52:  <passkey v='********************************'/>
10:12:52:  <team v='223518'/>
10:12:52:  <user v='Mindwarp'/>
10:12:52:
10:12:52:  <!-- Folding Slots -->
10:12:52:  <slot id='0' type='CPU'/>
10:12:52:  <slot id='1' type='GPU'/>
10:12:52:</config>
10:12:52:Trying to access database...
10:12:52:Successfully acquired database lock
10:12:52:Enabled folding slot 00: READY cpu:11
10:12:52:Enabled folding slot 01: READY gpu:0:TU104 [GeForce RTX 2070 Super] 8218
10:12:52:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14636 run:1180 clone:0 gen:6 core:0xa7 unit:0x000000069bf7a4d55e85515438d4ae11
10:12:52:WU00:FS00:Uploading 8.25MiB to 155.247.164.213
10:12:52:WU00:FS00:Connecting to 155.247.164.213:8080
10:12:52:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14642 run:1704 clone:0 gen:4 core:0xa7 unit:0x000000059bf7a4d55e8ba0473ebf12c8
10:12:52:WU02:FS00:Uploading 8.31MiB to 155.247.164.213
10:12:52:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:14632 run:711 clone:0 gen:7 core:0xa7 unit:0x000000079bf7a4d55e84f544d2694fc1
10:12:52:WU02:FS00:Connecting to 155.247.164.213:8080
10:12:52:WU04:FS00:Uploading 8.27MiB to 155.247.164.213
10:12:52:WU04:FS00:Connecting to 155.247.164.213:8080
10:12:52:WU01:FS00:Connecting to 65.254.110.245:8080
10:12:52:WU03:FS01:Connecting to 65.254.110.245:8080
10:12:52:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:12:52:WU01:FS00:Connecting to 18.218.241.186:80
10:12:52:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:12:52:WU03:FS01:Connecting to 18.218.241.186:80
10:12:53:WARNING:WU03:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:12:53:ERROR:WU03:FS01:Exception: Could not get an assignment
10:12:53:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:12:53:ERROR:WU01:FS00:Exception: Could not get an assignment
10:12:53:WU03:FS01:Connecting to 65.254.110.245:8080
10:12:53:WU01:FS00:Connecting to 65.254.110.245:8080
10:12:53:WU03:FS01:Assigned to work server 140.163.4.231
10:12:53:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2070 Super] 8218 from 140.163.4.231
10:12:53:WU03:FS01:Connecting to 140.163.4.231:8080
10:12:53:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:12:53:WU01:FS00:Connecting to 18.218.241.186:80
10:12:54:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:12:54:ERROR:WU01:FS00:Exception: Could not get an assignment
10:13:13:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:13:13:WU00:FS00:Connecting to 155.247.164.213:80
10:13:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
10:13:13:WU02:FS00:Connecting to 155.247.164.213:80
10:13:13:WARNING:WU04:FS00:WorkServer connection failed on port 8080 trying 80
10:13:13:WU04:FS00:Connecting to 155.247.164.213:80
10:13:15:ERROR:WU03:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
10:13:20:WU00:FS00:Upload 0.76%
10:13:20:WU02:FS00:Upload 0.75%
10:13:20:WU04:FS00:Upload 0.76%
10:13:53:WU01:FS00:Connecting to 65.254.110.245:8080
10:13:54:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:13:54:WU01:FS00:Connecting to 18.218.241.186:80
10:13:54:WU03:FS01:Connecting to 65.254.110.245:8080
10:13:54:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:13:54:ERROR:WU01:FS00:Exception: Could not get an assignment
10:13:54:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:13:54:WU03:FS01:Connecting to 18.218.241.186:80
10:13:54:WARNING:WU03:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:13:54:ERROR:WU03:FS01:Exception: Could not get an assignment
10:13:55:WU00:FS00:Upload 7.58%
10:14:15:WU00:FS00:Upload 9.09%
10:14:15:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
10:14:15:WU00:FS00:Trying to send results to collection server
10:14:15:WU00:FS00:Uploading 8.25MiB to 155.247.166.219
10:14:15:WU00:FS00:Connecting to 155.247.166.219:8080
10:14:25:WU00:FS00:Upload 7.58%
10:14:44:WU00:FS00:Upload 8.33%
10:14:44:ERROR:WU00:FS00:Exception: Transfer failed
10:14:45:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14636 run:1180 clone:0 gen:6 core:0xa7 unit:0x000000069bf7a4d55e85515438d4ae11
10:14:45:WU00:FS00:Uploading 8.25MiB to 155.247.164.213
10:14:45:WU00:FS00:Connecting to 155.247.164.213:8080
10:14:53:WU02:FS00:Upload 7.52%
10:14:53:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
10:14:53:WU02:FS00:Trying to send results to collection server
10:14:53:WU02:FS00:Uploading 8.31MiB to 155.247.166.219
10:14:53:WU02:FS00:Connecting to 155.247.166.219:8080
10:15:00:WU04:FS00:Upload 7.55%
10:15:00:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
10:15:00:WU04:FS00:Trying to send results to collection server
10:15:00:WU04:FS00:Uploading 8.27MiB to 155.247.166.219
10:15:00:WU04:FS00:Connecting to 155.247.166.219:8080
10:15:06:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:15:06:WU00:FS00:Connecting to 155.247.164.213:80
10:15:12:WU02:FS00:Upload 8.28%
10:15:12:ERROR:WU02:FS00:Exception: Transfer failed
10:15:13:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14642 run:1704 clone:0 gen:4 core:0xa7 unit:0x000000059bf7a4d55e8ba0473ebf12c8
10:15:13:WU02:FS00:Uploading 8.31MiB to 155.247.164.213
10:15:13:WU02:FS00:Connecting to 155.247.164.213:8080
10:15:27:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.164.213:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:15:27:WU00:FS00:Trying to send results to collection server
10:15:27:WU00:FS00:Uploading 8.25MiB to 155.247.166.219
10:15:27:WU00:FS00:Connecting to 155.247.166.219:8080
10:15:30:WU01:FS00:Connecting to 65.254.110.245:8080
10:15:31:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:15:31:WU01:FS00:Connecting to 18.218.241.186:80
10:15:31:WU03:FS01:Connecting to 65.254.110.245:8080
10:15:31:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:15:31:ERROR:WU01:FS00:Exception: Could not get an assignment
10:15:31:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:15:31:WU03:FS01:Connecting to 18.218.241.186:80
10:15:31:WARNING:WU03:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:15:31:ERROR:WU03:FS01:Exception: Could not get an assignment
10:15:34:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
10:15:34:WU02:FS00:Connecting to 155.247.164.213:80
10:15:34:WU02:FS00:Upload 0.75%
10:15:34:WU00:FS00:Upload 0.76%
10:15:53:WU02:FS00:Upload 7.52%
10:15:53:WU00:FS00:Upload 7.58%
10:15:53:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
10:15:53:WU02:FS00:Trying to send results to collection server
10:15:53:WU02:FS00:Uploading 8.31MiB to 155.247.166.219
10:15:53:ERROR:WU00:FS00:Exception: Transfer failed
10:15:53:WU02:FS00:Connecting to 155.247.166.219:8080
10:15:53:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14636 run:1180 clone:0 gen:6 core:0xa7 unit:0x000000069bf7a4d55e85515438d4ae11
10:15:53:WU00:FS00:Uploading 8.25MiB to 155.247.164.213
10:15:53:WU00:FS00:Connecting to 155.247.164.213:8080
10:16:00:WU02:FS00:Upload 0.75%
10:16:08:WU04:FS00:Upload 8.31%
10:16:19:WU04:FS00:Upload 9.82%
10:16:19:WU02:FS00:Upload 7.52%
10:16:19:ERROR:WU02:FS00:Exception: Transfer failed
10:16:19:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14642 run:1704 clone:0 gen:4 core:0xa7 unit:0x000000059bf7a4d55e8ba0473ebf12c8
10:16:19:WU02:FS00:Uploading 8.31MiB to 155.247.164.213
10:16:19:WU02:FS00:Connecting to 155.247.164.213:8080
10:16:26:WU04:FS00:Upload 11.33%
10:16:28:19:127.0.0.1:New Web connection
10:16:45:WU04:FS00:Upload 12.84%
10:16:45:ERROR:WU04:FS00:Exception: Transfer failed
10:16:45:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:14632 run:711 clone:0 gen:7 core:0xa7 unit:0x000000079bf7a4d55e84f544d2694fc1
10:16:45:WU04:FS00:Uploading 8.27MiB to 155.247.164.213
10:16:45:WU04:FS00:Connecting to 155.247.164.213:8080
10:17:03:WU00:FS00:Upload 9.09%
10:17:06:WARNING:WU04:FS00:WorkServer connection failed on port 8080 trying 80
10:17:06:WU04:FS00:Connecting to 155.247.164.213:80
10:17:06:WU02:FS00:Upload 8.28%
10:17:22:WU00:FS00:Upload 9.85%
10:17:22:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
10:17:22:WU00:FS00:Trying to send results to collection server
10:17:22:WU00:FS00:Uploading 8.25MiB to 155.247.166.219
10:17:22:WU00:FS00:Connecting to 155.247.166.219:8080
10:17:27:WARNING:WU04:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.164.213:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:17:27:WU04:FS00:Trying to send results to collection server
10:17:27:WU04:FS00:Uploading 8.27MiB to 155.247.166.219
10:17:27:WU04:FS00:Connecting to 155.247.166.219:8080
10:17:27:WU02:FS00:Upload 12.04%
10:17:27:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
10:17:27:WU02:FS00:Trying to send results to collection server
10:17:27:WU02:FS00:Uploading 8.31MiB to 155.247.166.219
10:17:27:WU02:FS00:Connecting to 155.247.166.219:8080
10:17:43:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:17:43:WU00:FS00:Connecting to 155.247.166.219:80
10:17:53:WU02:FS00:Upload 8.28%
10:17:53:ERROR:WU02:FS00:Exception: Transfer failed
10:17:57:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14642 run:1704 clone:0 gen:4 core:0xa7 unit:0x000000059bf7a4d55e8ba0473ebf12c8
10:17:57:WU02:FS00:Uploading 8.31MiB to 155.247.164.213
10:17:57:WU02:FS00:Connecting to 155.247.164.213:8080
10:18:04:WU02:FS00:Upload 0.75%
10:18:04:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:18:05:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14636 run:1180 clone:0 gen:6 core:0xa7 unit:0x000000069bf7a4d55e85515438d4ae11
10:18:05:WU00:FS00:Uploading 8.25MiB to 155.247.164.213
10:18:05:WU00:FS00:Connecting to 155.247.164.213:8080
10:18:08:WU01:FS00:Connecting to 65.254.110.245:8080
10:18:08:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:18:08:WU01:FS00:Connecting to 18.218.241.186:80
10:18:08:WU03:FS01:Connecting to 65.254.110.245:8080
10:18:08:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:18:08:ERROR:WU01:FS00:Exception: Could not get an assignment
10:18:08:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:18:08:WU03:FS01:Connecting to 18.218.241.186:80
10:18:08:WU04:FS00:Upload 7.55%
10:18:08:WARNING:WU03:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:18:08:ERROR:WU03:FS01:Exception: Could not get an assignment
10:18:17:WU02:FS00:Upload 7.52%
10:18:17:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
10:18:17:WU02:FS00:Trying to send results to collection server
10:18:17:WU02:FS00:Uploading 8.31MiB to 155.247.166.219
10:18:17:WU02:FS00:Connecting to 155.247.166.219:8080
10:18:26:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:18:26:WU00:FS00:Connecting to 155.247.164.213:80
10:18:26:WU00:FS00:Upload 0.76%
10:18:38:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
10:18:38:WU02:FS00:Connecting to 155.247.166.219:80
10:18:44:WU04:FS00:Upload 9.06%
10:18:45:WU02:FS00:Upload 0.75%
10:19:33:WU00:FS00:Upload 8.33%
10:20:23:WU00:FS00:Upload 9.09%
10:20:23:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
10:20:23:WU00:FS00:Trying to send results to collection server
10:20:23:WU00:FS00:Uploading 8.25MiB to 155.247.166.219
10:20:23:WU00:FS00:Connecting to 155.247.166.219:8080
10:20:46:WU02:FS00:Upload 8.28%
10:20:46:ERROR:WU02:FS00:Exception: Transfer failed
10:20:46:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14642 run:1704 clone:0 gen:4 core:0xa7 unit:0x000000059bf7a4d55e8ba0473ebf12c8
10:20:46:WU02:FS00:Uploading 8.31MiB to 155.247.164.213
10:20:46:WU02:FS00:Connecting to 155.247.164.213:8080
10:20:50:WU04:FS00:Upload 9.82%
10:20:50:ERROR:WU04:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
10:20:50:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:14632 run:711 clone:0 gen:7 core:0xa7 unit:0x000000079bf7a4d55e84f544d2694fc1
10:20:50:WU04:FS00:Uploading 8.27MiB to 155.247.164.213
10:20:50:WU04:FS00:Connecting to 155.247.164.213:8080
10:21:07:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
10:21:07:WU02:FS00:Connecting to 155.247.164.213:80
10:21:11:WARNING:WU04:FS00:WorkServer connection failed on port 8080 trying 80
10:21:11:WU04:FS00:Connecting to 155.247.164.213:80
10:21:14:WU02:FS00:Upload 0.75%
10:21:14:WU04:FS00:Upload 0.76%
10:21:20:WU00:FS00:Upload 8.33%
10:21:43:WU04:FS00:Upload 8.31%
10:22:10:WU00:FS00:Upload 9.09%
10:22:10:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
10:22:11:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14636 run:1180 clone:0 gen:6 core:0xa7 unit:0x000000069bf7a4d55e85515438d4ae11
10:22:11:WU00:FS00:Uploading 8.25MiB to 155.247.164.213
10:22:11:WU00:FS00:Connecting to 155.247.164.213:8080
10:22:22:WU01:FS00:Connecting to 65.254.110.245:8080
10:22:22:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:22:22:WU01:FS00:Connecting to 18.218.241.186:80
10:22:22:WU03:FS01:Connecting to 65.254.110.245:8080
10:22:22:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:22:22:ERROR:WU01:FS00:Exception: Could not get an assignment
10:22:22:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:22:22:WU03:FS01:Connecting to 18.218.241.186:80
10:22:22:WARNING:WU03:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:22:22:ERROR:WU03:FS01:Exception: Could not get an assignment
10:22:32:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:22:32:WU00:FS00:Connecting to 155.247.164.213:80
10:22:37:WU02:FS00:Upload 8.28%
10:22:37:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
10:22:37:WU02:FS00:Trying to send results to collection server
10:22:37:WU02:FS00:Uploading 8.31MiB to 155.247.166.219
10:22:37:WU02:FS00:Connecting to 155.247.166.219:8080
10:22:49:WU04:FS00:Upload 9.82%
10:22:51:WU02:FS00:Upload 7.52%
10:22:53:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.164.213:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:22:53:WU00:FS00:Trying to send results to collection server
10:22:53:WU00:FS00:Uploading 8.25MiB to 155.247.166.219
10:22:53:WU00:FS00:Connecting to 155.247.166.219:8080
10:23:01:WU00:FS00:Upload 7.58%
10:23:19:WU04:FS00:Upload 10.57%
10:23:19:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
10:23:19:WU04:FS00:Trying to send results to collection server
10:23:19:WU04:FS00:Uploading 8.27MiB to 155.247.166.219
10:23:19:WU04:FS00:Connecting to 155.247.166.219:8080
10:23:20:WU00:FS00:Upload 8.33%
10:23:20:ERROR:WU00:FS00:Exception: Transfer failed
10:23:26:WU04:FS00:Upload 7.55%
10:23:37:WU02:FS00:Upload 8.28%
10:23:37:ERROR:WU02:FS00:Exception: Transfer failed
10:25:00:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14642 run:1704 clone:0 gen:4 core:0xa7 unit:0x000000059bf7a4d55e8ba0473ebf12c8
10:25:00:WU02:FS00:Uploading 8.31MiB to 155.247.164.213
10:25:00:WU02:FS00:Connecting to 155.247.164.213:8080
10:25:14:WU04:FS00:Upload 8.31%
10:25:14:ERROR:WU04:FS00:Exception: Transfer failed
10:25:14:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:14632 run:711 clone:0 gen:7 core:0xa7 unit:0x000000079bf7a4d55e84f544d2694fc1
10:25:14:WU04:FS00:Uploading 8.27MiB to 155.247.164.213
10:25:14:WU04:FS00:Connecting to 155.247.164.213:8080
10:25:21:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
10:25:21:WU02:FS00:Connecting to 155.247.164.213:80
10:25:35:WARNING:WU04:FS00:WorkServer connection failed on port 8080 trying 80
10:25:35:WU04:FS00:Connecting to 155.247.164.213:80
10:25:42:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.164.213:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:25:42:WU02:FS00:Trying to send results to collection server
10:25:42:WU02:FS00:Uploading 8.31MiB to 155.247.166.219
10:25:42:WU02:FS00:Connecting to 155.247.166.219:8080
10:25:56:WARNING:WU04:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.164.213:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:25:56:WU04:FS00:Trying to send results to collection server
10:25:56:WU04:FS00:Uploading 8.27MiB to 155.247.166.219
10:25:56:WU04:FS00:Connecting to 155.247.166.219:8080
10:26:03:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
10:26:03:WU02:FS00:Connecting to 155.247.166.219:80
10:26:03:WU02:FS00:Upload 0.75%
10:26:15:WU04:FS00:Upload 7.55%
10:26:15:ERROR:WU04:FS00:Exception: Transfer failed
jloflin
Re: Multiple work units wont send.
Post by jloflin »
I have the same issue with the same server at Temple University. The Server Stats page says it is accepting, but the jobs columns both read "0". Apparently, vav3.ocis.temple.edu (155.247.166.219) has a glitch of some kind.
Randy
ingmannori
Post by ingmannori »
Hi, same issue here, starting from 04/19/20.
03:36:04:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14637 run:843 clone:0 gen:3 core:0xa7 unit:0x000000059bf7a4d55e8aa5bae8a1da93
03:36:04:WU00:FS00:Uploading 8.24MiB to 155.247.164.213
03:36:04:WU00:FS00:Connecting to 155.247.164.213:8080
03:36:25:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
03:36:25:WU00:FS00:Connecting to 155.247.164.213:80
03:36:44:WU02:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
03:36:46:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.164.213:80: Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato.
03:36:46:WU00:FS00:Trying to send results to collection server
03:36:46:WU00:FS00:Uploading 8.24MiB to 155.247.166.219
03:36:46:WU00:FS00:Connecting to 155.247.166.219:8080
04:00:12:ERROR:WU02:FS00:Exception: Transfer failed
04:00:12:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14367 run:665 clone:3 gen:49 core:0xa7 unit:0x000000359bf7a4d55e84b232086bf475
04:00:12:WU02:FS00:Uploading 6.51MiB to 155.247.164.213
04:00:12:WU02:FS00:Connecting to 155.247.164.213:8080
04:00:40:WU02:FS00:Upload 1.92%
04:00:40:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
04:00:40:WU02:FS00:Trying to send results to collection server
04:00:40:WU02:FS00:Uploading 6.51MiB to 155.247.166.219
04:00:40:WU02:FS00:Connecting to 155.247.166.219:8080
04:00:49:WU02:FS00:Upload 1.92%
04:00:49:WU03:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
04:01:31:WU03:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
04:02:14:WU03:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
04:02:56:WU03:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
04:03:01:WU02:FS00:Upload 2.88%
04:03:02:ERROR:WU02:FS00:Exception: Transfer failed
04:03:02:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14367 run:665 clone:3 gen:49 core:0xa7 unit:0x000000359bf7a4d55e84b232086bf475
04:03:02:WU02:FS00:Uploading 6.51MiB to 155.247.164.213
04:03:02:WU02:FS00:Connecting to 155.247.164.213:8080
04:03:26:WU02:FS00:Upload 1.92%
04:03:26:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
04:03:26:WU02:FS00:Trying to send results to collection server
04:03:26:WU02:FS00:Uploading 6.51MiB to 155.247.166.219
04:03:26:WU02:FS00:Connecting to 155.247.166.219:8080
04:03:39:WU03:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
04:03:45:WU02:FS00:Upload 1.92%
04:03:45:ERROR:WU02:FS00:Exception: Transfer failed
04:04:24:WU03:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
04:04:39:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14367 run:665 clone:3 gen:49 core:0xa7 unit:0x000000359bf7a4d55e84b232086bf475
04:04:39:WU02:FS00:Uploading 6.51MiB to 155.247.164.213
04:04:39:WU02:FS00:Connecting to 155.247.164.213:8080
04:05:00:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
04:05:00:WU02:FS00:Connecting to 155.247.164.213:80
04:05:07:WU03:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
06:28:20:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
06:28:20:WU00:FS00:Trying to send results to collection server
06:28:20:WU00:FS00:Uploading 8.24MiB to 155.247.166.219
06:28:20:WU00:FS00:Connecting to 155.247.166.219:8080
06:28:29:FS00:Finishing
06:28:31:WU00:FS00:Upload 1.52%
06:28:53:WU03:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
06:29:07:FS00:Paused
06:29:07:FS00:Shutting core down
06:29:07:WU03:FS00:0xa7:WARNING:Console control signal 1 on PID 39904
06:29:07:WU03:FS00:0xa7:Exiting, please wait. . .
06:29:08:WU03:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:29:10:FS00:Unpaused
06:29:10:FS00:Finishing
06:29:10:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14640 run:1974 clone:1 gen:8 core:0xa7 unit:0x000000089bf7a4d55e8b9f55939bb2c7
06:29:10:WU01:FS00:Uploading 8.20MiB to 155.247.164.213
06:29:10:WU01:FS00:Connecting to 155.247.164.213:8080
06:29:11:WU03:FS00:Starting
