Gpu isn't detected on version 7.6.9 > > use 7.6.13
j0taDasFestasPT
Post by j0taDasFestasPT »
Hi all im happy to see a good project going on.
I'm with a little problem with the last version "fah-installer_7.6.9_x86.exe" my gpu Asus Cerberus GTX 1050TI OC 4GB
isn't detected and on previous version was detected
here is the log
*********************** Log Started 2020-04-18T05:41:42Z ***********************
05:41:42:****************************** FAHClient ******************************
05:41:42:        Version: 7.6.9
05:41:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:41:42:      Copyright: 2020 foldingathome.org
05:41:42:       Homepage: https://foldingathome.org/
05:41:42:           Date: Apr 17 2020
05:41:42:           Time: 11:13:06
05:41:42:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
05:41:42:         Branch: master
05:41:42:       Compiler: Visual C++ 2008
05:41:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:41:42:       Platform: win32 10
05:41:42:           Bits: 32
05:41:42:           Mode: Release
05:41:42:           Args: --open-web-control
05:41:42:******************************** CBang ********************************
05:41:42:           Time: 11:10:09
05:41:42:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
05:41:42:           Bits: 32
05:41:42:******************************* System ********************************
05:41:42:            CPU: Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz
05:41:42:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
05:41:42:           CPUs: 6
05:41:42:         Memory: 7.94GiB
05:41:42:    Free Memory: 4.12GiB
05:41:42:        Threads: WINDOWS_THREADS
05:41:42:     OS Version: 6.2
05:41:42:    Has Battery: false
05:41:42:     On Battery: false
05:41:42:     UTC Offset: 1
05:41:42:            PID: 5924
05:41:42:            CWD: C:\Users\j0taDasFestasPT\AppData\Roaming\FAHClient
05:41:42:             OS: Windows 10 Enterprise
05:41:42:        OS Arch: AMD64
05:41:42:           GPUs: 0
05:41:42:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
05:41:42:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
05:41:42:  Win32 Service: false
05:41:42:******************************* libFAH ********************************
05:41:42:           Date: Apr 15 2020
05:41:42:           Time: 14:53:14
05:41:42:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
05:41:42:           Bits: 32
05:41:42:***********************************************************************
05:41:42:<config>
05:41:42:  <!-- Folding Slots -->
05:41:42:</config>
05:41:42:Trying to access database...
05:41:42:Successfully acquired database lock
05:41:42:Enabled folding slot 00: PAUSED cpu:5 (not configured)
05:41:46:17:127.0.0.1:New Web session
05:42:05:Set client configured
05:42:05:WU00:FS00:Connecting to 65.254.110.245:80
05:42:06:WU00:FS00:Connecting to 65.254.110.245:80
05:42:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:80': No WUs available for this configuration
05:42:07:WU00:FS00:Connecting to 18.218.241.186:80
05:42:07:WU00:FS00:Assigned to work server 155.247.164.213
05:42:07:WU00:FS00:Requesting new work unit for slot 00: READY cpu:5 from 155.247.164.213
05:42:07:WU00:FS00:Connecting to 155.247.164.213:8080
05:42:28:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:42:28:WU00:FS00:Connecting to 155.247.164.213:80
05:42:34:FS00:Paused
05:42:43:Saving configuration to config.xml
05:42:43:<config>
05:42:43:  <!-- User Information -->
05:42:43:  <team v='50711'/>
05:42:43:  <user v='j0taDasFestasPT'/>
05:42:43:
05:42:43:  <!-- Folding Slots -->
05:42:43:  <slot id='0' type='CPU'>
05:42:43:    <paused v='true'/>
05:42:43:  </slot>
05:42:43:</config>
05:42:49:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.164.213:80: Uma tentativa de ligao falhou porque o componente ligado no respondeu
05:42:49:ERROR:WU00:FS00:corretamente aps um perodo de tempo, ou a ligao estabelecida falhou
05:42:49:ERROR:WU00:FS00:porque o anfitrio ligado no respondeu.
Re: Gpu isn't detected on last stable version 7.6.9
Welcome to the F@H Forum j0taDasFestasPT,
The issue is that the client doesn't detect any GPU as shown below:
05:41:42: GPUs: 0
I would suggest that you manually download the GPUs.txt file from here: https://apps.foldingathome.org/GPUs.txt (right-click save as GPUs.txt)
Exit the client
Copy the GPUs.txt file from the Downloads folder to C:\Users\henso\AppData\Roaming\FAHClient
Start up the client and ensure that you can see your GPU
Add a GPU slot from FAHControl -> Configure -> Slots tab -> Add -> GPU -> OK -> Save
Tohya
Post by Tohya »
If adding a gpu slot fails, no gpu is added, reboot your computer. Then try to add a GPU slot again.
j0taDasFestasPT
OK guys i put it to work
Thanks very much you're the best !!!!!!!
Good Foldings everyone
eaddict
Post by eaddict »
Tohya wrote:If adding a gpu slot fails, no gpu is added, reboot your computer. Then try to add a GPU slot again.
No luck. Even trying one more time... ideas?
eaddict
Several pieces of data you could give us.
You could run GPU-Z and give use the Name and Device ID of your graphics card.
you could give us the first 200 lines of your Log, with FAHClient info, System Info, and the config
viewtopic.php?f=24&t=26036
With that info, we can make better guesses.
Jan
Post by Jan »
eaddict wrote:No luck. Even trying one more time... ideas?
Have you downloaded the GPUs.txt as PantherX recommended and saved it in your FAHClient folder?
benas_s
Post by benas_s »
I had the issue where my GPU was not detected after upgrading to the newest version (fully deleted and installed (advanced mode)).
GPUs.txt file was not created.
I had to download GPUs.txt file mentioned above and place it to C:\Users\{userName}\AppData\Roaming\FAHClient
You are about to lose lots of computing power from GPU calculations and new fixed version has to be released asap. Average Joe won't bother with this and use as is.
This is major issue.
j0taDasFestasPT
PantherX wrote:Welcome to the F@H Forum j0taDasFestasPT,
05:41:42: GPUs: 0
Exit the client
Copy the GPUs.txt file from the Downloads folder to %appdata% (write on explorer) and go to folder Roaming\FAHClient
I slighted changed the folder direction for easy understand by newbies
eaddict
Post by eaddict »
Yes
eaddict
Post by eaddict »
Here is the log file. Once I figure how to upload the screen captures I'll add the stuff from GPU-Z and Sysino.
*********************** Log Started 2020-04-19T14:36:52Z ***********************
14:36:52:****************************** FAHClient ******************************
14:36:52:        Version: 7.6.9
14:36:52:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:36:52:      Copyright: 2020 foldingathome.org
14:36:52:       Homepage: https://foldingathome.org/
14:36:52:           Date: Apr 17 2020
14:36:52:           Time: 11:13:06
14:36:52:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
14:36:52:         Branch: master
14:36:52:       Compiler: Visual C++ 2008
14:36:52:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:36:52:       Platform: win32 10
14:36:52:           Bits: 32
14:36:52:           Mode: Release
14:36:52:           Args: --open-web-control
14:36:52:         Config: C:\Users\eaddi\AppData\Roaming\FAHClient\config.xml
14:36:52:******************************** CBang ********************************
14:36:52:           Time: 11:10:09
14:36:52:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
14:36:52:           Bits: 32
14:36:52:******************************* System ********************************
14:36:52:            CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
14:36:52:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
14:36:52:           CPUs: 16
14:36:52:         Memory: 15.92GiB
14:36:52:    Free Memory: 13.70GiB
14:36:52:        Threads: WINDOWS_THREADS
14:36:52:     OS Version: 6.2
14:36:52:    Has Battery: false
14:36:52:     On Battery: false
14:36:52:     UTC Offset: -5
14:36:52:            PID: 10800
14:36:52:            CWD: C:\Users\eaddi\AppData\Roaming\FAHClient
14:36:52:             OS: Windows 10 Enterprise
14:36:52:        OS Arch: AMD64
14:36:52:           GPUs: 1
14:36:52:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2080 Super]
14:36:52:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
14:36:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.87
14:36:52:  Win32 Service: false
14:36:52:******************************* libFAH ********************************
14:36:52:           Date: Apr 15 2020
14:36:52:           Time: 14:53:14
14:36:52:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
14:36:52:           Bits: 32
14:36:52:***********************************************************************
14:36:52:<config>
14:36:52:  <!-- Folding Slot Configuration -->
14:36:52:  <cause v='COVID_19'/>
14:36:52:
14:36:52:  <!-- Slot Control -->
14:36:52:  <power v='LIGHT'/>
14:36:52:
14:36:52:  <!-- User Information -->
14:36:52:  <team v='250966'/>
14:36:52:  <user v='eaddict'/>
14:36:52:
14:36:52:  <!-- Folding Slots -->
14:36:52:  <slot id='0' type='CPU'/>
14:36:52:</config>
14:36:52:Trying to access database...
14:36:52:Successfully acquired database lock
14:36:52:Enabled folding slot 00: READY cpu:7
14:36:52:WU00:FS00:Starting
14:36:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\eaddi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 10800 -checkpoint 15 -np 7
14:36:52:WU00:FS00:Started FahCore on PID 10984
14:36:52:WU00:FS00:Core PID:11068
14:36:52:WU00:FS00:FahCore 0xa7 started
14:36:53:WU00:FS00:0xa7:*********************** Log Started 2020-04-19T14:36:52Z ***********************
14:36:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:36:53:WU00:FS00:0xa7:       Type: 0xa7
14:36:53:WU00:FS00:0xa7:       Core: Gromacs
14:36:53:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10984 -checkpoint 15 -np
14:36:53:WU00:FS00:0xa7:             7
14:36:53:WU00:FS00:0xa7:************************************ CBang *************************************
14:36:53:WU00:FS00:0xa7:       Date: Oct 26 2019
14:36:53:WU00:FS00:0xa7:       Time: 01:38:25
14:36:53:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:36:53:WU00:FS00:0xa7:     Branch: master
14:36:53:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:36:53:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:36:53:WU00:FS00:0xa7:   Platform: win32 10
14:36:53:WU00:FS00:0xa7:       Bits: 64
14:36:53:WU00:FS00:0xa7:       Mode: Release
14:36:53:WU00:FS00:0xa7:************************************ System ************************************
14:36:53:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
14:36:53:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
14:36:53:WU00:FS00:0xa7:       CPUs: 16
14:36:53:WU00:FS00:0xa7:     Memory: 15.92GiB
14:36:53:WU00:FS00:0xa7:Free Memory: 13.65GiB
14:36:53:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:36:53:WU00:FS00:0xa7: OS Version: 6.2
14:36:53:WU00:FS00:0xa7:Has Battery: false
14:36:53:WU00:FS00:0xa7: On Battery: false
14:36:53:WU00:FS00:0xa7: UTC Offset: -5
14:36:53:WU00:FS00:0xa7:        PID: 11068
14:36:53:WU00:FS00:0xa7:        CWD: C:\Users\eaddi\AppData\Roaming\FAHClient\work
14:36:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:36:53:WU00:FS00:0xa7:    Version: 0.0.18
14:36:53:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:36:53:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:36:53:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:36:53:WU00:FS00:0xa7:       Time: 01:52:30
14:36:53:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:36:53:WU00:FS00:0xa7:************************************ Build *************************************
14:36:53:WU00:FS00:0xa7:       SIMD: avx_256
14:36:53:WU00:FS00:0xa7:********************************************************************************
14:36:53:WU00:FS00:0xa7:Project: 14576 (Run 0, Clone 3779, Gen 51)
14:36:53:WU00:FS00:0xa7:Unit: 0x00000042287234c95e7b869df7a5b788
14:36:53:WU00:FS00:0xa7:Digital signatures verified
14:36:53:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
14:36:53:WU00:FS00:0xa7:Calling: mdrun -s frame51.tpr -o frame51.trr -x frame51.xtc -cpt 15 -nt 6
14:36:53:WU00:FS00:0xa7:Steps: first=25500000 total=500000
14:36:54:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
14:36:55:4:127.0.0.1:New Web session
14:36:56:11:127.0.0.1:New Web session
14:36:56:12:127.0.0.1:New Web session
14:36:56:13:127.0.0.1:New Web session
14:37:01:29:127.0.0.1:New Web session
14:37:25:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
14:37:55:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
14:38:26:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
14:38:57:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
14:39:27:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
14:39:57:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
14:40:27:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
14:40:57:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
14:41:27:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
14:41:57:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
14:42:27:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
14:42:57:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
14:43:27:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
14:43:57:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
14:44:27:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
14:44:56:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
14:45:27:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
14:45:56:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
14:46:26:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
14:46:57:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
14:47:27:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
14:47:58:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
14:48:28:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
14:48:59:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
14:49:29:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
14:49:58:39:127.0.0.1:New Web session
14:50:00:47:127.0.0.1:New Web session
14:50:01:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
14:50:05:Saving configuration to config.xml
14:50:05:<config>
14:50:05:  <!-- Folding Slot Configuration -->
14:50:05:  <cause v='COVID_19'/>
14:50:05:
14:50:05:  <!-- Network -->
14:50:05:  <proxy v=':8080'/>
14:50:05:
14:50:05:  <!-- Slot Control -->
14:50:05:  <power v='LIGHT'/>
14:50:05:
14:50:05:  <!-- User Information -->
14:50:05:  <team v='250966'/>
14:50:05:  <user v='eaddict'/>
14:50:05:
14:50:05:  <!-- Folding Slots -->
14:50:05:  <slot id='0' type='CPU'/>
14:50:05:</config>
14:50:32:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
14:51:03:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
14:51:33:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
14:52:03:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
14:52:33:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
14:53:03:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
14:53:33:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
14:54:03:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
14:54:33:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
14:55:03:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
14:55:33:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
14:56:03:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
14:56:33:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
14:57:03:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
14:57:33:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
14:58:03:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
eaddict
Post by eaddict »
eaddict
Post by eaddict »
Ok. What did you all do? Now the GPU is recognized but waiting for idle... whatever that means
I did go through my Device Manager and update all the device drivers again and reboot... maybe that helped.
ajm
Post by ajm »
It's "waiting for idle" because this is the standard GPU state when the Power slider is on Light.
eaddict
Post by eaddict »
ajm wrote:It's "waiting for idle" because this is the standard GPU state when the Power slider is on Light.
Thanks... moved it to Medium and is now awaiting a work unit.
