GPU project is stuck on download
SickNameDude
Post by SickNameDude »
My logs:
14:17:49:WU01:FS00:0xa7:       SIMD: avx_256
14:17:49:WU01:FS00:0xa7:********************************************************************************
14:17:49:WU01:FS00:0xa7:Project: 14626 (Run 107, Clone 4, Gen 21)
14:17:49:WU01:FS00:0xa7:Unit: 0x000000169bf7a4d65e89001d52deb1d2
14:17:49:WU01:FS00:0xa7:Digital signatures verified
14:17:49:WU01:FS00:0xa7:Calling: mdrun -s frame21.tpr -o frame21.trr -cpi state.cpt -cpt 15 -nt 10
14:17:49:WU01:FS00:0xa7:Steps: first=0 total=250000
14:17:50:WU01:FS00:0xa7:Completed 106624 out of 250000 steps (42%)
14:18:17:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
14:19:34:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
14:20:52:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
14:22:09:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
14:23:27:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
14:24:44:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
14:26:01:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
14:27:19:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
14:28:36:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
14:29:53:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
14:31:13:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
14:32:33:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
14:33:53:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
14:35:13:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
14:36:33:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
14:37:53:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
14:39:13:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
14:40:32:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
14:41:52:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
14:43:12:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
14:44:32:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
14:45:51:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
14:47:12:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:48:32:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:49:51:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
14:51:11:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
14:52:30:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
14:53:50:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
14:55:10:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
14:56:30:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
14:57:49:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
14:59:09:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
15:00:29:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
15:01:49:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
15:03:09:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
15:04:28:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
15:05:48:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
15:07:07:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
15:08:27:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
15:09:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:09:47:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
15:09:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:11:04:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
15:12:23:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
15:12:26:FS00:Shutting core down
15:12:26:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 12212
15:12:26:WU01:FS00:0xa7:Exiting, please wait. . .
15:12:27:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
15:12:27:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:12:27:WU01:FS00:Starting
15:12:27:WARNING:WU01:FS00:Changed SMP threads from 11 to 10 this can cause some work units to fail
15:12:27:WU01:FS00:Running FahCore: "H:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\junio\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 12268 -checkpoint 15 -np 10
15:12:28:WU01:FS00:Started FahCore on PID 7656
15:12:28:WU01:FS00:Core PID:11140
15:12:28:WU01:FS00:FahCore 0xa7 started
15:12:28:WU01:FS00:0xa7:*********************** Log Started 2020-04-16T15:12:28Z ***********************
15:12:28:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:12:28:WU01:FS00:0xa7:       Type: 0xa7
15:12:28:WU01:FS00:0xa7:       Core: Gromacs
15:12:28:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 7656 -checkpoint 15 -np
15:12:28:WU01:FS00:0xa7:             10
15:12:28:WU01:FS00:0xa7:************************************ CBang *************************************
15:12:28:WU01:FS00:0xa7:       Date: Oct 26 2019
15:12:28:WU01:FS00:0xa7:       Time: 01:38:25
15:12:28:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:12:28:WU01:FS00:0xa7:     Branch: master
15:12:28:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
15:12:28:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:12:28:WU01:FS00:0xa7:   Platform: win32 10
15:12:28:WU01:FS00:0xa7:       Bits: 64
15:12:28:WU01:FS00:0xa7:       Mode: Release
15:12:28:WU01:FS00:0xa7:************************************ System ************************************
15:12:28:WU01:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
15:12:28:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:12:28:WU01:FS00:0xa7:       CPUs: 12
15:12:28:WU01:FS00:0xa7:     Memory: 7.95GiB
15:12:28:WU01:FS00:0xa7:Free Memory: 4.63GiB
15:12:28:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
15:12:28:WU01:FS00:0xa7: OS Version: 6.2
15:12:28:WU01:FS00:0xa7:Has Battery: false
15:12:28:WU01:FS00:0xa7: On Battery: false
15:12:28:WU01:FS00:0xa7: UTC Offset: -4
15:12:28:WU01:FS00:0xa7:        PID: 11140
15:12:28:WU01:FS00:0xa7:        CWD: C:\Users\junio\AppData\Roaming\FAHClient\work
15:12:28:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:12:28:WU01:FS00:0xa7:    Version: 0.0.18
15:12:28:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:12:28:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:12:28:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
15:12:28:WU01:FS00:0xa7:       Time: 01:52:30
15:12:28:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:12:28:WU01:FS00:0xa7:************************************ Build *************************************
15:12:28:WU01:FS00:0xa7:       SIMD: avx_256
15:12:28:WU01:FS00:0xa7:********************************************************************************
15:12:28:WU01:FS00:0xa7:Project: 14626 (Run 107, Clone 4, Gen 21)
15:12:28:WU01:FS00:0xa7:Unit: 0x000000169bf7a4d65e89001d52deb1d2
15:12:28:WU01:FS00:0xa7:Digital signatures verified
15:12:28:WU01:FS00:0xa7:Calling: mdrun -s frame21.tpr -o frame21.trr -cpi state.cpt -cpt 15 -nt 10
15:12:28:WU01:FS00:0xa7:Steps: first=0 total=250000
15:12:29:WU01:FS00:0xa7:Completed 210088 out of 250000 steps (84%)
15:12:43:Removing old file 'configs/config-20200415-213537.xml'
15:12:43:Saving configuration to config.xml
15:12:43:<config>
15:12:43:  <!-- User Information -->
15:12:43:  <passkey v='********************************'/>
15:12:43:  <team v='225605'/>
15:12:43:  <user v='Jack'/>
15:12:43:
15:12:43:  <!-- Folding Slots -->
15:12:43:  <slot id='0' type='CPU'/>
15:12:43:  <slot id='1' type='GPU'/>
15:12:43:</config>
15:12:59:FS00:Shutting core down
15:12:59:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 11140
15:12:59:WU01:FS00:0xa7:Exiting, please wait. . .
15:12:59:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:13:27:WU01:FS00:Starting
15:13:27:WARNING:WU01:FS00:Changed SMP threads from 10 to 5 this can cause some work units to fail
15:13:27:WU01:FS00:Running FahCore: "H:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\junio\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 12268 -checkpoint 15 -np 5
15:13:27:WU01:FS00:Started FahCore on PID 1156
15:13:28:WU01:FS00:Core PID:2460
15:13:28:WU01:FS00:FahCore 0xa7 started
15:13:28:WU01:FS00:0xa7:*********************** Log Started 2020-04-16T15:13:28Z ***********************
15:13:28:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:13:28:WU01:FS00:0xa7:       Type: 0xa7
15:13:28:WU01:FS00:0xa7:       Core: Gromacs
15:13:28:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 1156 -checkpoint 15 -np 5
15:13:28:WU01:FS00:0xa7:************************************ CBang *************************************
15:13:28:WU01:FS00:0xa7:       Date: Oct 26 2019
15:13:28:WU01:FS00:0xa7:       Time: 01:38:25
15:13:28:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:13:28:WU01:FS00:0xa7:     Branch: master
15:13:28:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
15:13:28:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:13:28:WU01:FS00:0xa7:   Platform: win32 10
15:13:28:WU01:FS00:0xa7:       Bits: 64
15:13:28:WU01:FS00:0xa7:       Mode: Release
15:13:28:WU01:FS00:0xa7:************************************ System ************************************
15:13:28:WU01:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
15:13:28:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:13:28:WU01:FS00:0xa7:       CPUs: 12
15:13:28:WU01:FS00:0xa7:     Memory: 7.95GiB
15:13:28:WU01:FS00:0xa7:Free Memory: 4.04GiB
15:13:28:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
15:13:28:WU01:FS00:0xa7: OS Version: 6.2
15:13:28:WU01:FS00:0xa7:Has Battery: false
15:13:28:WU01:FS00:0xa7: On Battery: false
15:13:28:WU01:FS00:0xa7: UTC Offset: -4
15:13:28:WU01:FS00:0xa7:        PID: 2460
15:13:28:WU01:FS00:0xa7:        CWD: C:\Users\junio\AppData\Roaming\FAHClient\work
15:13:28:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:13:28:WU01:FS00:0xa7:    Version: 0.0.18
15:13:28:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:13:28:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:13:28:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
15:13:28:WU01:FS00:0xa7:       Time: 01:52:30
15:13:28:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:13:28:WU01:FS00:0xa7:************************************ Build *************************************
15:13:28:WU01:FS00:0xa7:       SIMD: avx_256
15:13:28:WU01:FS00:0xa7:********************************************************************************
15:13:28:WU01:FS00:0xa7:Project: 14626 (Run 107, Clone 4, Gen 21)
15:13:28:WU01:FS00:0xa7:Unit: 0x000000169bf7a4d65e89001d52deb1d2
15:13:28:WU01:FS00:0xa7:Digital signatures verified
15:13:28:WU01:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
15:13:28:WU01:FS00:0xa7:Calling: mdrun -s frame21.tpr -o frame21.trr -cpi state.cpt -cpt 15 -nt 4
15:13:28:WU01:FS00:0xa7:Steps: first=0 total=250000
15:13:28:WU01:FS00:0xa7:Completed 211029 out of 250000 steps (84%)
15:13:44:Removing old file 'configs/config-20200416-003837.xml'
15:13:44:Saving configuration to config.xml
15:13:44:<config>
15:13:44:  <!-- Slot Control -->
15:13:44:  <power v='full'/>
15:13:44:
15:13:44:  <!-- User Information -->
15:13:44:  <passkey v='********************************'/>
15:13:44:  <team v='225605'/>
15:13:44:  <user v='Jack'/>
15:13:44:
15:13:44:  <!-- Folding Slots -->
15:13:44:  <slot id='0' type='CPU'/>
15:13:44:  <slot id='1' type='GPU'/>
15:13:44:</config>
Error Messages: 13:19:42:ERROR:WU01:FS00:Exception: Could not get an assignment
If you could help me out that'd be great!
Re: GPU project is stuck on download
You can ignore the 10053 messages, those come from Web Control not closing its connection properly. Hopefully to be fixed in the next version.
Currently there are more requests for GPU WUs than the servers can supply. So it may take a while for an assignment to be made. That assignment may depend on what type of GPU you have and the client has detected. Could you post the first 200 lines of the log that shows the system info? Using the log window of FAHControl you may need to click on the Refresh button which causes a reload of the file from the beginning.
If the wait between GPU download attempts gets too long, more than a couple hours, you can pause just your GPU slot by right-clicking on the GPU slot in FAHControl. Wait about a minute before starting it again.
