FahCore returned: INTERRUPTED (102 = 0x66)
Good morning,
I would like to participate and be able to collaborate through my team 261556. However, despite of uninstalls, CPU remove and add, it is still stuck at ready state.
Try to start at attempt but immediatly fail as interrupted. See typical log feedback :
21:33:55:WU00:FS00:FahCore 0xa7 started
21:33:57:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
My system view :
21:26:41: CPU: Intel(R) Core(TM)2 Duo CPU T8300 @ 2.40GHz
21:26:41: CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
21:26:41: CPUs: 2
21:26:41: Memory: 2.00GiB
21:26:41:Free Memory: 1.29GiB
21:26:41: Threads: POSIX_THREADS
21:26:41: OS Version: 10.6
21:26:41:Has Battery: true
21:26:41: On Battery: false
21:26:41: UTC Offset: 2
21:26:41: PID: 184
21:26:41: CWD: /Library/Application Support/FAHClient
21:26:41: OS: Darwin 10.8.0 i386
21:26:41: OS Arch: AMD64
21:26:41: GPUs: 0
21:26:41: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
21:26:41: dlopen(libcuda.dylib, 1): image not found
21:26:41: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
21:26:41: dlopen(libOpenCL.dylib, 1): image not found
Any help would be appreciated. I am so sad to not be able to join my force for helping against this virus.
Hope you could help me.
Thanks for support.
My system view :
21:26:41: CPUs: 2
21:26:41: PID: 184
21:26:41: GPUs: 0
Thanks for support.
Re: FahCore returned: INTERRUPTED (102 = 0x66)
Welcome to the F@H Forum Bubsy,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file: viewtopic.php?f=16&t=26036
Due to a need for an updated or missing library, the minimum version for OS X to run the CPU folding core is 10.7 from what I last heard from the developer. Originally it was usable back to OS 10.6.8, but patching a bug last Fall the developer tools available only would go back to 10.7.
So if you can upgrade to 10.7 or later, folding should work on your CPU.
Good morning,
Thanks for your prompt feedback. Here the log :
Still crossing fingers...
*********************** Log Started 2020-04-16T10:04:04Z ***********************
10:04:04:************************* Folding@home Client *************************
10:04:04: Website: https://foldingathome.org/
10:04:04: Copyright: (c) 2009-2018 foldingathome.org
10:04:04: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:04:04: Args:
10:04:04: Config: /Library/Application Support/FAHClient/config.xml
10:04:04:******************************** Build ********************************
10:04:04: Version: 7.5.1
10:04:04: Date: May 11 2018
10:04:04: Time: 12:57:01
10:04:04: Repository: Git
10:04:04: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:04:04: Branch: master
10:04:04: Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
10:04:04: Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
10:04:04: -Wno-unused-local-typedefs
10:04:04: Platform: darwin 15.6.0
10:04:04: Bits: 64
10:04:04: Mode: Release
10:04:04:******************************* System ********************************
10:04:04: CPU: Intel(R) Core(TM)2 Duo CPU T8300 @ 2.40GHz
10:04:04: CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
10:04:04: CPUs: 2
10:04:04: Memory: 2.00GiB
10:04:04:Free Memory: 1.81GiB
10:04:04: Threads: POSIX_THREADS
10:04:04: OS Version: 10.6
10:04:04:Has Battery: true
10:04:04: On Battery: false
10:04:04: UTC Offset: 2
10:04:04: PID: 53
10:04:04: CWD: /Library/Application Support/FAHClient
10:04:04: OS: Darwin 10.8.0 i386
10:04:04: OS Arch: AMD64
10:04:04: GPUs: 0
10:04:04: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
10:04:04: dlopen(libcuda.dylib, 1): image not found
10:04:04: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
10:04:04: dlopen(libOpenCL.dylib, 1): image not found
10:04:04:***********************************************************************
10:04:04:<config>
10:04:04: <!-- Network -->
10:04:04: <proxy v=':8080'/>
10:04:04:
10:04:04: <!-- Slot Control -->
10:04:04: <power v='MEDIUM'/>
10:04:04:
10:04:04: <!-- User Information -->
10:04:04: <team v='261556'/>
10:04:04: <user v='Bubsy'/>
10:04:04:
10:04:04: <!-- Folding Slots -->
10:04:04: <slot id='1' type='CPU'/>
10:04:04:</config>
10:04:04:Trying to access database...
10:04:05:Successfully acquired database lock
10:04:05:Enabled folding slot 01: READY cpu:1
10:04:05:ERROR:Failed to register for display power changes
10:04:05:WU00:FS01:Starting
10:04:05:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:04:05:WU00:FS01:Started FahCore on PID 64
10:04:05:WU00:FS01:Core PID:67
10:04:05:WU00:FS01:FahCore 0xa7 started
10:04:09:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:04:11:WU00:FS01:Starting
10:04:11:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:04:11:WU00:FS01:Started FahCore on PID 87
10:04:11:WU00:FS01:Core PID:88
10:04:11:WU00:FS01:FahCore 0xa7 started
10:04:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:05:11:WU00:FS01:Starting
10:05:11:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:05:11:WU00:FS01:Started FahCore on PID 157
10:05:11:WU00:FS01:Core PID:160
10:05:11:WU00:FS01:FahCore 0xa7 started
10:05:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:06:11:WU00:FS01:Starting
10:06:11:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:06:11:WU00:FS01:Started FahCore on PID 167
10:06:11:WU00:FS01:Core PID:170
10:06:11:WU00:FS01:FahCore 0xa7 started
10:06:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:07:11:WU00:FS01:Starting
10:07:11:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:07:11:WU00:FS01:Started FahCore on PID 173
10:07:12:WU00:FS01:Core PID:176
10:07:12:WU00:FS01:FahCore 0xa7 started
10:07:13:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:08:12:WU00:FS01:Starting
10:08:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:08:12:WU00:FS01:Started FahCore on PID 179
10:08:12:WU00:FS01:Core PID:182
10:08:12:WU00:FS01:FahCore 0xa7 started
10:08:14:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:09:12:WU00:FS01:Starting
10:09:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:09:12:WU00:FS01:Started FahCore on PID 184
10:09:12:WU00:FS01:Core PID:187
10:09:12:WU00:FS01:FahCore 0xa7 started
10:09:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:10:12:WU00:FS01:Starting
10:10:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:10:12:WU00:FS01:Started FahCore on PID 190
10:10:12:WU00:FS01:Core PID:193
10:10:12:WU00:FS01:FahCore 0xa7 started
10:10:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:11:12:WU00:FS01:Starting
10:11:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:11:12:WU00:FS01:Started FahCore on PID 198
10:11:12:WU00:FS01:Core PID:201
10:11:12:WU00:FS01:FahCore 0xa7 started
10:11:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:12:12:WU00:FS01:Starting
10:12:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:12:12:WU00:FS01:Started FahCore on PID 204
10:12:12:WU00:FS01:Core PID:207
10:12:12:WU00:FS01:FahCore 0xa7 started
10:12:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:13:12:WU00:FS01:Starting
10:13:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:13:12:WU00:FS01:Started FahCore on PID 210
10:13:12:WU00:FS01:Core PID:213
10:13:12:WU00:FS01:FahCore 0xa7 started
10:13:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:14:12:WU00:FS01:Starting
10:14:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:14:12:WU00:FS01:Started FahCore on PID 216
10:14:12:WU00:FS01:Core PID:219
10:14:12:WU00:FS01:FahCore 0xa7 started
10:14:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:15:12:WU00:FS01:Starting
10:15:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:15:12:WU00:FS01:Started FahCore on PID 233
10:15:12:WU00:FS01:Core PID:236
10:15:12:WU00:FS01:FahCore 0xa7 started
10:15:13:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:16:12:WU00:FS01:Starting
10:16:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:16:12:WU00:FS01:Started FahCore on PID 240
10:16:12:WU00:FS01:Core PID:243
10:16:12:WU00:FS01:FahCore 0xa7 started
10:16:13:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:17:12:WU00:FS01:Starting
10:17:12:WU00:FS01:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 53 -checkpoint 15 -np 1
10:17:12:WU00:FS01:Started FahCore on PID 250
10:17:12:WU00:FS01:Core PID:253
10:17:12:WU00:FS01:FahCore 0xa7 started
10:17:13:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)Mod Edit: Added Code Tags - PantherX
If you edit your post (or when creating new replies click on the full editor next to submit), highlight the whole log entry the click on the code button at the top of that window it will put markers around it so that it appears in a scrollable window.
Noted. Thanks for notification.
Hope my old Mac could still contribute...
As I mentioned already, you will need to upgrade to 10.7 or later. Or run Windows or Linux on this Mac.
AndrewBienhaus
Damn.
Applies to me too. Any other fix?
Apple long ago abandoned a lot of good hardware, that's stuck at 10.6.8... my own included.
Unfortunatey no. The development system had been upgraded at some point to insure compatibility with later OS X versions as I understand it, and the updated version of the folding core when it was compiled could not be done for 10.6.8.
So the client itself still runs on 10.6.8, and FAHControl could be used to monitor other systems remotely. But the folding core needed to actually process a WU does not run.
AndrewBienhaus
ok, so, good excuse to pull any useful files off that old mac, and install Ubuntu 19... got it.
(copying now, 35 mins to go)
It's a 4 processor mac pro, if I remember whart's inside this monster chassis... so we'll see how that goes.
AndrewBienhaus
well, this part of the project is going to have to split into another thread...
