Problem: No WUs available for this configuration
Quad2000
Post by Quad2000 »
Hello together,
I´m new in folding@home and I want to support this awesome Project. But I have a Problem. The most time of the day my PC is IDLE. If I get e WU my values are 1Mio Points a day but the most of the time Nothing happens. Can you please help me? Is it because of the world wide run to F@H? No Server capacity? Or can I improve this?
Thank you very much for your help!
Have a nice day and stay Health!!!
*********************** Log Started 2020-04-15T12:05:02Z ***********************
12:05:02:************************* Folding@home Client *************************
12:05:02:        Website: https://foldingathome.org/
12:05:02:      Copyright: (c) 2009-2018 foldingathome.org
12:05:02:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:05:02:           Args: --open-web-control
12:05:02:         Config: C:\Users\....
12:05:02:******************************** Build ********************************
12:05:02:        Version: 7.5.1
12:05:02:           Date: May 11 2018
12:05:02:           Time: 13:06:32
12:05:02:     Repository: Git
12:05:02:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:05:02:         Branch: master
12:05:02:       Compiler: Visual C++ 2008
12:05:02:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:05:02:       Platform: win32 10
12:05:02:           Bits: 32
12:05:02:           Mode: Release
12:05:02:******************************* System ********************************
12:05:02:            CPU: AMD Ryzen 7 3700X 8-Core Processor
12:05:02:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
12:05:02:           CPUs: 16
12:05:02:         Memory: 31.95GiB
12:05:02:    Free Memory: 26.00GiB
12:05:02:        Threads: WINDOWS_THREADS
12:05:02:     OS Version: 6.2
12:05:02:    Has Battery: false
12:05:02:     On Battery: false
12:05:02:     UTC Offset: 2
12:05:02:            PID: 20448
12:05:02:            CWD: C:\Users\.....
12:05:02:             OS: Windows 10 Enterprise
12:05:02:        OS Arch: AMD64
12:05:02:           GPUs: 1
12:05:02:          GPU 0: Bus:45 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
12:05:02:  CUDA Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:6.1 Driver:11.0
12:05:02:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:445.75
12:05:02:  Win32 Service: false
12:05:02:***********************************************************************
12:05:02:<config>
12:05:02:  <!-- Folding Core -->
12:05:02:  <checkpoint v='30'/>
12:05:02:
12:05:02:  <!-- Network -->
12:05:02:  <proxy v=':8080'/>
12:05:02:
12:05:02:  <!-- Slot Control -->
12:05:02:  <power v='FULL'/>
12:05:02:
12:05:02:  <!-- User Information -->
12:05:02:  <passkey v='********************************'/>
12:05:02:  <team v='xxxxxx'/>
12:05:02:  <user v='xxxxxx'/>
12:05:02:
12:05:02:  <!-- Folding Slots -->
12:05:02:  <slot id='1' type='GPU'/>
12:05:02:</config>
12:05:02:Trying to access database...
12:05:02:Successfully acquired database lock
12:05:02:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463
12:05:02:WU00:FS01:Connecting to 65.254.110.245:8080
12:05:03:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:05:03:WU00:FS01:Connecting to 18.218.241.186:80
12:05:03:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:05:03:ERROR:WU00:FS01:Exception: Could not get an assignment
12:05:04:WU00:FS01:Connecting to 65.254.110.245:8080
12:05:04:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available
HaloJones
Re: Problem: No WUs available for this configuration
Post by HaloJones »
welcome to the club! I have five 1070s and at the moment three are idle.
the numbers of contributors has multiplied twenty-fold since the publicity about CV-19 and there are a number of scaling problems in meeting the demand the worst of which is the available of the science itself.
the science is being done by a very small number of scientists and they simply can't create the work fast enough for all of us to be working.
if you look in your Advanced Control app you shuold be able to see in the bottom left quadrant when the "Next Attempt" will be for work. If it is showing hours before the next one rather than minutes, you could try pausing the folding for a minute or so and then starting again.
other than that, it's pot luck at the moment as to whether you will get work.
4070 super
Jan
Post by Jan »
Quad2000
Post by Quad2000 »
Thank you very much!
