0 points after 16 hours of folding?
wdumon
Post by wdumon »
Hi,
I installed the Folding@Home client and started folding, left it doing that overnight. It's been working on full power (CPU ~80+%) but it's not generating any points, so I think it's not actually doing anything or at least not finishing anything? Anything I can do to check that? My stats are all empty, no points, no WUs finished, nothing?
Thanks for the help!
W.
Re: 0 points after 16 hours of folding?
Welcome to the F@H Forum wdumon,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=24&t=26036
Please note that you will be able to see your Stats once the completed WU has been uploaded to the Servers and the Stats system has been updated. This may take a while. However, once we have your log, we can see what's happening on your system :)
wdumon
Post by wdumon »
hi PantherX, thanks for the quick reply! Currently the WU is at 87%, even though the UI says it would take another 2h30 to complete, it's been like that (the ETA, not the progress %) all along. Let's see if it finishes up now? Log file below:
*********************** Log Started 2020-04-19T11:22:05Z ***********************
11:22:05:****************************** FAHClient ******************************
11:22:05:        Version: 7.6.9
11:22:05:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:22:05:      Copyright: 2020 foldingathome.org
11:22:05:       Homepage: https://foldingathome.org/
11:22:05:           Date: Apr 17 2020
11:22:05:           Time: 11:13:06
11:22:05:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
11:22:05:         Branch: master
11:22:05:       Compiler: Visual C++ 2008
11:22:05:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:22:05:       Platform: win32 10
11:22:05:           Bits: 32
11:22:05:           Mode: Release
11:22:05:           Args: --open-web-control
11:22:05:         Config: C:\Users\wdumo\AppData\Roaming\FAHClient\config.xml
11:22:05:******************************** CBang ********************************
11:22:05:           Time: 11:10:09
11:22:05:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
11:22:05:           Bits: 32
11:22:05:******************************* System ********************************
11:22:05:            CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
11:22:05:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
11:22:05:           CPUs: 4
11:22:05:         Memory: 7.60GiB
11:22:05:    Free Memory: 5.21GiB
11:22:05:        Threads: WINDOWS_THREADS
11:22:05:     OS Version: 6.2
11:22:05:    Has Battery: true
11:22:05:     On Battery: false
11:22:05:     UTC Offset: 2
11:22:05:            PID: 10788
11:22:05:            CWD: C:\Users\wdumo\AppData\Roaming\FAHClient
11:22:05:             OS: Windows 10 Enterprise
11:22:05:        OS Arch: AMD64
11:22:05:           GPUs: 1
11:22:05:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF108 [GeForce GT 630M]
11:22:05:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.1 Driver:9.0
11:22:05:OpenCL Device 1: Platform:0 Device:1 Bus:NA Slot:NA Compute:1.2 Driver:10.18
11:22:05:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:384.76
11:22:05:  Win32 Service: false
11:22:05:******************************* libFAH ********************************
11:22:05:           Date: Apr 15 2020
11:22:05:           Time: 14:53:14
11:22:05:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
11:22:05:           Bits: 32
11:22:05:***********************************************************************
11:22:06:<config>
11:22:06:  <!-- Slot Control -->
11:22:06:  <power v='FULL'/>
11:22:06:
11:22:06:  <!-- User Information -->
11:22:06:  <passkey v='*****'/>
11:22:06:  <team v='3455'/>
11:22:06:  <user v='wdumon'/>
11:22:06:
11:22:06:  <!-- Folding Slots -->
11:22:06:  <slot id='0' type='CPU'/>
11:22:06:</config>
11:22:06:Trying to access database...
11:22:06:Successfully acquired database lock
11:22:06:Enabled folding slot 00: READY cpu:4
11:22:06:WU00:FS00:Starting
11:22:06:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
11:22:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\wdumo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10788 -checkpoint 15 -np 1
11:22:08:WU00:FS00:Started FahCore on PID 7956
11:22:12:WU00:FS00:Core PID:8356
11:22:12:WU00:FS00:FahCore 0xa7 started
11:22:15:WU00:FS00:0xa7:*********************** Log Started 2020-04-19T11:22:15Z ***********************
11:22:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:22:15:WU00:FS00:0xa7:       Type: 0xa7
11:22:15:WU00:FS00:0xa7:       Core: Gromacs
11:22:15:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 7956 -checkpoint 15 -np 1
11:22:15:WU00:FS00:0xa7:************************************ CBang *************************************
11:22:15:WU00:FS00:0xa7:       Date: Oct 26 2019
11:22:15:WU00:FS00:0xa7:       Time: 01:38:25
11:22:15:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:22:15:WU00:FS00:0xa7:     Branch: master
11:22:15:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:22:15:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:22:15:WU00:FS00:0xa7:   Platform: win32 10
11:22:15:WU00:FS00:0xa7:       Bits: 64
11:22:15:WU00:FS00:0xa7:       Mode: Release
11:22:15:WU00:FS00:0xa7:************************************ System ************************************
11:22:15:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
11:22:15:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
11:22:15:WU00:FS00:0xa7:       CPUs: 4
11:22:15:WU00:FS00:0xa7:     Memory: 7.60GiB
11:22:15:WU00:FS00:0xa7:Free Memory: 4.68GiB
11:22:15:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:22:15:WU00:FS00:0xa7: OS Version: 6.2
11:22:15:WU00:FS00:0xa7:Has Battery: true
11:22:15:WU00:FS00:0xa7: On Battery: false
11:22:15:WU00:FS00:0xa7: UTC Offset: 2
11:22:15:WU00:FS00:0xa7:        PID: 8356
11:22:15:WU00:FS00:0xa7:        CWD: C:\Users\wdumo\AppData\Roaming\FAHClient\work
11:22:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:22:15:WU00:FS00:0xa7:    Version: 0.0.18
11:22:15:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:22:15:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:22:15:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:22:15:WU00:FS00:0xa7:       Time: 01:52:30
11:22:15:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:22:15:WU00:FS00:0xa7:************************************ Build *************************************
11:22:15:WU00:FS00:0xa7:       SIMD: avx_256
11:22:15:WU00:FS00:0xa7:********************************************************************************
11:22:15:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 18468, Gen 39)
11:22:15:WU00:FS00:0xa7:Unit: 0x00000034287234c95e7302d7c6385c78
11:22:15:WU00:FS00:0xa7:Digital signatures verified
11:22:15:WU00:FS00:0xa7:Calling: mdrun -s frame39.tpr -o frame39.trr -x frame39.xtc -e frame39.edr -cpi state.cpt -cpt 15 -nt 1
11:22:20:WU00:FS00:0xa7:Steps: first=19500000 total=500000
11:22:23:WU00:FS00:0xa7:Completed 433051 out of 500000 steps (86%)
11:22:31:9:127.0.0.1:New Web session
11:23:25:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
11:27:30:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
Post by Neil-B »
I am going to guess that you recently restarted either the client or the computer as the top of the log is quite recent.
Using the last two % counts (which may not be a good thing - normally would use more than one - and a good few after a restart) your TPF (Time Per Fold) looks to be 187sec which may vary up/down a bit whilst a WU is being processed (but not normally by a large amount) - this would mean the WU should fold in about 312 min - or 5 hrs 12 mins … This seems substantially lower than the 16 hours you are report and would give and ETA of about 41 minutes … I have to guess therefore that the client log above is showing these first two %age points in a bit of a catch up mode after the checkpoint until it gets to where you were before restart (I think I have spotted this behaviour myself in the past) and I would expect it to "slow down" so that the TPF becomes more like that I show below.
Using your reported eta and the number of folds left … eta 2.5 hrs / 13 * 100 gives an overall folding time of just over 19hrs (and a TPF of about 690s or 11mins 10secs) which tallies with the amount of time you are reporting.
As the WU further progresses you should see a %age report probably every 11 minutes or so would be my guess.
As to Points … Points are awarded at the end of the WU progress once it has been successfully uploaded to the Work Server (WS) or Collection Server (CS) … I see you have a passkey which is good … The points may take a while to make their way through to the stats system and as explained here https://foldingathome.org/support/faq/points/ you will for the 1st 10 WUs only receive the Base Points for the Project the WU is part of as indicated here https://apps.foldingathome.org/psummary ... The Estimated Points that your system will report at the end of the WU process includes any QRB as will the PPD display in the advanced control - even though you won't get this until you "qualify" for it.
wdumon
Post by wdumon »
Windows restarted to install updates indeed (pulled out this laptop and cleaned it for the sole purpose of it running FAH for now). It's now at 97.5% with an ETA of 30mins, so I think it's now indeed progressing as it should. Thanks for the input on the points and all, couldn't find a lot in the FAQ by just going through it.
Post by Neil-B »
Ok … Just in case it helps a few bits of background terminology you may see around the Forums - and there is probably a proper/more complete list of these and my descriptions will be fairly naïve. but hey I feel like typing for a bit:
TPF … Time Per Fold … Each Work Unit will have 100 folds (1% each) and will report each to the log - the time between these is used as a bit of a measure to check speed/progress … Folders get used to roughly how long WUs tend to take to complete - this is a nice easy measure to check.
WU … Work Unit … This is a package of work which will have a PRCG reference (Project, Run, Clone, Gen) - I'll leave the full explanation of those to others but it is the way of specifically identifying the WU in question
QRB … Quick Return Bonus … The science progresses better the faster WUs are returned - there is a history behind how this came about and is calculated, but all it really means is that if a WU is returned before "Timeout" and the QRB requirements (as per the link) are met you get many more points (the quicker the more you get)
Timeout … The point at which you no longer get QRB and the WU may be reissued to another folder - this doesn't mean "stop/dump", as there are very good reasons to keep folding as you may still be the first to return the WU
Expiration (or Deadline) … This is the point at which regrettably the WU has taken too long to process/upload and will be deleted by the Client software - If you find this happening your kit is simply not set up fast enough to fold :( … This can be an issue with older kit or where kit is regularly turned off or only runs folding for a few hours a day - the Project Summary link indicates both Timeout and Expiration for each project.
Core … These are the actual bits of programming that do the folding work … and they are very different for CPU and GPU folding due to the way these work … I'll get shot for saying this but GPUs are really fast, but relatively simple whereas CPUs are relatively much slower but more complex … This means that the researchers will decide whether their project needs to run on CPU or GPU - and very occasionally I believe they will do both.
Gromacs … A bit of Open Source coding that is used by the CPU Core to do the science
OpenMM … A bit of Open Source coding that is used by the GPU Core(s) to do the science
If you can find out why, this line is reducing your folding by 4.
I would try some steps:
Do not try to enable the GPU:
https://www.techpowerup.com/gpu-specs/g ... -630m.c353
It does not support OpenCL 1.2 and is technically not supported.
Your CPU is much more modern
Unless you have heat issues, you can hard code the config to use all 4 CPUs
On this white field should be a cpu item, click it and then click edit (if there is a gpu slot, remove it)
Type the number you want, and click save. i would start with 4.
Increasing the number only takes effect on the next Work Unit, you can reduce the number any time.
Post by Neil-B »
Could it be that core count was set to 1 when the WU was downloaded - subsequent increases in core count wont take effect until a new WU … but on a restart this message is in essence saying the current WU core count is less that the slot core count is now?
There is a long existing bug in the installer that often sets the request for the first WU to be for one CPU thread. Once downloaded at that setting, the WU settings will not allow raising the thread count higher.
If this happened on every install, the bug might have been identified and eliminated at some point. As it is, it only effects the first WU download, so has not been a high priority item to dig deeply into.
wdumon
Post by wdumon »
Hi guys, thanks for the explanations and the input! In the meantime I've updated my CPU count to 4 and the folding is going on on a second WU. The first completed and gave me 1000 points. Let's see what this next one does, ETA is about 12 hours.
wdumon
Post by wdumon »
Hi, now at WU number 5 and still getting the warning "lowered CPUs from 4 to 1", although I've configured it to 4 instead of -1. Any idea what could cause that?
2 log files below, first is only the errors/warnings, second is the full log file but truncated
13:39:16:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
14:31:47:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
16:13:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
16:14:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
******************************* Date: 2020-04-19 *******************************
******************************* Date: 2020-04-20 *******************************
14:12:20:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
19:34:43:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:23:06:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:23:06:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:23:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:23:07:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:23:07:ERROR:WU00:FS00:Exception: Could not get an assignment
05:23:08:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:23:09:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:23:09:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:23:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:23:10:ERROR:WU00:FS00:Exception: Could not get an assignment
05:24:08:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:24:08:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:24:09:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:24:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:24:10:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2020-04-21 *******************************
11:22:05:           Bits: 32
11:22:05:           Bits: 32
11:22:05:           CPUs: 4
11:22:05:           GPUs: 1
11:22:05:           Bits: 32
11:22:06:<config>
11:22:06:
11:22:06:
11:22:06:</config>
11:39:52:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
11:52:18:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
12:04:45:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
12:17:09:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
12:29:40:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
12:42:18:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
12:55:02:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
13:07:49:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
13:19:59:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
13:32:25:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
13:44:46:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
13:56:41:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
13:56:42:WU01:FS00:Connecting to 65.254.110.245:80
13:56:43:WU01:FS00:Assigned to work server 40.114.52.201
13:56:43:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 40.114.52.201
13:56:43:WU01:FS00:Connecting to 40.114.52.201:8080
13:56:43:WU01:FS00:Downloading 2.14MiB
13:56:44:WU01:FS00:Download complete
13:56:44:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13851 run:0 clone:35063 gen:33 core:0xa7 unit:0x0000002f287234c95e78814237951873
14:08:34:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
14:08:36:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
14:08:36:WU00:FS00:0xa7:Saving result file frame39.edr
14:08:36:WU00:FS00:0xa7:Saving result file frame39.trr
14:08:36:WU00:FS00:0xa7:Saving result file frame39.xtc
14:08:36:WU00:FS00:0xa7:Saving result file md.log
14:08:36:WU00:FS00:0xa7:Saving result file science.log
14:08:36:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
14:08:37:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:08:37:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:18468 gen:39 core:0xa7 unit:0x00000034287234c95e7302d7c6385c78
14:08:37:WU00:FS00:Uploading 2.51MiB to 40.114.52.201
14:08:37:WU01:FS00:Starting
14:08:37:WU00:FS00:Connecting to 40.114.52.201:8080
14:08:37:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\wdumo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 10788 -checkpoint 15 -np 4
14:08:37:WU01:FS00:Started FahCore on PID 3404
14:08:37:WU01:FS00:Core PID:5440
14:08:37:WU01:FS00:FahCore 0xa7 started
14:08:38:WU01:FS00:0xa7:*********************** Log Started 2020-04-19T14:08:38Z ***********************
14:08:38:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:08:38:WU01:FS00:0xa7:       Type: 0xa7
14:08:38:WU01:FS00:0xa7:       Core: Gromacs
14:08:38:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 3404 -checkpoint 15 -np 4
14:08:38:WU01:FS00:0xa7:************************************ CBang *************************************
14:08:38:WU01:FS00:0xa7:       Date: Oct 26 2019
14:08:38:WU01:FS00:0xa7:       Time: 01:38:25
14:08:38:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:08:38:WU01:FS00:0xa7:     Branch: master
14:08:38:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
14:08:38:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:08:38:WU01:FS00:0xa7:   Platform: win32 10
14:08:38:WU01:FS00:0xa7:       Bits: 64
14:08:38:WU01:FS00:0xa7:       Mode: Release
14:08:38:WU01:FS00:0xa7:************************************ System ************************************
14:08:38:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
14:08:38:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:08:38:WU01:FS00:0xa7:       CPUs: 4
14:08:38:WU01:FS00:0xa7:     Memory: 7.60GiB
14:08:38:WU01:FS00:0xa7:Free Memory: 5.27GiB
14:08:38:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
14:08:38:WU01:FS00:0xa7: OS Version: 6.2
14:08:38:WU01:FS00:0xa7:Has Battery: true
14:08:38:WU01:FS00:0xa7: On Battery: false
14:08:38:WU01:FS00:0xa7: UTC Offset: 2
14:08:38:WU01:FS00:0xa7:        PID: 5440
14:08:38:WU01:FS00:0xa7:        CWD: C:\Users\wdumo\AppData\Roaming\FAHClient\work
14:08:38:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
14:08:38:WU01:FS00:0xa7:    Version: 0.0.18
14:08:38:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:08:38:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:08:38:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
14:08:38:WU01:FS00:0xa7:       Time: 01:52:30
14:08:38:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:08:38:WU01:FS00:0xa7:************************************ Build *************************************
14:08:38:WU01:FS00:0xa7:       SIMD: avx_256
14:08:38:WU01:FS00:0xa7:********************************************************************************
14:08:38:WU01:FS00:0xa7:Project: 13851 (Run 0, Clone 35063, Gen 33)
14:08:38:WU01:FS00:0xa7:Unit: 0x0000002f287234c95e78814237951873
14:08:38:WU01:FS00:0xa7:Reading tar file core.xml
14:08:38:WU01:FS00:0xa7:Reading tar file frame33.tpr
14:08:38:WU01:FS00:0xa7:Digital signatures verified
14:08:38:WU01:FS00:0xa7:Calling: mdrun -s frame33.tpr -o frame33.trr -x frame33.xtc -e frame33.edr -cpt 15 -nt 4
14:08:38:WU01:FS00:0xa7:Steps: first=16500000 total=500000
14:08:40:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
14:08:42:WU00:FS00:Upload complete
14:08:42:WU00:FS00:Server responded WORK_ACK (400)
14:08:42:WU00:FS00:Final credit estimate, 2344.00 points
14:08:42:WU00:FS00:Cleaning up
14:16:24:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
14:24:54:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
14:25:58:28:127.0.0.1:New Web session
14:34:16:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
14:43:31:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
14:52:25:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
15:01:10:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
15:10:01:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
15:18:47:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
15:27:31:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
15:36:22:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
15:46:16:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
15:55:05:WU01:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
16:04:49:WU01:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
11:22:05:           Bits: 32
11:22:05:           Bits: 32
11:22:05:           CPUs: 4
11:22:05:           GPUs: 1
11:22:05:           Bits: 32
11:22:06:<config>
11:22:06:
11:22:06:
11:22:06:</config>
11:22:05:           Bits: 32
11:22:05:           Bits: 32
11:22:05:           CPUs: 4
11:22:05:           GPUs: 1
11:22:05:           Bits: 32
11:22:06:<config>
11:22:06:
11:22:06:
11:22:06:</config>
16:14:16:WU01:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
16:23:46:WU01:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
16:32:42:WU01:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
16:42:09:WU01:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
11:22:05:           Bits: 32
11:22:05:           Bits: 32
11:22:05:           CPUs: 4
11:22:05:           GPUs: 1
11:22:05:           Bits: 32
11:22:06:<config>
11:22:06:
11:22:06:
11:22:06:</config>
anandhanju
Post by anandhanju »
If you haven't tried this already: Set the current WU to finish. Once it upload and is no longer running any work unit, delete the existing slot and save your changes. Now go back in and create a new CPU slot with number of CPUs=4. You may have to use the Advanced Control for this.
wdumon wrote:Hi, now at WU number 5 and still getting the warning "lowered CPUs from 4 to 1", although I've configured it to 4 instead of -1. Any idea what could cause that?...
The reduction of 5 to 4 is to prevent the domain decomposition error. Simply put, the assigned WU can't be evenly distributed among 5 CPUs so had to use 4 CPUs. You can read more information about this here: http://www.gromacs.org/Documentation/Er ... ze_of_x_nm
wdumon
Post by wdumon »
hi PantherX, I set it to 4 and the message is 4 tot 1 not 5 tot 4. There's only 4 cores in the CPU as well :)
Sorry, I went off on a different tangent... so this message:
It means that the Assignment Server couldn't find a WU for 4 CPUs so instead lowered your CPU count to 1 and then assigned you a WU with 1 CPU.
EDIT: While there are cases of AS reducing the CPUs to assign a WU, the above isn't one of that. Instead, the above is a case where a WU is limited to a number of threads and even if the CPU Slot was configured to a higher value, it will not be able to use it unless a new WU is downloaded.
