FAH 7.6.9 can't detect Geforce 1060, but FAH 7.5.1 can
In the last release some bug - FAH 7.6.9 can't detect Geforce 1060, but if I install 7.5.1 it will detect.
Re: FAH 7.6.9 can't detect Geforce 1060, but FAH 7.5.1 can
Welcome to the F@H Forum cgistlaker,
I would suggest that you:
Manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to %AppData%\FAHClient
Reboot your system
Start up the client and ensure that you can see your GPU in the log file
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
Let us know if that works or not
Exit the client
Reboot your system
After installing FAH 7.6.9, reboot your computer. Then manually add a GPU Folding slot. FAHControl > Configure > Slots tab > Add GPU, click on the dot and leave everything default > OK > Save
Thanks, manually adding of GPU is solved my problem, but anyway it is a bug in new client that shoud be fixed. How can I report my problem to the developers?
You can create issues here: https://github.com/FoldingAtHome/fah-issues/issues
Thank you all, I will!
I can do this but it doesn't save. I even downloaded the GPU text file mentioned above.Tohya wrote:After installing FAH 7.6.9, reboot your computer. Then manually add a GPU Folding slot. FAHControl > Configure > Slots tab > Add GPU, click on the dot and leave everything default > OK > Save
Ideas?
eaddict, you seem to wish to spam tiny bits of your info across multiple threads.
to get the best help, you would put ALL your info in a single thread, started by you.
Your log, your GPU-Z info, what you have tried, etc.
eaddict to solve your problem you should change default CPU to GPU in the slots and after that add new CPU.
