GPU Errors (New User)
LegallyTheBear
Post by LegallyTheBear »
Took ages to get a work unit for my GPU and when I eventually got it I got this error:
00:15:39:WU01:FS01:0x22:ERROR:exception: There is no registered Platform called "OpenCL"
00:15:39:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
00:15:39:WU01:FS01:0x22:Saving result file science.log
00:15:39:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
00:15:39:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:15:39:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13874 run:0 clone:1598 gen:46 core:0x22 unit:0x0000003a0d5262775e7ade2723aa4647
Now my GPU shows up as "Failed" on the advanced viewer.
Any support would be appreciated,
LegallyTheBear
EDIT: FULL LOG:
00:15:29:WU01:FS01:0x22:*********************** Log Started 2020-04-18T00:15:29Z ***********************
00:15:29:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:15:29:WU01:FS01:0x22:       Type: 0x22
00:15:29:WU01:FS01:0x22:       Core: Core22
00:15:29:WU01:FS01:0x22:    Website: https://foldingathome.org/
00:15:29:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:15:29:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:15:29:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:15:29:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 1756 -checkpoint 15
00:15:29:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
00:15:29:WU01:FS01:0x22:     Config: <none>
00:15:29:WU01:FS01:0x22:************************************ Build *************************************
00:15:29:WU01:FS01:0x22:    Version: 0.0.2
00:15:29:WU01:FS01:0x22:       Date: Dec 6 2019
00:15:29:WU01:FS01:0x22:       Time: 21:30:31
00:15:29:WU01:FS01:0x22: Repository: Git
00:15:29:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:15:29:WU01:FS01:0x22:     Branch: HEAD
00:15:29:WU01:FS01:0x22:   Compiler: Visual C++ 2008
00:15:29:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:15:29:WU01:FS01:0x22:   Platform: win32 10
00:15:29:WU01:FS01:0x22:       Bits: 64
00:15:29:WU01:FS01:0x22:       Mode: Release
00:15:29:WU01:FS01:0x22:************************************ System ************************************
00:15:29:WU01:FS01:0x22:        CPU: AMD Ryzen 7 2700 Eight-Core Processor
00:15:29:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
00:15:29:WU01:FS01:0x22:       CPUs: 16
00:15:29:WU01:FS01:0x22:     Memory: 15.95GiB
00:15:29:WU01:FS01:0x22:Free Memory: 7.55GiB
00:15:29:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
00:15:29:WU01:FS01:0x22: OS Version: 6.2
00:15:29:WU01:FS01:0x22:Has Battery: false
00:15:29:WU01:FS01:0x22: On Battery: false
00:15:29:WU01:FS01:0x22: UTC Offset: 1
00:15:29:WU01:FS01:0x22:        PID: 9540
00:15:29:WU01:FS01:0x22:        CWD: C:\Users\Sonny\AppData\Roaming\FAHClient\work
00:15:29:WU01:FS01:0x22:         OS: Windows 10 Home
00:15:29:WU01:FS01:0x22:    OS Arch: AMD64
00:15:29:WU01:FS01:0x22:********************************************************************************
00:15:29:WU01:FS01:0x22:Project: 13874 (Run 0, Clone 1598, Gen 46)
00:15:29:WU01:FS01:0x22:Unit: 0x0000003a0d5262775e7ade2723aa4647
00:15:29:WU01:FS01:0x22:Reading tar file core.xml
00:15:29:WU01:FS01:0x22:Reading tar file integrator.xml
00:15:29:WU01:FS01:0x22:Reading tar file state.xml
00:15:31:WU01:FS01:0x22:Reading tar file system.xml
00:15:39:WU01:FS01:0x22:Digital signatures verified
00:15:39:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:15:39:WU01:FS01:0x22:Version 0.0.2
00:15:39:WU01:FS01:Uploading 7.00KiB to 13.82.98.119
00:15:39:WU01:FS01:Connecting to 13.82.98.119:8080
00:16:14:WU01:FS01:Upload complete
00:16:14:WU01:FS01:Server responded WORK_ACK (400)
00:16:14:WU01:FS01:Cleaning up
Last edited by LegallyTheBear on Sat Apr 18, 2020 12:50 am, edited 2 times in total.
Re: GPU Errors (New User)
Welcome to the F@H Forum LegallyTheBear,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=61&t=26036 :)
LegallyTheBear
PantherX wrote:Welcome to the F@H Forum LegallyTheBear,
Hi, thanks for your response! I have edited my post with the log file, incase you cant see it I'll include it here as well:
Rel25917
Post by Rel25917 »
That does not include the first part of the log showing the system configuration. There is no registered Platform called "OpenCL" is likely a driver problem.
Unfortunately, it is still missing the section that I need to see. If you're using FAHControl, you will need to click on "Refresh" and then untick the "Follow" button. Scroll to the top and then select the first ~100 lines. I need to see something similar to this:
*********************** Log Started 2020-04-17T01:47:06Z ***********************
01:47:06:************************* Folding@home Client *************************
01:47:06:        Website: https://foldingathome.org/
01:47:06:      Copyright: (c) 2009-2018 foldingathome.org
01:47:06:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:47:06:           Args:
01:47:06:         Config: C:\Users\PantherX-H\AppData\Roaming\FAHClient\config.xml
01:47:06:******************************** Build ********************************
01:47:06:        Version: 7.5.1
01:47:06:           Date: May 11 2018
01:47:06:           Time: 13:06:32
01:47:06:     Repository: Git
01:47:06:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
01:47:06:         Branch: master
01:47:06:       Compiler: Visual C++ 2008
01:47:06:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:47:06:       Platform: win32 10
01:47:06:           Bits: 32
01:47:06:           Mode: Release
01:47:06:******************************* System ********************************
01:47:06:            CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
01:47:06:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
01:47:06:           CPUs: 8
01:47:06:         Memory: 31.94GiB
01:47:06:    Free Memory: 27.76GiB
01:47:06:        Threads: WINDOWS_THREADS
01:47:06:     OS Version: 6.2
01:47:06:    Has Battery: false
01:47:06:     On Battery: false
01:47:06:     UTC Offset: 12
01:47:06:            PID: 11296
01:47:06:            CWD: C:\Users\PantherX-H\AppData\Roaming\FAHClient
01:47:06:             OS: Windows 10 Enterprise
01:47:06:        OS Arch: AMD64
01:47:06:           GPUs: 1
01:47:06:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
01:47:06:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
01:47:06:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.19
01:47:06:  Win32 Service: false
01:47:06:***********************************************************************
01:47:06:<config>
01:47:06:  <!-- Folding Slot Configuration -->
01:47:06:  <client-type v='advanced'/>
01:47:06:
01:47:06:  <!-- Network -->
01:47:06:  <proxy v=':8080'/>
01:47:06:
01:47:06:  <!-- Slot Control -->
01:47:06:  <pause-on-start v='true'/>
01:47:06:  <power v='full'/>
01:47:06:
01:47:06:  <!-- User Information -->
01:47:06:  <passkey v='********************************'/>
01:47:06:  <team v='69411'/>
01:47:06:  <user v='PantherX'/>
01:47:06:
01:47:06:  <!-- Work Unit Control -->
01:47:06:  <next-unit-percentage v='100'/>
01:47:06:
01:47:06:  <!-- Folding Slots -->
01:47:06:  <slot id='0' type='CPU'>
01:47:06:    <cpus v='4'/>
01:47:06:  </slot>
01:47:06:  <slot id='1' type='GPU'/>
01:47:06:</config>
01:47:06:Trying to access database...
01:47:06:Successfully acquired database lock
01:47:06:Enabled folding slot 00: PAUSED cpu:4 (by user)
01:47:06:Enabled folding slot 01: PAUSED gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 (by user)
01:47:28:FS00:Unpaused
01:47:28:FS01:Unpaused
LegallyTheBear
Rel25917 wrote:That does not include the first part of the log showing the system configuration. There is no registered Platform called "OpenCL" is likely a driver problem.
https://throwbin.io/57AJRRM Is my full log, It wouldn't let me post as it reached the character limit.
Unfortunately, it is still missing the initial section (compare my log post above to yours). May I suggest that you restart your system and then it will generate a new log file which you can then post here :)
LegallyTheBear
PantherX wrote:Unfortunately, it is still missing the initial section (compare my log post above to yours). May I suggest that you restart your system and then it will generate a new log file which you can then post here :)
Restarted my system and Folding@Home this is what I got
https://throwbin.io/63Pn3Aq
Thanks for that... Do note that there's a new version released a short while ago 7.6.9
I think something might be wrong when you installed the drivers as this is shown in your log file:
01:24:26:CUDA Device 0: Platform:0 Device:0 Bus:28 Slot:0 Compute:7.5 Driver:11.0
01:24:26:       OpenCL: Not detected: clGetPlatformIDs() returned -1001
If you see my log file, I have both CUDA and OpenCL values. However, since your GPU hasn't been allocated a WU, I am not sure if it will fold or not. Currently, there's a massive demand for GPU WUs and work is being done to mitigate the shortage.
Rel25917
Post by Rel25917 »
You are using windows 10 so I'm assuming windows installed the driver and they only install a partial driver, you need to get the driver from nvidia to get openCL to fold.
