GTX 1660 showing as gpu:0:[xxx] gets no WUs
barkydoggo
Post by barkydoggo »
My GPU suddenly had a name change in my F@H client and won't get WUs anymore. I've reinstalled drivers, rebooted multiple times, re-added the GPU slot. Any suggestions?
14:44:21:Adding folding slot 01: READY gpu:0:[xxx]
14:44:22:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
Re: GTX 1660 showing as gpu:0:[xxx] gets no WUs
(This is a guess, I did not see the first 200 lines of your log to make a good guess, so it is a bad guess)
Search for and delete GPUs.txt and have the client re-download it.
That may help.
barkydoggo
JimboPalmer wrote:(This is a guess, I did not see the first 200 lines of your log to make a good guess, so it is a bad guess)
That may help.
That is a good idea! And I did it, which unfortunately didn't solve the issue.
BUT
I solved it! I added a 2nd GPU slot and it detected my GPU properly. Looks like the iGPU on the processor showed up after a Windows Update. I paused that slot and am now folding like normal again.
Hope this helps anyone else with this issue.
Thank you!
iceman1992
Post by iceman1992 »
I'm curious, since I also have a 1660, what kind of PPD are you getting?
barkydoggo
iceman1992 wrote:I'm curious, since I also have a 1660, what kind of PPD are you getting?
I'm not too sure as I'm having a really difficult time getting WUs. Current counter is saying 678567 with the i9-9900 folding too. This is my prebuilt work PC, a Dell Optiplex 7071.
iceman1992
Ah okay that sounds in line with what I'm getting. I get 500-600K PPD just from the GPU.
Sttormin88
Post by Sttormin88 »
Hello there, I am having the same issue with my 1060.
What do I need to do to fix this xxx issue?
Casey_Goode
Post by Casey_Goode »
Thanks for this! Must have been an update, was doing great and then suddenly noticed the huge drop in daily points and that the GPU was labeled as XXX.
Updated the driver and still no good, but came here and BOOM solved. Just went to configure and added a new GPU slot and there it is! Now here's to hoping it gets a work unit.
You've been bitten by a new bug.
Some provisional GPUs from Intel have been added to GPUs.txt for some internal testing. Unfortunaely this has disrupted a number of previously working GPU slots. You happened to find the solution: Add a new GPU slot for the old GPU.
The first GPU slot used to point to your existing GTX 1660 GPU and it has been "updated" and it now points the unsupported Intel iGP. Leave that slot alone and pay attention to the new one you added.
mbell82
Post by mbell82 »
I'm also getting issues with a new GTX 1660.
GPU 0 Bus:38 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce 1660]
Not detected: failed to open dynamic library 'nvidia.dll': the specified module could not be found.
OpenCl Not detected: clGetPlatformIDs() returned -1001
Does this mean I am missing an Nvidia driver? Or is this an issue in FAH?
I originally had an integrated graphics APU.
When I look at the Slots tab, it has two entries.
CPU 0
GPU 1
And, in case it helps, here is a recent part of the Log
15:05:13:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:13416 run:590 clone:292 gen:0 core:0x22 unit:0x0000000212bc7d9a5f0f8f5d47381128
15:05:13:WU00:FS01:Connecting to 18.188.125.154:8080
15:05:13:WU00:FS01:Server responded WORK_ACK (400)
15:05:13:WU00:FS01:Cleaning up
15:05:13:WU00:FS01:Connecting to 65.254.110.245:8080
15:05:13:WU00:FS01:Assigned to work server 18.188.125.154
15:05:13:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660] from 18.188.125.154
15:05:13:WU00:FS01:Downloading 6.96MiB
15:05:14:WU00:FS01:Download complete
15:05:14:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13418 run:250 clone:96 gen:5 core:0x22 unit:0x0000000b12bc7d9a5f12829d9f698e42
15:05:14:WU00:FS01:Starting
15:05:14:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
15:06:15:WU00:FS01:Starting
15:06:15:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
15:06:51:WU03:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
gunnarre
Post by gunnarre »
mbell82 wrote:I'm also getting issues with a new GTX 1660.
Please post the first lines of your logs in Code tags. See "How to post post a log file" here: viewtopic.php?f=61&t=26036
Have you (re-)installed the drivers from Nvidia.com?
mbell82
Post by mbell82 »
bruce wrote:Have you (re-)installed the drivers from Nvidia.com?
I feel like such a noob! Can't believe I never thought to update the drivers. Built the computer. Used an integrated graphics cpu for a while. But, I updated everything. Finally got the graphics card...and the new processor only cpu...what do i do? Not update the drivers. Sheesh!
Unfortunately, it is still doing the same thing. So, here is the log beginning after I did the driver update.
15:56:22:WU03:FS00:0xa7:*********************** Log Started 2020-07-23T15:56:22Z ***********************
15:56:22:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:56:22:WU03:FS00:0xa7:       Type: 0xa7
15:56:22:WU03:FS00:0xa7:       Core: Gromacs
15:56:22:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 705 -lifeline 10356 -checkpoint 15 -np
15:56:22:WU03:FS00:0xa7:             11
15:56:22:WU03:FS00:0xa7:************************************ CBang *************************************
15:56:22:WU03:FS00:0xa7:       Date: Nov 27 2019
15:56:22:WU03:FS00:0xa7:       Time: 03:40:09
15:56:22:WU03:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
15:56:22:WU03:FS00:0xa7:     Branch: master
15:56:22:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
15:56:22:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:56:22:WU03:FS00:0xa7:   Platform: win32 10
15:56:22:WU03:FS00:0xa7:       Bits: 64
15:56:22:WU03:FS00:0xa7:       Mode: Release
15:56:22:WU03:FS00:0xa7:************************************ System ************************************
15:56:22:WU03:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
15:56:22:WU03:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:56:22:WU03:FS00:0xa7:       CPUs: 12
15:56:22:WU03:FS00:0xa7:     Memory: 15.95GiB
15:56:22:WU03:FS00:0xa7:Free Memory: 9.68GiB
15:56:22:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
15:56:22:WU03:FS00:0xa7: OS Version: 6.2
15:56:22:WU03:FS00:0xa7:Has Battery: false
15:56:22:WU03:FS00:0xa7: On Battery: false
15:56:22:WU03:FS00:0xa7: UTC Offset: -5
15:56:22:WU03:FS00:0xa7:        PID: 1368
15:56:22:WU03:FS00:0xa7:        CWD: C:\Users\mtbel\AppData\Roaming\FAHClient\work
15:56:22:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
15:56:22:WU03:FS00:0xa7:    Version: 0.0.19
15:56:22:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:56:22:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:56:22:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
15:56:22:WU03:FS00:0xa7:       Date: Nov 25 2019
15:56:22:WU03:FS00:0xa7:       Time: 17:12:41
15:56:22:WU03:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
15:56:22:WU03:FS00:0xa7:************************************ Build *************************************
15:56:22:WU03:FS00:0xa7:       SIMD: avx_256
15:56:22:WU03:FS00:0xa7:********************************************************************************
15:56:22:WU03:FS00:0xa7:Project: 14816 (Run 502, Clone 2, Gen 14)
15:56:22:WU03:FS00:0xa7:Unit: 0x00000011455e42065ec7cf64fbba181b
15:56:22:WU03:FS00:0xa7:Digital signatures verified
15:56:22:WU03:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
15:56:22:WU03:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -cpi state.cpt -cpt 15 -nt 10
15:56:22:WU03:FS00:0xa7:Steps: first=0 total=250000
15:56:23:WU03:FS00:0xa7:Completed 54266 out of 250000 steps (21%)
15:56:24:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
15:56:24:WU02:FS00:Connecting to 40.114.52.201:80
15:56:26:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
15:56:26:WU02:FS00:Trying to send results to collection server
15:56:26:WU02:FS00:Uploading 1.76MiB to 52.224.109.74
15:56:26:WU02:FS00:Connecting to 52.224.109.74:8080
15:56:28:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
15:56:28:WU02:FS00:Connecting to 52.224.109.74:80
15:56:30:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: No connection could be made because the target machine actively refused it.
15:56:45:WU03:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
15:57:12:Removing old file 'configs/config-20200717-041802.xml'
15:57:12:Saving configuration to config.xml
15:57:12:<config>
15:57:12:  <!-- Network -->
15:57:12:  <proxy v=':8080'/>
15:57:12:
15:57:12:  <!-- Slot Control -->
15:57:12:  <power v='FULL'/>
15:57:12:
15:57:12:  <!-- User Information -->
15:57:12:  <passkey v='********************************'/>
15:57:12:  <team v='241865'/>
15:57:12:  <user v='Mbell82'/>
15:57:12:
15:57:12:  <!-- Folding Slots -->
15:57:12:  <slot id='0' type='CPU'/>
15:57:12:  <slot id='1' type='GPU'/>
15:57:12:</config>
15:57:57:WU03:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
15:57:58:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14580 run:0 clone:965 gen:404 core:0xa7 unit:0x000001ec287234c95e7a34c108e4fc2f
15:57:58:WU02:FS00:Uploading 1.76MiB to 40.114.52.201
15:57:58:WU02:FS00:Connecting to 40.114.52.201:8080
15:57:59:WU00:FS01:Starting
15:57:59:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
15:57:59:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:13416 run:1163 clone:7 gen:4 core:0x22 unit:0x0000000512bc7d9a5f02af79737998e7
15:57:59:WU00:FS01:Connecting to 18.188.125.154:8080
15:57:59:WU00:FS01:Server responded WORK_ACK (400)
15:57:59:WU00:FS01:Cleaning up
15:57:59:WU00:FS01:Connecting to 65.254.110.245:8080
15:57:59:WU00:FS01:Assigned to work server 140.163.4.241
15:57:59:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660] from 140.163.4.241
15:57:59:WU00:FS01:Connecting to 140.163.4.241:8080
15:58:01:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
15:58:01:WU02:FS00:Connecting to 40.114.52.201:80
15:58:03:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
15:58:03:WU02:FS00:Trying to send results to collection server
15:58:03:WU02:FS00:Uploading 1.76MiB to 52.224.109.74
15:58:03:WU02:FS00:Connecting to 52.224.109.74:8080
15:58:05:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
15:58:05:WU02:FS00:Connecting to 52.224.109.74:80
15:58:08:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: No connection could be made because the target machine actively refused it.
15:58:11:WU00:FS01:Downloading 7.85MiB
15:58:14:WU00:FS01:Download complete
15:58:14:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11744 run:0 clone:9038 gen:239 core:0x22 unit:0x000001648ca304f15e6bc3f634b840d0
15:58:14:WU00:FS01:Starting
15:58:14:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
15:59:10:WU03:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
15:59:14:WU00:FS01:Starting
15:59:14:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
16:00:23:WU03:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
16:00:36:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14580 run:0 clone:965 gen:404 core:0xa7 unit:0x000001ec287234c95e7a34c108e4fc2f
16:00:36:WU02:FS00:Uploading 1.76MiB to 40.114.52.201
16:00:36:WU02:FS00:Connecting to 40.114.52.201:8080
16:00:38:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
16:00:38:WU02:FS00:Connecting to 40.114.52.201:80
16:00:41:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
16:00:41:WU02:FS00:Trying to send results to collection server
16:00:41:WU02:FS00:Uploading 1.76MiB to 52.224.109.74
16:00:41:WU02:FS00:Connecting to 52.224.109.74:8080
16:00:43:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
16:00:43:WU02:FS00:Connecting to 52.224.109.74:80
16:00:45:ERROR:WU02:FS00:Exception: Failed to connect to 52.224.109.74:80: No connection could be made because the target machine actively refused it.
16:00:51:WU00:FS01:Starting
16:00:51:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
16:01:36:WU03:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
16:02:49:WU03:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
16:03:28:WU00:FS01:Starting
16:03:28:ERROR:WU00:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
That's not the part we need. About one page from the extreme top of the file it shows the GPUs that were found along with the drivers. That's the beginning of the execution of 0xa7.
My GUESS is that you need to add a slot for the device ... or maybe something else.
If copying from the log window in FAHControl, remove the check from Follow and Refresh to load from the beginning of the log. Then scroll all the way to the beginning of the log, we are looking for the first 100-200 lines.
