How do I know whether the F@H WU is working?
Janpieter_Sollie
Post by Janpieter_Sollie »
I have a WU with an ETA of 24h, and after 30m, the counter is still at 0%.
Radeontop shows 100% gfx pipeline usage,
dmesg shows no errors.
log.txt of folding@home shows no progress of WU00, only WU01, which is running on the CPU
the heat sensor of the GPU is also pretty OK (70°C)
in ps aux, I see the FAHCore process has been started:
/opt/foldingathome/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 705 -lifeline 2567 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
with clinfo, I can see necessary libs are present:
Number of platforms 1
Platform Name AMD Accelerated Parallel Processing
Platform Vendor Advanced Micro Devices, Inc.
Platform Version OpenCL 2.1 AMD-APP (3004.6)
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
Platform Host timer resolution 1ns
Platform Extensions function suffix AMD
Number of devices 1
Device Vendor Advanced Micro Devices, Inc.
Device Vendor ID 0x1002
Device Version OpenCL 1.2 AMD-APP (3004.6)
Driver Version 3004.6
Device OpenCL C Version OpenCL C 1.2
Device Type GPU
...but it does not progress at all! not even a tiny 0.01%
Any suggestions?
Re: How do I know whether the F@H WU is working?
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=81&t=26036 :)
You can also use the tool GPU-Z to see if there's any utilization on the GPU.
Janpieter_Sollie
All right, here's the log:
*********************** Log Started 2020-04-18T09:01:46Z ***********************
09:01:46:************************* Folding@home Client *************************
09:01:46:        Website: https://foldingathome.org/
09:01:46:      Copyright: (c) 2009-2018 foldingathome.org
09:01:46:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:01:46:           Args:
09:01:46:         Config: /opt/foldingathome/config.xml
09:01:46:******************************** Build ********************************
09:01:46:        Version: 7.5.1
09:01:46:           Date: May 12 2018
09:01:46:           Time: 22:51:07
09:01:46:     Repository: Git
09:01:46:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
09:01:46:         Branch: master
09:01:46:       Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
09:01:46:        Options: -std=gnu++98 -O3 -funroll-loops
09:01:46:       Platform: linux2 4.14.0-3-amd64
09:01:46:           Bits: 64
09:01:46:           Mode: Release
09:01:46:******************************* System ********************************
09:01:46:            CPU: AMD Ryzen 5 2600X Six-Core Processor
09:01:46:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:01:46:           CPUs: 12
09:01:46:         Memory: 23.51GiB
09:01:46:    Free Memory: 22.46GiB
09:01:46:        Threads: POSIX_THREADS
09:01:46:     OS Version: 5.5
09:01:46:    Has Battery: false
09:01:46:     On Battery: false
09:01:46:     UTC Offset: 2
09:01:46:            PID: 2612
09:01:46:            CWD: /opt/foldingathome
09:01:46:             OS: Linux 5.5.16 x86_64
09:01:46:        OS Arch: AMD64
09:01:46:           GPUs: 1
09:01:46:          GPU 0: Bus:9 Slot:0 Func:0 AMD:5 Fiji XT [Radeon R9 Fury X]
09:01:46:           CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
09:01:46:                 libcuda.so: cannot open shared object file: No such file or
09:01:46:                 directory
09:01:46:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3004.6
09:01:46:***********************************************************************
09:01:46:<config>
09:01:46:  <!-- Configuration -->
09:01:46:  <config-rotate-dir v='/opt/foldingathome/configs'/>
09:01:46:
09:01:46:  <!-- Folding Slot Configuration -->
09:01:46:  <client-type v='advanced'/>
09:01:46:  <cpus v='2'/>
09:01:46:
09:01:46:  <!-- HTTP Server -->
09:01:46:  <allow v='127.0.0.1 192.168.177.0/24'/>
09:01:46:
09:01:46:  <!-- Slot Control -->
09:01:46:  <power v='FULL'/>
09:01:46:
09:01:46:  <!-- User Information -->
09:01:46:  <passkey v='********************************'/>
09:01:46:  <user v='Janpieter_Sollie'/>
09:01:46:
09:01:46:  <!-- Web Server -->
09:01:46:  <web-allow v='127.0.0.1 192.168.177.0/24'/>
09:01:46:
09:01:46:  <!-- Work Unit Control -->
09:01:46:  <stall-detection-enabled v='true'/>
09:01:46:
09:01:46:  <!-- Folding Slots -->
09:01:46:  <slot id='0' type='GPU'/>
09:01:46:  <slot id='2' type='CPU'/>
09:01:46:</config>
09:01:46:Trying to access database...
09:01:46:Successfully acquired database lock
09:01:46:Enabled folding slot 00: READY gpu:0:Fiji XT [Radeon R9 Fury X]
09:01:46:Enabled folding slot 02: READY cpu:2
09:01:46:WU00:FS00:Starting
09:01:46:WU00:FS00:Running FahCore: /opt/foldingathome/FAHCoreWrapper /opt/foldingathome/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 705 -lifeline 2612 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
09:01:46:WU00:FS00:Started FahCore on PID 2627
09:01:46:WU00:FS00:Core PID:2631
09:01:46:WU00:FS00:FahCore 0x22 started
09:01:46:WU01:FS02:Starting
09:01:46:WU01:FS02:Running FahCore: /opt/foldingathome/FAHCoreWrapper /opt/foldingathome/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 2612 -checkpoint 15 -np 2
09:01:46:WU01:FS02:Started FahCore on PID 2632
09:01:46:WU01:FS02:Core PID:2636
09:01:46:WU01:FS02:FahCore 0xa7 started
09:01:47:WU00:FS00:0x22:*********************** Log Started 2020-04-18T09:01:46Z ***********************
09:01:47:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
09:01:47:WU00:FS00:0x22:       Type: 0x22
09:01:47:WU00:FS00:0x22:       Core: Core22
09:01:47:WU00:FS00:0x22:    Website: https://foldingathome.org/
09:01:47:WU00:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
09:01:47:WU00:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
09:01:47:WU00:FS00:0x22:             <rafal.wiewiora@choderalab.org>
09:01:47:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 2627 -checkpoint 15
09:01:47:WU00:FS00:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
09:01:47:WU00:FS00:0x22:     Config: <none>
09:01:47:WU00:FS00:0x22:************************************ Build *************************************
09:01:47:WU00:FS00:0x22:    Version: 0.0.2
09:01:47:WU00:FS00:0x22:       Date: Dec 6 2019
09:01:47:WU00:FS00:0x22:       Time: 21:20:17
09:01:47:WU00:FS00:0x22: Repository: Git
09:01:47:WU00:FS00:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
09:01:47:WU00:FS00:0x22:     Branch: core22
09:01:47:WU00:FS00:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
09:01:47:WU00:FS00:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
09:01:47:WU00:FS00:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
09:01:47:WU00:FS00:0x22:       Bits: 64
09:01:47:WU00:FS00:0x22:       Mode: Release
09:01:47:WU00:FS00:0x22:************************************ System ************************************
09:01:47:WU00:FS00:0x22:        CPU: AMD Ryzen 5 2600X Six-Core Processor
09:01:47:WU00:FS00:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:01:47:WU00:FS00:0x22:       CPUs: 12
09:01:47:WU00:FS00:0x22:     Memory: 23.51GiB
09:01:47:WU00:FS00:0x22:Free Memory: 22.35GiB
09:01:47:WU00:FS00:0x22:    Threads: POSIX_THREADS
09:01:47:WU00:FS00:0x22: OS Version: 5.5
09:01:47:WU00:FS00:0x22:Has Battery: false
09:01:47:WU00:FS00:0x22: On Battery: false
09:01:47:WU00:FS00:0x22: UTC Offset: 2
09:01:47:WU00:FS00:0x22:        PID: 2631
09:01:47:WU00:FS00:0x22:        CWD: /opt/foldingathome/work
09:01:47:WU00:FS00:0x22:         OS: Linux 5.5.16 x86_64
09:01:47:WU00:FS00:0x22:    OS Arch: AMD64
09:01:47:WU00:FS00:0x22:********************************************************************************
09:01:47:WU00:FS00:0x22:Project: 14549 (Run 0, Clone 1501, Gen 21)
09:01:47:WU00:FS00:0x22:Unit: 0x0000001a0d5262775e863e35fccb0ab1
09:01:47:WU00:FS00:0x22:Reading tar file core.xml
09:01:47:WU00:FS00:0x22:Reading tar file integrator.xml
09:01:47:WU00:FS00:0x22:Reading tar file state.xml
09:01:47:WU00:FS00:0x22:Reading tar file system.xml
09:01:47:WU00:FS00:0x22:Digital signatures verified
09:01:47:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
09:01:47:WU00:FS00:0x22:Version 0.0.2
09:01:47:WU01:FS02:0xa7:*********************** Log Started 2020-04-18T09:01:46Z ***********************
09:01:47:WU01:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
09:01:47:WU01:FS02:0xa7:       Type: 0xa7
09:01:47:WU01:FS02:0xa7:       Core: Gromacs
09:01:47:WU01:FS02:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2632 -checkpoint 15 -np 2
09:01:47:WU01:FS02:0xa7:************************************ CBang *************************************
09:01:47:WU01:FS02:0xa7:       Date: Nov 5 2019
09:01:47:WU01:FS02:0xa7:       Time: 06:06:57
09:01:47:WU01:FS02:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
09:01:47:WU01:FS02:0xa7:     Branch: master
09:01:47:WU01:FS02:0xa7:   Compiler: GNU 8.3.0
09:01:47:WU01:FS02:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
09:01:47:WU01:FS02:0xa7:   Platform: linux2 4.19.0-5-amd64
09:01:47:WU01:FS02:0xa7:       Bits: 64
09:01:47:WU01:FS02:0xa7:       Mode: Release
09:01:47:WU01:FS02:0xa7:************************************ System ************************************
09:01:47:WU01:FS02:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
09:01:47:WU01:FS02:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
09:01:47:WU01:FS02:0xa7:       CPUs: 12
09:01:47:WU01:FS02:0xa7:     Memory: 23.51GiB
09:01:47:WU01:FS02:0xa7:Free Memory: 22.35GiB
09:01:47:WU01:FS02:0xa7:    Threads: POSIX_THREADS
09:01:47:WU01:FS02:0xa7: OS Version: 5.5
09:01:47:WU01:FS02:0xa7:Has Battery: false
09:01:47:WU01:FS02:0xa7: On Battery: false
09:01:47:WU01:FS02:0xa7: UTC Offset: 2
09:01:47:WU01:FS02:0xa7:        PID: 2636
09:01:47:WU01:FS02:0xa7:        CWD: /opt/foldingathome/work
09:01:47:WU01:FS02:0xa7:******************************** Build - libFAH ********************************
09:01:47:WU01:FS02:0xa7:    Version: 0.0.18
09:01:47:WU01:FS02:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:01:47:WU01:FS02:0xa7:  Copyright: 2019 foldingathome.org
09:01:47:WU01:FS02:0xa7:   Homepage: https://foldingathome.org/
09:01:47:WU01:FS02:0xa7:       Time: 06:13:26
09:01:47:WU01:FS02:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
09:01:47:WU01:FS02:0xa7:************************************ Build *************************************
09:01:47:WU01:FS02:0xa7:       SIMD: avx_256
09:01:47:WU01:FS02:0xa7:********************************************************************************
09:01:47:WU01:FS02:0xa7:Project: 14380 (Run 527, Clone 4, Gen 8)
09:01:47:WU01:FS02:0xa7:Unit: 0x00000008455e42075e932e7bc2a650be
09:01:47:WU01:FS02:0xa7:Digital signatures verified
09:01:47:WU01:FS02:0xa7:Calling: mdrun -s frame8.tpr -o frame8.trr -cpi state.cpt -cpt 15 -nt 2
09:01:47:WU01:FS02:0xa7:Steps: first=0 total=2500000
09:01:47:WU01:FS02:0xa7:Completed 517954 out of 2500000 steps (20%)
09:02:23:WU01:FS02:0xa7:Completed 525000 out of 2500000 steps (21%)
GPU-Z is not available for this system, as it does not contain a GUI & is linux-based
I am not a Linux expert but maybe you can find this thread useful: viewtopic.php?f=81&t=34288
Janpieter_Sollie
I also saw that one ... unfortunately, this doesn't help (not even a little bit): the opencl drivers for cards GCN < 2.0 are a totally different driver than the ones I'm trying to use, and the card is detected by the opencl driver, it simply doesn't work
Rel25917
Post by Rel25917 »
Based on temp and radeontop it looks like it should be working but 30 minutes is an awfully long time to not hit 1%. The 24 hour ETA is just a default guess since you haven't done that project yet, it updates once some progress is seen. That card seems comparable to a 980ti so shouldn't be that slow of a performer. Have other gpu units ran ok?
