Supported GPU but unsupported because of name
TheProgrammer7
Post by TheProgrammer7 »
I use the computer MSI GF53 8RD and in the advertising they showed that they added the GPU with a Max Q Design, since the name is different the app thinks the GPU is unsupported :( . Is it possible to make it work or does the Max Q Design make it incompatible? (I hope not)
Re: Supported GPU but unsupported because of name
Welcome to the F@H Forum TheProgrammer7,
Please not that Max-Q seems to be a branding term for laptop designs and performance: https://blogs.nvidia.com/blog/2018/12/14/what-is-max-q/
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=38&t=26036 :)
Also, for your GPU, can you please post pictures of GPU-Z so we can identify if the Device ID is whitelisted or not.
TheProgrammer7
*********************** Log Started 2020-04-18T10:13:57Z ***********************
10:13:57:****************************** FAHClient ******************************
10:13:57:        Version: 7.6.9
10:13:57:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:13:57:      Copyright: 2020 foldingathome.org
10:13:57:       Homepage: https://foldingathome.org/
10:13:57:           Date: Apr 17 2020
10:13:57:           Time: 11:13:06
10:13:57:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
10:13:57:         Branch: master
10:13:57:       Compiler: Visual C++ 2008
10:13:57:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:13:57:       Platform: win32 10
10:13:57:           Bits: 32
10:13:57:           Mode: Release
10:13:57:           Args: --open-web-control
10:13:57:         Config: C:\Users\Admin\AppData\Roaming\FAHClient\config.xml
10:13:57:******************************** CBang ********************************
10:13:57:           Time: 11:10:09
10:13:57:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
10:13:57:           Bits: 32
10:13:57:******************************* System ********************************
10:13:57:            CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
10:13:57:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
10:13:57:           CPUs: 12
10:13:57:         Memory: 7.85GiB
10:13:57:    Free Memory: 4.45GiB
10:13:57:        Threads: WINDOWS_THREADS
10:13:57:     OS Version: 6.2
10:13:57:    Has Battery: true
10:13:57:     On Battery: false
10:13:57:     UTC Offset: 8
10:13:57:            PID: 4448
10:13:57:            CWD: C:\Users\Admin\AppData\Roaming\FAHClient
10:13:57:             OS: Windows 10 Home
10:13:57:        OS Arch: AMD64
10:13:57:           GPUs: 2
10:13:57:          GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 [xxx]
10:13:57:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:5 GP107M [GeForce GTX 1050 Ti Max-Q]
10:13:57:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
10:13:57:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
10:13:57:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
10:13:57:  Win32 Service: false
10:13:57:******************************* libFAH ********************************
10:13:57:           Date: Apr 15 2020
10:13:57:           Time: 14:53:14
10:13:57:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
10:13:57:           Bits: 32
10:13:57:***********************************************************************
10:13:57:<config>
10:13:57:  <!-- Slot Control -->
10:13:57:  <power v='FULL'/>
10:13:57:
10:13:57:  <!-- User Information -->
10:13:57:  <passkey v='*****'/>
10:13:57:  <team v='251999'/>
10:13:57:  <user v='TheProgrammer7'/>
10:13:57:
10:13:57:  <!-- Folding Slots -->
10:13:57:  <slot id='0' type='CPU'/>
10:13:57:</config>
10:13:57:Trying to access database...
10:13:57:Successfully acquired database lock
10:13:57:Enabled folding slot 00: READY cpu:12
10:13:57:WU00:FS00:Starting
10:13:57:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 4448 -checkpoint 15 -np 12
10:13:58:WU00:FS00:Started FahCore on PID 13628
10:14:00:WU00:FS00:Core PID:13972
10:14:00:WU00:FS00:FahCore 0xa7 started
10:14:00:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T10:14:00Z ***********************
10:14:00:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:14:00:WU00:FS00:0xa7:       Type: 0xa7
10:14:00:WU00:FS00:0xa7:       Core: Gromacs
10:14:00:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 13628 -checkpoint 15 -np
10:14:00:WU00:FS00:0xa7:             12
10:14:00:WU00:FS00:0xa7:************************************ CBang *************************************
10:14:00:WU00:FS00:0xa7:       Date: Oct 26 2019
10:14:00:WU00:FS00:0xa7:       Time: 01:38:25
10:14:00:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:14:00:WU00:FS00:0xa7:     Branch: master
10:14:01:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:14:01:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:14:01:WU00:FS00:0xa7:   Platform: win32 10
10:14:01:WU00:FS00:0xa7:       Bits: 64
10:14:01:WU00:FS00:0xa7:       Mode: Release
10:14:01:WU00:FS00:0xa7:************************************ System ************************************
10:14:01:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
10:14:01:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
10:14:01:WU00:FS00:0xa7:       CPUs: 12
10:14:01:WU00:FS00:0xa7:     Memory: 7.85GiB
10:14:01:WU00:FS00:0xa7:Free Memory: 3.92GiB
10:14:01:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:14:01:WU00:FS00:0xa7: OS Version: 6.2
10:14:01:WU00:FS00:0xa7:Has Battery: true
10:14:01:WU00:FS00:0xa7: On Battery: false
10:14:01:WU00:FS00:0xa7: UTC Offset: 8
10:14:01:WU00:FS00:0xa7:        PID: 13972
10:14:01:WU00:FS00:0xa7:        CWD: C:\Users\Admin\AppData\Roaming\FAHClient\work
10:14:01:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:14:01:WU00:FS00:0xa7:    Version: 0.0.18
10:14:01:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:14:01:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:14:01:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:14:01:WU00:FS00:0xa7:       Date: Oct 26 2019
10:14:01:WU00:FS00:0xa7:       Time: 01:52:30
10:14:01:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:14:01:WU00:FS00:0xa7:     Branch: master
10:14:01:WU00:FS00:0xa7:************************************ Build *************************************
10:14:01:WU00:FS00:0xa7:       SIMD: avx_256
10:14:01:WU00:FS00:0xa7:********************************************************************************
10:14:01:WU00:FS00:0xa7:Project: 13861 (Run 0, Clone 10917, Gen 61)
10:14:01:WU00:FS00:0xa7:Unit: 0x000000450d5a98395e730d54dcc40f09
10:14:01:WU00:FS00:0xa7:Digital signatures verified
10:14:01:WU00:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -x frame61.xtc -e frame61.edr -cpi state.cpt -cpt 15 -nt 12
10:14:01:WU00:FS00:0xa7:Steps: first=7625000 total=125000
10:14:10:WU00:FS00:0xa7:Completed 14151 out of 125000 steps (11%)
10:14:47:21:127.0.0.1:New Web session
10:15:24:WU00:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
10:16:35:WU00:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
10:17:23:WU00:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
10:18:11:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
10:19:09:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
10:19:58:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
10:20:45:WU00:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
10:21:34:WU00:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
10:22:21:WU00:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
10:23:11:WU00:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
10:24:11:WU00:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
10:25:03:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
10:25:50:WU00:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
10:26:37:WU00:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
10:27:25:WU00:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
10:28:14:WU00:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
10:29:02:WU00:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
10:29:51:WU00:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
10:30:38:WU00:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
10:31:25:WU00:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
10:32:12:WU00:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
10:33:00:WU00:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
10:33:51:WU00:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
10:34:38:WU00:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
10:35:26:WU00:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
10:36:13:WU00:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
10:37:01:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
10:37:48:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
10:38:35:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
10:39:22:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
10:40:09:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
10:40:56:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
10:41:43:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
10:42:30:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
10:43:17:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
10:44:08:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
10:44:57:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
10:45:45:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
10:46:33:WU00:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
10:47:20:WU00:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
10:48:07:WU00:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
10:48:54:WU00:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
10:49:41:WU00:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
10:50:29:WU00:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
10:51:16:WU00:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
10:52:03:WU00:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
10:52:51:WU00:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
10:53:39:WU00:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
10:54:27:WU00:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
10:55:14:WU00:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
10:56:01:WU00:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
10:56:48:WU00:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
10:57:35:WU00:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
10:58:23:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
10:59:11:WU00:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
10:59:58:WU00:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
11:00:45:WU00:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
11:01:32:WU00:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
11:02:20:WU00:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
11:03:07:WU00:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
11:03:54:WU00:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
11:04:41:WU00:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
11:05:29:WU00:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
11:06:16:WU00:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
11:07:03:WU00:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
11:07:50:WU00:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
11:08:37:WU00:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
11:09:34:WU00:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
11:10:31:WU00:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
11:11:22:WU00:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
11:12:14:WU00:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
11:13:08:WU00:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
11:14:00:WU00:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
11:14:52:WU00:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
11:15:40:WU00:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
11:16:27:WU00:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
11:17:18:WU00:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
11:18:05:WU00:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
11:18:52:WU00:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
11:19:40:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
11:20:27:WU00:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
11:21:14:WU00:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
11:22:01:WU00:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
11:22:48:WU00:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
11:23:36:WU00:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
11:24:23:WU00:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
11:25:10:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
11:25:57:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
11:25:58:WU01:FS00:Connecting to 65.254.110.245:80
11:25:59:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
11:25:59:WU01:FS00:Connecting to 18.218.241.186:80
11:26:00:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:26:00:WU01:FS00:Connecting to 65.254.110.245:80
11:26:00:WU01:FS00:Assigned to work server 155.247.164.213
11:26:00:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 155.247.164.213
11:26:00:WU01:FS00:Connecting to 155.247.164.213:8080
11:26:22:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
11:26:22:WU01:FS00:Connecting to 155.247.164.213:80
11:26:45:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
11:26:48:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
11:26:48:WU00:FS00:0xa7:Saving result file frame61.edr
11:26:48:WU00:FS00:0xa7:Saving result file frame61.trr
11:26:48:WU00:FS00:0xa7:Saving result file frame61.xtc
11:26:48:WU00:FS00:0xa7:Saving result file md.log
11:26:48:WU00:FS00:0xa7:Saving result file science.log
11:26:48:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:26:49:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:26:49:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13861 run:0 clone:10917 gen:61 core:0xa7 unit:0x000000450d5a98395e730d54dcc40f09
11:26:49:WU00:FS00:Uploading 5.26MiB to 13.90.152.57
11:26:49:WU00:FS00:Connecting to 13.90.152.57:8080
11:26:55:WU00:FS00:Upload 33.29%
11:26:55:WU01:FS00:Downloading 1.23MiB
11:27:01:WU00:FS00:Upload 66.57%
11:27:02:WU01:FS00:Download 60.74%
11:27:07:WU00:FS00:Upload 98.67%
11:27:07:WU00:FS00:Upload complete
11:27:07:WU00:FS00:Server responded WORK_ACK (400)
11:27:07:WU00:FS00:Final credit estimate, 2087.00 points
11:27:07:WU00:FS00:Cleaning up
11:27:08:WU01:FS00:Download 70.86%
11:27:14:WU01:FS00:Download 80.98%
11:27:21:WU01:FS00:Download 91.10%
11:27:25:WU01:FS00:Download complete
11:27:25:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14198 run:0 clone:204 gen:70 core:0xa7 unit:0x000000509bf7a4d55e66d071c330045f
11:27:25:WU01:FS00:Starting
11:27:25:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 4448 -checkpoint 15 -np 12
11:27:26:WU01:FS00:Started FahCore on PID 15260
11:27:26:WU01:FS00:Core PID:17096
11:27:26:WU01:FS00:FahCore 0xa7 started
11:27:27:WU01:FS00:0xa7:*********************** Log Started 2020-04-18T11:27:26Z ***********************
11:27:27:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:27:27:WU01:FS00:0xa7:       Type: 0xa7
11:27:27:WU01:FS00:0xa7:       Core: Gromacs
11:27:27:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 15260 -checkpoint 15 -np
11:27:27:WU01:FS00:0xa7:             12
11:27:27:WU01:FS00:0xa7:************************************ CBang *************************************
11:27:27:WU01:FS00:0xa7:       Date: Oct 26 2019
11:27:27:WU01:FS00:0xa7:       Time: 01:38:25
11:27:27:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:27:27:WU01:FS00:0xa7:     Branch: master
11:27:27:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:27:27:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:27:27:WU01:FS00:0xa7:   Platform: win32 10
11:27:27:WU01:FS00:0xa7:       Bits: 64
11:27:27:WU01:FS00:0xa7:       Mode: Release
11:27:27:WU01:FS00:0xa7:************************************ System ************************************
11:27:27:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
11:27:27:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:27:27:WU01:FS00:0xa7:       CPUs: 12
11:27:27:WU01:FS00:0xa7:     Memory: 7.85GiB
11:27:27:WU01:FS00:0xa7:Free Memory: 3.57GiB
11:27:27:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
11:27:27:WU01:FS00:0xa7: OS Version: 6.2
11:27:27:WU01:FS00:0xa7:Has Battery: true
11:27:27:WU01:FS00:0xa7: On Battery: false
11:27:27:WU01:FS00:0xa7: UTC Offset: 8
11:27:27:WU01:FS00:0xa7:        PID: 17096
11:27:27:WU01:FS00:0xa7:        CWD: C:\Users\Admin\AppData\Roaming\FAHClient\work
11:27:27:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:27:27:WU01:FS00:0xa7:    Version: 0.0.18
11:27:27:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:27:27:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:27:27:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:27:27:WU01:FS00:0xa7:       Time: 01:52:30
11:27:27:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:27:27:WU01:FS00:0xa7:************************************ Build *************************************
11:27:27:WU01:FS00:0xa7:       SIMD: avx_256
11:27:27:WU01:FS00:0xa7:********************************************************************************
11:27:27:WU01:FS00:0xa7:Project: 14198 (Run 0, Clone 204, Gen 70)
11:27:27:WU01:FS00:0xa7:Unit: 0x000000509bf7a4d55e66d071c330045f
11:27:27:WU01:FS00:0xa7:Reading tar file core.xml
11:27:27:WU01:FS00:0xa7:Reading tar file frame70.tpr
11:27:27:WU01:FS00:0xa7:Digital signatures verified
11:27:27:WU01:FS00:0xa7:Calling: mdrun -s frame70.tpr -o frame70.trr -cpt 15 -nt 12
11:27:27:WU01:FS00:0xa7:Steps: first=35000000 total=500000
11:27:27:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
11:27:38:50:127.0.0.1:New Web session
11:27:51:FS00:Paused
11:27:53:FS00:Shutting core down
11:27:54:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 17096
11:27:54:WU01:FS00:0xa7:Exiting, please wait. . .
11:27:54:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:27:55:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:28:10:Saving configuration to config.xml
11:28:10:<config>
11:28:10:  <!-- Slot Control -->
11:28:10:  <power v='FULL'/>
11:28:10:
11:28:10:  <!-- User Information -->
11:28:10:  <passkey v='*****'/>
11:28:10:  <team v='251999'/>
11:28:10:  <user v='TheProgrammer7'/>
11:28:10:
11:28:10:  <!-- Folding Slots -->
11:28:10:  <slot id='0' type='CPU'>
11:28:10:    <paused v='true'/>
11:28:10:  </slot>
11:28:10:</config>
11:29:11:Saving configuration to config.xml
11:29:11:<config>
11:29:11:  <!-- Folding Slot Configuration -->
11:29:11:  <cause v='COVID_19'/>
11:29:11:
11:29:11:  <!-- Slot Control -->
11:29:11:  <power v='FULL'/>
11:29:11:
11:29:11:  <!-- User Information -->
11:29:11:  <passkey v='*****'/>
11:29:11:  <team v='251999'/>
11:29:11:  <user v='TheProgrammer7'/>
11:29:11:
11:29:11:  <!-- Folding Slots -->
11:29:11:  <slot id='0' type='CPU'>
11:29:11:    <paused v='true'/>
11:29:11:  </slot>
11:29:11:</config>
11:31:04:FS00:Unpaused
11:31:04:WU01:FS00:Starting
11:31:04:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 4448 -checkpoint 15 -np 12
11:31:04:WU01:FS00:Started FahCore on PID 9260
11:31:05:WU01:FS00:Core PID:2712
11:31:05:WU01:FS00:FahCore 0xa7 started
11:31:06:WU01:FS00:0xa7:*********************** Log Started 2020-04-18T11:31:05Z ***********************
11:31:06:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:31:06:WU01:FS00:0xa7:       Type: 0xa7
11:31:06:WU01:FS00:0xa7:       Core: Gromacs
11:31:06:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 9260 -checkpoint 15 -np
11:31:06:WU01:FS00:0xa7:             12
11:31:06:WU01:FS00:0xa7:************************************ CBang *************************************
11:31:06:WU01:FS00:0xa7:       Date: Oct 26 2019
11:31:06:WU01:FS00:0xa7:       Time: 01:38:25
11:31:06:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:31:06:WU01:FS00:0xa7:     Branch: master
11:31:06:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
11:31:06:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:31:06:WU01:FS00:0xa7:   Platform: win32 10
11:31:06:WU01:FS00:0xa7:       Bits: 64
11:31:06:WU01:FS00:0xa7:       Mode: Release
11:31:06:WU01:FS00:0xa7:************************************ System ************************************
11:31:06:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
11:31:06:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:31:06:WU01:FS00:0xa7:       CPUs: 12
11:31:06:WU01:FS00:0xa7:     Memory: 7.85GiB
11:31:06:WU01:FS00:0xa7:Free Memory: 2.61GiB
11:31:06:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
11:31:06:WU01:FS00:0xa7: OS Version: 6.2
11:31:06:WU01:FS00:0xa7:Has Battery: true
11:31:06:WU01:FS00:0xa7: On Battery: false
11:31:06:WU01:FS00:0xa7: UTC Offset: 8
11:31:06:WU01:FS00:0xa7:        PID: 2712
11:31:06:WU01:FS00:0xa7:        CWD: C:\Users\Admin\AppData\Roaming\FAHClient\work
11:31:06:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:31:06:WU01:FS00:0xa7:    Version: 0.0.18
11:31:06:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:31:06:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:31:06:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:31:06:WU01:FS00:0xa7:       Time: 01:52:30
11:31:06:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:31:06:WU01:FS00:0xa7:************************************ Build *************************************
11:31:06:WU01:FS00:0xa7:       SIMD: avx_256
11:31:06:WU01:FS00:0xa7:********************************************************************************
11:31:06:WU01:FS00:0xa7:Project: 14198 (Run 0, Clone 204, Gen 70)
11:31:06:WU01:FS00:0xa7:Unit: 0x000000509bf7a4d55e66d071c330045f
11:31:06:WU01:FS00:0xa7:Digital signatures verified
11:31:06:WU01:FS00:0xa7:Calling: mdrun -s frame70.tpr -o frame70.trr -cpi state.cpt -cpt 15 -nt 12
11:31:06:WU01:FS00:0xa7:Steps: first=35000000 total=500000
11:31:06:WU01:FS00:0xa7:Completed 2982 out of 500000 steps (0%)
11:31:13:Saving configuration to config.xml
11:31:13:<config>
11:31:13:  <!-- Folding Slot Configuration -->
11:31:13:  <cause v='COVID_19'/>
11:31:13:
11:31:13:  <!-- Slot Control -->
11:31:13:  <power v='FULL'/>
11:31:13:
11:31:13:  <!-- User Information -->
11:31:13:  <passkey v='*****'/>
11:31:13:  <team v='251999'/>
11:31:13:  <user v='TheProgrammer7'/>
11:31:13:
11:31:13:  <!-- Folding Slots -->
11:31:13:  <slot id='0' type='CPU'/>
11:31:13:</config>
11:31:21:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
11:31:57:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
11:32:34:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
11:33:16:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
11:33:54:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
11:34:32:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
11:35:11:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
11:35:50:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
11:36:29:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
11:37:08:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
11:37:47:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
11:38:26:WU01:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
11:39:05:WU01:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
11:39:44:WU01:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
11:40:23:WU01:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
11:41:02:WU01:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
11:41:41:WU01:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
11:42:20:WU01:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
11:42:59:WU01:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
11:43:39:WU01:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
11:44:19:WU01:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
11:44:58:WU01:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
11:45:37:WU01:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
11:46:16:WU01:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
11:46:55:WU01:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
11:47:34:WU01:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
11:48:14:WU01:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
11:48:53:WU01:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
11:49:32:WU01:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
11:50:11:WU01:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
11:50:50:WU01:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
11:51:29:WU01:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
11:52:09:WU01:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
11:52:48:WU01:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
11:53:27:WU01:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
11:54:06:WU01:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
11:54:45:WU01:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
11:55:25:WU01:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
11:56:04:WU01:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
11:56:43:WU01:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
11:57:23:WU01:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
11:58:02:WU01:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
11:58:42:WU01:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
11:59:21:WU01:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
12:00:01:WU01:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
12:00:40:WU01:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
12:01:19:WU01:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
12:01:58:WU01:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
12:02:37:WU01:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
12:03:16:WU01:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
12:03:56:WU01:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
12:04:35:WU01:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
12:05:14:WU01:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
12:05:53:WU01:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
12:06:32:WU01:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
12:07:11:WU01:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
12:07:50:WU01:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
12:08:29:WU01:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
12:09:08:WU01:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
12:09:47:WU01:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
12:10:26:WU01:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
12:11:06:WU01:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
12:11:45:WU01:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
12:12:27:WU01:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
12:13:13:WU01:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
12:14:01:WU01:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
12:14:48:WU01:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
12:15:38:WU01:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
12:16:32:WU01:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
12:18:50:WU01:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
12:21:16:WU01:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
12:23:18:WU01:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
12:24:44:WU01:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
12:26:10:WU01:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
12:27:25:WU01:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
12:28:43:WU01:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
12:29:59:WU01:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
12:31:16:WU01:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
12:32:43:WU01:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
12:34:07:WU01:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
12:35:23:WU01:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
12:36:39:WU01:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
12:37:59:WU01:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
12:39:21:WU01:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
12:40:46:WU01:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
12:41:59:WU01:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
12:43:07:WU01:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
12:44:14:WU01:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
12:45:20:WU01:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
12:46:27:WU01:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
12:47:35:WU01:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
12:47:59:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
12:48:45:WU01:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
12:49:58:WU01:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
12:51:03:WU01:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
12:52:19:WU01:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
12:53:31:WU01:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
12:54:40:WU01:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
12:55:50:WU01:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
12:57:15:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
12:57:16:WU00:FS00:Connecting to 65.254.110.245:80
12:57:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:57:17:WU00:FS00:Connecting to 18.218.241.186:80
12:57:17:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:57:17:WU00:FS00:Connecting to 65.254.110.245:80
12:57:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:57:18:WU00:FS00:Connecting to 18.218.241.186:80
12:57:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:57:19:ERROR:WU00:FS00:Exception: Could not get an assignment
12:57:19:WU00:FS00:Connecting to 65.254.110.245:80
12:57:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:57:20:WU00:FS00:Connecting to 18.218.241.186:80
12:57:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:57:20:WU00:FS00:Connecting to 65.254.110.245:80
12:57:21:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:57:21:WU00:FS00:Connecting to 18.218.241.186:80
12:57:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:57:22:ERROR:WU00:FS00:Exception: Could not get an assignment
12:58:19:WU00:FS00:Connecting to 65.254.110.245:80
12:58:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:58:20:WU00:FS00:Connecting to 18.218.241.186:80
12:58:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:58:21:WU00:FS00:Connecting to 65.254.110.245:80
12:58:21:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
12:58:21:WU00:FS00:Connecting to 18.218.241.186:80
12:58:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:58:22:ERROR:WU00:FS00:Exception: Could not get an assignment
12:58:43:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
12:58:45:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
12:58:45:WU01:FS00:0xa7:Saving result file frame70.trr
12:58:45:WU01:FS00:0xa7:Saving result file md.log
12:58:45:WU01:FS00:0xa7:Saving result file pullf.xvg
12:58:45:WU01:FS00:0xa7:Saving result file pullx.xvg
12:58:45:WU01:FS00:0xa7:Saving result file science.log
12:58:45:WU01:FS00:0xa7:Saving result file traj_comp.xtc
12:58:45:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:58:46:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:58:46:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14198 run:0 clone:204 gen:70 core:0xa7 unit:0x000000509bf7a4d55e66d071c330045f
12:58:46:WU01:FS00:Uploading 2.65MiB to 155.247.164.213
12:58:46:WU01:FS00:Connecting to 155.247.164.213:8080
12:59:07:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
12:59:07:WU01:FS00:Connecting to 155.247.164.213:80
12:59:10:WU01:FS00:Upload 2.36%
12:59:43:WU01:FS00:Upload 4.71%
12:59:56:WU00:FS00:Connecting to 65.254.110.245:80
12:59:57:WU00:FS00:Assigned to work server 13.90.152.57
12:59:57:WU00:FS00:Requesting new work unit for slot 00: READY cpu:12 from 13.90.152.57
12:59:57:WU00:FS00:Connecting to 13.90.152.57:8080
12:59:59:WU00:FS00:Downloading 4.50MiB
13:00:05:WU00:FS00:Download 40.32%
13:00:09:WU01:FS00:Upload 7.07%
13:00:11:WU00:FS00:Download 61.18%
13:00:15:WU01:FS00:Upload 65.99%
13:00:16:WU00:FS00:Download complete
13:00:16:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:18459 gen:76 core:0xa7 unit:0x000000570d5a98395e730f8c8f7f3125
13:00:16:WU00:FS00:Starting
13:00:16:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 4448 -checkpoint 15 -np 12
13:00:17:WU00:FS00:Started FahCore on PID 15232
13:00:17:WU00:FS00:Core PID:13808
13:00:17:WU00:FS00:FahCore 0xa7 started
13:00:18:WU00:FS00:0xa7:*********************** Log Started 2020-04-18T13:00:17Z ***********************
13:00:18:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:00:18:WU00:FS00:0xa7:       Type: 0xa7
13:00:18:WU00:FS00:0xa7:       Core: Gromacs
13:00:18:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 15232 -checkpoint 15 -np
13:00:18:WU00:FS00:0xa7:             12
13:00:18:WU00:FS00:0xa7:************************************ CBang *************************************
13:00:18:WU00:FS00:0xa7:       Date: Oct 26 2019
13:00:18:WU00:FS00:0xa7:       Time: 01:38:25
13:00:18:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:00:18:WU00:FS00:0xa7:     Branch: master
13:00:18:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:00:18:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:00:18:WU00:FS00:0xa7:   Platform: win32 10
13:00:18:WU00:FS00:0xa7:       Bits: 64
13:00:18:WU00:FS00:0xa7:       Mode: Release
13:00:18:WU00:FS00:0xa7:************************************ System ************************************
13:00:18:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
13:00:18:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
13:00:18:WU00:FS00:0xa7:       CPUs: 12
13:00:18:WU00:FS00:0xa7:     Memory: 7.85GiB
13:00:18:WU00:FS00:0xa7:Free Memory: 3.28GiB
13:00:18:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:00:18:WU00:FS00:0xa7: OS Version: 6.2
13:00:18:WU00:FS00:0xa7:Has Battery: true
13:00:18:WU00:FS00:0xa7: On Battery: false
13:00:18:WU00:FS00:0xa7: UTC Offset: 8
13:00:18:WU00:FS00:0xa7:        PID: 13808
13:00:18:WU00:FS00:0xa7:        CWD: C:\Users\Admin\AppData\Roaming\FAHClient\work
13:00:18:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:00:18:WU00:FS00:0xa7:    Version: 0.0.18
13:00:18:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:00:18:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:00:18:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:00:18:WU00:FS00:0xa7:       Time: 01:52:30
13:00:18:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:00:18:WU00:FS00:0xa7:************************************ Build *************************************
13:00:18:WU00:FS00:0xa7:       SIMD: avx_256
13:00:18:WU00:FS00:0xa7:********************************************************************************
13:00:18:WU00:FS00:0xa7:Project: 13860 (Run 0, Clone 18459, Gen 76)
13:00:18:WU00:FS00:0xa7:Unit: 0x000000570d5a98395e730f8c8f7f3125
13:00:18:WU00:FS00:0xa7:Reading tar file core.xml
13:00:18:WU00:FS00:0xa7:Reading tar file frame76.tpr
13:00:18:WU00:FS00:0xa7:Digital signatures verified
13:00:18:WU00:FS00:0xa7:Calling: mdrun -s frame76.tpr -o frame76.trr -x frame76.xtc -e frame76.edr -cpt 15 -nt 12
13:00:18:WU00:FS00:0xa7:Steps: first=9500000 total=125000
13:00:18:WU01:FS00:Upload complete
13:00:19:WU01:FS00:Server responded WORK_ACK (400)
13:00:19:WU01:FS00:Final credit estimate, 1722.00 points
13:00:19:WU01:FS00:Cleaning up
13:00:20:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
13:01:42:Saving configuration to config.xml
13:01:42:<config>
13:01:42:  <!-- Folding Slot Configuration -->
13:01:42:  <cause v='COVID_19'/>
13:01:42:
13:01:42:  <!-- Network -->
13:01:42:  <proxy v=':8080'/>
13:01:42:
13:01:42:  <!-- Slot Control -->
13:01:42:  <power v='FULL'/>
13:01:42:
13:01:42:  <!-- User Information -->
13:01:42:  <passkey v='*****'/>
13:01:42:  <team v='251999'/>
13:01:42:  <user v='TheProgrammer7'/>
13:01:42:
13:01:42:  <!-- Folding Slots -->
13:01:42:  <slot id='0' type='CPU'/>
13:01:42:</config>
13:02:03:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
13:03:46:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
13:05:15:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
13:06:59:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
13:08:25:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
13:09:52:WU00:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
13:12:11:WU00:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
13:14:07:WU00:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
13:15:41:WU00:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
13:17:15:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
13:18:59:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
Sorry for the inconvinience I caused. I am new here. There you go! :)
HaloJones
Post by HaloJones »
I would suggest that you:
Manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to %AppData%\FAHClient
Reboot your system
Start up the client and ensure that you can see your GPU in the log file
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
Let us know if that works or not :)
single 1070
TheProgrammer7
It works! :D Thanks for the help!
TheProgrammer7
I am not sure if it is actually going to work since it is still waiting on a WS assignment
TheProgrammer7
I think it isnt working since the client actually supports it, but the Folding@Home Servers dont have any WU's assigned for this "new" GPU so it is staying idle.
There are currently more requests for GPU work assignments than the servers can fill. So it can take a bit of waiting to get a WU, but eventually your GPU should get one.
TheProgrammer7
Ok
