PRCG 13876 (0,81,28)
favrepeoria
Post by favrepeoria »
See a long time to upload this WU. GPU has moved on and completed a couple other units since. Thought I would check in as it keeps getting a failure to upload. Seems the server may not be responding?
03:22:47:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13876 run:0 clone:81 gen:28 core:0x22 unit:0x000000240d5262775e7cf10c73387f35
03:22:47:WU00:FS01:Uploading 48.04MiB to 13.82.98.119
03:22:47:WU00:FS01:Connecting to 13.82.98.119:8080
03:23:08:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:23:08:WU00:FS01:Connecting to 13.82.98.119:80
03:23:30:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:23:30:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13876 run:0 clone:81 gen:28 core:0x22 unit:0x000000240d5262775e7cf10c73387f35
03:23:30:WU00:FS01:Uploading 48.04MiB to 13.82.98.119
03:23:30:WU00:FS01:Connecting to 13.82.98.119:8080
03:23:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:23:51:WU00:FS01:Connecting to 13.82.98.119:80
03:24:12:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:24:30:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13876 run:0 clone:81 gen:28 core:0x22 unit:0x000000240d5262775e7cf10c73387f35
03:24:30:WU00:FS01:Uploading 48.04MiB to 13.82.98.119
03:24:30:WU00:FS01:Connecting to 13.82.98.119:8080
03:24:51:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:24:51:WU00:FS01:Connecting to 13.82.98.119:80
03:25:12:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:26:07:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13876 run:0 clone:81 gen:28 core:0x22 unit:0x000000240d5262775e7cf10c73387f35
03:26:07:WU00:FS01:Uploading 48.04MiB to 13.82.98.119
03:26:07:WU00:FS01:Connecting to 13.82.98.119:8080
03:26:28:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:26:28:WU00:FS01:Connecting to 13.82.98.119:80
03:26:49:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 13.82.98.119:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Re: PRCG 13876 (0,81,28)
Welcome to the F@H Forum favrepeoria,
Please note that the Server (13.82.98.119) is currently down. Once it is operational, it will be in service.
