Strange error message :-0 new to folding!
Cruddson001
Post by Cruddson001 »
Hi I get a strange error message when I open FAH control centre (Client Advanced Control.)
https://www.dropbox.com/s/a59wyoxjmp5m4 ... g.jpg?dl=0
"On client "local" 127.0.0.1:xxxxx:
Option 'gpu-index' has not default and is not set
iter should be GtkTreeIter"
Has this anything to do with the spare capacity at the moment?
Do I have a virus?
The computer's fans have been running flat out for three days no with no folding happening. :eo
I have tried restarting my computer and the router.
I think Windows was doing an update also.
Help please!
ajm
Re: Strange error message :-0 new to folding!
Post by ajm »
There seems to be something wrong with the configuration of your GPU. Could you please post the first 200 or so lines of your logs (tab Log in the Advanced Control), starting with
13:14:09:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
13:14:09:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
13:14:09:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
13:14:09:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 15700 -checkpoint 15
13:14:09:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
13:14:09:WU00:FS01:0x22:     Config: <none>
13:14:09:WU00:FS01:0x22:************************************ Build *************************************
13:14:09:WU00:FS01:0x22:    Version: 0.0.2
13:14:09:WU00:FS01:0x22:       Date: Dec 6 2019
13:14:09:WU00:FS01:0x22:       Time: 21:30:31
13:14:09:WU00:FS01:0x22: Repository: Git
13:14:09:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
13:14:09:WU00:FS01:0x22:     Branch: HEAD
13:14:09:WU00:FS01:0x22:   Compiler: Visual C++ 2008
13:14:09:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:14:09:WU00:FS01:0x22:   Platform: win32 10
13:14:09:WU00:FS01:0x22:       Bits: 64
13:14:09:WU00:FS01:0x22:       Mode: Release
13:14:09:WU00:FS01:0x22:************************************ System ************************************
Just after that, the client describes your configuration. If there is an error, someone here will be able to find it and tell you what to do.
EDIT: more about the posting of logs here: viewtopic.php?p=261082&f=24#p261082
@ajm
It turns out that the essential part begins with *** System *** but you're not really wrong.
@Cruddson001
You do not have a virus. Yes, something is missing from your setup which would be shown it the next part of the log that ajm asked for.
Strictly guessing here, have you installed/updated the GPU drivers from the website for NVIDIA or AMD (depending on the brand of GPU you have)?
Post by Neil-B »
.. and I'll add to that guess ... has windows just updated your drivers for you as part of the update?
Cruddson001
Hi I have just seen your replies for which I am very grateful. I'm at work this morning but will get back to you asap.
Cruddson001
ajm wrote:There seems to be something wrong with the configuration of your GPU. Could you please post the first 200 or so lines of your logs (tab Log in the Advanced Control), starting with
Hi the button is greyed out.
Can I simply uninstall and reinstall the folding app?
Cruddson001
bruce wrote:@ajm
@Cruddson001
No, and actually, I was only folding on my CPU not the GPUs the past few weeks, until it stopped.
Cruddson001
Neil-B wrote:.. and I'll add to that guess ... has windows just updated your drivers for you as part of the update?
No I wouldn't have thought so, and the GPUs were never part of my folding activites (so far!)
ajm
Post by ajm »
Cruddson001 wrote:Hi the button is greyed out.
Sure you can. When you uninstall, click the "Data" checkbox" too, it's safer. And if you have chosen a team and/or entered a passkey, you can first make a copy of the file Config.xml in C:\Users\YOURUSERNAME\AppData\Roaming\FAHClient - it contains everything you need to reconfigure you account when you reinstall.
Cruddson001
Hey Guys it's up and running again!
https://www.dropbox.com/s/3ojk6vk6atp1a ... n.jpg?dl=0
Thanks for all your help.
:D
Cruddson001
Hi sorry about the delay I have been working hard.
I would like to get my graphics cards involved in folding at this stage, so any help would be gratefull received.
I am posting what I think is the log you have asked for below.
18:02:47:****************************** FAHClient ******************************
18:02:47:      Version: 7.6.9
18:02:47:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:02:47:    Copyright: 2020 foldingathome.org
18:02:47:     Homepage: https://foldingathome.org/
18:02:47:         Date: Apr 17 2020
18:02:47:         Time: 11:13:06
18:02:47:     Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
18:02:47:       Branch: master
18:02:47:     Compiler: Visual C++ 2008
18:02:47:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:02:47:     Platform: win32 10
18:02:47:         Bits: 32
18:02:47:         Mode: Release
18:02:47:         Args: --open-web-control
18:02:47:       Config: C:\Users\User\AppData\Roaming\FAHClient\config.xml
18:02:47:******************************** CBang ********************************
18:02:47:         Time: 11:10:09
18:02:47:     Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
18:02:47:         Bits: 32
18:02:47:******************************* System ********************************
18:02:47:          CPU: AMD FX(tm)-4130 Quad-Core Processor
18:02:47:       CPU ID: AuthenticAMD Family 21 Model 1 Stepping 2
18:02:47:         CPUs: 4
18:02:47:       Memory: 15.95GiB
18:02:47:  Free Memory: 11.22GiB
18:02:47:      Threads: WINDOWS_THREADS
18:02:47:   OS Version: 6.2
18:02:47:  Has Battery: false
18:02:47:   On Battery: false
18:02:47:   UTC Offset: 1
18:02:47:          PID: 11268
18:02:47:          CWD: C:\Users\User\AppData\Roaming\FAHClient
18:02:47:           OS: Windows 10 Enterprise
18:02:47:      OS Arch: AMD64
18:02:47:         GPUs: 2
18:02:47:        GPU 0: Bus:1 Slot:0 Func:0 AMD:0 Barts PRO [Radeon HD 6850]
18:02:47:        GPU 1: Bus:4 Slot:0 Func:0 AMD:0 Barts PRO [Radeon HD 6850]
18:02:47:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:02:47:               specified module could not be found.
18:02:47:
18:02:47:Win32 Service: false
18:02:47:******************************* libFAH ********************************
18:02:47:         Date: Apr 15 2020
18:02:47:         Time: 14:53:14
18:02:47:     Revision: 216968bc7025029c841ed6e36e81a03a316890d3
18:02:47:         Bits: 32
18:02:47:***********************************************************************
18:02:47:<config>
18:02:47:  <!-- Slot Control -->
18:02:47:  <power v='FULL'/>
18:02:47:
18:02:47:  <!-- User Information -->
18:02:47:  <user v='Crudsson001'/>
18:02:47:
18:02:47:  <!-- Folding Slots -->
18:02:47:  <slot id='0' type='CPU'>
18:02:47:    <paused v='true'/>
18:02:47:  </slot>
18:02:47:  <slot id='1' type='GPU'>
18:02:47:  </slot>
18:02:47:  <slot id='2' type='GPU'>
18:02:47:  </slot>
18:02:47:</config>
18:02:47:Trying to access database...
18:02:47:Successfully acquired database lock
18:02:47:Enabled folding slot 00: PAUSED cpu:2 (by user)
18:02:47:Enabled folding slot 01: PAUSED gpu:0:Barts PRO [Radeon HD 6850] (by user)
18:02:47:Enabled folding slot 02: PAUSED gpu:1:Barts PRO [Radeon HD 6850] (by user)
18:02:47:ERROR:No compute devices matched GPU #0 {
18:02:47:ERROR:  "vendor": 4098,
18:02:47:ERROR:  "device": 26425,
18:02:47:ERROR:  "type": 1,
18:02:47:ERROR:  "species": 0,
18:02:47:ERROR:  "description": "Barts PRO [Radeon HD 6850]"
18:02:47:ERROR:}.  You may need to update your graphics drivers.
18:02:47:ERROR:No compute devices matched GPU #1 {
18:02:55:11:127.0.0.1:New Web session
18:03:10:FS00:Unpaused
18:03:10:FS01:Unpaused
18:03:10:FS02:Unpaused
18:03:10:WU03:FS00:Starting
18:03:10:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\User\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 11268 -checkpoint 15 -np 2
18:03:11:WU03:FS00:Started FahCore on PID 17432
18:03:12:WU03:FS00:Core PID:13420
18:03:12:WU03:FS00:FahCore 0xa7 started
18:03:12:WU00:FS01:Connecting to 65.254.110.245:80
18:03:12:WU01:FS02:Connecting to 65.254.110.245:80
18:03:12:WU03:FS00:0xa7:*********************** Log Started 2020-05-02T18:03:12Z ***********************
18:03:12:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:03:12:WU03:FS00:0xa7:       Type: 0xa7
18:03:12:WU03:FS00:0xa7:       Core: Gromacs
18:03:12:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 706 -lifeline 17432 -checkpoint 15 -np
18:03:12:WU03:FS00:0xa7:             2
18:03:12:WU03:FS00:0xa7:************************************ CBang *************************************
18:03:12:WU03:FS00:0xa7:       Date: Oct 26 2019
18:03:12:WU03:FS00:0xa7:       Time: 01:38:25
18:03:12:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:03:12:WU03:FS00:0xa7:     Branch: master
18:03:12:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
18:03:12:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:03:12:WU03:FS00:0xa7:   Platform: win32 10
18:03:12:WU03:FS00:0xa7:       Bits: 64
18:03:12:WU03:FS00:0xa7:       Mode: Release
18:03:12:WU03:FS00:0xa7:************************************ System ************************************
18:03:12:WU03:FS00:0xa7:        CPU: AMD FX(tm)-4130 Quad-Core Processor
18:03:12:WU03:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 1 Stepping 2
18:03:12:WU03:FS00:0xa7:       CPUs: 4
18:03:12:WU03:FS00:0xa7:     Memory: 15.95GiB
18:03:12:WU03:FS00:0xa7:Free Memory: 11.29GiB
18:03:12:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
18:03:12:WU03:FS00:0xa7: OS Version: 6.2
18:03:12:WU03:FS00:0xa7:Has Battery: false
18:03:12:WU03:FS00:0xa7: On Battery: false
18:03:12:WU03:FS00:0xa7: UTC Offset: 1
18:03:12:WU03:FS00:0xa7:        PID: 13420
18:03:12:WU03:FS00:0xa7:        CWD: C:\Users\User\AppData\Roaming\FAHClient\work
18:03:12:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
18:03:12:WU03:FS00:0xa7:    Version: 0.0.18
18:03:12:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:03:12:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:03:12:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
18:03:12:WU03:FS00:0xa7:       Time: 01:52:30
18:03:12:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:03:12:WU03:FS00:0xa7:************************************ Build *************************************
18:03:12:WU03:FS00:0xa7:       SIMD: avx_256
18:03:12:WU03:FS00:0xa7:********************************************************************************
18:03:12:WU03:FS00:0xa7:Project: 13851 (Run 0, Clone 36351, Gen 70)
18:03:12:WU03:FS00:0xa7:Unit: 0x0000005a287234c95e787ec96410608c
18:03:12:WU03:FS00:0xa7:Digital signatures verified
18:03:12:WU03:FS00:0xa7:Calling: mdrun -s frame70.tpr -o frame70.trr -x frame70.xtc -e frame70.edr -cpi state.cpt -cpt 15 -nt 2
18:03:12:WU03:FS00:0xa7:Steps: first=35000000 total=500000
18:03:13:WU00:FS01:Assigned to work server 192.0.2.1
18:03:13:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts PRO [Radeon HD 6850] from 192.0.2.1
18:03:13:WU01:FS02:Assigned to work server 192.0.2.1
18:03:13:WU00:FS01:Connecting to 192.0.2.1:8080
18:03:13:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Barts PRO [Radeon HD 6850] from 192.0.2.1
18:03:13:WU01:FS02:Connecting to 192.0.2.1:8080
18:03:14:WU03:FS00:0xa7:Completed 128892 out of 500000 steps (25%)
18:03:34:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
18:03:34:WU00:FS01:Connecting to 192.0.2.1:80
18:03:34:WARNING:WU01:FS02:WorkServer connection failed on port 8080 trying 80
18:03:34:WU01:FS02:Connecting to 192.0.2.1:80
18:03:48:Removing old file 'configs/config-20200427-184155.xml'
18:03:48:Saving configuration to config.xml
18:03:48:<config>
18:03:48:  <!-- Slot Control -->
18:03:48:  <power v='FULL'/>
18:03:48:
18:03:48:  <!-- User Information -->
18:03:48:  <user v='Crudsson001'/>
18:03:48:
18:03:48:  <!-- Folding Slots -->
18:03:48:  <slot id='0' type='CPU'/>
18:03:48:  <slot id='1' type='GPU'/>
18:03:48:  <slot id='2' type='GPU'/>
18:03:48:</config>
18:04:34:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_GATEWAY_TIME_OUT
18:04:34:ERROR:WU01:FS02:Exception: 10001: Server responded: HTTP_GATEWAY_TIME_OUT
18:04:34:WU00:FS01:Connecting to 65.254.110.245:80
18:04:34:WU01:FS02:Connecting to 65.254.110.245:80
18:04:35:WU00:FS01:Assigned to work server 192.0.2.1
18:04:35:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts PRO
I have just resolved a heat retention issue with my CPU by installing up graded case fans.
I have tried to update the GPU drivers to the latest ones but have failed. This is due to the age of my graphics cards.
I list below my current graphics driver specifications.
Driver Packaging Version: 15.301.1901-160226a-318062E
Catalyst version: 15.8
Provider: AMD Inc.
2D Driver version: 8.01.01.1533
Direct 3D Version: 9.14.10.01171
Open GL Version: 6.14.10.13417
Mantle Driver Version: 9.1.10.0099
AMD Catalyst Control Center Version: 2015.0804.21.41908
There is a more recent version of the driver (16.60.2011-170210a-311199C,) but for some unknown reason it refuses to install.
I have AMD Crossfire installed.
EDIT:
Just found these links:
https://community.amd.com/thread/214565
https://linustechtips.com/main/topic/75 ... nt-update/
I guess there is no updated driver for my cards.
ajm
Post by ajm »
I'm sorry, but I don't think that your cards (Radeon HD 6850) will be able to fold correctly.
They would need FP64 (double precision), and they lack that feature: https://www.techpowerup.com/gpu-specs/r ... -6850.c255
Yes, in the HD 6000 series AMD only supported DP (FP64) processing on the HD 6900 cards. Projects that did not require DP finished up last year.
Cruddson001
Okay, thanks guys.
