I've got a Windows Threadripper machine with a 2080Ti and 2070 Super (main PC, gaming, content creation when not folding) and a Linux i5-2500K with a 1080 & GTX980 in it.
The linux machine is almost always getting work units, and rotating through the WU servers for the GPU's and CPU regularly. The Windows PC is NOT. It will sit and hammer the same two empty WU servers for *hours* without trying a different one, remaining idle.
I can see this behavior in my SQUID logs on my home network too... the windows PC just never picks a new server.
is there any way to persuade the WIndows client to rotate when it doesn't find work? I'd much rather have the big system cranking through these tasks as fast as it can vs the older system slowly being busy all the time...
Windows Folding client not rotating WU servers
Re: Windows Folding client not rotating WU servers
Those two servers the client is connecting to are not Work Servers but Assignment Servers. They do not hand out WUs, but direct your client to a WS that lists having available connections and WUs of the right type for your system.
If you post the first 200 lines or so of your log file, people here can take a look at it to see if there is a configuration problem.
Of course after messing with it all day, I go to get some new clean logs and I got Work Units... It still seems fishy that the windows machine has a much harder time to get work, as its trying more often and sitting idle for far longer amounts of time... but it is what it is I guess...
Thanks for taking the time to check it out. (I snipped a bit of info out, but it's obviously working as its doing stuff...)
*********************** Log Started 2020-04-16T22:46:54Z ***********************
22:46:54:************************* Folding@home Client *************************
22:46:54: Website: https://foldingathome.org/
22:46:54: Copyright: (c) 2009-2018 foldingathome.org
22:46:54: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:46:54: Args: --open-web-control
22:46:54: Config: <snip>\AppData\Roaming\FAHClient\config.xml
22:46:54:******************************** Build ********************************
22:46:54: Version: 7.5.1
22:46:54: Date: May 11 2018
22:46:54: Time: 13:06:32
22:46:54: Repository: Git
22:46:54: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:46:54: Branch: master
22:46:54: Compiler: Visual C++ 2008
22:46:54: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:46:54: Platform: win32 10
22:46:54: Bits: 32
22:46:54: Mode: Release
22:46:54:******************************* System ********************************
22:46:54: CPU: AMD Ryzen Threadripper 2950X 16-Core Processor
22:46:54: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
22:46:54: CPUs: 32
22:46:54: Memory: 63.88GiB
22:46:54: Free Memory: 50.16GiB
22:46:54: Threads: WINDOWS_THREADS
22:46:54: OS Version: 6.2
22:46:54: Has Battery: false
22:46:54: On Battery: false
22:46:54: UTC Offset: -7
22:46:54: PID: 21032
22:46:54: CWD: <snip>\AppData\Roaming\FAHClient
22:46:54: OS: Windows 10 Enterprise N
22:46:54: OS Arch: AMD64
22:46:54: GPUs: 2
22:46:54: GPU 0: Bus:65 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2070 Super]
22:46:54: 8218
22:46:54: GPU 1: Bus:66 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev.
22:46:54: A] M 13448
22:46:54: CUDA Device 0: Platform:0 Device:0 Bus:66 Slot:0 Compute:7.5 Driver:11.0
22:46:54: CUDA Device 1: Platform:0 Device:1 Bus:65 Slot:0 Compute:7.5 Driver:11.0
22:46:54:OpenCL Device 0: Platform:0 Device:0 Bus:66 Slot:0 Compute:1.2 Driver:445.87
22:46:54:OpenCL Device 1: Platform:0 Device:1 Bus:65 Slot:0 Compute:1.2 Driver:445.87
22:46:54: Win32 Service: false
22:46:54:***********************************************************************
22:46:54:<config>
22:46:54: <!-- Network -->
22:46:54: <proxy v='<proxy>'/>
22:46:54: <proxy-enable v='true'/>
22:46:54:
22:46:54: <!-- User Information -->
22:46:54: <passkey v='********************************'/>
22:46:54: <team v='243214'/>
22:46:54: <user v='lafrad'/>
22:46:54:
22:46:54: <!-- Folding Slots -->
22:46:54: <slot id='0' type='GPU'>
22:46:54: <gpu-index v='1'/>
22:46:54: <next-unit-percentage v='90'/>
22:46:54: <paused v='true'/>
22:46:54: </slot>
22:46:54: <slot id='1' type='GPU'>
22:46:54: <gpu-index v='0'/>
22:46:54: <next-unit-percentage v='95'/>
22:46:54: </slot>
22:46:54: <slot id='2' type='CPU'>
22:46:54: <cpus v='12'/>
22:46:54: <next-unit-percentage v='97'/>
22:46:54: </slot>
22:46:54: <slot id='3' type='CPU'>
22:46:54: <cpus v='10'/>
22:46:54: </slot>
22:46:54:</config>
22:46:54:Trying to access database...
22:46:54:Successfully acquired database lock
22:46:54:Enabled folding slot 00: PAUSED gpu:1:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 (by user)
22:46:54:Enabled folding slot 01: PAUSED gpu:0:TU104 [GeForce RTX 2070 Super] 8218 (by user)
22:46:54:Enabled folding slot 02: PAUSED cpu:12 (by user)
22:46:54:Enabled folding slot 03: PAUSED cpu:10 (by user)
22:47:24:FS00:Unpaused
22:47:24:FS01:Unpaused
22:47:24:FS02:Unpaused
22:47:24:FS03:Unpaused
22:47:24:WU03:FS03:Starting
22:47:24:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" <snip>\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 705 -lifeline 21032 -checkpoint 15 -np 10
22:47:24:WU03:FS03:Started FahCore on PID 13092
22:47:24:WU03:FS03:Core PID:25556
22:47:24:WU03:FS03:FahCore 0xa7 started
22:47:24:WU01:FS02:Starting
22:47:24:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" <snip>\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 21032 -checkpoint 15 -np 12
22:47:24:WU01:FS02:Started FahCore on PID 2528
22:47:24:WU01:FS02:Core PID:11472
22:47:24:WU01:FS02:FahCore 0xa7 started
22:47:24:WU00:FS00:Connecting to <proxy>
22:47:24:WU02:FS01:Connecting to <proxy>
22:47:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:47:24:WU03:FS03:0xa7:*********************** Log Started 2020-04-16T22:47:24Z ***********************
22:47:24:WU03:FS03:0xa7:************************** Gromacs Folding@home Core ***************************
22:47:24:WU03:FS03:0xa7: Type: 0xa7
22:47:24:WU03:FS03:0xa7: Core: Gromacs
22:47:24:WU03:FS03:0xa7: Args: -dir 03 -suffix 01 -version 705 -lifeline 13092 -checkpoint 15 -np
22:47:24:WU03:FS03:0xa7: 10
22:47:24:WU03:FS03:0xa7:************************************ CBang *************************************
22:47:24:WU03:FS03:0xa7: Date: Oct 26 2019
22:47:24:WU01:FS02:0xa7:*********************** Log Started 2020-04-16T22:47:24Z ***********************
22:47:24:WU03:FS03:0xa7: Time: 01:38:25
22:47:24:WU01:FS02:0xa7:************************** Gromacs Folding@home Core ***************************
22:47:24:WU03:FS03:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:47:24:WU01:FS02:0xa7: Type: 0xa7
22:47:24:WU03:FS03:0xa7: Branch: master
22:47:24:WU01:FS02:0xa7: Core: Gromacs
22:47:24:WU03:FS03:0xa7: Compiler: Visual C++ 2008
22:47:24:WU01:FS02:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 2528 -checkpoint 15 -np
22:47:24:WU03:FS03:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:47:24:WU01:FS02:0xa7: 12
22:47:24:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:47:24:WU03:FS03:0xa7: Platform: win32 10
22:47:24:WU01:FS02:0xa7:************************************ CBang *************************************
22:47:24:WU03:FS03:0xa7: Bits: 64
22:47:24:WU01:FS02:0xa7: Date: Oct 26 2019
22:47:24:WU03:FS03:0xa7: Mode: Release
22:47:24:WU01:FS02:0xa7: Time: 01:38:25
22:47:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:47:25:WU03:FS03:0xa7:************************************ System ************************************
22:47:25:WU01:FS02:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:47:25:ERROR:WU00:FS00:Exception: Could not get an assignment
22:47:25:WU03:FS03:0xa7: CPU: AMD Ryzen Threadripper 2950X 16-Core Processor
22:47:25:WU01:FS02:0xa7: Branch: master
22:47:25:WU03:FS03:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
22:47:25:WU01:FS02:0xa7: Compiler: Visual C++ 2008
22:47:25:WU03:FS03:0xa7: CPUs: 32
22:47:25:WU01:FS02:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:47:25:WU03:FS03:0xa7: Memory: 63.88GiB
22:47:25:WU01:FS02:0xa7: Platform: win32 10
22:47:25:WU03:FS03:0xa7:Free Memory: 50.09GiB
22:47:25:WU01:FS02:0xa7: Bits: 64
22:47:25:WU03:FS03:0xa7: Threads: WINDOWS_THREADS
22:47:25:WU01:FS02:0xa7: Mode: Release
22:47:25:WU03:FS03:0xa7: OS Version: 6.2
22:47:25:WU01:FS02:0xa7:************************************ System ************************************
22:47:25:WU03:FS03:0xa7:Has Battery: false
22:47:25:WU01:FS02:0xa7: CPU: AMD Ryzen Threadripper 2950X 16-Core Processor
22:47:25:WU03:FS03:0xa7: On Battery: false
22:47:25:WU01:FS02:0xa7: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
22:47:25:WU03:FS03:0xa7: UTC Offset: -7
22:47:25:WU01:FS02:0xa7: CPUs: 32
22:47:25:WU03:FS03:0xa7: PID: 25556
22:47:25:WU01:FS02:0xa7: Memory: 63.88GiB
22:47:25:WU03:FS03:0xa7: CWD: <snip>\AppData\Roaming\FAHClient\work
22:47:25:WU01:FS02:0xa7:Free Memory: 50.09GiB
22:47:25:WU03:FS03:0xa7:******************************** Build - libFAH ********************************
22:47:25:WU01:FS02:0xa7: Threads: WINDOWS_THREADS
22:47:25:WU03:FS03:0xa7: Version: 0.0.18
22:47:25:WU01:FS02:0xa7: OS Version: 6.2
22:47:25:WU03:FS03:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:47:25:WU01:FS02:0xa7:Has Battery: false
22:47:25:WU03:FS03:0xa7: Copyright: 2019 foldingathome.org
22:47:25:WU01:FS02:0xa7: On Battery: false
22:47:25:WU03:FS03:0xa7: Homepage: https://foldingathome.org/
22:47:25:WU01:FS02:0xa7: UTC Offset: -7
22:47:25:WU03:FS03:0xa7: Date: Oct 26 2019
22:47:25:WU01:FS02:0xa7: PID: 11472
22:47:25:WU03:FS03:0xa7: Time: 01:52:30
22:47:25:WU01:FS02:0xa7: CWD: <snip>\AppData\Roaming\FAHClient\work
22:47:25:WU03:FS03:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:47:25:WU01:FS02:0xa7:******************************** Build - libFAH ********************************
22:47:25:WU03:FS03:0xa7: Branch: master
22:47:25:WU01:FS02:0xa7: Version: 0.0.18
22:47:25:WU03:FS03:0xa7: Compiler: Visual C++ 2008
22:47:25:WU01:FS02:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:47:25:WU03:FS03:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:47:25:WU01:FS02:0xa7: Copyright: 2019 foldingathome.org
22:47:25:WU03:FS03:0xa7: Platform: win32 10
22:47:25:WU01:FS02:0xa7: Homepage: https://foldingathome.org/
22:47:25:WU03:FS03:0xa7: Bits: 64
22:47:25:WU01:FS02:0xa7: Date: Oct 26 2019
22:47:25:WU03:FS03:0xa7: Mode: Release
22:47:25:WU01:FS02:0xa7: Time: 01:52:30
22:47:25:WU03:FS03:0xa7:************************************ Build *************************************
22:47:25:WU01:FS02:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:47:25:WU03:FS03:0xa7: SIMD: avx_256
22:47:25:WU03:FS03:0xa7:********************************************************************************
22:47:25:WU03:FS03:0xa7:Project: 14632 (Run 1822, Clone 0, Gen 7)
22:47:25:WU03:FS03:0xa7:Unit: 0x000000089bf7a4d55e84f5384acb7b68
22:47:25:WU03:FS03:0xa7:Digital signatures verified
22:47:25:WU03:FS03:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -cpi state.cpt -cpt 15 -nt 10
22:47:25:WU03:FS03:0xa7:Steps: first=0 total=2500000
22:47:25:WU01:FS02:0xa7:************************************ Build *************************************
22:47:25:WU03:FS03:0xa7:Completed 332260 out of 2500000 steps (13%)
22:47:25:WU01:FS02:0xa7: SIMD: avx_256
22:47:25:WU01:FS02:0xa7:********************************************************************************
22:47:25:WU01:FS02:0xa7:Project: 14616 (Run 285, Clone 4, Gen 19)
22:47:25:WU01:FS02:0xa7:Unit: 0x000000169bf7a4d65e83252ea1be7c0c
22:47:25:WU01:FS02:0xa7:Digital signatures verified
22:47:25:WU01:FS02:0xa7:Calling: mdrun -s frame19.tpr -o frame19.trr -cpi state.cpt -cpt 15 -nt 12
22:47:25:WU01:FS02:0xa7:Steps: first=0 total=250000
22:47:25:WU01:FS02:0xa7:Completed 141063 out of 250000 steps (56%)
22:47:27:WU00:FS00:Connecting to <proxy>
22:47:27:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:47:27:ERROR:WU02:FS01:Exception: Could not get an assignment
22:47:27:WU02:FS01:Connecting to <proxy>
22:47:27:WU00:FS00:Assigned to work server 140.163.4.241
22:47:27:WU00:FS00:Requesting new work unit for slot 00: READY gpu:1:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 140.163.4.241
22:47:28:WU02:FS01:Assigned to work server 128.252.203.10
22:47:28:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2070 Super] 8218 from 128.252.203.10
22:47:28:WU02:FS01:Connecting to <proxy>
22:47:44:WU00:FS00:Downloading 7.92MiB
22:47:50:WU00:FS00:Download 54.42%
22:47:54:WU00:FS00:Download complete
22:47:54:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11745 run:0 clone:3223 gen:61 core:0x22 unit:0x000000518ca304f15e6a1517d7087551
22:47:54:WU00:FS00:Starting
22:47:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" <snip>\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 21032 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
Welcome to the F@H Forum lafrad,
I noticed few things:
1) next-unit-percentage by default is 99% and you have changed that. Please note that it would negatively impact your bons points since the total time to process the WU (started from when it is downloaded from the Server to when it is uploaded to the Server) is increased.
2) I would suggest that you try a single CPU Slot of 16 or 24. If you want multiple slots, use these values instead; 2, 4, 6, 8, 12, 16. I would avoid using 10 since it's a multiple of 5 which may or may not bode well for the WU.
I'm far less interested in points and far more interested in getting work for the fast GPUs to be saturated. The 2080TI and 2070 Super churn though the work very quickly, and chances are they will return the result before the average GPU's out in the field... More work gets done the less they are idle. The percentages I have chosen has given the COVID style work units about 5-15 minutes "head start" to have a WU waiting when the previous one finishes, so it has cut down the time it ends up waiting (after completion) to get another one (less idle time). I'm not doing this for the slower GPUs/CPU in my other PC. (I have tried to adjust that/go back to default, no change in how much the windows machine gets its work).
I haven't had any issues getting work for the 10 and 12 thread CPU slots... I haven't seen any errors or warnings... is it possible its causing trouble for the server? Otherwise, I've found this setup to leave the system feel like its unloaded for day-to-day use, and I can pause the 10 thread slot to go play a game and not feel any real impact on FPS (and enable it again when I'm done)....
As long as you don't have any errors or "domain decompostion" errors when using 10 CPUs, you're good. The Servers won't be impacted by the number of CPUs you're folding with. They will try to allocate the best possible WU for your hardware. Glad that you have found the optimum folding configuration for your systemlafrad wrote:...I haven't had any issues getting work for the 10 and 12 thread CPU slots... I haven't seen any errors or warnings... is it possible its causing trouble for the server? Otherwise, I've found this setup to leave the system feel like its unloaded for day-to-day use, and I can pause the 10 thread slot to go play a game and not feel any real impact on FPS (and enable it again when I'm done)....
