fold-anon = true, even when not?
AndrewBienhaus
Post by AndrewBienhaus »
HI,
noticed that in the config.xml on the couple of ubuntu machines I have running, even though the name, team, and key have been entered correctly, the "fold-anon" setting is still set to "true".
should I be changing this to false?
HaloJones
Re: fold-anon = true, even when not?
Post by HaloJones »
ignore it. it's not used I think so you can just forget it or even delete the line from the config.xml. I have and it made no difference whatsoever.
4070 super
Please see my response here: viewtopic.php?p=326851#p326851
