No gpu utilization
No gpu utilization
Hi, I got an older machine of mine going and i installed the F@H client on it so i could contribute more and for some reason its folding on the cpu but not recognizing the gpu is there too. is it too old?
Video card is a GTX 650TI
FU*K CANCER!!!!!!!
Re: No gpu utilization
The GPU itself is on the list of working chips, so it should work in general. Could you please post the first 200 lines of your FAH log with specs about your system, video cards, etc? There is a range of things that could help.
https://www.techpowerup.com/gpu-specs/g ... 0-ti.c1188
Your card can fold, it supports both OpenCL 1.2 and Double Precision floating point math
here is hints on posting the log
viewtopic.php?f=24&t=26036
Here's the log as requested
*********************** Log Started 2020-04-22T06:08:09Z ***********************
06:08:09:****************************** FAHClient ******************************
06:08:09: Version: 7.6.9
06:08:09: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:08:09: Copyright: 2020 foldingathome.org
06:08:09: Homepage: https://foldingathome.org/
06:08:09: Date: Apr 17 2020
06:08:09: Time: 11:13:06
06:08:09: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
06:08:09: Branch: master
06:08:09: Compiler: Visual C++ 2008
06:08:09: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:08:09: Platform: win32 10
06:08:09: Bits: 32
06:08:09: Mode: Release
06:08:09: Args: --open-web-control
06:08:09:******************************** CBang ********************************
06:08:09: Time: 11:10:09
06:08:09: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
06:08:09: Bits: 32
06:08:09:******************************* System ********************************
06:08:09: CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
06:08:09: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:08:09: CPUs: 4
06:08:09: Memory: 7.93GiB
06:08:09: Free Memory: 5.40GiB
06:08:09: Threads: WINDOWS_THREADS
06:08:09: OS Version: 6.2
06:08:09: Has Battery: false
06:08:09: On Battery: false
06:08:09: UTC Offset: 10
06:08:09: PID: 5752
06:08:09: CWD: C:\Users\\AppData\Roaming\FAHClient
06:08:09: OS: Windows 10 Home
06:08:09: OS Arch: AMD64
06:08:09: GPUs: 0
06:08:09: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:11.0
06:08:09:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
06:08:09: Win32 Service: false
06:08:09:******************************* libFAH ********************************
06:08:09: Date: Apr 15 2020
06:08:09: Time: 14:53:14
06:08:09: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
06:08:09: Bits: 32
06:08:09:***********************************************************************
06:08:09:<config>
06:08:09: <!-- Folding Slots -->
06:08:09:</config>
06:08:09:Trying to access database...
06:08:09:Successfully acquired database lock
06:08:09:Enabled folding slot 00: PAUSED cpu:3 (not configured)
06:08:14:17:127.0.0.1:New Web session
06:09:01:Set client configured
06:09:02:WU00:FS00:Connecting to 65.254.110.245:80
06:09:03:WU00:FS00:Connecting to 65.254.110.245:80
06:09:03:WU00:FS00:Assigned to work server 155.247.164.213
06:09:03:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.213
06:09:03:WU00:FS00:Connecting to 155.247.164.213:8080
06:09:05:WU00:FS00:Downloading 1.24MiB
06:09:07:WU00:FS00:Download complete
06:09:07:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14307 run:5 clone:143 gen:87 core:0xa7 unit:0x000000659bf7a4d55e66c532dd38d2fa
06:09:07:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
06:09:07:WU00:FS00:Connecting to cores.foldingathome.org:80
06:09:08:WU00:FS00:FahCore a7: Downloading 6.71MiB
06:09:10:Saving configuration to config.xml
06:09:10:<config>
06:09:10: <!-- User Information -->
06:09:10: <team v=''/>
06:09:10: <user v=''/>
06:09:10:
06:09:10: <!-- Folding Slots -->
06:09:10: <slot id='0' type='CPU'/>
06:09:10:</config>
06:09:11:WU00:FS00:FahCore a7: Download complete
06:09:11:WU00:FS00:Valid core signature
06:09:11:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
06:09:11:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
06:09:11:WU00:FS00:Starting
06:09:11:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 706 -lifeline 5752 -checkpoint 15 -np 3
06:09:11:WU00:FS00:Started FahCore on PID 11060
06:09:12:WU00:FS00:Core PID:10596
06:09:12:WU00:FS00:FahCore 0xa7 started
06:09:13:WU00:FS00:0xa7:*********************** Log Started 2020-04-22T06:09:13Z ***********************
06:09:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:09:13:WU00:FS00:0xa7: Type: 0xa7
06:09:13:WU00:FS00:0xa7: Core: Gromacs
06:09:13:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 11060 -checkpoint 15 -np
06:09:13:WU00:FS00:0xa7: 3
06:09:13:WU00:FS00:0xa7:************************************ CBang *************************************
06:09:13:WU00:FS00:0xa7: Date: Oct 26 2019
06:09:13:WU00:FS00:0xa7: Time: 01:38:25
06:09:13:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
06:09:13:WU00:FS00:0xa7: Branch: master
06:09:13:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:09:13:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:09:13:WU00:FS00:0xa7: Platform: win32 10
06:09:13:WU00:FS00:0xa7: Bits: 64
06:09:13:WU00:FS00:0xa7: Mode: Release
06:09:13:WU00:FS00:0xa7:************************************ System ************************************
06:09:13:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
06:09:13:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:09:13:WU00:FS00:0xa7: CPUs: 4
06:09:13:WU00:FS00:0xa7: Memory: 7.93GiB
06:09:13:WU00:FS00:0xa7:Free Memory: 5.42GiB
06:09:13:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:09:13:WU00:FS00:0xa7: OS Version: 6.2
06:09:13:WU00:FS00:0xa7:Has Battery: false
06:09:13:WU00:FS00:0xa7: On Battery: false
06:09:13:WU00:FS00:0xa7: UTC Offset: 10
06:09:13:WU00:FS00:0xa7: PID: 10596
06:09:13:WU00:FS00:0xa7: CWD: C:\Users\\AppData\Roaming\FAHClient\work
06:09:13:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:09:13:WU00:FS00:0xa7: Version: 0.0.18
06:09:13:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:09:13:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:09:13:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:09:13:WU00:FS00:0xa7: Time: 01:52:30
06:09:13:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
06:09:13:WU00:FS00:0xa7:************************************ Build *************************************
06:09:13:WU00:FS00:0xa7: SIMD: avx_256
06:09:13:WU00:FS00:0xa7:********************************************************************************
06:09:13:WU00:FS00:0xa7:Project: 14307 (Run 5, Clone 143, Gen 87)
06:09:13:WU00:FS00:0xa7:Unit: 0x000000659bf7a4d55e66c532dd38d2fa
06:09:13:WU00:FS00:0xa7:Reading tar file core.xml
06:09:13:WU00:FS00:0xa7:Reading tar file frame87.tpr
06:09:13:WU00:FS00:0xa7:Digital signatures verified
06:09:13:WU00:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -cpt 15 -nt 3
06:09:13:WU00:FS00:0xa7:Steps: first=43500000 total=500000
06:09:14:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
06:09:18:FS00:Shutting core down
06:09:18:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 10596
06:09:18:WU00:FS00:0xa7:Exiting, please wait. . .
06:09:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:09:19:WU00:FS00:Starting
06:09:19:WARNING:WU00:FS00:Changed SMP threads from 3 to 4 this can cause some work units to fail
06:09:19:WARNING:WU00:FS00:AS lowered CPUs from 4 to 3
06:09:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 706 -lifeline 5752 -checkpoint 15 -np 3
06:09:19:WU00:FS00:Started FahCore on PID 3416
06:09:19:WU00:FS00:Core PID:10992
06:09:19:WU00:FS00:FahCore 0xa7 started
06:09:19:WU00:FS00:0xa7:*********************** Log Started 2020-04-22T06:09:19Z ***********************
06:09:19:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:09:19:WU00:FS00:0xa7: Type: 0xa7
06:09:19:WU00:FS00:0xa7: Core: Gromacs
06:09:19:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 3416 -checkpoint 15 -np 3
06:09:19:WU00:FS00:0xa7:************************************ CBang *************************************
06:09:19:WU00:FS00:0xa7: Date: Oct 26 2019
06:09:19:WU00:FS00:0xa7: Time: 01:38:25
06:09:19:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
06:09:19:WU00:FS00:0xa7: Branch: master
06:09:19:WU00:FS00:0xa7: Compiler: Visual C++ 2008
06:09:19:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:09:19:WU00:FS00:0xa7: Platform: win32 10
06:09:19:WU00:FS00:0xa7: Bits: 64
06:09:19:WU00:FS00:0xa7: Mode: Release
06:09:19:WU00:FS00:0xa7:************************************ System ************************************
06:09:19:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
06:09:19:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:09:19:WU00:FS00:0xa7: CPUs: 4
06:09:19:WU00:FS00:0xa7: Memory: 7.93GiB
06:09:19:WU00:FS00:0xa7:Free Memory: 5.42GiB
06:09:19:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:09:19:WU00:FS00:0xa7: OS Version: 6.2
06:09:19:WU00:FS00:0xa7:Has Battery: false
06:09:19:WU00:FS00:0xa7: On Battery: false
06:09:19:WU00:FS00:0xa7: UTC Offset: 10
06:09:19:WU00:FS00:0xa7: PID: 10992
06:09:19:WU00:FS00:0xa7: CWD: C:\Users\\AppData\Roaming\FAHClient\work
06:09:19:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:09:19:WU00:FS00:0xa7: Version: 0.0.18
06:09:19:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:09:19:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
06:09:19:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
06:09:19:WU00:FS00:0xa7: Time: 01:52:30
06:09:19:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
06:09:19:WU00:FS00:0xa7:************************************ Build *************************************
06:09:19:WU00:FS00:0xa7: SIMD: avx_256
06:09:19:WU00:FS00:0xa7:********************************************************************************
06:09:19:WU00:FS00:0xa7:Project: 14307 (Run 5, Clone 143, Gen 87)
06:09:19:WU00:FS00:0xa7:Unit: 0x000000659bf7a4d55e66c532dd38d2fa
06:09:19:WU00:FS00:0xa7:Digital signatures verified
06:09:19:WU00:FS00:0xa7:Calling: mdrun -s frame87.tpr -o frame87.trr -cpi state.cpt -cpt 15 -nt 3
06:09:19:WU00:FS00:0xa7:Steps: first=43500000 total=500000
06:09:20:WU00:FS00:0xa7:Completed 282 out of 500000 steps (0%)
06:10:11:Saving configuration to config.xml
06:10:11:<config>
06:10:11: <!-- Slot Control -->
06:10:11: <power v='FULL'/>
06:10:11:
06:10:11: <!-- User Information -->
06:10:11: <team v=''/>
06:10:11: <user v=''/>
06:10:11:
06:10:11: <!-- Folding Slots -->
06:10:11: <slot id='0' type='CPU'/>
06:10:11:</config>
06:10:29:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)FU*K CANCER!!!!!!!
I can't tell which GPU you have. The log you posted says
So it seems like you have no GPU that FAH supports. FAH does have a list of supported GPUs which include both AMD GPUs and nVIDIA GPUs used commonly in gaming computers so that wouldn't surprise me.
FAH does not support GPU folding on Intel GPUs.
06:08:09: GPUs: 0
06:08:09:******************************* libFAH ********************************FAH does not support GPU folding on Intel GPUs.
Yes, the GTX 650 Ti is supported.
Be sure you've installed the drivers from nvidia.com (not from Microsoft) and you've rebooted.
If that doesn't work, please post the first couple of pages from FAH's log per the instructions below.
yes currently using the latest drivers from nvidia through the geforce experience.
i will add since i made this post i have done a complete reinstall of windows and all the drivers on a new ssd and the issue is still here
FU*K CANCER!!!!!!!
Post a fresh copy of the first 100 lines of FAH's log.
Start FAHControl and check the "expert" configuration settings for GPU=FALSE or GPU=TRUE
Near the place where you can find FAH's log do you find a file called GPUS.txt?
If there's no GPUs.txt file, then follow these instructions to enable the GPU Slot:
Manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to %AppData%\FAHClient
Reboot your system
Start up the client and ensure that you can see your GPU in the log file
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
BTW, I noticed this in your log file:
Where you have double back-slash when compared to mine:
CWD: C:\Users\PantherX-H\AppData\Roaming\FAHClient
Exit the client
Reboot your system
PantherX i followed what you said to do but it hasn't worked unfortunately.
I edited out users
I edited out users
FU*K CANCER!!!!!!!
Humm... that's weird. Can you please post a fresh copy of the log?
Middle of the night blurry: some one said you need to reboot after adding GPUs.txt and then adding the GPU slot can stick.
So reboot and Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
again.
again.
rebooted several times. Downloaded the file again and replaced the file in F@H client. Restarted several times again, each time trying to add gpu in config. When i highlight gpu and click add a name and value box appear. i cant go further.
FU*K CANCER!!!!!!!
*********************** Log Started 2020-04-22T08:40:33Z ***********************
08:40:33:****************************** FAHClient ******************************
08:40:33: Version: 7.6.9
08:40:33: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:40:33: Copyright: 2020 foldingathome.org
08:40:33: Homepage: https://foldingathome.org/
08:40:33: Date: Apr 17 2020
08:40:33: Time: 11:13:06
08:40:33: Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
08:40:33: Branch: master
08:40:33: Compiler: Visual C++ 2008
08:40:33: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:40:33: Platform: win32 10
08:40:33: Bits: 32
08:40:33: Mode: Release
08:40:33: Config: C:\Users\\AppData\Roaming\FAHClient\config.xml
08:40:33:******************************** CBang ********************************
08:40:33: Time: 11:10:09
08:40:33: Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
08:40:33: Bits: 32
08:40:33:******************************* System ********************************
08:40:33: CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
08:40:33: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
08:40:33: CPUs: 4
08:40:33: Memory: 7.93GiB
08:40:33: Free Memory: 5.98GiB
08:40:33: Threads: WINDOWS_THREADS
08:40:33: OS Version: 6.2
08:40:33: Has Battery: false
08:40:33: On Battery: false
08:40:33: UTC Offset: 10
08:40:33: PID: 10028
08:40:33: CWD: C:\Users\\AppData\Roaming\FAHClient
08:40:33: OS: Windows 10 Home
08:40:33: OS Arch: AMD64
08:40:33: GPUs: 1
08:40:33: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK106 [GeForce GTX 650 Ti]
08:40:33: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:11.0
08:40:33:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
08:40:33: Win32 Service: false
08:40:33:******************************* libFAH ********************************
08:40:33: Date: Apr 15 2020
08:40:33: Time: 14:53:14
08:40:33: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
08:40:33: Bits: 32
08:40:33:***********************************************************************
08:40:33:<config>
08:40:33: <!-- Folding Slot Configuration -->
08:40:33: <cause v='COVID_19'/>
08:40:33:
08:40:33: <!-- Network -->
08:40:33: <proxy v=':8080'/>
08:40:33:
08:40:33: <!-- Slot Control -->
08:40:33: <power v='MEDIUM'/>
08:40:33:
08:40:33: <!-- User Information -->
08:40:33: <team v=''/>
08:40:33: <user v=''/>
08:40:33:
08:40:33: <!-- Folding Slots -->
08:40:33: <slot id='0' type='CPU'/>
08:40:33:</config>
08:40:33:Trying to access database...
08:40:33:Successfully acquired database lock
08:40:33:Enabled folding slot 00: READY cpu:3
08:40:33:WU01:FS00:Starting
08:40:33:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 706 -lifeline 10028 -checkpoint 15 -np 3
08:40:33:WU01:FS00:Started FahCore on PID 10164
08:40:33:WU01:FS00:Core PID:10192
08:40:33:WU01:FS00:FahCore 0xa7 started
08:40:34:WU01:FS00:0xa7:*********************** Log Started 2020-04-22T08:40:33Z ***********************
08:40:34:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:40:34:WU01:FS00:0xa7: Type: 0xa7
08:40:34:WU01:FS00:0xa7: Core: Gromacs
08:40:34:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 706 -lifeline 10164 -checkpoint 15 -np
08:40:34:WU01:FS00:0xa7: 3
08:40:34:WU01:FS00:0xa7:************************************ CBang *************************************
08:40:34:WU01:FS00:0xa7: Date: Oct 26 2019
08:40:34:WU01:FS00:0xa7: Time: 01:38:25
08:40:34:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:40:34:WU01:FS00:0xa7: Branch: master
08:40:34:WU01:FS00:0xa7: Compiler: Visual C++ 2008
08:40:34:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:40:34:WU01:FS00:0xa7: Platform: win32 10
08:40:34:WU01:FS00:0xa7: Bits: 64
08:40:34:WU01:FS00:0xa7: Mode: Release
08:40:34:WU01:FS00:0xa7:************************************ System ************************************
08:40:34:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
08:40:34:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
08:40:34:WU01:FS00:0xa7: CPUs: 4
08:40:34:WU01:FS00:0xa7: Memory: 7.93GiB
08:40:34:WU01:FS00:0xa7:Free Memory: 5.95GiB
08:40:34:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
08:40:34:WU01:FS00:0xa7: OS Version: 6.2
08:40:34:WU01:FS00:0xa7:Has Battery: false
08:40:34:WU01:FS00:0xa7: On Battery: false
08:40:34:WU01:FS00:0xa7: UTC Offset: 10
08:40:34:WU01:FS00:0xa7: PID: 10192
08:40:34:WU01:FS00:0xa7: CWD: C:\Users\\AppData\Roaming\FAHClient\work
08:40:34:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:40:34:WU01:FS00:0xa7: Version: 0.0.18
08:40:34:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:40:34:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
08:40:34:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
08:40:34:WU01:FS00:0xa7: Time: 01:52:30
08:40:34:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:40:34:WU01:FS00:0xa7:************************************ Build *************************************
08:40:34:WU01:FS00:0xa7: SIMD: avx_256
08:40:34:WU01:FS00:0xa7:********************************************************************************
08:40:34:WU01:FS00:0xa7:Project: 14379 (Run 1716, Clone 1, Gen 27)
08:40:34:WU01:FS00:0xa7:Unit: 0x0000001d455e42075e932ed5d8e35d11
08:40:34:WU01:FS00:0xa7:Digital signatures verified
08:40:34:WU01:FS00:0xa7:Calling: mdrun -s frame27.tpr -o frame27.trr -cpt 15 -nt 3
08:40:34:WU01:FS00:0xa7:Steps: first=0 total=250000
08:40:35:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
08:43:14:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
08:45:50:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
08:48:24:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)FU*K CANCER!!!!!!!
