MSI GAMING GeForce RTX 2070 8GB GDRR6 256-bit HDMI/DP/USB Ra
SilentPanda
Post by SilentPanda »
This is for "MSI GAMING GeForce RTX 2070 8GB GDRR6 256-bit HDMI/DP/USB Ray Tracing Turing Architecture HDCP Graphics Card (RTX 2070 GAMING Z 8G)" (amazon description)
0x10de:0x1f07:6:0:0:NVIDIA Corporation:NVIDIA GeForce RTX 2070
*********************** Log Started 2020-04-15T20:09:33Z ***********************
20:09:33:************************* Folding@home Client *************************
20:09:33:        Website: https://foldingathome.org/
20:09:33:      Copyright: (c) 2009-2018 foldingathome.org
20:09:33:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:09:33:           Args: --open-web-control
20:09:33:         Config: <none>
20:09:33:******************************** Build ********************************
20:09:33:        Version: 7.5.1
20:09:33:           Date: May 11 2018
20:09:33:           Time: 13:06:32
20:09:33:     Repository: Git
20:09:33:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:09:33:         Branch: master
20:09:33:       Compiler: Visual C++ 2008
20:09:33:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:09:33:       Platform: win32 10
20:09:33:           Bits: 32
20:09:33:           Mode: Release
20:09:33:******************************* System ********************************
20:09:33:            CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
20:09:33:         CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
20:09:33:           CPUs: 12
20:09:33:         Memory: 31.90GiB
20:09:33:    Free Memory: 17.39GiB
20:09:33:        Threads: WINDOWS_THREADS
20:09:33:     OS Version: 6.2
20:09:33:    Has Battery: false
20:09:33:     On Battery: false
20:09:33:     UTC Offset: -5
20:09:33:            PID: 9660
20:09:33:            CWD: C:\Users\myaccount\AppData\Roaming\FAHClient
20:09:33:             OS: Windows 10 Enterprise
20:09:33:        OS Arch: AMD64
20:09:33:           GPUs: 0
20:09:33:  CUDA Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:7.5 Driver:11.0
20:09:33:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:445.87
20:09:33:  Win32 Service: false
20:09:33:***********************************************************************
20:09:33:<config>
20:09:33:  <!-- Folding Slots -->
20:09:33:</config>
20:09:33:Connecting to assign1.foldingathome.org:8080
20:09:33:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to connect to assign1.foldingathome.org:8080: An attempt was made to access a socket in a way forbidden by its access permissions.
20:09:33:Connecting to assign2.foldingathome.org:80
20:09:33:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to connect to assign2.foldingathome.org:80: An attempt was made to access a socket in a way forbidden by its access permissions.
20:09:33:Trying to access database...
20:09:33:Successfully acquired database lock
20:09:33:Enabled folding slot 00: PAUSED cpu:11 (not configured)
20:09:36:10:127.0.0.1:New Web connection
20:10:21:Set client configured
20:10:22:WU00:FS00:Connecting to 65.254.110.245:8080
20:10:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:10:22:WU00:FS00:Connecting to 18.218.241.186:80
20:10:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:10:22:ERROR:WU00:FS00:Exception: Could not get an assignment
20:10:34:Saving configuration to config.xml
20:10:34:<config>
20:10:34:  <!-- User Information -->
20:10:34:  <team v='3446'/>
20:10:34:  <user v='SilentPanda'/>
20:10:34:
20:10:34:  <!-- Folding Slots -->
20:10:34:  <slot id='0' type='CPU'/>
20:10:34:</config>
20:11:22:WU00:FS00:Connecting to 65.254.110.245:8080
20:11:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:11:22:WU00:FS00:Connecting to 18.218.241.186:80
20:11:22:WU00:FS00:Assigned to work server 40.114.52.201
20:11:22:WU00:FS00:Requesting new work unit for slot 00: READY cpu:11 from 40.114.52.201
20:11:22:WU00:FS00:Connecting to 40.114.52.201:8080
20:11:26:Saving configuration to config.xml
20:11:26:<config>
20:11:26:  <!-- Network -->
20:11:26:  <proxy v=':8080'/>
20:11:26:
20:11:26:  <!-- User Information -->
20:11:26:  <team v='3446'/>
20:11:26:  <user v='SilentPanda'/>
20:11:26:
20:11:26:  <!-- Folding Slots -->
20:11:26:  <slot id='0' type='CPU'/>
20:11:26:</config>
20:11:35:Saving configuration to config.xml
20:11:35:<config>
20:11:35:  <!-- Network -->
20:11:35:  <proxy v=':8080'/>
20:11:35:
20:11:35:  <!-- User Information -->
20:11:35:  <team v='3446'/>
20:11:35:  <user v='SilentPanda'/>
20:11:35:
20:11:35:  <!-- Folding Slots -->
20:11:35:  <slot id='0' type='CPU'/>
20:11:35:</config>
20:11:43:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
20:11:43:WU00:FS00:Connecting to 40.114.52.201:80
20:11:49:ERROR:WU00:FS00:Exception: Server did not assign work unit
20:12:30:Saving configuration to config.xml
20:12:30:<config>
20:12:30:  <!-- Network -->
20:12:30:  <proxy v=':8080'/>
20:12:30:
20:12:30:  <!-- User Information -->
20:12:30:  <team v='3446'/>
20:12:30:  <user v='SilentPanda'/>
20:12:30:
20:12:30:  <!-- Folding Slots -->
20:12:30:  <slot id='0' type='CPU'/>
20:12:30:</config>
20:12:59:WU00:FS00:Connecting to 65.254.110.245:8080
20:12:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:12:59:WU00:FS00:Connecting to 18.218.241.186:80
20:13:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:13:00:ERROR:WU00:FS00:Exception: Could not get an assignment
20:14:33:Connecting to assign1.foldingathome.org:8080
20:14:33:Updated GPUs.txt
20:15:36:WU00:FS00:Connecting to 65.254.110.245:8080
20:15:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:15:37:WU00:FS00:Connecting to 18.218.241.186:80
20:15:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:15:37:ERROR:WU00:FS00:Exception: Could not get an assignment
20:16:49:Saving configuration to config.xml
20:16:49:<config>
20:16:49:  <!-- Network -->
20:16:49:  <proxy v=':8080'/>
20:16:49:
20:16:49:  <!-- User Information -->
20:16:49:  <team v='3446'/>
20:16:49:  <user v='SilentPanda'/>
20:16:49:
20:16:49:  <!-- Folding Slots -->
20:16:49:</config>
20:16:49:WU00:FS00:Slot ID 0 no longer exists and not yet downloaded, dumping
20:16:49:WU00:FS00:Cleaning up
20:17:07:Adding folding slot 00: READY cpu:11
20:17:07:Saving configuration to config.xml
20:17:07:<config>
20:17:07:  <!-- Network -->
20:17:07:  <proxy v=':8080'/>
20:17:07:
20:17:07:  <!-- User Information -->
20:17:07:  <team v='3446'/>
20:17:07:  <user v='SilentPanda'/>
20:17:07:
20:17:07:  <!-- Folding Slots -->
20:17:07:  <slot id='0' type='CPU'/>
20:17:07:</config>
20:17:08:WU00:FS00:Connecting to 65.254.110.245:8080
20:17:08:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:17:08:WU00:FS00:Connecting to 18.218.241.186:80
20:17:08:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:17:08:ERROR:WU00:FS00:Exception: Could not get an assignment
20:18:08:WU00:FS00:Connecting to 65.254.110.245:8080
20:18:08:WU00:FS00:Assigned to work server 150.136.14.110
20:18:08:WU00:FS00:Requesting new work unit for slot 00: READY cpu:11 from 150.136.14.110
20:18:08:WU00:FS00:Connecting to 150.136.14.110:8080
20:18:08:WU00:FS00:Downloading 3.11MiB
20:18:09:WU00:FS00:Download complete
20:18:09:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16422 run:2265 clone:0 gen:22 core:0xa7 unit:0x0000001c96880e6e5e8bdd6b6f4bfe18
20:18:09:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
20:18:09:WU00:FS00:Connecting to cores.foldingathome.org:80
20:18:09:WU00:FS00:FahCore a7: Downloading 6.71MiB
20:18:10:WU00:FS00:FahCore a7: Download complete
20:18:10:WU00:FS00:Valid core signature
20:18:10:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
20:18:10:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
20:18:10:WU00:FS00:Starting
20:18:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\myaccount\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9660 -checkpoint 15 -np 11
20:18:10:WU00:FS00:Started FahCore on PID 15412
20:18:10:WU00:FS00:Core PID:20360
20:18:10:WU00:FS00:FahCore 0xa7 started
20:18:11:WU00:FS00:0xa7:*********************** Log Started 2020-04-15T20:18:10Z ***********************
20:18:11:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:18:11:WU00:FS00:0xa7:       Type: 0xa7
20:18:11:WU00:FS00:0xa7:       Core: Gromacs
20:18:11:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 15412 -checkpoint 15 -np
20:18:11:WU00:FS00:0xa7:             11
20:18:11:WU00:FS00:0xa7:************************************ CBang *************************************
20:18:11:WU00:FS00:0xa7:       Date: Oct 26 2019
20:18:11:WU00:FS00:0xa7:       Time: 01:38:25
20:18:11:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:18:11:WU00:FS00:0xa7:     Branch: master
20:18:11:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:18:11:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:18:11:WU00:FS00:0xa7:   Platform: win32 10
20:18:11:WU00:FS00:0xa7:       Bits: 64
20:18:11:WU00:FS00:0xa7:       Mode: Release
20:18:11:WU00:FS00:0xa7:************************************ System ************************************
20:18:11:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
20:18:11:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
20:18:11:WU00:FS00:0xa7:       CPUs: 12
20:18:11:WU00:FS00:0xa7:     Memory: 31.90GiB
20:18:11:WU00:FS00:0xa7:Free Memory: 16.88GiB
20:18:11:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:18:11:WU00:FS00:0xa7: OS Version: 6.2
20:18:11:WU00:FS00:0xa7:Has Battery: false
20:18:11:WU00:FS00:0xa7: On Battery: false
20:18:11:WU00:FS00:0xa7: UTC Offset: -5
20:18:11:WU00:FS00:0xa7:        PID: 20360
20:18:11:WU00:FS00:0xa7:        CWD: C:\Users\myaccount\AppData\Roaming\FAHClient\work
20:18:11:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:18:11:WU00:FS00:0xa7:    Version: 0.0.18
20:18:11:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:18:11:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:18:11:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:18:11:WU00:FS00:0xa7:       Time: 01:52:30
20:18:11:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:18:11:WU00:FS00:0xa7:************************************ Build *************************************
20:18:11:WU00:FS00:0xa7:       SIMD: avx_256
20:18:11:WU00:FS00:0xa7:********************************************************************************
20:18:11:WU00:FS00:0xa7:Project: 16422 (Run 2265, Clone 0, Gen 22)
20:18:11:WU00:FS00:0xa7:Unit: 0x0000001c96880e6e5e8bdd6b6f4bfe18
20:18:11:WU00:FS00:0xa7:Reading tar file core.xml
20:18:11:WU00:FS00:0xa7:Reading tar file frame22.tpr
20:18:11:WU00:FS00:0xa7:Digital signatures verified
20:18:11:WU00:FS00:0xa7:Reducing thread count from 11 to 10 to avoid domain decomposition by a prime number > 3
20:18:11:WU00:FS00:0xa7:Calling: mdrun -s frame22.tpr -o frame22.trr -x frame22.xtc -cpt 15 -nt 10
20:18:11:WU00:FS00:0xa7:Steps: first=5500000 total=250000
20:18:12:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
20:19:25:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
20:19:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:20:37:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
20:21:48:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
20:22:56:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
20:24:03:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
20:25:10:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
20:26:24:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
20:27:36:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
Thanks.
Re: MSI GAMING GeForce RTX 2070 8GB GDRR6 256-bit HDMI/DP/US
This GPU is already listed in the GPUs.txt file:
0x10de:0x1f07:2:7:TU106 [GeForce RTX 2070 Rev. A] M 7465
Your client will need to be able to connect to the servers to download the updated list and install it.
SilentPanda
Thanks. I saw that in there before I sent but it didn't work, but I deleted my GPUs.txt and restarted the client and it took. Sorry for the trouble!
Post by Neil-B »
No trouble ... the forums are here to assist ... and people like Joe_H will spot issues from logs far quicker/better than many of us can ... if you have questions dont feel you are troubling anyone by asking them :)
Welcome to the F@H Forum SilentPanda,
Please note that if you notice that your GPU slot is idle because it can't get any WUs, that is due to the demand of GPUs exceeding the supply. Work is being done to increase the supply to meet the demand :)
