How does F@H decide whether a work unit is okay or faulty?
FoldingFodder
Post by FoldingFodder »
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: How does F@H decide whether a work unit is okay or fault
Post by Jesse_V »
The client performs a number of checks, such as ensuring that the simulation produces valid and sensible mathematical results and that all the files are present and working correctly. Additionally, the server performs a number of sanity and validation checks on the returned workunit. For example, is the client sending an actual F@h workunit, does the workunit have all the expected files, does the workunit follow the correct format, was the workunit processed with the correct FAHCore, are all the atoms in sane locations, and so on. If these checks fail, the workunit is marked as faulty and the server will reassign it to someone else. If the workunit fails for several different people, it notifies one of the research labs that something is wrong that particular trajectory that cannot be explained by glitches, user action, or unstable hardware.
